View Full Version : LT1-LT4 Modifications
- Crane Gold NSA 1.6RR
- Anyone Runnung this cam ?
- fastest lt1 6 speed?
- electric pump or standard
- Thinking of parting out project....
- Your opinion here
- lt1 underdrive crank pulley w/o the different alternator pulley?
- Well Guys Parts are In
- ati super damper for lt1
- GMMG: which headers?
- Best head/cam combo for stock bottom end?
- opti?
- Opti
- built supercharged t/a almost finished few ?
- CC503 & 3.42s with M6...
- Any one know this guys set up?
- H/C Parts List. Do I have everything I need?
- black or silver zr1's
- How do you preoil a fresh engine?
- How hard is it to remove the LT1 PCM???
- redneck racing converter?
- 355 build opinions
- happy birthday to me!!
- 400-600 Shot
- LT1 Header question.
- 10sec allmotor LT1! questions
- Hypertech programmer worth the money??
- Lt1 engine problems
- LT1's riding Bumpers FTMFW!
- Who can name the weakest part??
- studs or bolts...
- So i pulled the trigger on a VFN Reg Sunoco pin on hood 2day!
- lt1 missing problems
- Jegs Wire set???
- Best Sounding LT1 Exhaust????
- what headers for 4" exhaust?
- Correct ARP Headbolts?
- Those without Power Steering and Factory Rack...
- Trick Flow 21 Degree LT1's - Info & Pics
- 355 or 383
- Transgo shift kit
- LT1 Canfield Heads arrive ...
- rim question backspacing
- Nitrous Question
- Cannot remove crank balancer bolts
- air liq (98-02)camaro v6 into a camaro lt1
- No power after engine swap...
- 69 Camaro with 95 lt1 cam help
- Whats the low down on Optispark?
- Pro mags and valve covers
- Happy Birthday to me!!!
- Leaking transmission fluid
- Trouble Code P0134
- Official answer to oil filter adapter gasket question???
- Lets talk/rant about coolant hoses
- New H/C Set Up
- New guy here and I have a question.
- high rpm wot cracking noises
- Proliance Radiators
- can a ls1 SS spoiler fit a lt1
- Bolt On LT1 Times Inside
- Stock lt1 injectors are rated @ X PSI?
- Anyone running these???
- TEA 220cc vs AI 200cc on a 383
- over the valve cover spark plug wires?
- LT1 heads ?
- 02 sensors bad already?
- Bumper Support
- Looking into true duals
- can someone look at me datamaster files and tune?
- How to tell
- Popping noise while turning
- What's this worth?
- Dyno'd my turd.... :)
- tuning questions
- What sponsor sells EGR blockoffs cheap?
- AIR delete quesion
- header bolt help
- front needs raising
- K&N CAI Problem
- The Big Suck
- Anyone else have this issue with Hot Cam
- auto tap who likes/dislikes it and why?
- 383 need cam , some advice
- What a great night...
- Help
- 388 LT1 guys in here
- Will this X-Pipe fit my 1996 lt1?
- lt1 into a 1995 v6 camaro
- new setup, question about injectors?!?!?!?
- Another LT1 tuned by PCMForLess...
- lets hear how much power you stock 4l60e can handle
- Lt-4 km
- T56 dust cover bolts
- chiltons manual...
- gm847??
- Occasional misfire in High RPM under load
- Injectors
- Is this typical?
- Please help,my g-body failed smog,high Co and HC with pic of report!
- Should I buy?
- Are the Vortec 4.3l V6the only ones?
- true duals or stick wit cat back?
- Griffin Radiator for stand up
- Who all has removed the bracket that connects the alternator to the intake?
- GMHTP LT1 Build...
- New PB AGAIN!! 10.84@124
- Next mod before headers?
- Lt1 Question
- LTX VS Stang on PINKS NOW
- New Best - 11.18 @ 120.33 N/A
- gm847
- help
- Whats a good transcooler?
- Odometer??
- auto shifting early and wont down shift after manifold swap
- LS1 rockers
- Trick Flow Gen X Heads
- Need help...please..
- 1le a/c delete pulley
- What Ignition Box
- AFS105 = AC Delco???
- Car is surging at low rpms
- Any difference
- How long can i drive wit o2's unplugged?
