- Dyno Tune nitrous systems?
- How can I get about 400 H.P. out of a TPI 350
- car still runs BAD. 100miles/15gallons
- need new engine 355 or 383??
- Ported Maf ends
- The OFFICIAL LTX Shootout 09 smack talkin thread
- Need advice:Installing my GMMG
- Difference between 93 LT1's & 94-97 LT1's
- Is Power Shifting Bad For Your Clutch/Flywheel?
- Best Sound Duals Setup ?
- Funny video with C Sikora in it....
- optispark question
- Help!! High and Rough Idle!!
- RaceTronix Fuel Pump
- loss of power
- dyno numbers and ETs in the same day
- LT1 tick
- High Res track pics 8-08-08
- alcohol rated fuel pump
- finally going to do headers, which gaskets?
- Ok what next??? Suggestions.
- need tranny help!!!!!
- Copper header gaskets
- Help me
- a little update....
- Spark Plug Torque specs?
- CNC-Motorsports Roller rockers
- Help me match an off the shelf cam to the converter I want to use...
- Running a 100 shot on a stock tune & 91 octane?
- AI gave me estimate...wow. Help!
- Cam upgrade from a CC306????
- 94 Lt1
- Buick Roadmaster; Texas Vehicle...spline drive opti?
- Weird misfire down low \=
- Intake leak?!
- How to make a 355?
- 95+ Opti harness
- arp torque settings ?
- Ported Aftermarket Castings
- Launch Delay
- a.i 224 cam
- Fuel pressure regulator for eaton s/c setup?
- Slow Crank at Hot Starts
- Common Engine Reassembly Mistakes
- Stock 03 cobra 39lb injectors in LT1?
- $2,000 what should I do?
- Lt1 intake question
- MAP unplugged ?
- Backfiring? and i know it is not my optispark
- my 97 camaro SS vid with CC503 & TSP Rumbler
- Gonna pull my Z28 out of storage.... Here is the performance plan..
- LT1 Street/Strip Motor Build ?s
- Handheld Tuner
- $150 .040 over shortblock. Should I?
- help, engine running like shit.
- same exhaust, but one is ALOT louder..
- Dyno Predictions!?
- couple questions on my 97Z28 guys..anything will be great
- enggine knock/low idle
- LT1 oil pumps ? 10552/10555
- LE 383 LT4 Dyno Results
- Couple string pipe questions
- Dragbag assist?
- Another misfire, opti or coil or o2's??
- 383 lifespan
- Torquing Sequence on a 94 LT1?
- no rpo codes ? wtf!!!!!!!
- headers and rocker arms
- racing shifter
- Where You On Top Or Bottom??
- Borla vs Corsa for a 95 z28
- PCM .bin file needed
- hp range??
- Help me prove then wrong...
- bigger injectors or possible bad fuel pump
- wrecked camaro
- Plastic Shield Inside the Door
- headers??
- Why was my thread deleted?
- 94 Z28 overheating....................
- high compression LT1 guys
- car doesnt hold an idle
- LT1 Valve Springs
- 4l60e aftermarket shifter
- Mustang owner coming over to the LTx side
- transgo kit for 95 camaro 4l60e
- LT1 With New Shoes
- A few pics of my LT1 at my sponsor's car show
- msd opti....
- Damn You Radiator!!
- LT4 Hotcam Kit HP Gains?
- 918 spring pressure loss?
- porting my heads
- i need some help with changing spark plug wires
- High Performance Poniac Article!!!
- Tall Valve Covers
- 17 year old needing advice or ideas
- hesitation and wierd idle
- gen 1 to lt1 swap
- which opti
- cc306 vs. AI 226/234
- Msd6al
- track times
- power locks starting to not work??
- strong 4l60's?
- le2 heads /le1 billet cam/ le intake
- high revving ?
- header install help!
- front air dam
- LPP LT1 headers and Y now on SALE
- High RPM 'hitch'
- What is this solenoid?
- lt1 or lt4
- LT1 w/ Eaton M112 supercharged!
- t56 trans
- New Track Times!!
- AFR rev kit?
- lt1 daily driver ?
- would it make a differance moding my Mids?
- starter sparked and went dead
- help! will not turn over
- I need height measurements on electric water pumps
- Keeps blowing inj fuses
- mids 2 LT what do I need ?
- A little getto But it runs
- Who's got a Glasstek Cowl Hood??
