PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 [115] 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224
  1. Merry Christmas!
  2. i need opinions please give imput
  3. This can't be good...
  4. If I go to synthetic oil will my Opti-Spark work better?
  5. tuning
  6. Epic Looking True Duals
  7. Need some honest opinions
  8. identifying headers
  9. LT-4 valvesprings??
  10. has any body used lakewood rear lca
  11. Questions for rebuild..
  12. How to jack up motor for oil pan gasket
  13. How to test valve springs
  14. LT1 Won't Start
  15. Rear Lower Control Arms & Relocation Brackets
  16. Does anyone make a carb style EFI intake for an lt1 or will something have to be fabb
  17. nice pic of my car
  18. i need help with my opti
  19. Kyle finished up the 2009 LTX Shootout website!
  20. mods 4 lt1 m6????
  21. exhaust hangers
  22. Its almost back from the Machine Shop... And I am not agreeing with them...
  23. Time to change the steering column...HELP! lol
  24. Debating on cams...
  25. Quiet high flow exhaust
  26. Finally got the motor in and running! Vid!
  27. Cam with no tune??
  28. mounting brackets on my hood
  29. Valvetrain set up
  30. ported LT1 manifold?
  31. Thoughts on standard COMP Magnum (not Pro) 1.6 rockers
  32. Quick LT1 Nitrous question
  33. Random NON-smooth acceleration..
  34. Bit of a different question, but here it goes...
  35. Slicks on stock wheels
  36. herron performance
  37. Best heads for lt4 hotcam
  38. Help!
  39. lack of power
  40. injectors?
  41. hard starts on cold mornings
  42. got my hood put on today
  43. True Duals that exits out the rear?
  44. 918 beehive springs in LT1
  45. Oil leak
  46. what would u rather have wet or dry
  47. 95 z28 oil leak
  48. Nitrous Outlet
  49. LE1 budget head/3k convert/ LE1 cam/ daily drivers..
  50. dry-wet
  51. ***Best ignition box for traditional distributor and F.A.S.T standalone, etc.**
  52. What LT1 Heads Do you have? How ya Like em?
  53. bcm / plug help
  54. Unplugged the o2's....
  55. Where to put jackstands in the front?
  56. Help! Best place to buy ICM? need it fast!
  57. ob1 tuning???
  58. advice junkie
  59. I am stock no longer
  60. LT1 won't turn over
  61. Advice on a cam
  62. Best place for true duels for LT1?
  63. LT1 - LS fuel pump?
  64. Your Opinions please
  65. Summit Universal X-Pipe Kits
  66. 95 in engine into a 94?
  67. LPP LT advise with install
  68. Quick question about a part on the K&N FIPK
  69. I need some help
  70. Are these numbers and times realistic? Tell me what you think!!
  71. replacing gauge cluster/rolling back odo
  72. Timing Chain
  73. lt1 build up
  74. Funny clip...
  75. Correct Oil pan gasket?
  76. dumb question, brace yourselves.
  77. Ebay find
  78. LT1 parts sponsors??
  79. AS&M TB Gasket Question
  80. Intermediate Pipe Help..
  81. Horsepower Engineering
  82. oil weight?
  83. Trickflow GenX Heads, Compression?
  84. Old opti-spark caps needed for the Shootout trophies.
  85. Should i go LTs or Electric Cutout?
  86. ? about cam swap
  87. Would cast be ok or do I need forged?
  88. ob2 to ob1
  89. 4l60e ?? converter ??
  90. Vids of my junk going down the track...
  91. 10's on stock bottom ends
  92. What mods would you do to an LT1 with $1000???
  93. ob1 tuning???
  94. thought on AI 226/234 cam kit?
  95. LS1 Rockers on LT1
  96. what it takes to run E85
  97. Polished her up and took some pics.
  98. pros and cons
  99. Spirited driving
  100. what converter?
  101. lt1 max amount of nitrous ??
  102. gmpp springs for 847
  103. a couple of simple questions
  104. 30# injectors, stock pump
  105. going 1st gen sbc need help
  106. Cam question for Emissions Counties???
  107. No spark! ideas?
  108. 4000stall on LT1
  109. Oil pan/Timing chain cover gasket... HELP!
  110. A4 to M6 swap help please
  111. true duals?
  112. bottom end
  113. Iron Vs. Aluminum
  114. 1.7rr?
  115. Help bent opti rotor
  116. what pushrods???
  117. 4.56 gear, 325/50, stock ecm will it make it?
  118. time to get my T/A back on the road....
  119. Who is gonna be first to the 8's with a nitrous LT1????
  120. Ctrique My Mod Wish List Please
  121. cam advice please!
