View Full Version : LT1-LT4 Modifications
- LT1 to Vortec 350 (HELP!!!)
- will these fit my car?
- new bottom end
- Whats the difference between an H-pipe and a X-pipe?
- lt1 383 6 speed CAM
- oil heater delete?
- what plug
- Billet Grill guys please help!
- Question!!!!!!!!
- Whats the difference between the F-Body and Roadmaster LT1's?
- A/C Help
- Questions about Impala Head gaskets, 10.8:1 Pistions & my 355 Build
- Is the cam in a 1994 Vette different from the cam in a 96 formula?
- Top dead center
- ECM Tuners or programmers
- Troubleshooting the AIR pump
- tire size + stock gear question
- A/C and P/S delete questions
- LE 232/240 cam
- never drive an M6 in san fran.
- Which Y-pipe to get for Mac midlength headers?
- cam and rockers
- Xmas in January
- Installing used cam ?'s
- LOW oil Pressure???
- fans never run
- starter takes forever?????????????
- video of lt1 long tubes with purple hornies
- poly mount opinions please
- HELP!!! LT1 Overheating!!
- did some work today for my project.
- lloyd elliot still have a website???
- oil pressure sending unit
- Holley adj. fuel pressure regulator...
- a few LPP header questions
- is this possible?
- LT1 Tunning Software
- How can I tell if this is a hotcam or not?
- this is sad
- Mufflers!
- Shimming oil pump spring?
- c4 vette fuel rail covers???
- cam swap
- Gasket Part Numbers????
- cutting off rear quarter panel
- headers install
- ***GM Stock Shortblock Heads/Cam - 10's NA & 9's on N2o
- Vacuum Lines
- Nitrous addicts step inside....
- Stalls
- A new knocking sound from my car...
- Spun bearing / rod knocking question
- y-pipe and Cats????
- After market Blocks
- 4l60e vss sensor
- just the head gasket?
- how to pass emissions?
- LT1 head gaskets
- LS1 Ram air hood on a LT1??????
- What is a fair price for a 93 Lt1?
- windage fitment issue.
- new valve springs
- 383 p/v clearance with custom cam
- pacesetter headers and y-pipe
- Electric Water Pump
- summit universal x pipe???????
- TSP Trueduals
- Header write up?
- emissions evap delete question
- Top End Rebuild, Gasket Kit...PICS
- lt1 showem off (pix)
- 383 stroker from lt1
- LT1 dies at warm up
- Build ?S
- msd rebuild help.
- headers and short throw.
- Can you re-use a clutch PP?
- Retorque heads/ oil pump prime??
- Just bought an lt1 scanmaster for $100~!!!!!
- Head Bolts
- Anyone make their own alternator relocation brackets?
- Obd1 dlc
- i got an amazing deal wat you think?
- super victor conversion
- Need some help with current set-up?
- Need Help or idea??
- LS6 lifters...
- A 350 Vs 383 question
- Need Help with my 97 TA
- Does anybody know where I can find the GMHTP bolton article?
- LT1 crank question??
- SBC W/ LT1 connecting rods
- Opti Cap/Rotor Bolts??
- gas pedal/throttle cable?
- 97-02 tail lights
- i need someone to tap my heads
- need spme tips ...plz
- What cam for me?
- Will LT's work w/ catbacks?
- Installing header gaskets?
- Reg Issue or Fuel Pump?
- real quick question on deleting ac
- inner door water deflector
- driveshaft length
- 95 z28 turbo
- injector ?
- crane Lifters
- Anyone Know What This Is?
- My ComBo
- Cam Heads Combo
- Stock MAF size
- 02 snowflakes on 93camaro?
- Check it out!
- so who has had the pleasure of swapping valve springs in the car...
- tune up
- Timing spoof for nitrous
- Finding pushrod length, HELP!
- Problems with the good ole LT1
- new setup almost done, a few questions first
- crossover coolant tube on the back of the heads??
- Aftermarket fan
- Pulling Heads with Studs?