- 355 (LE1 cam/LE2 heads) LT1 is complete. Final dyno numbers inside
- crazy vibration
- One way hose? (pics)
- cam lock rockers
- Motor issues
- Walbro pump bad after 40 miles.
- My 67 SS getting a Nitrous Outlet treatment...
- ok i know its been beaten to death
- Who uses block/ valvetrain girdles
- car wont idle
- Please explain why MY car won't 60ft...
- True Duals
- ICM / coil assembly cooling solution?
- would these fit
- The numbers are in! Dynoed FINALLY!
- dodge forum
- What cam for stock heads?
- Tranny problem?
- Hold up. (has pictures)
- 39x LTx - Year casting to use?
- Oil change?
- 94 Camaro Z28 Gear Swap!!
- Open Header Guys - - Come In Here!!
- Ac
- D.S Saftey Loop
- Trick Flow Makes a Cold Air Intake for LT1's
- What Lifters and gasket set for Hotcam Kit?
- 4.10 daily drivers?
- AI 226/234 first impressions
- Lingenfelter CAI
- sealant for sensors
- Help on cam choice
- How to tell the difference from nsa and sa rockers
- LPP lt1 headers
- installing engine..HELP!
- valve covers
- exhaust
- Out of the blue, DTC16, DTC18, DTC51
- Water Pump Q's on 94 Z28
- Thoughts on cam
- Stock Shift Point
- Power steering problem...
- Does the Canton oil pan require the Canton gasket?
- 1 3/4 Headers??
- LT1 Over-heating
- 1994 Corvette part #s needed please!
- Summit Electric Cutouts
- Slp Loud Mouth
- E Brake Woahs!
- Rev Limiter for a CC503
- wagon LT1
- A/C woes!!
- is machine work needed for rod bolt swap???
- Windage tray and stud kit questions
- Cam Swap Nightmare!
- Need pic of something
- fuel pump question
- Is 210 or more coolant gauge normal or it should always stay 160?
- Headers ?'s
- Great Deal
- LT1 O2 Sensors (searched...)
- My LPE headed 383 --- 56k? probably not
- Tuning advice
- Thinking it may be time for a "Tune".
- Couple of Questions about 93's
- Finished installing my LS1 Borla exhaust on my LT1
- HP/TQ predictions...
- Huge LT1 part out
- My T56 Conversion..
- backfire question
- Please help me diagnose my dieseling problem
- ode to my LT's
- What is this cut/port on the bottom of the LT4 Manifold
- Carbed LT1?
- LT1 Hooker Super Comp LT vs. Pacesetter LT's
- Still chasing this oil problem...
- Got me a LS1 Alum DS...... Questions?
- 350 to 396 questions ???
- New build
- Testing Plug Wires
- 94 3.4 firebird to 1994 corvette LT1 swap
- help with meziere e water pump.
- Best fuel pump for my setup
- primary resting on motor mount
- Failed emision test
- Rear main seal. difference between 93-96 and 1997 seal?
- timing question
- Can anyone tell if this bottom end is forged?
- Throttle return Springs
- urgent please. dumb question about coolant sensor
- can i run a h pipe istead of a x pipe.
- The BIGGEST CAM i can put on a stock bottom end?
- Will aftermarket ignition box cure minor cam surge?
- True Duals Over The Axle
- Cam/Head Question. Please Help!
- Horrible Gas Mileage Need Help!!!!!!
- backfiring problem ????
- Inj alcohol through a NOS nozzle..
- HELP 383 with tpis afr head very low hp 322HP
- Is the 383 Scat Pro Comp Series 9000 Crankshaft any good?
- A NEW opti question
- AI 185cc
- Reluctor Ring = Crankshaft Sensor?
- LS1 Brake booster and master cylinder
- Carbed LT goes 9's in Denver
- Start up problem
- Best Bang For The Buck Questions
- Ok I Dont Kno Why This Site Wont Let Me Post A For Sale Add In The For Sale Thread...
- A plan....I think
- clean 94 z28/m6 plus abunch of good stuff
- LT1 vs. LT1
- Takin The Ss To The Paint Shop
- Dynaspark
- throttle body question
- Tune on basically stock LT1
- Trick Flow Polymer Elbow or 1LE?
- need help with lt1 in chevelle
- Spark Problem
- Code 36
- Stock oil size pickup?
- can i temp cap/block off the rear brakes?
- airfoil
- mids vs lt headers
- Myth or Fact. on 60ft.
