- LQ9 ECM Tuneable?
- 1/2 inch stainless header flanges
- bellhousing question
- 99 trans am suspension in 79 TA???
- Looking for a Engine...
- LQ4 Engine Bay Fire
- LS Motorbike??
- no fuel after startup?
- no spark
- whats involved in switching to a t-56 (wiring & computer)
- ls1 in g body cutlass
- Flexplate covers for auto transmissions
- A/C Wiring Question On Wait4Me Harness?
- lsx foxbody - motor plate vs. aje tubular
- Quick cylinder head coolant line question
- a friends project we working on (67 nova ls1)
- No Heater flow
- who did LT1 swap to a 4 gen 3.4 v6
- 5 Pin MAF
- LS1 into a 92 K15 headers?
- Reggie Jackson's LSX Showcar
- 5.3 fly by wire question
- 73 Nova Bumpers
- Anybody looking for a ls1/a4
- LS1 Transmission Choice
- 4L80-E 4L60-E Electronics compatible?
- LS1 to C3 Corvette
- Accessories questions
- DLC for 98 harness/pcm
- 944 LS1 Conversion
- Injector Size And Steam Tube
- Hmm... Ford Five Hundred?
- Conversion 2001 Pontiac Firebird
- swap help
- Alternator and AC connectors.
- general emissions?
- Looking For Pics Of 94to98 Style Fbod Conversions..
- Where to find wrecked donor cars?
- Took the LS1 Nova to the track again, better numbers this time
- Carb'd LS2 (LS364/440)
- lsx in 69 camaro help my confusion
- Oil Pan modifications?
- my rx7 lives
- ls1 into 2nd gen camaro
- ATTN: a-body owners???????????
- LS1 in a Fox Body
- Part number for GM TH350 adapter
- Lq4 anyone?
- Oil Pressure sender/switch?
- Pefect for your ls1 powered street rod!
- 2001 5.3 fuel regulator?
- LSX swap Cruise control
- a camaro boat
- gen I 350 w/ls based retrofit
- Scared myself for 1st time!
- t56. skip shifting, hurt tranny?
- Part # Help
- Nova test runs video
- For those of you that changed over to the GTO pan...
- check it out single turbo kit for the lsx swaped cars
- fuel system in mustang
- gen1 sbc vs ls1 engine length
- Oil temp sensor location/adapter
- 240 stock engine weight?
- Name this part? One of you bought it...
- Carb fuel feeds/regulators/pumps
- 71 blazer 4x4 conversion
- No start/spark help-6.0L in a CJ5
- LQ4 Swap
- Buddy moving to Texas. What are the Smog laws like
- Stand-alone wiring harness alternative?
- Oil pressure port?
- A/C on 68 fire bird LS1
- 2nd gen radiator hose questions.
- The first LSx conversion I ever saw...
- Hinson LSX Swap Kit 240sx S13
- Anyone who swapped a LS1 into a E30 BMW please check in!
- ls1 in 69 camaro
- Cold Air Intake
- i need lt1 to ls2 questions answered DAMMIT!!!
- *LSx Swap* - FS : '99 PCM and Harness for M6 - $320
- anyone done a Lincoln LS with ls1
- Good source for metric bolts
- search not working, anyone know 3rd gen camaro ps fitting size?
- ls1 in a mustang
- No 64-67 GTO/Tempest/Lemans projects?
- LQ9 accesories compared to LS1
- Where to find these connectors?
- Aternator Not Charging
- ls7 in impala ss
- V6 to V8 Camaro
- Heads and Cam Question
- My vega conversion vs. 5.0
- Ohm range for the stock fuel sending unit ('00 T/A)
- LS1 into kit car- carb sizing query?
- Clutch Master Cylinder
- 944 v. rx7
- Custom Header Questions....
- LT1/LS1 swap question
- Track Performance!
- Anybody with a real BRP mount kit ?
- Has anybody ever swapped an ls1 in an OBD2 car in a state with emissions ?
- Stand Alone Computer For 4l60
- Will GM A body font disc brakes fit on a Nova?
- Any interesting Pulley set-ups
- urboed Ls1 BMW 5 series
- LS2 based amphibious car
- Headers for 5.3 in a Jeep CJ-7...
- Anybody running these block hugger headers on their project ?
- What am I getting myself into?
- What would you do?
- which headers can I use... which accessories???
- I started and I have Oil Pressure !
- purge canister
- Need Fuel pump plumbing advise
- LS Chevelle Headers
- Another LS14 Project.
- Lsx. Which Way do I Go?
- What type of fittings
- Interested in a Modified Howe Radiator?
- Gbody guys?
- Fuel level sensor output...only to gauge or to gauge and PCM?? DTC CODE
- Rubber shifter boot?
