View Full Version : LT1-LT4 Modifications
  1. Rocker Studs
  2. New Module/Chip For 1996 LT1?
  3. Dyno Tune!!
  4. WTB a used stall coverter
  5. Does switching to main studs require honing?
  6. PS Y fit any headers?
  7. LS2 Exhaust Manifolds! Will they fit my LT1?
  8. new info on my moneypit
  9. MSD Pro billet opti
  10. Electric water pump
  11. transmission help
  12. Supercharge Stock LT1? YES or NO . .
  13. What springs for Hotcam?
  14. Estimate hp/times
  15. 4 bolt LT1
  16. is a lt1 and a ls1 tranny cooler the same
  17. After 3 hours under the Hood
  18. How much boost on LT1?
  19. Car's idle is jumpy,lossing alittle bit of power
  20. New to the LT1
  21. couple of problems hope u guys can help.
  22. car runs like shit
  23. Corsa db mufflers??
  24. TT2's?
  25. weird problem.
  26. passenger fog light
  27. Which Distributor...if Any... Would Best Fit A Machined Lt1/lt4 Intake Manifold??
  28. Water pump replaced, misfire now.
  29. full coolant flush
  30. Need Help! I want the fastest Stock block N/A LT1 M6
  31. CEL and fixes..
  32. main caps
  33. Bad sensor?
  34. new updated pics with the new wheels
  35. Any new mods
  36. Help with odd '95 caprice problem
  37. P1351 Code! 96 Camaro Z28
  38. Car will not start up. Please Help
  39. ABS question
  40. Ran out of oil!!! Rear main seal??
  41. 1/4 mile times
  42. Knocking noise NEED HELP!!!!!!!!
  43. Msd r Stock plug wires
  44. Need Help, 94 A4 Z28 Won't Shift Under Wot, And aAdvice With Tunercat
  45. Check this out!! Vid
  46. Two Issues here
  47. problems after header install
  48. hid kit
  49. lt1 with turbo
  50. what do you guy think about this opti?
  51. Just bought a 94 Formula!
  52. Help!!!!!!!!!!!!!!!!!!!!!!!!!!!
  53. how hard to change throttle/cruise control cables?
  54. Its fixed!!!
  55. New Best!
  56. AI cam
  57. True Dual LT1 Guys...
  58. Help!!!
  59. I keep going through o2 sensors
  60. starter solenoid
  61. Couple of Questions
  62. Pleaseee Helppp
  63. Possible mpg decrease
  64. 4L80E into LT1
  65. Question about otvc looms.
  66. Finally got a Cardomain page made for my LT1!
  67. LT1 cluster question.
  68. little photoshoot
  69. Best place to get throw-out bearing?
  70. Jegs Damper
  71. Taylor Spark Plug Wires ???
  72. Guys who have done compression check in here
  73. Putting the heads on
  74. i need a piece for my ciai
  75. 94 lt1 cpu
  76. Over Tightened Valves?
  77. Head Gasket ?
  78. Valve springs
  79. Loosing power????
  80. how cold is too cold!?
  81. GMC sierra vs Z28 gas mileage
  82. 700r4 ?$
  83. What do you think of my future setup?
  84. Low Oil Light Wont Go Away
  85. Hooker Long Tube Headders
  86. Had somethind weird happen last night....
  87. Clutch
  88. lunati 60120
  89. ran into a problem
  90. a/c question
  91. Taner in Car Craft!
  92. need 96 lt1 impala crank hub
  93. partially open cutout
  94. Friend looking at a 94z....need help! Im not an LT1 guy
  95. idle is too high,whats the problem?
  96. LT1 cam and engine upgrade advice...PLEASE HELP!
  97. Most Reliable Injectors????
  98. quick coolant question
  99. Need Help with wiring
  100. Throttle Body
  101. Curious loss of power.
  102. where is the cheapest place to get a lt4 hotcam kit?
  103. Problem?
  104. Help settle an argument
  105. 94 T/A M-6 Running very rich and stalls when moved.
  106. reprogram for speedo...
  107. Install Complete! do think i'll hit lo 12's?
  108. a few questions
  109. I Got to drive a GM Fuel-Cell Vehicle!
  110. low voltage
  111. what size injectors for 383
  112. what are the symtoms of a bent valve?
  113. ls1 cam in lt1
  114. 94 TA + Window motor/'Trans Am' Logo Repair
  115. Made a few pulls...
  116. AC problems
  117. Trying to see what route I want to go..
  118. is my rear shot?
  119. Fuel problem "Need help fast"
  120. Car is...doing indescribable things... Opti?
  121. 4L60E to t-56
  122. Oil behind the TB Plates and in the Intake Manifold.. how? NOT PCV
  123. Formula with prostars or drag Welds
  124. Running Issues
  125. LT1 "fine" tuning PCM
  126. Computer issue
  127. cam install problems
  128. What should the numbers be
  129. New LT1 Long Block
  130. Need some help/Advice (Knock Sensor, Head Gaskets etc)
  131. why would electric fan on aftermarket cooler make trans hotter?
