View Full Version : LT1-LT4 Modifications
  1. Advice on Alternator Overdrive Pulley for LT1
  2. Oil Leak Help!!
  3. Help Please!!!
  4. need help
  5. O/R Y for stock manifolds...
  6. Do you need a PCV valve?
  7. question regarding intake mods.
  8. LT1 v. LT4 Heads, and what is needed to go to LT4?
  9. I just bought a 98' Z28
  10. Powerdyne
  11. Catalytic Converters
  12. 383 Flywheel Questions
  13. 93 Z28 cuts out and surges please help!
  14. Storing a shortblock for the winter
  15. Fastest Stock LT1
  16. Got my MadZ28 mail order tune today
  17. LT1 Backfire after round of Mods. HELP
  18. couple vids from the track lastnight
  19. Will driveshaft fit?
  20. Help reading 02 sensor info?
  21. fuel pressure problems need help
  22. LE2 package and higher miles?
  23. Part Identification. Will Not Pass Smog
  24. studs??
  25. front and rear sway bar
  26. Ignition module?
  27. Help!! Need advice ASAP on LT4 heads?'s
  28. Help me!?
  29. Went to the track and beat another LS1
  30. Changing Plugs and Wires!
  31. LT1's WIth C6's Wheels (PICTURES)
  32. Help on LPP header install . . .
  33. 2 lt1's are better than one...new dd pics
  34. going back to the track
  35. 383 tear down, more damage than I thought
  36. Ripped a Cross Member right off the Car..
  37. Lets See The Alt. Relocation Brackets
  38. 94 Z28 A4 1-2 Gear Flyby (video)
  39. Question for you LT1 Guys
  40. stock shortblock rev limit
  41. looking to build a low 11s high 10s 383
  42. Some pics from the strip of EPP Formula
  43. Who drives their car on the street without bumper supports and/or crash bars?
  44. installing wheel studs
  45. Sound clip of SLP Dual/Dual catback on a cammed car?
  46. Wilson lt1 intake
  47. Lingenfelter Heads
  48. Which TB for a 398 stroker?? 52 or 58
  49. Making a racecar a streetcar
  50. which shocks will handle better Koni or bilstien for 96 impala SS?
  51. rod bolts,main cap bolts?
  52. Fuel capacity of the LT1 tank ?
  53. Soft seal aluminum header gaskets.
  54. manifold bolts
  55. Need some help Deleted ABS Fare????
  56. list of cars and options
  57. if i went to 2.5" duals in the near future...
  58. need advice for the plan of my car
  59. need advice on buying an LT1
  60. Project Cheap A** LT1 build video
  61. ls1 driveshaft?
  62. LT1 edit?
  63. Fuel rail disconnection question
  64. Comp Cam XFI 292 cam in lt1
  65. nitrouson stock motor/trans
  66. Will a 5.7 350 UD pulley from a Chevy truck Vortec fit an LT1 350?
  67. My Car in the 1/8 mile
  68. alternator mounting options?
  69. non self-aligning 1.6 rockers
  70. Long tubes finally in, EGR question
  71. 93 Z28 Questions
  72. Ls1 or LT1??? Swap
  73. LE1 guys, you may enter
  74. oil cooler questions
  75. Our '95 Formula made it back to the track
  76. Part number for Melling oil pump with white spring
  77. Wheres the best...
  78. debating boost
  79. LT1 in 1969 Camaro
  80. I have a code? P1441
  81. 160* t-stat. what do i need for a fan switch?
  82. 355 stroker question
  83. C4 Air Cleaner Intake Box INTO A F BODY LT1
  84. header bolt help.....
  85. fuel system questions... all new stuff
  86. need a list of things i should do a tune up on. 93 z28 a4
  87. LT1 two stage nitrous
  88. Car running hotter than normal, water pump going out? 200-220 degrees
  89. is the magnaflow bullet any quieter?
  90. Draglite's
  91. 94 a4 ?
  92. Dyno'd a 383 LT1 w/a little nitrous
  93. LT1 Expert/Author needed
  94. time is on my side
  95. Be carefull when you go to the dyno
  96. LT1 swap,,,
  97. Need suggestions for 800HP!!
  98. Pondering Edelbrock Pro-Flo XT intake.............
  99. lose power from arcing/misfire?
  100. Pilot Bearing removal
  101. Cooling issues
  102. 4L60E question
  103. LT1 stickers
  104. ? on my 1/4 times
  105. LT-x SFI Bellhousing finally available
  106. Low Oil Light:Limp Mode?
  107. What would it take?
  108. cam question
  109. Hi-6 & lx-92 coil?
  110. Spark Plug Brand and Gap?
  111. Ran a new best tonight!
  112. Coil Arcing? (Videos)
  113. 93 Z28 Guts In A V6 Car...
