View Full Version : LT1-LT4 Modifications
  1. 96 z28 and i'm freakin stumped! help!
  2. Anyone know where OBX headers can be found?
  3. LT1 extended crank to start after a few hours of sitting, ECT?
  4. HELP!!! oil pump went out
  5. Exhaust leak or rocker noise?
  6. 95 z28 temperature gague does not work
  7. Time for heads....on a budget
  8. Name that sound...
  9. Posi is dying, what to do
  10. 93 T/A excessive cranking
  11. anyone running a ls1 4l60e
  12. What Next?
  13. Fuel Smell
  14. almost there woo
  15. Heart Attack moment
  16. Shops in South Carolina
  17. URGENT NEED HELP! Intake Manifold
  18. Canton 242T + Stock Dipstick
  19. 6LE front bumper inside PICS
  20. lt1 help
  21. Alternator question
  22. Squeak at low rpms not the belt
  23. LS1 tranny on a LT1
  24. oil coolers
  25. Need to relocate my brake/fuel lines
  26. How to tune 94 PCM on 95 car/cable
  27. LT4 H/I or not?
  28. I'm fed up with this!
  29. LS MAF on LT1?
  30. how to learn how to blue print a engine?
  31. What All Is Needed For ABS Delete?
  32. corvette lt1 into 95 firebird formula
  33. Low Mount Power Steering???
  34. eBay electric cutouts?
  35. LT1 Parts for sale
  36. Hiss when I open gas cap.
  37. ATI super damper LT1 install ?'s
  38. I'm trying to make it to the shootout... (2013, lol!)
  39. Code 16 help
  40. Code 63
  41. where can I buy GM timing chain set???
  42. how many miles
  43. School me on two things:
  44. New best 60' and raceweight...lol
  45. New Stall, not happy, need answers
  46. Cooling issues, need help
  47. Temp guage only gets past first line.
  48. Anyone with 1st Gen LE Ported Trick Flow 195's???
  49. 96 LT1 newly installed cc503
  50. Whats it worth!!!!
  51. What head gaskets for a 383 motor?
  52. port heads and intake manifold
  53. New clutch time!
  54. Broke a u-joint, now RPM related vibration?
  55. Best 4.10 gears to buy?
  56. Unknown Connector, Radiator Mount Thing, Broken Hood Latch Bracket w Pics
  57. Few pics and Idle vids of the new build!
  58. Stock exhaust / catback question..
  59. Which is louder, loudmouth bullet or magnaflow bullet?
  60. M6 Idle questions
  61. Starter Bolts?
  62. Could this be my problem?? help
  63. over heating
  64. Dont know what to do with my lt1! stuck by options
  65. Th400 stall
  66. This Cam Seem Good On Stock ShortBlock?
  67. lt1 tune help
  68. where can i find the vss??
  69. OptiSpark Overhaul…. Help, PLEASE!!!
  70. LT1 randomly dies not sure what the issue is...
  71. Brake Line Routing
  72. Is the coolant pipe on back of heads necessary
  73. issues or am i paranoid
  74. what to set the lash on a solid lifter engine?
  75. Running Rough
  76. o2 sims
  77. ABS delete?
  78. what length stage 8 header bolts are you using?
  79. finally getting my camaro tuned and dynoed tomorrow
  80. OBDII Dataport Communication
  81. Which competition clutch is best for me?
  82. T400 guys here
  83. What timing chain set???
  84. Any tips to reduce drone with TDs
  85. advice for buying a lt1 camaro
  86. Did a search, but didn't get a clear answer.
  87. 383 is running!!!!
  88. Sprucing up a 150k mile LT1
  89. 95 impala no start
  90. LT1 383 valvetrain problems FIXXED THANKS EVERYONE THAT HELPED
  91. GM MLS header gaskets
  92. After rebuild startup problems??
  93. Exhaust Manifold Questions
  94. Bought a few new parts before the Shootout
  95. Corvette goes up in flames
  96. Anyone use lt1 tuning .com
  97. After 4 years she runs again! vid
  98. drag radials
  99. Michigan people!!!!
  100. LT1 Custom intake help
  101. Manual Pedal Assembly Question
  102. over the radiator intake
  103. HELP!! Z28 stalls
  104. Need advice on goodies!
  105. car smoking
  106. 96 Trans Am Restoration
  107. NEED help on pcm communication 96 TA lt1
  108. car has a slight shake at high speeds
  109. Trim on doors
  110. Spark issue on whole passenger side.
  111. Exhaust gasket fail
  112. What to do with stock LT1 cam?
  113. New stall, question.
  114. quiet exhaust system
  115. Injector sizes
  116. So whats quieter than an SLP Loudmouth?
  117. Tuning software for LT1
  118. Pulled for "Loud exhuast" in my other car.
  119. Stripped Head Bolt!
  120. 93-96 Dash Pad
  121. lt1 to 400 rwhp for 5k?
  122. magnaflow tail pipes??
  123. New Paint on the TA...whats your fav?
  124. Can you mix plugs of the same brand?
  125. new 94 z28
  126. what does your 9.5"converter slip?
