View Full Version : Conversions & Hybrids
  1. LS1/6 '88 BMW M3 daily driver
  2. Idea's for Air intake setup
  3. engine mounts ls1 into 94 camaro
  4. Just another LS1 2nd Gen RX7... 56k beware...
  5. Someone please lay it out for me. Fuel system! 68 c10 lsx motor
  6. 68 camaro with ls1 supercharged?
  7. Photos - Year One Experience 2006
  8. Low and high speed fans...
  9. LS2 280Z Exhaust done!
  10. Motor Mount--Really??
  11. mustang ls1 headers?????
  12. I need to make a custom plug wire
  13. New source for gauge adapter fittings
  14. Ready for a heart transplant but don't know who to give it to...?
  15. Starting issue no spark no fuel
  16. LS1 in a fox coupe
  17. TT LS1 in a Volvo Wagon! NEED HELP TOO!
  18. 69 Camaro / LS1 Rear Brake Caliper Question
  19. need a picture of F-body wiring harness routing on passenger side near exhaust
  20. 02 SS to 69 Camaro Hybrid
  21. cooling
  22. Cruise control with Drive-by-Wire issue.....
  23. Need some LS1 ---> SBC mount adapter plate specs
  24. Online parts database?
  25. LS1 swap in 94 z28
  26. Restoring a 2001 Z28, worth the trouble?
  27. what to keep from fc chassis
  28. In need of advice
  29. What Size Fuse With F-Body LS1 Fans?
  30. ford 9 inch in s13?
  31. putting 408 into my 93 T/A
  32. Well I tried starting the stang today
  33. different engines
  34. Wiring Harness info.
  35. LS7 engine swap in a 4x4 truck
  36. Need Suggestions for an alternator
  37. Ok spill the beans....
  38. Hi Flow Cats
  39. $ to convert LQ9 to F-body accessories?
  40. power steering delete
  41. Anyone ever build a kit car??
  42. Dodge Shadow swap?
  43. Vibration?
  44. 3rd Gen Guys - Need Wheel/Tire Input
  45. Pictures of aluminum floor, fuel tanks, and suspension
  46. 6.0 4L80E computer
  47. Clutch master cylinder??
  48. Thinking of selling swap parts
  49. Help with 95camaro engine swap
  50. Shopping for take-outs at salvage yards
  51. Headers for ls1 in 98 silverado?
  52. LS2 Swapped Porsche 911 Widebody. Project<Pics.
  53. 88-98 silverado LSx swaps? how many?
  54. oil pressure???
  55. Cold Air Tubing
  56. C5 vs CTSV balancer
  57. Anybody successfully extended their wiring harness?
  58. Air Intake Tubing Question
  59. Hyd clutch problems, v. strange. please help.
  60. Can a 700R4 handle 6700 rpm ?
  61. Standalone Harness?
  62. 65 Chevelle Swap pictures
  63. Advantage of 5.3L over 4.8L?
  64. t 56 conversion
  65. Where do you install youre oil pressure sensor?
  66. looking for help with TH400 transmission and NA LS1 in a 70 Nova
  67. 3rd Gen Tach - Strange Problem
  68. LS1 swap candidate car 87 Turbo II RX7
  69. ls1 240sx up and running and killing tires
  70. An introduction...And my build...
  71. 73 Nova
  72. T56 ==> C4 corvette bracket
  73. LS1 Dragster...why not?
  74. Trailblazer swap???
  75. Looking for a bit of help regarding C4 corvette swap...
  76. Making 1 out of 2
  77. how vss pulses on a 1988 third gen
  78. yup it was wrapped in plastic...
  79. headers/swap parts for 6.0l S-10
  80. FWD 383 is Finished!
  81. help
  82. What psi radiator cap for LS1 with old school radiator?
  83. my ls1 powered rx7 gets mini tubbed and caged
  84. sump oil pan infomation
  85. Should the starter crank the motor without a harness?
  86. WTB - f-body oil pan, widage tray, tube and dipstick.
  87. Twin Turbo Ultima GTR
  88. 1st gen S10ers
  89. need wiring help
  90. What will it look like with an LS1
  91. Eliminate the power steering pump
  92. Six months and she's back on the ground.
  93. With ZERO tuning the LS7 Monte SS rocks the dyno rollers with 487/470 RWHP/RWTQ!
  94. Headers on an LS1 98' Silverado
  95. corvette harness
  96. LS1 into a TT 300ZX
  97. Fueling the 68 c-10
  98. ls-1 or carburated s-10?
  99. 6.0l for my s-10 xtreme
  100. The Day Has Arrived!!! It Runs!
  101. How to make a 700r4 work with an LS1?
  102. LQ4 into C4 Vette build is getting very close to completion
  103. LS1-1970ElCamino-Th350-will it work?
  104. What year camaro is this????
  105. 2 Plugs I have no idea what they're for...
  106. LS1 & T56 in 1985 El Camino questions
  107. LSX into an BMW 3 series!
  108. T56 mount...rubber or poly
  109. LSX Conversion Car Websites - Post Yours Here!
  110. Shifters
  111. Wiring harness sensor wires
  112. LS1 in Foxbody need help radiator hose
  113. Taking off for Viva Las Vegas
  114. teaser
  115. Junkyard Gen II Iron vs Aluminum
  116. Need help.. pics included
  117. Ls1 Fox Body Mustang?
  118. TH400 into 3rd gen ls1
  119. The ultimate LS1 sleeper . . . .
  120. LED Sequential Tail Light Install Video
  121. 66 nova LS1
  122. LS1 into LT1 k-member
  123. T56 bolt to 8.1L 496 big block?
  124. Ls6 383 Powered Miata
  125. It is getting so close to "Fire Time"
  126. started detailing the ls1
  127. Trying to test gauge to see if it works
  128. LS1 booster/master to a 67 brake pedal
  129. t56 clutch bleeding. stumped.
