View Full Version : LT1-LT4 Modifications
  1. Progress on my LTXshootout entry
  2. Collant Cross over tube in back of heads
  3. Flat 93-97 Hood?
  4. ????What to do?????
  5. i hear there was a thread about me
  6. Will this flywheel work?
  7. same car, same issues, but an idea
  8. Good Old Break Light!
  9. any idea?
  10. ajustable fuel pressure regulator
  11. if noone is interested in my car i might be considering a part out
  12. want this finished, lotta questions
  13. Lt4 Cam And The Hot Cam Are Not The Same Guys
  14. 94 Bird Front Seal Oil Leak
  15. Diagnosis?
  16. I need pictures of headlights of LT1
  17. guess ill show some pictures!
  18. 94 LT1 camaro window motors
  19. LT1-LT4 diffrences
  20. smells like gas
  21. madman solid motor mounts
  22. 3 questions i need answers for pls.
  23. 305's or 315's fitting
  24. Coming to complete stop the car somtimes stumbles to take off
  25. how long do the MAF wires need extended to put the LT1 WS6 ram air box onto a 95 T/A
  26. mpg question
  27. Passed NJ Emissions!! LE2/LE1 Emissions cam
  28. Using only 1 knock sensor?
  29. 1996 Range Rover Overfinch 570
  30. Power window question
  31. My project toward the ltx shootout...
  32. Cam question
  33. New LT1 intake update
  34. Question for LT1 owners....
  35. bad fuel pressure regulator
  36. Suncoast Predator Hood
  37. dipstick and oil fill neck are loose
  38. new timing chain
  39. Gas Mileage Report...
  40. should I go coated or non coated on my LT's ?
  41. Out playin with the Camaro
  42. so had something wierd happen yesterday
  43. my next setup
  44. Headers question????
  45. Oil Pressure Sensor Help
  46. Spark plug changing help!
  47. DynoTune Air/Fuel Ratio Lean Shut-Down Switch
  48. looking 4 hp #,and some help.
  49. look 4 hp#,and some help.
  50. LT1 Moddification ?'s
  51. Heads for 11's
  52. Asking for a friend...lt4 valve springs
  53. Wont start!!! Help guys
  54. American Thunder?
  55. new opti suggestions
  56. Drip.. Drop.. Water pump leaks.
  57. headers done finally but...
  58. Im Going To Be A Dad!!!!!!!!!
  59. AFR Hydra Rev Kit
  60. Shift problem on automatic
  61. Fuel Press Help!
  62. Lots of progress
  63. Pics of my new exhaust (True Duals)
  64. Brake light questions
  65. New 383 runs great but won't idle - what to do?
  66. Need some ideas for my calibration
  67. What year LT1 is the best?
  68. What Kinda Rods Are These?
  69. kieth black hyperutectics pistons and lt1 rods 150
  70. 6 speed clutch questions????problem
  71. Pig rich cough, cough??
  72. Need serious help!!!
  73. header clearance
  74. valve float?
  75. Thoughts of new LT1 Intake Design
  76. MSD 6A or 6AL
  77. Please help! Problem with fuel pump wiring(?)
  78. i f*cked up
  79. Weird overheating problem
  80. What are good numbers from ported stock heads?
  81. 383 LT1 from Golen -- reliable?
  82. Opti Spark vacuum ports
  83. can i keep my stock cam and rockers?
  84. what msd retard box to use???
  85. weight question...
  86. How to take off super tight valve cover bolts?
  87. how long o2's extensions
  88. Electrical issue i think?
  89. Question on OEM fuel line material
  90. miss / vibration help please
  91. I need heeeeeelllppppp! help n e one?
  92. LT1 Valve Adjustment: Comp Valvetrain
  93. Which Exhaust Muffler is the BEST Brand that gives sound and performance for stock?
  94. Please Help! Exhaust Bump is driving me crazy
  95. AIR fitting thread size?
  96. Need stock electric fan....ASAP
  97. Looking for pics of Pacesetter LT ORY with Cats install
  98. Lifter question pls
  99. Fuel rail upgrades..options?
  100. Putting a new opti in. Someone help out.
  101. What Pistons to get for a le1 355?
  102. Traction control problem on a 93?
  103. Fuel pressure safety
  104. what do you guys think?
  105. Tuning...Maf or Speed Density?
  106. Injector Size
  107. this motherf**kin opti man...
  108. what parts for lt1???
  109. camaro trans am lt1
  110. A/C delete?
  111. TPIS ZZ9 Cam is this the right cam?
  112. My T70 Build
  113. Looking to trade my a4 for an m6
  114. Finished my Car today!!!
  115. Almost ready for the shootout
  116. Just picked up my first copy of GM High - Tech Performance
  117. My car sounds like poop....
  118. wHAT HEAD AND CAM PACKAGE
  119. Anyone know where to find OBDI code reader?
  120. datalogging issues
  121. Is a tune necessary for deleting AIR/EGR??
  122. removing Traction control
  123. Por-15 + Y
  124. getting a deal. 383 questions
  125. oil shooting out of 3 rocker arms in idle?!?