  132. trying for 12s
  133. Spark Plugs
  134. P0174 code. What's causing it?
  135. Gearing
  136. another opti i think this is the 5th one
  137. low resolution opti code
  138. It Finaly Runs
  139. Question about EGR and AIR block-offs with race style headers
  140. anyone else have ticking at hot idle?
  141. Engine Build Choices Driving Me Crazy
  142. roller rockers need to adjust
  143. block number ideantification
  144. Percy's XX Carbon Exhaust Header Gaskets
  145. B&B Triflow EXhaust??? Whats your opinion
  146. Where to Buy OEM Quality Body Panels
  147. Car stumbles when you hit brake???????
  148. too big a cam for stock heads?
  149. trifecta
  150. Doing Head Gaskets
  151. Timing Chain
  152. LT4 Hot Cam < ??
  153. TKO 5-speed vs. Richmond six speed
  154. got the YSI in last night!
  155. Suspension
  156. Broken 10 bolt
  157. LS1 Smooth bellow on LT1 Ram Air?
  158. LT1 Power Drop
  159. Comp Cams 503 in 383
  160. timing cover removal and help....?
  161. Fuel pressure Regulator??
  162. 94-96 Gauge Cluster Anyone?..
  163. Need suspension measurements form LT1 guys!
  164. lets hear the break down on bolt on's ls1 and cobras what they run with bolt ons
  165. Emergency Brake Cable
  166. Where's the best prices??
  167. lost driver's license
  168. So I got an extra $30 Summit bucks with $100 purchase what should I buy?
  169. overheating issue.
  170. Bolt for Torque Arm Bushing
  171. Need help... Oil blow back???? #@@$%&
  172. truely truely how much can i sell my car for??? 97 383 stroker
  173. Future Plans
  174. Reverse Lockout Solenoid
  175. 96 LT1 timing cover?
  176. This cracks me up!
  177. where can I get a ready togo nitrous set?
  178. 94+ harness on 93 car?
  179. Running Rich
  180. LT4 is hard to start - but once started runs OK
  181. Bought a TA, Doing an A4 - T56 & LT motor swap or Swap Cams, IM etc?
  182. nitrous question.
  183. ignition coil
  184. 98-02 guage cluster
  185. LT1 Block
  186. Need some Tuning Help :)
  187. Dyno tune Jackson ms, little rock ar, or dallas tx
  188. Help with MSD opti
  189. Cadillac Racing Lifters Spec?
  190. What would someone be willing to spend for the 396 from PEPE
  191. 94 Formula wont start.
  192. what do i need to install a stall
  193. Bolt-on E85#'s
  194. help fast
  195. Ford injectors
  196. So who likes my sig?
  197. Run MSD 8.5's over-the-valvecover?
  198. shifters
  199. LT1 M6 Bolt-on guys with 4.11s come on in...
  200. Strange knocking comming from under the drivers side
  201. 96 LT1 computer/flywheel Q's
  202. Rear main observation
  203. Cam Help
  204. 94 block heads into 95 car
  205. hypertech
  206. Few pics of my car from a local show.
  207. Header Installation Question
  208. Pulling my Motor and Tranny out of my OBDII 96 & going to an OBDI 95 TA, Knock Sen. ?
  209. BCM is making a clicking noise
  210. whats my motor/trans/ecm worth?
  211. LT4 Hot Cam Kit What Should I Expect??
  212. Ladies and Gentlemen, my nitrous is now.......
  213. Fuel pump/regulator?
  214. Strange Misfire
  215. Bad O2 making me lose?..
  216. does anyone on here have this setup?
  217. 94-96 camaro gauge cluster in 93?
  218. Wanting To Run Nitrous On Hyper Slugs
  219. help!!!!
  220. '93 LT1 T56 Better Gear Ratio?
  221. camaros in idaho!!!
  222. Head bolts. Thread sealer
  223. 1/4 mile
  224. bmr vs hotchkis
  225. 1500$ what to do
  226. How do u put fluid in a six speed tranny??
  227. o2's?
  228. switched to RP, lost some oil pres.
  229. E.W.P And Heating up?
  230. Tag lights
  231. Need injectors
  232. Ideas on cams?
  233. detail my car today got some pics...
  234. cam dowel pin
  235. 4th of july fun!
  236. My first LT1 rebuild and I need some help.
  237. what cam?
  238. Optima battery problems! Need Help!
  239. MSD Blaster coil... Opinions?
  240. How Hard To Change Injectors LT1
  241. affordable water pump
  242. Manual fan turn on switch is it worth it
  243. post slp loudmouth vids if you got em ...
  244. Next bolt on opinion
  245. need lots of help! opti install issues
  246. single plane intake worth it on my setup?
  247. Any performance advantage w/EGR Delete
  248. ASR Delete
  249. what does it do ?
  250. lt4 hot package
