View Full Version : Conversions & Hybrids
  1. What is everyone doing for power steering hoses?
  2. how much would you build and sell a third gen ls1 for?
  3. PNP switch question
  4. THIRD GEN Formula LS1 SWAP
  5. Idea for my chevelle chassis...Am I crazy??
  6. Ls1 Coupe With T 76
  7. My LS1 in a '69 Z/28
  8. has anyone tried the chevelle or firstgen fbody headers on a thirdgen?
  9. Fired up the Camaro on Saturday.. vid
  10. LS1 Fox body suspension question
  11. ls1 swap air lid question
  12. LS1 RX7 project in classifieds
  13. 3rd gen f-body request.
  14. Paging John McGraw: LS2 Oil Pan ???
  15. Ls1 E36 Bmw
  16. Best pan/accessories for a third gen camaro swap?
  17. Who wants to help me wire my LS1/Mustang swap?
  18. swap ls1
  19. What headers with ATS mounts?
  20. Alternator and PS pump differences
  21. Starting Problem - Help trouble shooting
  22. Do I Have to cut the frame
  23. My next hump in the road, gauges.
  24. C6 instument cluster in older car
  25. location to pick up tach signal?
  26. Fuel Gauge HELP!!
  27. LS1-LS2 Corvette alternator bracket
  28. Where are you guys getting all your parts for the swap?
  29. Truck power steering Variable orifice solenoid
  30. grounds at the top of the harness
  31. Which headers for 71 Chevelle
  32. more progress
  33. Do I need to ground my battery directly to my block?
  34. ls1 t56 into a 2000 v6 auto
  35. Project '98 S-10 drag truck....
  36. Another LT1-LS1 swap here!
  37. LS1 oil pan swap, exactly what needs to be changed
  38. LS1 Catera
  39. THANKS everyone
  40. Speed sensors (VSS) on transfer cases???
  41. 3rd gen guys COME IN!!!!
  42. Ls6 ??
  43. Anyone convert...
  44. Do I need a specific PCM??
  45. A/C clutch engaged but does it signal the PCM to increase idle?
  46. Steering Wheels & airbags?
  47. LS1/ 84 T/A runs and drives-and it's fast!!!!!!!
  48. Anybody have a Pontiac 400 they pulled out?
  49. LM7 91 S-10 questions
  50. Intank pump or external? Tank questions...
  51. Clutch not disengaging
  52. It CRANKS!!!
  53. LS1 Emblem on Ford Logo
  54. ls6 into an 99 trans am
  55. f body 98 to 02 computer motor swap?
  56. 240Z Headers
  57. Manual and auto harness differences
  58. honda w/ tq
  59. Megasquirt & MSD 6010 Box to control everything to run LS1? (no factory harness/pcm)
  60. 1991 Corvette w/ LQ4/LS6 hybrid is ALIVE
  61. my 71 vega GT LS1/T56
  62. need help putting ls1 in 88 swb 4x4
  63. What LS based dash in my 70 Chevelle??
  64. Last wiring question (hopefully)
  65. ls1 and auto in 71 nova
  66. Will This Work?????????????
  67. Question about 4L60E
  68. 68 PT Camaro Banks TT SBC or ls1
  69. V6 swap for LT1????
  70. Quite muflers with LS1
  71. ls1 t56 into a 71 chevelle?
  72. any one put an ls1 in a 350z or g35?
  73. Wiring up a chevy keyed ignition, help
  74. All this talk about a T56 in a Fox, so here's my swap thread.
  75. fuel tank question
  76. priming the gen III
  77. intake elbows
  78. My Nova getting an LS1
  79. more electrical gremlins taunting me
  80. Crank trigger
  81. diff in harness ?
  82. LSX engine placement Question
  83. Painted my camaro the other day...
  84. LS1 bellhousing bolt pattern or drawing NEEDED!
  85. Drive-By-Wire Gas Pedal Compatibility
  86. Alt. wiring problem,,
  87. Ls1 C3
  88. buick 3.8 turbo motor in a 98-2002 camaro
  89. Cleaned up the wiring some more...
  90. Conversion won't start... baffled
  91. Fuse/Relay Panel - Junkyard
  92. whats it take to hide the power steering resivour?
  93. Any Chevelle guys running hydroboost?
  94. Low profile fans needed for my 55 ChevyTruck
  95. Its Alive!!!
  96. pics of my 69 camaro blackwidow in progress
  97. Tanks inc. sump
  98. ??? Fair Price For Low Mile LS1... & T56 ???
  99. 5.3 intake & cam options
  100. Found a motor have some questions
  101. wtb 1998 ls1 f-body engine harness
  102. Drivability problems have me stumped! Please help!
  103. 02 Sensor question for my LS1 swap
  104. Here is a really stupid question
  105. LT1/T56 into 98+ s10
  106. New to the forum, couple of questions
  107. Accessory Drive pictures
  108. ls1 into '56 bel-air?
  109. bellhousing boss ?????????
  110. lt1 pinouts
  111. LS1 Wire question??
  112. wiring size for the harness that goes to the CPS?
  113. LS1 240sx Hit the dyno today.... Its all Done!
  114. Need some help,68 chevelle th350, ls1
  115. buick century
  116. Harness connectors
  117. Old School LS6
  118. making it idle??? Ls1 all wired fused and relay
  119. turbo LS1 fox ideas
  120. Ls1 Rwd In A 93 Prelude Omg-
  121. Another wiring question? Please help!!
  122. My 93 04 LS1 mustang, mating MN12 ?s.
  123. Cj7 Finally On It's Way
  124. Lengthen PCM harness... what size wire?
  125. A few in depth questions
  126. HELP LSX in 67 II...
  127. Opinions on custom dash arrangement...
  128. are TAC modules interchangable?
