View Full Version : LT1-LT4 Modifications
  1. Third O2 to measure AFR?
  2. t-tops
  3. 4l60 ?
  4. Installed a little cam, enjoy
  5. What plug wires for Delteq??
  6. 95 LT1 misfire
  7. im stumped, can anyone help?
  8. edlebrock, summit brand, BBK, throttle bodys.... any good?
  9. Pics.. How low are you guys?
  10. ac hose splicing?
  11. pop through exhaust possible o2 problem?
  12. Should I upgrade injectors?
  13. Guys with bolt ons and nitrous, come inside!
  14. Fuel Tank question?
  15. Bolter
  16. oil pump drive
  17. Finally doing it! New paint!
  18. gauge cluster interchangibility? re flash pcm?
  19. possible aftermarket cam
  20. LT1 stumbles at 5000rpm
  21. true duals with flowmaster single chambers
  22. race fuel
  23. how much rwhp can a magnaflow catback handle without being very restrictive?
  24. Driver side O2 location
  25. Need Help With Fuel Pump!!!!
  26. Walbro fuel pump installation "HELP"
  27. Starting trouble when hot
  28. red top injectors and LT1
  29. Best way to find vac leak?
  30. dyno tuning.
  31. P0420, P0441, P0420
  32. Finallly gona install my exhaust,only question is what mufflers?
  33. Just wondering what a LT1 M6 convertable weighs
  34. What will I run?
  35. NEED HELP, Lt1 popping from exhaust
  36. Let me get this staight,how to complete a good exhaust system?
  37. Suncoast Predator hood
  38. Trans is shot :( How much is a low stall?
  39. good opti>?
  40. Another Problem
  41. help! car died and wont start!!!!!
  42. idling
  43. stock cylinder heads ?
  44. Turbo Lt1 ?s
  45. Hate to do it, another what it run/power it will make thread.
  46. lt1 backfire problem need help!
  47. BMW e46 M3 VS LT1 Stock TRANS AM.. WHO WiLL WiN?
  48. My modded LT1 runs better without the tune???
  49. finally solving all my motor problems
  50. 96 trans am, Window fell off the track
  51. Longtubes compared to Shorties
  52. big trouble pushrod/guideplate related
  53. Almost Ready
  54. Best places to shop online for LT1's?
  55. definition of full bolt ons
  56. Water Temp. Gauge question?
  57. hard starting multiple misfire?
  58. csi/csr electric water pump/ 383ci and road racing?
  59. man will yall please check out these headers. are they too legit to quit? lol
  60. lt4 km
  61. LT1 swap possible?
  62. One last cam install question
  63. 3'' y-pipe or 2 1/2'' x-pipe
  64. LT1 camaro guys might be interested......
  65. ac delco 904's
  66. ur thoughts on edelbrock heads/intake
  67. Lt1 misfire...
  68. 13 year old LT1 vs 03 Cobra with a Whipple...
  69. Are Walbro pumps really that bad??
  70. I figured I would start an Oil Type war! LOL
  71. 40mile trips and trouble codes
  72. Open Headers
  73. Anyone have stock cam SPECIFICS?
  74. LE heads go 10s N/A Drops 5/10th w/TH400
  75. Meziere wires and relay
  76. Do I need injectors?
  77. I'm looking for pics of DIY rear mount turbo installs
  78. stock pushrods with cam
  79. 400hp 11 sec lt1!!!
  80. Does anyone have evidence that the air flow booster works
  81. Gen 1 Engine in to 4th gen camaro
  82. First Post! Wish it didnt have to be this though(rad. leak)
  83. Abs
  84. Brake Issues after the LSx Upgrade
  85. Is it OK to go no T-Stat??? Opinions...
  86. thinkin about swappin the 355 into my boat.
  87. over tightend rockers (power loss)?
  88. great...
  89. Car cuts out at 4500 RPM.
  90. My S60 is here
  91. Cam Bearing Oil Holes
  92. How to use fuel line disconnect tool?
  93. Finally after 6 months the nitrous is in! (pics and video included)
  94. I still don't get how to restore a/c into the vents..
  95. 6.950" pushrod sound right??
  96. meziere pump
  97. doing a top end!!
  98. Is Their a Min. Tolerance For A Flywheel?
  99. Oil plug pin hole
  100. lt1 high idle problem
  101. LE1 h/c track times
  102. Opinions On Headers
  103. additional modification
  104. help
  105. Weird driving problem
  106. Next Mod???
  107. a few pics from the track
  108. What is this....*PIX*
  109. LT1 Water Pump Drive Shaft R/R
  110. Help: 97 lt1 overheating randomly
  111. Quick Cam Recommendation
  112. hood inserts cut??
  113. cam break-in procedure
  114. Opti Tricks
  115. who all makes 4" cutouts?