- It Started - Then It Farted
- Oil Pan Thread
- coils covers
- LS1 connector identification
- ls1 cobra swap is complete with videos
- T56 Kit Motor Mounts and Tranny mount
- LS1 Third gen
- Motor mount bolt part number
- temporary storage ofanls1
- 1983 BMW 320 - Progress update
- LS1'ed chevelle and driveshafts
- 383 stroker in 93 240sx
- Another one comes to life
- HELP-LQ4 + BW ST-10 + 80 fairmont = ????
- Let's see your electric fan setup
- 66 elcomino+cammed ls1=?
- Anybody have this problem with Lokar tranny dipstick?
- My site is back up again!!!
- carbed ls1's
- Original gauges and LSx
- LS2 in 91 Z....
- From LT1 to LQ4
- Ls6 in a 98 gmc 1500
- GM #10108509 Heater Hose Loop
- camaro subframe
- steering question...
- Starter Problem
- s13-s14, curb weight after ls1 swap
- Anyone try this?
- What year is my engine
- pin# for serial data line????
- 1993 ls1 z28 lives
- ls1 in 93 t.a.
- How much for a T-56?
- 1991 Camaro Ls1 Swap cammed Shaved firewall
- Edelbrock timing control module F/S
- lsx ps pump to saginaw steering box
- Procedure for first startup
- Clutch master pushrod modification
- Exhaust Flanges
- 69 camaro horn relay upgrade
- LSX engine/tranny source
- lt1 to ls1 swap
- Need help finding a project
- ls1 in a 74 Datsun b210
- gunna pick up a 5.7 shortblock this weekend!
- camaro subframe assistance
- 03 5.3 Electronic throttle control
- Radiator woes: What radiator for 67-72 GM pickup?
- Cam swap?
- LS1 in '66 Nova?
- AN-4 conversion
- Oil an removal install?
- Need idler pulley in place of power steering pump
- LS1 install into 63 impala?
- PCM harness through firewall grommet?
- A couple "finished" pics, Lots of pics... vids soon to come!
- New 8 Quart oil pan what do you guys think?
- ID this connector?
- T-56 with a 4x4 transfer case ?s.
- Electrical Question
- Header Question For Corvette?
- Flexplate exposed on auto tranny LSx's?
- LS1 to SBC motor mount plate question - Street and Performance plates too thick?
- 2 fuel lines?
- Corvette FPR/filter?
- getting pcm reprogrammed...
- All LS1/Caprice/Impala SS people in here....
- Ok, so no LS1 in Eclipse... but how about...
- Engine advice/Swap question(s)
- Help with Engine ID/Swap advice
- LS1 Mustang Swap Article for Popular Hot Rodding Magazine
- Do LQ4 and LS1 sensors interchange?
- 240sx LS1 swappers, need some help here!
- LS7 crate motor in 79 Z28
- Suggestions for charcoal canister
- Running Donor 02 z28 in SF area - $6300
- Dumb Question?????
- Mods before dropping in the motor?
- CTS-V oil pan, pickup and screen for sale for LSX Swap
- ssr rear end?
- LS1 into 1964 Chevy Malibu S.S.
- Z06 motor in an Escalade???
- Granatelli or factory MAF sensor?
- using ls1 headers??????
- Do I need a pressure Regulator?
- ls1 bmw 5 series conversion
- Carbed 5.3, 6.0 68 Firebird
- How to tell if the VSS is working or not???
- Any turbo fox/sn95 out there????
- Fuel pressure regulator plumbing?
- SBC 383 in a 1994 Firebird 3.4 Car
- Wiring harness ?????'s
- Vehicle Weight
- engine/trans angle vs. rear end angle
- Chassis fabrication.....
- Cheap fuel pressure gauge for schrader valve?
- hp tuners flashing problem
- fuel problems help
- No tach signal
- T56 reverse lockout solenoid plug?
- LS2 Datusn Dyno Results!
- LS1 into a 99GT??
- LS4 oil pan
- Walbro forgeries being sold
- BMW Z3 conversion
- how much will i gain?
- LSx Diamension differences ???
- Plug Size
- oil p/u question for gto ls1
- Need some help w/ conversion
- Built LT1 in 94-96 9C1 Caprice or LS1 Swapped in 98+ S10
- Crate Engine -> No MAF-> What do I need?
- What the heck radiator is this? (6.0L Police Package content)
- 2000 5.3 vortec to a 2003 4l60e out of s10???
- f/s lsx to mustang motor mounts
- anyone went the other way with a swap???
- Any way to tell exactly what engine I bought?
- ALT Light for '02 harness?
- Oil filter/Pan flow direction
- Debating about selling my ls1/fox project...
- 97 gmc z71 conversion
- ls1 fairmont part II
- TT Chevelle went to the drag strip. Update.
- Radiator question
- LS1 S10... questions