  129. 91 Z28 Lives, first Video done.
  130. 3rd gen or 98+ v6
  131. 2003 Silverado air intake temp sensor part#?
  132. Electronic throttle woes... need some help
  133. Who does wiring harness mods?
  134. anybody have pix of an lsx in a 93-97 camaro?
  135. LS1 in a 72' Datsun 510 has it been done ?
  136. fenderwell mounted pcm cover
  137. Thread pitch and size of the F-body AC pressor sensor
  138. Need help on PCM and Harness
  139. Ideas? What Color for my Fuel Rail Covers?
  140. need direction
  141. Stumbles when I get on it?
  142. 92Z LS1 project (come in)
  143. New Engine Choices for S10 swap!!
  144. ls1 6sp in a 74 nova
  145. fuel tank return line
  146. Ready for LSX swap
  147. 4L80e GURU's I have a question for you..
  148. 5.3 Wrangler Picutres here!
  149. Here's a question
  150. LS1 into Nissan Pickup?
  151. Remove VATS from PCM??
  152. 71 Chevelle hooker header pics
  153. 78 Trans am LS1-turbo set up?
  154. C5 fuel level sensor
  155. Dual post coil wiring?????
  156. LS1/2/4/6/7 Fiero???
  157. Oldschool LS1 (71 Camaro)
  158. harrisburg pa hotrod tour
  159. Pic's of my 5.3L swap in an S-10
  160. Big Block Headers on LS1 Motor???
  161. LS1 swap issues- starter isn't working
  162. fuel issues
  163. another one lives! but with issues :(
  164. Revised ATS oil pan
  165. t56 to 4l60 ???
  166. 81 camaro ls1????
  167. KATech Tensioner Install
  168. 1993 1500 silverado guage cluster harness
  169. my hybrid...
  170. Conversion to TurboLS6 Powa' Part Trois
  171. S & P High Mount AC installed
  172. Looking to install a manual trans in the 2000 and up
  173. 72 c/10 ls-1 install?
  174. more progress
  175. LS1 driveshaft to 12-bolt
  176. Another hybrid clutch story!
  177. ls1 stang questions
  178. LS1 240sx....
  179. Another bug fixed
  180. Anyone need P-Ayr replica LS1?
  181. is return fuel line needed, can regulator be placed next to tank?
  182. 5.3 LH6 DOD conversion questions
  183. Volvo 5.0 or LS1
  184. headers for ls1 s-10 swap...f-body?
  185. GTO LS1 into a 72 Malibu
  186. Flex-a-lite Electric Fans??
  187. After 12 years, finally motor swap time, need advice
  188. Custom bending for intake tubing
  189. Help very strange annoying problem.
  190. Help, short O2 sensor? (stock one doesn't fit)
  191. LS1 install. Fellow Chevelle's help.
  192. any ls1 manifolds that clear 56 chevy 605
  193. LS2 E40 Engine Control Module J1 Pin Assignments
  194. What is the thread pitch and size of the oil sending unit?
  195. Walbro Fuel Pump
  196. GM 4th gen camaro w/ ls7
  197. websites/resources for moving brake master
  198. ls1 rx7's for sale... (?)
  199. Ls1/t56 in a e39 5 series?
  200. Change vin after swap????
  201. trying to put LS1 in 92 Camaro RS
  202. LS1 crank and cam snesor types?
  203. Pleae Help an Old F*rt... SBC, LT1, LS1... WHICH ONE?!
  204. the new numbers-ls2stang
  205. 1999 tahoe possible?
  206. Valve Cover Mods
  207. thirdgen ls1 swap questions
  208. coolant lines
  209. Accel ecu and spagetti wiring also updated body pics
  210. Ls1 240sx for sale
  211. Next up.. dropping in the LS2
  212. Injector seals LS1
  213. Another VSS question
  214. tunning question regarding a swap
  215. Opinions
  216. Installing a LS2 in a Older GTO with FI
  217. FD RX7 LSx conversion
  218. 6.0L oil pan ?
  219. lt1 help
  220. Gas tank vent
  221. It Lives
  222. Carroll Shelby did it first...
  223. 3.8l V6 Qs...........
  224. Looking for a temp sending unit
  225. Truck High mount A/C compressor bracket
  226. Temp Gauge
  227. Engine Harness
  228. To Notch Or Not To Notch ???????????
  229. LS1 into 87 T/A WS6
  230. LS-1 Swap
  231. Stock fuel pump 12v wire
  232. Tell me why my car runs like poop if I have the TPS connected
  233. Lokar Steel Braided Dipstick Tube Question
  234. VSS in Muncie 4 speed
  235. Moved Alternator - Need Custom Length Serpentine Belt
  236. monte carlo?
  237. LS1 swap into 95 v6 camaro? help
  238. What pcm to use with my hybrid engine.
  239. T56 VSS Sensor
  240. Smaller flywheel on Gen III?
  241. LS1 on engine stand
  242. Wiring harness question
  243. Ground wires points and or connection
  244. Difference between fbody and c5 steering pump
  245. Will a 6.0 out of a 2004-5 van work for a swap? Is it LS1 or LS2?
  246. Dry Sump LS1/T56 into E30 BMW Conversion parts on ebay
  247. Engine not fitting right
  248. ecm question
  249. Alternator wiring question
  250. LSx/T-56 in a '97 BMW 328 vert?
