View Full Version : LT1-LT4 Modifications
  1. cc306 question
  2. a few questions about the lt4
  3. 93 LT1 w/M6 I need to transfer to another Fbody..plz help..
  4. Few Valve Spring Questions
  5. harmonic balancer fell off
  6. Cleaning the Engine Bay?
  7. is my vacuum to low?
  8. belt to use with asp pulley? i searched
  9. LT4 Hot Cam Kit????
  10. Is it possible to screw up a nonvent opti install?
  11. LT1 install Tips or Tricks?
  12. 350 LT1's in the 11's?
  13. 2005 G35 Vs LT1?
  14. opti spark
  15. Looking For Stuff To Do To My Car Today...
  16. Cranking, i think no spark
  17. intake elbow for 58mm tb???
  18. I'm removing my 2" Drop...
  19. few turbo LT-1 questions
  20. hypertech programer question
  21. opti or sensor or fuelpump
  22. Good deal on ford 9'' rear???
  23. Port Velocity, shape of ports, etc
  24. What are good street/strip tires
  25. Help.......Someone tell me whats wrong
  26. Wiring Harness...
  27. HELP!!!!!!!!!!! Car won't start..
  28. t56?
  29. car stalled in reverse why?
  30. Need some help!!
  31. damn this low coolant sensor!!
  32. LE1 LE2 guys, ive got a ???
  33. random question
  34. How to tell if your car came with a stall??
  35. Magnaflow!!
  36. Part number for the Dynomax bullet?
  37. I have made my decision...
  38. lt1 dart heads
  39. opti cap and rotor
  40. Opti Question
  41. Reccomended Oil Pump, Pan, Filter?
  42. AC Delete
  43. spiral flow duals
  44. High HP guys, will this PCV setup work?
  45. Need some help
  46. 4.10
  47. Simple LT and tune?
  48. Yet another opti question
  49. When I hit the gas I hear a clunk
  50. Rebuild
  51. 11's possible,stall and 3.73 gears?
  52. Obd1 Obd2
  53. car won't start
  54. Nitrous users need advice
  55. AFR 227's what headers?
  56. Lost to my Nephew. ?
  57. Electrical
  58. 2 options..which one?
  59. difficlutly with timing chain and reluctor
  60. clutch master cylinder movement
  61. Go Figure....
  62. New LT1 Owner Need Rocker Arm Help!
  63. OBD I (#11-Malfunction Ind. Lamp) issue
  64. cam help comparison
  65. Stupid K&N FIPK question.
  66. Anyone else have a 95 OBD1?
  67. cddd
  68. 95 LT1...I NEED HELP!!! (kinda long)
  69. **VID** FASTFATBOY on the local 600ft track
  70. hydra rev kit?
  71. What year is my LT1 ??
  72. I'm Freezing My ASS off!
  73. Review this kit please
  74. Replacing injectors
  75. Lt1 coolant lines?
  76. Kooks Y-pipe
  77. Single Digit Guys Inside
  78. Turbo on Long Tubes?
  79. Header question
  80. Walbro keeps making noise?
  81. sportlines with lt's
  82. LSX swap or wait and get an LS1 car?
  83. 40 series with longtubes
  84. What do you guys think?
  85. White Trash needs your help
  86. waterpump housing tubes
  87. Jacobs ignition box and nitrous mastermind.. on a LT1??
  88. I'm looking for pics of lt1 firebirds painted in Orange
  89. recharging your A/C?
  90. 96LT1 Help!
  91. Headers???
  92. A/C evaporator box delete
  93. Accel DFI
  94. Broken heater box
  95. Help please
  96. CAI Install.... throw code?
  97. CC306 cam only guys ???
  98. What do you guys think?
  99. who's from jacksonville nc
  100. relocating PS fluid resivoir
  101. Oldest opti?
  102. Whats the name?
  103. oil leak!
  104. Tracked the Z on spray.... questions about 150 shot?
  105. Most HP for the least amount of $$$$$$$$
  106. Some new times for my 396 LT-4
  107. New to Lt1's
  108. LTX's In Stock Eliminator At Rockingham
  109. Hot cam
  110. What are the differences in the TB cables?
  111. what are the differnce between casts on lt1 heads
  112. headers "looking for the caps to block the air system"
  113. valve springs and rockers??
  114. Tune ?
  115. Rerouting the belt
  116. thinking about selling my car, details inside
  117. H/C/I LT1 almost done, cast your predictions!
  118. tight fit with headers
  119. Mail order or custom tune??
  120. What the best 383 twin turbo heads/cam
  121. How much are ya'll spraying on stock internals?
  122. brake peddal is hard as hell to push
  123. V6 & Z28 rear ends. R they the same?
  124. Edelbrock intake...
  125. Timing Question
  126. I Need Help Please
  127. 12's finally!!
