View Full Version : LT1-LT4 Modifications
  1. Static Compression Race/Pump.
  2. 95 camaro
  3. where to lift engine from
  4. gen 1 into LT1 car. got questions
  5. Starting issue
  6. ARP 134-1802 Oil pan bolt kit
  7. i figured i let everyone know im getting my car tuned on 5/23 at tpis
  8. need traction help
  9. Buying an Engine Stand tonight, any pointers?
  10. colling fan issue
  11. Coolant Sensor light came on.
  12. What Would You Do???
  13. new gear install question!!
  14. is there an easier way to do plugs?
  15. DTC PO441 question about the emission lines. help needed.
  16. Must be doing something right !!
  17. 93-95 vs 96-97 crank hub
  18. Quick update on my opti spark project
  19. lt1 won't start
  20. Need some input on what how these mods will affect the engines gas mileage..
  21. Cam swap compatibilty questions
  22. Stump the mechanic/electrician
  23. Installed new opti and now car won't start
  24. Downloadable OBDII Logger/Scanner
  25. questions about a lt1
  26. Pulling my T-56, need quick advice
  27. No spin no crank no start on rebuilt LT1
  28. Water pump drive gear removal
  29. Gm Cam 19244485 NOT GM847
  30. Please ID this plug on 96 Engine Harness
  31. Leak free oil pan and timing cover? Whats the trick?
  32. Car threw these codes, need help troubleshooting
  33. cloyes timing set 9-3545x9
  34. wtf happened to my car?
  35. Alternator brace/bracket question
  36. Price for Price
  37. P1864 code
  38. Lol why does everyone have a big problem with open headers on street cars?
  39. What are a good pair of header gaskets/header bolts? Does it matter much?
  40. Rod Bolt Replacement Lesson...if you're thinking about doing it come in....
  41. Oil Pressure Sensor
  42. Rear gears
  43. Nitto Nt05R question
  44. LT1 tuners, opinion needed
  45. Getting fuel pump in tank w/o breaking sending unit arm
  46. 97 emissions and pvc delete help.
  47. Is swapping ls1 driveshaft a direct replace
  48. No kick down and spark retard problems
  49. Anyone in the dfw area that would like to help open up my LT1?
  50. How much in labor for heads swap?
  51. help with noise
  52. Batt'ry...
  53. alchy/meth injected lt1 ? has it been done anyone running one
  54. Lt1 Daily Driver build advice
  55. Can a shot header gasket cause a lot of power loss? Also how much for gears+labor?
  56. Changed o2s with brand new ones and still sputters a bit..
  57. Dyno results CAI, AS&M mids and GMMG, with sound
  58. FYI impala head gasket discontinued
  59. Ported LT4 intake (what's it worth?)
  60. Freaki Headlight won't pop up.
  61. maf codes
  62. Gears?
  63. Best heads for 383 stroker?
  64. from mustang to camaro
  65. Hitting Rev limiter 1-2 my solution
  66. cap replacement
  67. Issues after rebuild
  68. What numbers do yall think my z28 will put out on the dyno on monday??
  69. permatex thread sealant cure time?
  70. Questions about my exhaust and backpressure
  71. Going through the wiring behind the dash, SHBOX doesnt have this stuff
  72. What cam
  73. Please help, idk whats wrong with my car..
  74. Need Help Identifying This Box
  75. Cost estimate of stock shortblock rebuild?
  76. 3" drive shaft
  77. Rock Auto discount code inside
  78. length of stock 96 cam
  79. Noob with the 383
  80. HVAC Vacuum Line Check Valve Part #?
  81. lt1 headache
  82. New LE 226/232 110 cam, street and dyno results.
  83. DTC 16 - Tested... Opti?
  84. Getting back into the game, need advice
  85. What drive shaft are y'all using?
  86. High RPM Miss I've had for years that I can't figure out
  87. Misfire perhaps?
  88. Maybe a pcm problem??
  89. New PB 1/4 CC503
  90. Fresh rebuild problems :(
  91. Email from bob at dynaspark!!
  92. Nervous about getting my 96 Z28 tuned here
  93. Low RPM stumble
  94. pcm
  95. New member, new car, need header advice for Missouri inspection
  96. Will Energy Suspension 3.18130 work on a ws6
  97. LT4 valve covers and OTVC kit???
  98. New to the Group and Just bought this 97 t/a
  99. Seafoam in lt1 good adea?
  100. H.I.D's for fog lights???
  101. Fabbed up some true duals for my OBX headers
  102. Ticking from Injectors
  103. Pavlock LCA's..anyone run em?
  104. Ls1 fuel tank in Lt1
  105. battery randomly dies....need help
  106. lt1 info needed
  107. Need a stock 94-95 A4 Bin File!
  108. spin tech
  109. smog legal headers for California
  110. Trans part question
  111. Spring it up
  112. engine missing big time...
  113. Doors Won't Lock or Unlock
  114. Changing timing cover seals with engine out?
  115. Transmission / Speedometer Problems
  116. 7730 run a LT1?
  117. block filling
  118. Cooling Fan Diagnostics
  119. HELP!!!! idle problem
  120. LT1 Motor Plate for Mustang
  121. oil pan gasket options?