  122. ABS inoperable
  123. help with Y-pipe
  124. possibly trading vehicles. opinions?
  125. What size injectors to go with
  126. 96 ta-ws6
  127. Where can I find a good Timing Set Up?
  128. Final Opinions: 383 Cam
  129. suspenion issue
  130. longtube hitting
  131. how much hp can a stock cluth take?
  132. Moser, Strange,12bolt 9" etc.
  133. Finally got started on the mods!
  134. My hotcam numbers are in.
  135. LT1 will not Start..No Spark..Need help.
  136. Smoking LT1
  137. LT1 Racecar Wiring
  138. Any way to drop 60's?
  139. My clutch went boom!!!! Pics inside
  140. Need help
  141. 1LE Drive Shaft
  142. LS1 DS Installed
  143. Should I replace the rear main seal?
  144. 396 & ATI FluiDampr
  145. thinking bout goin carb... questions on the intake
  146. water temp gauge help
  147. My dyno #s
  148. Injector help!!!
  149. too many choices!
  150. Wrong shift rpm
  151. Rods, pistons what else?
  152. autometer fuel pressure question ????
  153. Damn!
  154. Arp Head studs or bolts
  155. msd ignition box
  156. Autometer ES Guages?
  157. FYI: Header Insulation Engine Compartment Temps
  158. How much torx need?
  159. Help!
  160. Your opinions!!!!
  161. What did I do wrong
  162. LT4 valve springs
  163. Time for a spool!
  164. quick stock crank and I beam rod question
  165. Whats the trick for getting the door bars out??
  166. Can anyone identify these springs
  167. Rebuild Questions
  168. Comp Pro Mag 1.6 RR problems
  169. lt1 power limit
  170. Horsepower estimates
  171. Hit and Run
  172. Cam Installitation help
  173. if i turbo
  174. lots of ? on bolt on performance
  175. Which Turbo System???
  176. EGR Removal
  177. Well... I'm not doing that again...
  178. Anyone know where I can find
  179. Do I need to up idle or cam surge?
  180. 0 reading from o2's???..
  181. dyno #'s with trickflow lt1 heads
  182. 4.10s with a4 and say a 503,306 cam
  183. best clutch for 400hp?
  184. Rear end going out?!
  185. Fuel Injectors
  186. dilema: nitrous or supercharger for LT1
  187. what size injestors?
  188. Help help again, another acting up lt
  189. Running rich in open loop? heh..
  190. Step Cooler Plugs
  191. Finally got some Pic's!
  192. valve springs
  193. lt1 383 wont start need help!!
  194. Does anyone know lt1 rebuild ?
  195. headers. pacesetter LT's and ORY? or maybe LPP
  196. LT1 with 3" SS hood.
  197. what does it take to go to a monoblade TB?
  198. cam or spray first?
  199. Suspension or nitrous?
  200. lt1 dyno tuner?
  201. 98+ center console
  202. Rwhp estimate!!!!!!
  203. Clutch question...
  204. I need some guidance
  205. thepartladi
  206. coil conversion kit
  207. lt1 cam
  208. coolant question
  209. 96 camaro Plugs and Wires
  210. Crane Gold NSA 1.6RR
  211. Anyone Runnung this cam ?
  212. fastest lt1 6 speed?
  213. electric pump or standard
  214. Thinking of parting out project....
  215. Your opinion here
  216. lt1 underdrive crank pulley w/o the different alternator pulley?
  217. Well Guys Parts are In
  218. ati super damper for lt1
  219. GMMG: which headers?
  220. Best head/cam combo for stock bottom end?
  221. opti?
  222. Opti
  223. built supercharged t/a almost finished few ?
  224. CC503 & 3.42s with M6...
  225. Any one know this guys set up?
  226. H/C Parts List. Do I have everything I need?
  227. black or silver zr1's
  228. How do you preoil a fresh engine?
  229. How hard is it to remove the LT1 PCM???
  230. redneck racing converter?
  231. 355 build opinions
  232. happy birthday to me!!
  233. 400-600 Shot
  234. LT1 Header question.
  235. 10sec allmotor LT1! questions
  236. Hypertech programmer worth the money??
  237. Lt1 engine problems
  238. LT1's riding Bumpers FTMFW!
  239. Who can name the weakest part??
  240. studs or bolts...
  241. So i pulled the trigger on a VFN Reg Sunoco pin on hood 2day!
  242. lt1 missing problems
  243. Jegs Wire set???
  244. Best Sounding LT1 Exhaust????
  245. what headers for 4" exhaust?
  246. Correct ARP Headbolts?
  247. Those without Power Steering and Factory Rack...
  248. Trick Flow 21 Degree LT1's - Info & Pics
  249. 355 or 383
  250. Transgo shift kit