- Car acting crazy, throwing codes P1642 and P1642
- need a water pump welded
- 408 lt1
- a/c delete pulley
- Comment on my LT1 Build!?
- Installing an aftermarket A4 shifter
- Is this used car dealer charging me too much for parts?
- engine running way rich.
- Climate control
- now what????
- Hot Cam?
- air conditioning
- Happy new year!!!
- exhaust
- Need suggestions for for cheap 355 build
- Will a 94Z throw codes without dash lights being on?
- 300 HP Rated Pistons??
- Finished up my new toy collection, OH YEA!
- Vibrations above 1800rpm
- thinking about a new intake manifold
- Header and Y pipe question
- anybody got a fan shroud?
- Noob question about head gaskets
- Oil is disappearing
- What should i expect from my cammed LT1
- Happy new year
- Heater not working
- Best Sounding LT1 on LS1Tech??????
- TPS code
- trap speed and hp?
- Cooling Fans
- Borla mufflers?
- Need some input
- Alternator Whine!!!
- Finally did the LS1 lid conversion
- Cam Video?
- feeling down about my lt1...
- SUCCESS!!! No more leaks!
- LT1 Cold Start Question
- Where I can buy AC Delco part from ?
- heads
- Checking Rod and Main Bearings
- HELP crank snout being a beyotch
- Will this work
- Powerful everyday car?
- Throttle Body sticking....
- im stuck between choosing
- BEST price on nonvented OPTI
- O2 sensor electrical question
- Friendly Stock Bottom End Cams
- question on somw heads im lookin at for my lt1...
- Vibrations at 55MPH. Suggestions?
- High compression cam specs
- Fan issue
- wiring in a switch to prevent start
- lt1 trans am cowl hood
- help with cam and valve springs
- want to swap from my obd1 for a obd2 pcm, have questions
- anyone have a stock front sway bar fs
- v8 swap
- Intermittent code 43
- burned up front O2 sensor???
- need opinions!!
- Help!! Header question
- lt1 vs l1
- Question on this spring kit.
- need help deciding on a clutch
- 95 LT1 AI Cam-only Motor Build Pics
- Track times! NEED Help!
- plugging water pump shaft hole
- Money Decisions
- have a few questions with lowered f-bodies
- dyno 380hp/355tq @ 6k thoughts
- Fidanza and Spec Flywheels
- A/C box
- cracked LT1 Pacesetter LT
- Hmm i think i have a problem.
- pic request lt1 guys
- lt1 runs on ls1 computer using modded OPTI
- Finally got my christmas present
- Tranny mount
- LT1 Nitrous Build
- Coil Per cylinder
- "Low Coolant" light
- Coolant Capacity
- LT1 Tuning / Dyno Weekend
- will an ltx cam fit a sbc
- need a new opti
- custom dual TB intake
- F/S: '97 TA whole car or parts...SALVAGE TITLE
- can i pass smog with these headers?
- I took some new Idle vids with the new cam
- high idle
- I think I figured out why I couldn't launch my car
- loudmouth installation
- LT1 build up ????
- 96 lt1 help
- 94 LT1 runs for a few seconds then dies, help!
- Where can I still find, Delteq Opti-Direct Ignition System?
- Searched, no luck. LTx head gaskets on GENI, or? Anyone have stock LTx springs 4sale?
- Where are all the N2O LT1's at?
- Stock short block and Stock long block
- Crankshaft sprocket puller?
- check out my new tires!!!!
- headlight failure
- Engine takes to long to idle down. 93 Z auto
- LTX Tech is currently down
- WTF Is this normal ?
- some updated pics of my project carb. conversion
- engine bay cleanup
- Re-searching a mild build
- v6 to v8
- another stupid cam ?
- Car won't start??
- Finally a respectable time for my mods
- Hard starts after car sits?
- 4.11s
- wide band O2
- braided fuel lines for lt1
- what the heck is wrong with my fuel system.
- starter question
- Anyone change out oil pump spring
- RPM fluctuation at idle in drive or neutral?
- need steering column advice
- high voltage tps
- oil pump question
- OBD 2 to OBD 1???
- Merry Xmas to myself
