View Full Version : LT1-LT4 Modifications
  1. anybody running the comp XFI cam?? voodoo?
  2. My LT1 already up for sale!
  3. Anyone Know How 2 Install Flame Thrower For Lt1 T/a?
  4. Is POWER PROGRAMMER III really useful or not?
  5. pcmforless
  6. Are there two types of header bolt pattens on LT1s?
  7. anyone impala owners using low buck headers?
  8. Sellen my trans am
  9. vacum leak
  10. ported stock heads with LE2 cam
  11. 188000 miles
  12. LT1 Patriot spring kit?
  13. so im dripping oil
  14. Msd Optispark
  15. open cutout rev lmao
  16. Valve spring swap....Help ASAP
  17. coolant issues...ideas?
  18. Anybody have CSR rebuilt their LT1 water pump?
  19. Car dies/stutters after cam swap
  20. lt1 swap help!
  21. Torque spec for ARP rod bolts
  22. WOT shift points on LT4 Hotcam kit?
  23. 10's on stock heads/cam...no nitrous :D
  24. Another drag wheel question
  25. LT1 Block??
  26. does anyone have some pics of engine bay with no motor or trans in car
  27. ? reguarding SuperVic and SS hood clearance
  28. Anyone built a 370CI MOTOR?
  29. Trickflow Heads
  30. lt1 with 98+ SS spoiler Brake Problem?
  31. Help with o2 sensor removal...
  32. which piston rings???
  33. polyeurothane mounts??
  34. lt1 magnaflow vid
  35. Has anyone made reservations yet for a hotel?
  36. removing bumper supports???
  37. Where online can I buy a dipstick tube?
  38. time for a clutch
  39. 30th anniversary firebirds?? not T/A's
  40. tps sensor
  41. Anyone heard of Thumpr cams?
  42. Car won't start after cam swap
  43. took my new engine to the track
  44. Cooling issues Please Help!!
  45. Caddilac racing lifters
  46. drag wheel question
  47. Well the 383 build has started. What better motivation is there then the shootout.
  48. Lt1 Help!
  49. Lt4????
  50. Is this right? opti rotor loose??
  51. Need some help finding a web page...
  52. 15" weld wheels
  53. Part Number Needed
  54. Car shuts off at speeds
  55. LT1 Info page,<very helpful>
  56. Calling The_merv. Benton/Bryan Arkansas.
  57. Turn Signal Lever problem
  58. nothing to do, so i should accomplish this
  59. gm 847 ?
  60. lt4 head gasket ???
  61. lt4 head gasket ???
  62. What causes car to run rich?
  63. Help me diagnose my high rpm problem, logfile included
  64. PO43 on LT1... Replaced Everything and its still there...
  65. LTx Extreme Street...what's it gonna take?
  66. 1.5 SA vs 1.6 NSA rr questions
  67. sensor ?
  68. Oil pressure question?
  69. optispark gone bad!
  70. local f-body owners . . . !
  71. Ultra Copper
  72. Best heads for boost?
  73. Header Gasket Question...
  74. mileage drop with cam (hotcam, cc305 and the like)
  75. Fuel Problem I Think!!!!!!!!!!help
  76. new 383 pic
  77. pressure
  78. Car Craft to do LT1 build
  79. Quick question
  80. intake?
  81. Yay!!! Getting The T/a Today!
  82. Abs
  83. is this a ram hdx clutch?
  84. What are the chances of a torque converter going bad?
  85. 30 overbore help!
  86. Can't get tach signal to work shift light or window switch
  87. Lost a lobe (or more) on my solid roller LT1 yesterday...
  88. Delteq Owners Inside
  89. loosing oil pressure???
  90. sa vs nsa rockkers for a daily driver
  91. car falls on its face from a dead stop
  92. puttin in LTs, anything i should know?
  93. In Despret Need Of Help
  94. Just showing off.....
  95. Help me out guys!!
  96. 1.6rr help
  97. Losing coolant??
  98. '95 B-body LT-1 in a '94 F-body
  99. Transplanting 94 shortblock into 93 Fbody. What do I need?
  100. Couple questions
  101. help me out with intake installation.
  102. SLP Lid on LT1
  103. opinions on what to do next???
  104. optimal quench height?
  105. Cograts to Tony, all up in CHP!
  106. LTX Shootout Question?
  107. huge problem....car wont rev.
  108. Hp?
  109. I'm stumped. Tiny off-idle stumble.
  110. wtb lt1 longtube headers
  111. where to get new opti??
  112. obd2 cable - what cars and years will it work for
  113. Low end miss + lack of power
  114. will car run with out harmonic balancer on
  115. Cam Question?
  116. price on lt4 intake?
  117. Guaging interest. The Ultimate LT1 alternator relocation bracket.
  118. exhaust sounds and opinions
  119. T/a Question Newbie
  120. anyone need spring locators??