  126. Need tune?
  127. LT1 swap help!?
  128. Possible Rear End Problem?
  129. lt4 or machine mine?
  130. lots of questions all help greatly aprieciated
  131. Magnaflow Cat-back?
  132. Coolant/Hose Questions ( I searched first)
  133. Head & Cam Price?
  134. Smooth Idle cam??
  135. is anyone good a photochop?
  136. anyone intrested in a 58MM BBK Throttle body
  137. dfi and stock gauges? need help
  138. lt1 with mods..
  139. abs unit delete?
  140. 94 Z28 Running Rough
  141. What would my time be?
  142. You Guys Are My Last Hope
  143. how did you set up your crane 227 valvetrain?
  144. Low Mount Alternator Bracket?
  145. underdrive pulleys
  146. To get Injectors or not to...
  147. lt1 mid headers w/o Emission
  148. Lt1...
  149. wierd.. very wierd
  150. Low oil pressure!
  151. fuel pump???
  152. Tires
  153. roller rockers ?
  154. What timing chain do you guys reccomend ?
  155. Scanned code help
  156. which oil is the best
  157. Converter for TH-350 to LT1?
  158. Going for JET DST
  159. No2
  160. Anyone here interested in a LS1 intake setup for there LT1?
  161. Car misses..
  162. car woulnt start and im pissed
  163. oil sensor.....
  164. X pipe kits
  165. turbo lt1 launch pic..
  166. black lt1 camaros on convo pros
  167. What could be wrong? dyno issues
  168. RPM limit for stock bottom end
  169. How about a stall/60ft comparo guys?
  170. trifecta tunning
  171. Nitrous on LT1
  172. FS: 1994 Formula (396) / Part Out
  173. Removing A/C Condenser
  174. About to install an EWP a little help...
  175. Injector Question
  176. Lt1 rebuild/mod guides
  177. Whats this ticking noise! (video inside)
  178. 383 stroker
  179. crane 227 or lpe 219/219
  180. Is a 4000 stall too big for an LT1???
  181. Here's my situation
  182. Driver side shock tower bolt stuck
  183. 93-97 Firebird Bi-Xenon Projector Retro-fit (Pics)
  184. 50 mph punch, smoke...
  185. ? on roller rocker arms
  186. stall/gears
  187. stock springs seats
  188. Anybody Have Any Write Ups For A 97camaross???
  189. Tune or not tune.....
  190. 3rd and 4th gen headers interchange?
  191. I now have true duals out the back!!
  192. security questions
  193. how much hp can you gain from a basic port job?
  194. Hub/Balancer Issue?
  195. can I keep a broken EGR system instead of blocking it off
  196. just bought an 94z28 6-speed
  197. Projector Headlights for 93-97 fbirds..
  198. Timing chain gear question
  199. Volt Draw issue
  200. 383 Vs 355
  201. PCM for less tune
  202. No Start, I really need help!
  203. Ai New Best Track Time/Broken Parts
  204. m6 gear ratio question?
  205. Heres the deal!!!!!!
  206. Turbo and cam ?
  207. Poor Idle after water pump and distributer cap replacement
  208. Need opinions on 383 build-up
  209. Ac compressor..
  210. help looking for adjustable timing set for lt1
  211. Is This Exhaust setup worth it?
  212. ls1 cam only ?
  213. stock valve covers clear RR's?
  214. msd opti?
  215. patriot gold double springs on lt1
  216. any ideas on a cam???
  217. Have any of you ever had an EGR valve go bad?
  218. motor swap
  219. tranny cooler install question..
  220. is this price decent?
  221. LTX Shootout now has its own FORUM
  222. does cast heads flow better than aluminum?
  223. LT1 aftermarket header questions...
  224. Price list to get to 12.4
  225. what color exactly is the lt4 intake manifold
  226. corvette servo
  227. 1991 Rs 5.0..
  228. Cutout Wonder...
  229. Stumbles / Hunts / Low (500 RPM) Idle
  230. Pro's and con's of deleting AIR/EGR
  231. T-56 High TRQ clutch: What works for you?
  232. new fs post in tx
  233. cluster?
  234. lt1 stuff
  235. 355 forged/LE3 worth?
  236. canton valve covers
  237. Any one wanna trade??
  238. guideplate install ?
  239. Thrown rod
  240. Fitting a 3rd gen catback on to a 4th gen car? Anyone done it?
  241. baby cammed 383 passing sniffer?
  242. Which Cam? CC305, CC306, CC503 or GM847
  243. who sells energy susp.poly mounts?
  244. opinions needed...
  245. torque arm question?
  246. opti question
  247. 383 Rebuild On Hold (Converter + Rocker Advice)
  248. what should i run with a good 60?
  249. Boosted 383 LT1 open loop issues, advice needed!
  250. oil pressure problem