  128. A Sneak Peek...
  129. lt1 swap
  130. Who here has non-coated pacesetters?
  131. EGR Delte Ques.???
  132. Sweet Thunder Flow
  133. X-Pipe w/Bullets
  134. 96 LT1 worth buying? Your input needed!
  135. LT1 Turbo - Optimum Setups
  136. 4L60E lockup problem...
  137. Chrome Radiator hold down where to buy ?
  138. Power Steering Delete
  139. 1994 Scan Help
  140. Lt4
  141. Elevation
  142. Would this be betteR?
  143. First suspension mod
  144. Sluggish problem
  145. The "How To" Cam Install
  146. How to make my 95' Ta outrun a 04' GTO?
  147. best place to buy clutch?
  148. Drivetrain Problem??
  149. fuel pressure on 383 lt4?
  150. roller rockers need help
  151. Vortech vs Procharger? I Searched and Researched!
  152. NEED TO KNOW: Arkansas DOESNT have state inpection?
  153. where should I list my S-trim kit for sale at?
  154. Budget 12 second LT1 engine
  155. Will 12" Brakes Clear 16" Rims?
  156. 3 or 4 channel abs
  157. Grounding Kit = 9HP?
  158. GM847 cam and Edelbrock heads
  159. Random Technology Y-pipe?
  160. Started the car up for the first time in 3 months...
  161. pulling the lt1
  162. Magnaflow on stock manifolds/y pipe?
  163. LS1 intake on Lt1...I KNow, simple Q's..
  164. '93 LT1 with a couple lights on...
  165. JOE O? Is he still doing cams?
  166. TH350 conversion?
  167. which muffler to replace LM2 muffler??
  168. Building motor
  169. Need a good book for rebuilding LT1's..
  170. Question about price of 1995 Camaro
  171. good daily driver cam?
  172. lt header ground clearence question
  173. pcmforless!!!!!!!!
  174. Trying to find Camaro headlight company
  175. To spray, or not to spray?
  176. 95 camaro Z-28
  177. best power mods for a LT1?
  178. SLP, Lingenfelter, or Moroso CAI?
  179. A few questions
  180. Another Induction Question.
  181. My BFG KDW's Suck...
  182. New Motor, No Start...Help ASAP!!
  183. help with lowered 96 T/A
  184. Opinions and what not on Heads
  185. LT1 rebuild. opinions please!
  186. Cooling issues (urgent)
  187. No Start
  188. Headlight Question
  189. LT1 Bottom End
  190. Throttle linkage?
  191. burning oil.
  192. DTC Malf 43 ESC Fail
  193. Who would you like to see race at the shootout?
  194. car wont start after motor swap
  195. Application specific cam help
  196. H OR X pipe?
  197. What cylinders go lean on Lt1's
  198. Need some advice - post header install auto shift issues
  199. What Should I Do?
  200. Guys, can I get your input / support
  201. New gears and intake
  202. Heads Cam Motor Internal
  203. what size belt for light weight udp
  204. best cam for stock heads?
  205. Before I Install
  206. Should I go Carbed?
  207. Another cam Q??
  208. How many rwhp will i gain from these mods?
  209. '95 LT1 miss-fire
  210. 93 Lt1 & 94 Lt1
  211. Leave it in or take it out?
  212. Fuel Pump Question
  213. sportline springs..
  214. Safe rev limit for a superchargered lt1?
  215. question
  216. Twin turbo
  217. Running 9.5's and header problems
  218. rear gear questions
  219. Cruising and Idle Question
  220. 94 vette vs 96 ram air TA
  221. plug wires
  222. Random Knock
  223. I just warm my z up and head out for a cruise
  224. spark plug wires
  225. Valvetrain Noise...EOS replacement??
  226. #5 spark plug wire problem! HEADERS!
  227. High horsepower guys, what are you using for vacuum pump?
  228. Oil Pressure!!
  229. **VID** of me playing on the street
  230. Bad coil? (delteq opti delete)
  231. Pewter SS spoiler on a black lt1?
  232. Opti Question
  233. Car is breaking up and misfiring...
  234. Clutch dragging & disengagement issues...Pics inside
  235. looking for exhaust clips
  236. Arkansas State law on tinting?
  237. Weird Noise from engine. Possibly lifters?
  238. Power loss??
  239. Help ASAP please!
  240. rocker arm
  241. stupid ?
  242. Question
  243. powerdyne on a 383 lt-1
  244. Magnaflow dual/dual
  245. Need some ideas.
  246. LT1 Issues (knocking/ticking/can't pull codes)
  247. someone buy this....
  248. Wow look at this intake setup
  249. You CAN fit a ls1 ws6 intake under a lt1 ws6 hood...
  250. Sadly leaving the LT1 world