  121. top speed?
  122. please help!
  123. Brake Booster Help
  124. need help!
  125. Rollor Rockers
  126. How much would you pay for.......
  127. OBDII software + tuning software + laptop = ???
  128. Best spring to handle .600 lift?
  129. Fuel Pump relay or fuse question
  130. Looking for some new seats, any recomendations?
  131. rear defroster issue
  132. weird rear-end noise
  133. Problem with the cold
  134. Aftermarket turn signals?
  135. coated or heat-wrapped??
  136. Thunder Racing, OTVC-Side mount pics?
  137. Anyone with Long Tube Headers Please Advise
  138. Race Car Wiring
  139. dont run your f-body out of gas
  140. 52mm throttle body
  141. crappy vid of my car.........
  142. Center Console Question?
  143. Small Base Circle Cam
  144. need some help
  145. Please HELP!
  146. my first 12 sec pass
  147. LT1 fuel rail
  148. Low Mount Alternator setup
  149. first time at the track in my LT1.. or any car for that matter
  150. LT1's and Rainy/Moist Weather?
  151. cc503 and 3600 Stall?
  152. Torque converter HELP
  153. Piggy back Chip
  154. Which pulley? and some other questions..
  155. fastest stock interal Bolt on LT1
  156. Help guys i need some help, car broke down
  157. Rev limiter
  158. Silver Formula Pics?
  159. Found My Massive Oil Leak!!!
  160. 383 stroker? good kit?
  161. How To: Cam Install
  162. Issues with misfire or fuel?
  163. cutout situation
  164. engine sounds
  165. walk around idle vid
  166. i think im screwed, tell me what to do.
  167. Sportline Springs In Las Vegas...
  168. R.P.M LT1 Build.....
  169. got backfire?
  170. Blocking EGR
  171. Oil pressure drop????'s
  172. v6 to v8 conversion computer ?'s
  173. LS1 Driveshaft swap
  174. Fuel Pump Question
  175. Refresh my memory on clogged cats...
  176. Ulta-Z hood on a black LT1
  177. Update on my a/c evaporator core removal
  178. exhaust leak
  179. Plug wire questions
  180. what springs with gm 847 cam
  181. help please starter problems
  182. 95 Vette Lt1 idling rough
  183. Price for LT1??
  184. Headers
  185. She's almost done! Complete custom. Pics!
  186. Intake seating
  187. Brake light
  188. Do I Need This Hose
  189. Dual cutouts vs. Single cutout
  190. 315/30/18 Drag Radial
  191. Hazard relay position LT1
  192. lt1 sensor list
  193. s/c or turbo
  194. underdrive pulleys
  195. A4 to T56 conversion kit
  196. Non-LSx For sale section
  197. Firebird/formula front bumper on T/A?
  198. Harmonic Balancer ?
  199. motor mounts
  200. Guage Cluster
  201. windshield wipers
  202. injector not working
  203. what do i need to convert a lt1 to a lt4???
  204. Changing from Synthetic to Regular Oil-Problems?
  205. how do i change the dowel pin in a cam
  206. Caprice LT1 ECM
  207. pacesetters on 383???
  208. Comp Cams XFI 260 HR13
  209. Heads and cam
  210. Odd smell and popping sound...
  211. Burning Oil And Popping
  212. rear mounted turbo question
  213. 355 build ????'s
  214. Fuel octane / tune question
  215. Hard starting and won't idle right
  216. My lt1 vs. 700rwhp supra kill in streetracing section
  217. LT1 for 67 Camaro having probs
  218. dissapointed in my dyno # with cc306 cam
  219. Driving Positions?
  220. lt1 forced induction
  221. studs...
  222. header
  223. hooker super competition long tube headers
  224. WHICH CAM?? need help
  225. whats the chances?
  226. Do cynlinder heads normally survive a thrown rod?
  227. engine tore down, NoW WhAt
  228. Are the LT1 engines a 4 bolt main?
  229. LT1 vs LT5 Cost Question
  230. what is this?
  231. do i need these lines coming off the water pump
  232. look at this pic of my cam timing
  233. overheating prob..
  234. Where Does this line go and do i need it
  235. coil is firing but car wont start?!
  236. fp running rich question
  237. Suggestions for Header bolts!!
  238. Flat connector or Square for the front o2s?
  239. interesting old thread about torquey cams
  240. optispark going bad after sitting too long?
  241. Car Question
  242. Tune Up = Faster =]
  243. motor switch question
  244. Head Torque Spec.
  245. egr pipe.
  246. LS1 valvetrain on Lt1 heads?
  247. Two wires until Im done. Help quick!
  248. 383 project build questions
  249. Opti order
  250. So Weiland is making ANOTHER intake for the LsX engines...