  114. Distributor Problem???
  115. tune(shift problems)
  116. Pulled my trans, clutch, flywheel, have some clutch and oil/seal questions.
  117. car dies in 3rd
  118. 1 liter
  119. First post - LT4 front main seal question
  120. Building a 383
  121. Lt1/lt4 In 92 Camaro?
  122. What kind of oil pump do i need?
  123. Lt1/lt4 Injector Size?
  124. Cam/Heads install questions
  125. 1.6 RT W/ stock cam/springs
  126. More 230/236 cam only results
  127. What Length 02 Extensions with Pacesetter LT's?
  128. cleaned up the engine bay
  129. Heeeellllp!!!!!
  130. trans to motor, got advice?
  131. Will the 97 rear main seal work on a 94?
  132. I can't decide..
  133. Fuel Line Question, is one a breather/vent?
  134. "Project Cheap A** LT1" Nitrous Vid
  135. Cam Card for cc306
  136. vibrating under car
  137. msd optispark bearing slop
  138. Upgrading cluster from crap to digital...
  139. New car!
  140. rocker arm ?
  141. Getting 1.6 rr and springs need advise.
  142. tranny ?
  143. whos car is this??
  144. Best heads
  145. module ide opti?
  146. backfire/weird acceleration?
  147. front license options
  148. Do our cars need back pressure?
  149. anyone have beat opti 2 coil wires?
  150. cam question
  151. lt1 build plan
  152. Car runs like crap after adjusting rockers
  153. New car - Z28
  154. car overheated what happened?
  155. move steering column?
  156. MAF question?
  157. Replacement rubber for elbow?
  158. How? and thank you for helping
  159. Noob question
  160. finally got into the 11's NA
  161. finally got into the 11's NA
  162. Need help finding this Formula WS6 ad!
  163. how to make cat back pipe wider?
  164. help?
  165. Screw traction problems
  166. bolts on
  167. Exhaust Help
  168. Clearance issues with these headers?
  169. Anyone email tuned?
  170. Crane 6, or msd 6al?
  171. b&m ripper = more noise vibrations?
  172. need help asap!
  173. How much boost on stock bottom end?
  174. basic questions unanswered in the F.A.Q.
  175. LT1 Fuel Injector "Firing Order?"
  176. lpp header install question
  177. 383 LT1 w/ F1A procharger...vid
  178. New Best
  179. clutch flywheel and flexplate?
  180. what others are saying about LT1's
  181. cam swap now it wont start help
  182. v6 to v8
  183. please give me your opinions??
  184. Free LT1 WS6 Hood For Test Fitter
  185. first time to the track
  186. what else do i need??
  187. full-length sfc's?
  188. LT1 stalls at red lights.. Sputters PLS HELP
  189. Exhaust Susgestions
  190. Anyone else hate to sell a car?
  191. dyno numbers
  192. Still Running Funny
  193. just want to tell my excitement
  194. 350 hp lt1?
  195. Roller rocker ratio ?
  196. rocker arm or exhaust leak
  197. Crank Position Sensor
  198. Answer this please.
  199. lt1 - ls1 mpg differneces and why?
  200. Exhaust Leak and BLM Question?
  201. clutch porn, plus install questions
  202. build sheet
  203. where to get .033" thick LT1 head gaskets?
  204. New car...Problems
  205. need some help/advice
  206. LS7 Lifters and Pushrod Length
  207. weight reduction??
  208. need help locating a part
  209. valve spring help
  210. Comp 07-468-8
  211. service engine soon????
  212. Front Sway Bar
  213. Do yourself a favor, get your driveshaft balanced.
  214. porting heads ?
  215. P600B to D-1 or F-1
  216. Best Exaust System for an LT1
  217. What upgrade next?
  218. lt1 carb conversion?
  219. lt1 to ls1 conversion
  220. Valve Springs????
  221. yella terra shaft rockers
  222. Help: Few question on first build.
  223. Finally got my 12 sec slip
  224. induction parts combo questions
  225. 3.73 or 390
  226. I need help
  227. need suggestions on motor
  228. ***Ai 383R long block with TFS 215 heads goes 9.6@139.9mph NA ***
  229. Hello Everyone
  230. dyno?
  231. k-member
  232. whats the general consensus on a setup like this?
  233. Pics of my car... DIAL UP DEATH!
  234. My 10.35@130mph (vid)
  235. 93 lt1 trans am vs any other lt1 f body what differences or problems
  236. What spark plugs with boost?
  237. lt4 valve springs
  238. Edelbrock 2108 Cam-My track times
  239. 94 Octane?
  240. Is it possible?
  241. Need Help...
  242. AIR/EGR PCM delete
  243. video I made...
  244. What does everyone think of this motor?
  245. what plugs for my 396 LT4?
  246. tunning question
  247. Crossmember mounted torque arms!
  248. Measuring Opti & Ignition
  249. NX 150 shot question
  250. Question about 1.6 rockers and bee hive springs