- Small head unit problem...
- Where and how much?
- Mids w/ a cam okay?
- AFR head / piston valve relief question
- 99 s10 transmission into 97 camaro
- Can a stock LT1 motor hang a wheel?
- Ford owners... lol
- unplugged o2's= high oil pressure??
- what head?
- best place to purchase hooker lt y pipe
- Y-Pipe struggle and questions!!! pics
- ls1 steering shaft
- Pattern and Dimensions for Fuel Rail Covers
- Sorry Guys I went to a LS1
- Good experiences with MSD opti???
- Rod and Piston suggestions?
- rear end out of line?
- Great now I think they are really noisy
- shop told me the problem, the opti is shot.....
- 3rd gen steering wheel adapter on 4th gen t/a
- Subframe Connectors What do you have??
- Stock 1/4 time for 96-97 ws6/SS
- Whats Size Pushrods For 383 w gm 847
- misfire at high rpms?
- best place to buy optispark
- FBody LT1 Compression Ratio
- How restrictive is the stock Camaro exhaust?
- 700r4 swap
- good LT1 turbo topend?
- u-joints 1le aluminum driveshaft
- How to clear codes on OBDII TA?
- Sell, or not to sell?
- Where to find NGK TR6 plugs?
- TB question
- stock bottom end-nitrous-cam
- Who is a guy who Cuts Custom Grind Blower Cams
- Second time at track w/ Cadillac Cam!!!!
- 355 Rebuild
- 383 or 396
- Problems with my sons 94 z28
- neen some help what is it worth
- trans question
- Engine Removal 94 LT1 (PICS INSIDE)
- New PB 1/4 mile this time!!
- Whoa is me
- Z doesnt wanna start! need input!
- flowtech vs magnaflow?
- head gasket/ stumble
- line locks?
- gm847 open headers...vid
- Kooks LT what oil filter to use?
- DMH Low Profile E-CutOuts...
- Hilarious
- park neutral safety switch wire
- ac delete writeup?
- TH-350/400 guys come on in
- So what is the T56 worth out of a LTx F-Body?
- Differential Cover... Help me decide
- turn signals
- More misfire woes
- ss lt1 intake
- need some help
- th 400
- electric water pump?
- emissions!!!!!!
- Rewiring '95 TCS switch harness for'97+ TCS switch
- Is this a blown head gasket??
- Cap & Rotor install ?
- Where to buy.....?
- my "where does this go" thread
- 98-02 brake conversion?
- please help me!friends head is swelling
- Rough Day and need to vent!
- eliminating accessories
- LT1 Canfield heads - Which Guide plates?
- Pro Mag valve lash
- New brakes, right rear caliper sticking
- what header wrap?
- 4.3 LT1 external parts the same as a 5.7?
- What exhaust to run?
- Sparkplugs
- 97 Trans am running a bit rough...
- suspension
- Which type supercharger for an LT1?
- Those using MSD Opti's, I have a question
- Help with cam choice...
- Lt1 cam
- please help wont start
- bad cold start problem
- By_pass fans on car...
- Broke sypder plate, which lifters?
- Which clutch??
- Check Gages Light
- PS removal?? How to?
- EVAP with a Monoblade
- New Vlavetrain = burning oil
- Comp Cams XFI 268 cam...
- My LE2 Swap and Before/After True Duals *Videos*
- lt1 in a s10 performance upgrade
- Pulling SES Codes Manually without a scanner?
- What do you think of this Tuner?
- SES comes on at idle
- Aftermarket steering wheel?
- New best but broke trans
- Shakedown runs with cc306 + full bolt-ons
- Help with ALDL cable
- No real street time on my cam, lmk what you think
- In the market for headers..
- brake issue.
- YEEEEHAH! I made it on all outtakes
- AI 200cc H/C Track Times UPDATE!!
- I have a question about the mass air flow sensor
- Thanksgiving Present II - Install! with pics
- does cutting off a turndown tip help with resonance???
- LS1 radiator in to LT1
- Tuning Question.. please help
- IAC valve---95/96 different???
- lightweight battery
- Finished up the Dyno Tune.
- vigilante 2800 9.5 converter
- oil pressure sending unit
- Best shorty headers?
- EV6 injectors on a LT1...
- symptoms of a bad pcm?