  116. solid roller vs. hydraulic roller motor.....advantages and disadvantages
  117. Relocating Coil?
  118. Any info on the Best heads for a 292xfi cam?
  119. Opne vs. Closed Loop
  120. Runs like crap in closed loop, great in open loop
  121. P0441, P0174 ...and a misfire code ...help!!!!!!!
  122. Pcm Tune after cc306?
  123. Best Intake for Turbo Lt1
  124. Lt1 Nitrous Pics!!
  125. Who LOVES their LT1.....
  126. issues
  127. Fluid leak, need help.
  128. Opti spark all wet!!
  129. Carrier and pinion bearings
  130. Opti Seal
  131. got some codes and need some input (16,41,42)
  132. Engine Bay Color Scheme
  133. random SES light
  134. ls1 corvette lid fit lt1 firebird???
  135. lt1 fuel line help
  136. In need of ecm
  137. rpms take some time to kick???
  138. Carnage Report..
  139. carb'd Lt1s
  140. transmission problems
  141. Car Starts Dies Then Won't Restart
  142. Lt1 Camaro For Sale W/ 98-02 Front Clip
  143. FUEL PUMP bad maybe need help
  144. Exhaust setup?
  145. Accessories problem...
  146. clutch pedal stuck to floor
  147. All motor 10.62 LT1 video... Hookin and bookin...
  148. lt1 starter issues
  149. Window switch or motor??
  150. Possible new Intake manifold for LTX
  151. Are LS1 aluminum driveshafts the same from auto to M-6?
  152. Whats a good single muffler (bullet)
  153. 52mm or 58mm throttle body, gains?
  154. Stock Header Bolts? HELP!
  155. Part Number
  156. what valvetrain parts should i get??
  157. ok gear swap question?
  158. LS1 brake upgrade question
  159. Can't decide on a cam, HELP (Yes I Read the Sticky)
  160. Pictures of smooveZ's rides!
  161. vats system/security light
  162. 242932 TCI stall will this work for a 96t/a cause it aint workin for me please help
  163. opti question
  164. fans
  165. is something wrong?
  166. 396LT1 MorePerformance engines? 3.875 Callies Stealth crank Help
  167. Accessory bracket replacement
  168. True duals w/not enough ground clearance
  169. Picking the right torque converter
  170. Couple of Problems
  171. Still can't separate LT1 from transmission!
  172. LT1 Rebuild, need opinions or ideas
  173. Sb2.2/lt1?
  174. Is this ok...and can it be fixed?
  175. Someone fix this pic so I can put it in my sig
  176. Just picked up an MSD Opti, would you like my opinion?
  177. Hit a snag...
  178. Questions on multiple matters. Frost plugs, tranny and rear spring dampener
  179. pistons and opinions
  180. TCC Lockup tuning question.
  181. Any write ups for removing the ABS?
  182. Good fuel pump for lt1
  183. Best Springs, Push Rods and Rocker arms??
  184. need some help with rad. hoses
  185. basic mainentance
  186. What parts would you like to see the aftermarket develop?
  187. lt1 newb questions/ideas??
  188. What gears should i get?
  189. Little Trouble buttining up my H/C motor swap p1351
  190. optis failing help please
  191. De-pressurizing the fuel lines
  192. need help choosing crank
  193. bent pushrods after cam install
  194. traction control
  195. mid tube headers??
  196. valve cover screws
  197. new to Tucson 1995 LT1 looking for mechanic
  198. Looks like a vacuum leak,where to start?
  199. All motor track results!!!!
  200. What cam is in my car?
  201. EWP problems...
  202. gas cap question along with other newbie questions
  203. Need Help ignition problem?
  204. Putting on a New K-Member & LS1 Brakes... & found a crank problem
  205. Pics of my vehicles
  206. Yank stealth 3000
  207. LS1 front brake spindle 1 complete
  208. NEED HELP! 94-96 Z28 gauge cluster into 93 Z28
  209. stripped distributor gear
  210. Forged Pistons?
  211. what are these?
  212. 93 Lt1 Guys TB Linkage
  213. help?
  214. help! Ses light came on code p0400!!
  215. new 2 LT1
  216. Cam bearings
  217. A question about sensors
  218. Optimal plug gap for TR-55s?
  219. Bigger Brake Kit?
  220. ALDL Cable problems.. firebird
  221. What series carrier???
  222. ACCEL Opti?
  223. SES light and emissions testing question for a 97 LT1
  224. Started my new 355 today. Starts fine but won't idle
  225. Step In If U No About Nos And Spark Plug Gaps
  226. average breaking point for stock 10 bolt
  227. how hard to change opti
  228. Changing the Tranny Fluid..Need Help..
  229. Setup Suggestions??
  230. IACV question
  231. Moroso CAI filter question..
  232. please help
  233. Is this plug fouled?
  234. opti issues?
  235. moroso solid mounts
  236. lts installed and q's....
  237. Looking for the old muscle car sound,what do you recommend?
  238. ID'ing Valve Springs
  239. solid roller lifters which is the best
  240. What can i do to
  241. looking for a shop to help with motor advice and build up
  242. Tell Me Why Long Tubes Are Better Than Shortys
  243. A few hours from Firing off!! (PICS)
  244. pacesetter header coating
  245. I failed smog,could it be the knn air intake?
  246. will i hit the 12's?
  247. trying to decide which muffler
  248. Stock 10 bolt? How much abuse will it take?
  249. Coolant in Oil Pan
  250. question about my car?
