View Full Version : LT1-LT4 Modifications
  1. New lt1
  2. Parts list for Header Installation
  3. Adjustable Torque arm and Control arms needed ?
  4. new best
  5. LT1 front bumper repaint
  6. Need options on brakes
  7. How much power ?
  8. opinions on this setup?
  9. lt1 with 1.26 valve springs
  10. HP plateau; Pulling Vacuum
  11. iac problem
  12. dual X exhaust
  13. torque converter question
  14. what valve springs and push rods should i get?
  15. LT1 Ram Clutch disc - will this one work?
  16. slightly touched up converted to LT1 style GM 18* heads or AI's 215cc TFS heads?
  17. Ground Wire Help
  18. how much power do you think it will make?
  19. Last blot...stripped
  20. Starter Help?
  21. Opti Help!
  22. I'm always breaking stuff
  23. My story : the LT1 Pacesetter LT project
  24. AI 200cc's
  25. im looking for a budget motor who can help
  26. AC dripping on 02 sensor???
  27. LE1 Build finally fired today
  28. bbk underdrive pulley question
  29. I Blew A Ring On Juice
  30. The beast won't crank!!!
  31. Firt LT1 build (383/H?/C?/Blower)
  32. bleeder screw size?
  33. Low fuel pressure.. ??
  34. Mac Mids problem
  35. MAF size on an LT1
  36. destroyed rear dif
  37. Compression Ratio
  38. Moroso p/n 20185 oil pan and Kooks headers?
  39. Center bolt valve covers???
  40. Installing now PLZ HELP
  41. 18 Degree Heads
  42. how loose should valves be? (cant move with fingers,only with pliers)
  43. Hungry LT1
  44. ALOMST DONE!! pics
  45. Still paying the price
  46. A4-M6 swap
  47. Weird LT1 Issue
  48. whats the fastest stock bottomend lt1?
  49. how much will it cost to have bent valve replaced?
  50. 70k Mile LT1
  51. evap system
  52. Radiator Help
  53. no spark, no fuel
  54. New best last night!
  55. Nitrous help?
  56. Question for all you B-body guys.
  57. Brake dust issues...
  58. Anyone ever do a LT1 FWD?
  59. LT 1 w/ distributor in rear?
  60. Sts Lt1?
  61. Crazy Fuel Gage
  62. Back on the road
  63. Need help for my lt1
  64. A package came today!
  65. Steam Tube seal rings
  66. y-pipe to mufflex question
  67. Lt4 Hot Cam
  68. crank pulley F.S
  69. new set up
  70. steering questin....
  71. just put in fan switch, anything else?
  72. lt4 conversion?
  73. Nitrous?
  74. Header question! Help asap!
  75. fuel issue?
  76. replacing push rods?
  77. What 1.6 rockers?
  78. 165,000 97 WS6 Formula needs a rebuild...
  79. Hot Tanking Heads Fully Assembled?
  80. Anyone have any pictures with a stock pump n screen Melling issue
  81. shouldn't be the opti
  82. Got my car dyno'd
  83. tapping noise
  84. Header questions
  85. Header installation??
  86. anyone know thi answer to an f body electrical problem or two???
  87. Dipstick!!!!!!!!!!?
  88. dark smoke on hard take off
  89. need help quick
  90. Wtf
  91. I wanna go FAST!
  92. Crank pulley removal (97 LT1)
  93. Anyone ever ran a cam only CC306 with auto??
  94. Ticking Noise
  95. Question!!!!!!!
  96. Dieseling
  97. 30# INJECTORS HITTING 91%DC. What size to get?
  98. upgrade ya
  99. Check these bad boys out!
  100. clearance issues or no?
  101. what elbow
  102. hey how is a good way to get ahold of loydd elliot
  103. Check out LTXtech.com!
  104. The Fastest LT1's on LS1TECH.com
  105. MY CARRRRR!!! have to go through ltxtech.com first though..itll link you to the page
  106. just got my car done and well READ LOL
  107. How Real Men Work on F-Bodies
  108. spark plug gap help
  109. Ok I am almost ready & curious... what should I trap/run/dyno?
  110. Trann Question
  111. Just bought car and need HELP!!!
  112. Plastigage Question
  113. Does anyone have this cam?
  114. shift kit
  115. Fuel pump issue?
  116. guess my time
  117. Pure BAD ASS!!!!
  118. put lt1 intake on 406 possible
  119. need answers about building 396
  120. low rpm stutter... searched!
  121. paying the price
  122. Cam Surge or Stutter Datamaster Log
  123. My new LE2 heads are in the car!!!!Pics!!!!
  124. opti again
  125. where to get software to tune lt1's???