  122. P0372 on 96 z28
  123. NEED HELp
  124. Think I screwed up
  125. Photos of Left Side of LT1 Engine and Wire Harness
  126. I'm back!
  127. i think its time now!
  128. Fiberglass hatch w/lexan
  129. Engine oil recommended by builder 20w50
  130. Murdered Out
  131. Need AFR. for my LT1
  132. No heater core with stock waterpump
  133. efi 24x guys ? inside
  134. would it be wise to sell my F1A procharger setup for a turbo?
  135. Well aint this just peachy?
  136. would u use pcmforless to tune a 24x ls pxm
  137. air pump relay under hood
  138. series of unfortunate events
  139. does any one know where i can get a pro charger bracket for lt1 impala SS 94-96
  140. Injectors
  141. lt1 355 first start up help..
  142. My 1995 Z28 project with pictures
  143. Code 44, possible fixes?
  144. Stronger ignition for E85?
  145. Competition Clutch guys come in, I need advice real quick!
  146. Racetronix fuel pump install questions
  147. Whats that silver box under the dash
  148. double roller timing chain for use with 24x system
  149. Breaking Up After 5K RPM
  150. Lt1 t56 clutch
  151. Valve cover issues
  152. confused about head bolts.
  153. TSP Rumbler Modification?
  154. rockers hitting valve covers
  155. Fine tuning help
  156. what plugs/oil for my 11.6.1 357
  157. After installing my new heads...
  158. Can u use LS1 maf
  159. 503 cam
  160. Confused about water pumps...
  161. lt1 no start
  162. Lt4 intake
  163. High Humidity, High Idle?
  164. quick question please help
  165. Which plugs?
  166. Hydraulic roller adjustment question
  167. LT1 Heater core delete (Need pictures of looped or plugged waterpumps)
  168. security light HELP!!!!!
  169. Question for those who have had to notch the floor for pacesetter y-pipe clearance
  170. NHRA rules ?
  171. Lt1 timing set
  172. HELP LT1 355ci
  173. Header collector gasket choice?
  174. EWP Rebuildable?
  175. LE3 dyno results, not happy. Thoughts?
  176. Guys with ARP wheel studs come in please.
  177. bad opti spark?
  178. 95 LT1 Problem -- Possessed by Satan
  179. Always improving..Progress on the new build
  180. Car is hesitating and backfiring first mile? Help
  181. Headers to Catback?
  182. Where can I get these items?
  183. LOW oil pressure at hot idle
  184. Stripped wheel stud
  185. Whats left for bolt ons?
  186. LT1 surging/hesitating when Hot
  187. Performance ICM?
  188. SD tune.
  189. loss of power
  190. I can't find a Water Pump Drive Shaft.....
  191. 94 camaro v6 with87 5.7 carb. th350 driveshaft size???
  192. Do I have the only Millenium Yellow F-Body?
  193. LTX Shootout CALLOUTS! Multiple classes! See if you are inside
  194. Chrome Accessories..Need Some Input
  195. fuel pressure
  196. PCV valve?
  197. Is this forged?
  198. COMP Cams Pro-Magnum 1.60 Roller Rocker replacement PolyLock 7/16" part number help .
  199. Dirty Bird?
  200. Looking for info on Eagles 3.25 stroke 1 piece crank.
  201. Short block ????'s
  202. Z8's and a few others may remember this car
  203. 24x diy: Dowel Pin Question
  204. Car won't start
  205. valvetrain noise from my headers??
  206. gurus please help
  207. can someone help me figure this out?
  208. ?'s on Drill Mod on PP TB
  209. LT1 Flywheels
  210. After lunch, shes going back in!!
  211. Tuning issue or not?
  212. oil pan timing cover gaskit
  213. Oil Pressure Question
  214. Headers and X pipe on the way
  215. LT-1 Serpentine Kit
  216. Is my dampner on all the way?
  217. Opti vacumn reading?
  218. Draining Radiator Question
  219. Old pro charger commercial. lol
  220. Biggest cam for 383
  221. LT1 Cooling Fans Current....anybody every actually measure it???
  222. TTS Datamaster file -- can anyone help me diagnose?
  223. What autometer gauges match stock?
  224. How high to spin turboed 383?
  225. Cam Swap Questions
  226. Rocker Arm Conversion Question
  227. turbo hotside routing
  228. LT1 didn't pass smog what are my options??
  229. valve spring problems/questions
  230. I'm stumped.
  231. Whats the best oild to use in my stock lt1
  232. My 96 TA just died on me....?!
  233. CC306 lifter problem?
  234. Car shakes under light acceleration.
  235. Putting ac back on my car
  236. Efi 24x question with my swap
  237. Wheres this car now?
  238. Why doesn't my A/C or cooling fans work
  239. Texas Speed Xpipe
  240. 96 Camaro z28 rough driving and rough idle
  241. Stall Question
  242. Is a tune needed when doing a stall converter??
  243. 95 camaro need help with SES light and data scan
  244. any 355 ltx afr 195 or larger heads!! guys on here
  245. Alt re-location brackets....that keep AC/PS
  246. New "performance muffler" yo
  247. Intake manifold question
  248. Summit Racing Oil Pan
  249. my 97 WS6
  250. Evil Opti Plate Pictures