  127. car starts but sputters
  128. ICM, opti or coil problems
  129. Bolt on/150 shot track results
  130. I just had to post this here, insane price for a bone stock high mileage Camaro....
  131. 95 lt1 firebird exhaust manifold question
  132. I want roller rockers on my LT1
  133. 6 speed locked in 1st
  134. Feed back on eBay low mount alternator brackets, please.
  135. LT1 cam swap lacks power?
  136. More Power
  137. LT4 knock module questions
  138. Did I miss anything? (mods)
  139. The head of one of my spark plugs is cracked?
  140. Braided power steering lines
  141. LT1 396 Turbo Build?
  142. WS6 Lower Control Arm Help
  143. Best nitrous piston 300+
  144. 88 Iroc swap no start
  145. HELP, car wont start
  146. I think i have a misfire? Please help details in thread.
  147. Who can give me part numbers for lt1 bearings
  148. Lt1 with gen1 cam questions??
  149. Mecum Auction
  150. le2 or le1
  151. le2 or le1
  152. Dead cylinder
  153. broken exhaust bolt AND extractor
  154. Turbo stalled guys. WHat size stall?
  155. 700r4 shifter cable adjustment?
  156. plug on heads (noob question)
  157. LT1 WISEMEN -in here plz
  158. LT1 swap .. advice?
  159. Installing X pipes over the axle
  160. 96 lt1 misfire. please help
  161. best 96 lt1 cam
  162. After 17 years it may be time for a rebuild!
  163. How do I uninstall the stock exhaust manifold
  164. LT1 90k miles - What should I look for?
  165. Pacesetter Lt's and ORY to SLP LM1
  166. Where to buy 8.5 MSD wires?
  167. Just installed my x pipe on the z28....I LOVE IT!!!
  168. June Issue of Camaro Performers
  169. Lt1 th350 and vss
  170. What other parts will I need for a Hotcam kit?
  171. LT4 vs LT4 ED Timing Sets
  172. Lt1 4l60e hybrid help
  173. 95 Z rear gears
  174. TDC question
  175. Road Racing/Autox Cam Selection
  176. New Track Times
  177. Heads/Intake?
  178. cc306 and rr
  179. lt1 fuel pressure bleeding down
  180. Don't understand Different RR on I/E
  181. How will an LT1 with LT and a jegs universal x pipe with dumps sounds?
  182. opinions or preferably experience with these
  183. Lets post pics torque arms
  184. Strange problem on 95 Z-28, please help!
  185. 93 LT1 mod questions.
  186. Car cover recommendations
  187. 360 LT1 bottom end ideas
  188. Mac catback vs Magnaflow catback
  189. 27 spline 700r4 help
  190. Shift kit and rear end
  191. Dyno tune in NJ
  192. needs some advice
  193. coating guide plates?
  194. dual fuel pumps
  195. Tuning idle tunercat
  196. Reman engine
  197. craigslist deal
  198. Lt1 misfire (resolved)
  199. Only getting 6.5 mpg w my 383 Stroker
  200. What GM vehicle uses 42lb injectors stock?
  201. O2 Sensor Simulator?
  202. efi connection people won't start throwing code
  203. Cam info?
  204. 95 lt1 383 stroker project questions
  205. cam Ques ?????
  206. And So It Begins!
  207. 1074 head gaskets?
  208. 97 LT1 questions.
  209. Oil leaking on valve cover on oil fill tube.
  210. How much did u pay for your block?
  211. how many people used stock 96-97 timing cover for 24x
  212. speedometer issue
  213. Bosch type 2 or type 3 injectors for an lt1? Help me decide
  214. Electrical Issues
  215. Exhaust System Ground Clearance
  216. efi 24x part number for the double row
  217. pouring smoke at 6k...
  218. Replacing lifters
  219. Start LT1 UP After Storage Quick Question??
  220. What are these codes
  221. Need single muffler suggestions, bullet after Y and dump
  222. heater line delete
  223. Whats the consensus on GM cooling system sealant tabs?
  224. Sbc heads fit on 95 lt1 engine block
  225. 355 lt1 open x pipe idle
  226. Ported intake
  227. how to reinstall k member with motor
  228. Rear end, wheels gears, brakes,
  229. 1996 z28 big plans
  230. Racetronix Fuel Pump Wiring Harness
  231. Getting my stock flywheel fixed/resurfaced, got a question.
  232. Kooks is building a true dual for our F-Bodies!
  233. Idle issue and driving issue
  234. Coolant Return Line Question
  235. Stock rear end killed
  236. Is this my fuel gauge broken? New cluster time?
  237. What is this part, see pic?
  238. Potential future C4 owner, Please Help :)
  239. 4 Barrel TB guys inside please...
  240. How much hp can a walbro 255 support?
  241. Surging TPS Voltage
  242. Heads/Cam advice
  243. LT1 Kooks LT & ORY to GMMG
  244. What double roller gearset for efi24x system
  245. LT1 dyno tuners...what happened to them?
  246. turbo size question
  247. Excellent cam on Stock heads? need help
  248. aeromotive 340 pump question
  249. Failed Opti? Come Inside!
  250. Optispark, fuel pump?