  126. LT1 wiring harness pinouts
  127. Cola Crankshafts
  128. New bolt-on LT1 record
  129. strong chassis
  130. To Heavy
  131. opti install linx?
  132. air foils
  133. 1/4 mile
  134. will I be dissapointed?
  135. Cam and Nitrous
  136. Le2 head and cam from lloyd elliot
  137. Aligning balancer for Lt1???
  138. goin to the track guess my times
  139. Throttle Body Bypass?
  140. tuning???
  141. I think my cars a Factory Freak
  142. New PB with my AI h/c setup.....
  143. New H/C/H build doesn't feel right
  144. Car Is Smokin With No Codes ??? Help....
  145. Alittle Engine Cleaning
  146. The Best Header Gasket!
  147. cam swap?
  148. Turbo lt1 videos
  149. Bolt on order???
  150. Took Some Pics of My Car
  151. OBD2 to OBD1 swap possible?
  152. Strength and Weight
  153. Fuel pump wiring Q..
  154. Some OBD2 to OBD1 Swap Problems from a 96 to a 94
  155. air/fuel sensor
  156. What's leaking?? Pics!
  157. Pump gas on built motor ?'s
  158. Question on lines for ls1 brake upgrade
  159. Today's Entertainment
  160. lpp headers?
  161. blue or white smoke
  162. Transmission leaking!
  163. curious?
  164. Banging back & possible engine vibration.
  165. Cool Video of someones LT1
  166. Quick Question
  167. how much??????
  168. what should my car be running
  169. what should i expect?
  170. First Time At The Track With The Car
  171. Cam Surge / Stutter / Miss
  172. Injector size
  173. car wont stay running..
  174. Another stock ten bolt falls
  175. Just finished painting my LE3 intake
  176. My 385 LT1 Dyno Graphs need some input
  177. Oil Cooler
  178. Smell of gas from my LT1
  179. edelbrock tubular headers for sale
  180. LT1 Pushrods...
  181. exhaust..
  182. DO i have to?
  183. I have a problem!
  184. EGR Block off plates...
  185. LS1 DS/Nitros Results
  186. Jet shift kit
  187. camshaft guys check this out?
  188. Is there any way to hide the n20 lines in a lt1?
  189. Leaving for Iraq..
  190. best headers for lt1?
  191. Help Please. ;/
  192. 93 myth?
  193. AFR 180cc lt1 heads
  194. high idle ses light on/off
  195. Radiator Replacement
  196. ok for your blower folks...
  197. Need some help here. Headers + Y pipe
  198. So, who wants to be the first Hydrogen-Hybrid LT1?
  199. Cam
  200. Fuel Injector ?
  201. wont start no spark
  202. quick question on a 383 rod length
  203. high flow cat
  204. H/C/I how much did u guys pay
  205. Opti Problems
  206. gm 847 w hotcam roller rockers
  207. F-Body Install (130+ Install Guides)
  208. Octane Boosters??
  209. Lt1
  210. I Need Instructions On How To Wire My CutOut
  211. car falls on its face
  212. Detonation?? new prob!
  213. Check out this SS hood. Looks to work with LS1 lid.
  214. beaten to death topic here but could use some help
  215. most power?
  216. Early Early christmas present!
  217. need some things answerd on the eagle kits..
  218. stock installed heights on lt1 head with stock retainer
  219. What do u guys think about this....
  220. LE1 or LE2 questions..
  221. Ltx Hub Pull Video
  222. Front Sway Bar question??
  223. Exhaust Pop
  224. Cam and Head Questions????
  225. What Blower/Cam set up?
  226. my 383 lt1 build... should be fun.
  227. Bad hesitation leading to car shutting off
  228. Help Oil temp
  229. need help with freescan/vemaster
  230. How much can I make off this?
  231. Which Short Blocks?
  232. lt1 crank pulley help
  233. Spark Plug Wire Wrap
  234. Revised Phatkops single plane 383...
  235. RAM Powergrip HD vs. ZOOM Dual sided Kevlar
  236. LS7 Lifters
  237. 2009 LTX Shootout date has been set
  238. New cam, and tune and what not...help.
  239. going to track next week guess times
  240. oil pan gasket
  241. Fuel Pump For Blower
  242. lq1 and lq4 diff ??
  243. This can't be kosher..
  244. Lt1 Hub Need to be lined up?
  245. how much is my mids holding me back?
  246. compression?
  247. got a problem
  248. so i blew the motor now i need to figure out what to sell it for
  249. factory head cc specs
  250. Edelbrock's Semi-CNC LT4 heads