  130. Bosch 02 sensor interchange
  131. Wiring upgrade for older cars pics and ideas.
  132. Crap
  133. 4.8 trans am.
  134. what to buy?
  135. Chevelle Fuel Tank
  136. LS1 Stroker FWD - Tuners Beware!
  137. G-Body LS7 swap complete and running!!!
  138. Viper T56 to 99' LS1
  139. Air intake.... Who is interested?
  140. LSx into my 65 Vette
  141. LS1 S10 pro-street project for sale
  142. C5 PCM same as F body PCM?
  143. Need picture of IAC Valve
  144. 8.1L 496 pass emissions for 5.7L TBI?
  145. IROC Camaro finished pics
  146. Need help wiring pop-up headlights
  147. F-body motor mounts.....
  148. catch can for pcv -oil in intake
  149. possible conversion
  150. Normal Idle speed?
  151. VATS Removal?
  152. Want to swap 3.8 to 5.7.....
  153. ls1/t56 combined shipping weight
  154. Ready to start but.....Help!
  155. Throttle Position Controller
  156. 4th gen harness labeling?
  157. LS2 Throttlebody
  158. What to put it in???
  159. Fuel Pump pressure test and other ?
  160. EFI Sensor Suppliers
  161. Truck 5.3 HP question
  162. LS1 master question
  163. 3rdgen LS1 Swap, Engine not running on all 8...
  164. twin turbo headers and downpipes are done!! ...
  165. Lt1 T56 Onto Ls1???
  166. ls1 into 96 s10 blazer 4x4
  167. LS1 Chevelle Induction
  168. Converter Louckup/Unlock?
  169. Auto to Manual trans harness
  170. Going into a 79 camaro
  171. Source for LS1 information?
  172. kit car assembler
  173. First Gen Hooker Mounts with t56??
  174. Toyota Corolla GTS
  175. gm guide
  176. S&P mounts positioning
  177. '68 Lincoln Continental + LQ4/4L80E
  178. Wiring question pertaining to old voltage regulator.
  179. A/C Question
  180. looking to do something diferrent
  181. Anyone ever delt with these bozos
  182. Carburated 6.0L swap
  183. front sump oil pan
  184. Cold Air Filter
  185. LS1 chevelle headers
  186. LS1 Converted Chevy Silverado
  187. GTO windage tray w/F-Body oil pan?
  188. Wiring Question
  189. For those of you who have done the V6 to LS1 swap..
  190. A/c condensor
  191. Harness/Engine interchange help needed
  192. LSx into '06 Miata?
  193. 6.0 in a Jeep CJ5-Vacuum ?
  194. Which Computer?
  195. Dimensions of 5.3L vs. 6.0L?
  196. my camaro's gone
  197. turn key engine supply
  198. Lt1 ??
  199. 6.0l Ls1 Fly Wheel To Lt1 T56 Tranny??
  200. Hot Rod Mag 'Old-Schooling the LS1'
  201. Good low mile waterpump for sale
  202. Camaro oil pressure sensor specs
  203. How much oil with S&P F-Body pan?
  204. Need to confirm a wire color on 02 Camaro PCM
  205. new to ls1
  206. Help please. LS1 in my RX7 wont start
  207. headers
  208. clutch master cylinder
  209. Is eBay low, high, or about average on LSx and LTx engines?
  210. 77 Bandit TA
  211. I need a Fbody oil pan
  212. ATS LSX engine plates in stock!
  213. First trip to the track
  214. Lokar part # for throttle cable?
  215. Time for some update pics
  216. 6.0 Lq9 into 68 sbrc
  217. ls1 into a 97 v6 camaro...HELP
  218. Lm7 Computer
  219. 79 Camaro with LS1
  220. Power Steering Pulley Question
  221. Jeep
  222. What thermostat with the CSR housing?
  223. What is this connector for ?
  224. A/C compress options?
  225. windage tray
  226. 3rd Gen LS1 Quick Question
  227. Is this a good deal?
  228. Help, What could it be?
  229. LsX engine swap into 1967 corvette
  230. ford longtube headers adapted for ls1 thirdgens
  231. ?s about T-56 trans.
  232. What about making acc. brackets for S10 swap?
  233. 3.5 gen Camaro update - Guages, exhaust, etc
  234. what else do i need? advice...
  235. Gen 3 in '55 Studebaker PU - Camaro Subframe
  236. Throttle cable ? for Mustang guys
  237. LSx Center sump oil pan?
  238. need gto oil pan pics please,need to buy.
  239. High Mount A/C Bracket
  240. fox driveshaft
  241. Question Reguarding Procharger in Rx7
  242. 5.3 to TH400 problems
  243. 2nd gen headers
  244. March Performance or Street and Performance Pulleys
  245. Exhaust Question? Need some facts
  246. LS1 ballast resistors
  247. putting a 5.3L in a '55 Studebaker pickup on a '75 Camaro subframe - mods?
  248. Upgrades for your conversion
  249. LQ9 windage tray with LS1 oil pan?
  250. LS2 into 1967 Tempest/GTO Clone
