PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 [136] 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. opti + leak =?s
  2. new opti car still wont start
  3. pic request
  4. Lt5
  5. Lt4 Km
  6. cc306 question
  7. borla xr1 duals soundclips?
  8. Weird Tap
  9. What should I do?
  10. Car seems to be lagging a bit??
  11. Summer Build Finished (56k no way)
  12. VERY random constant missfire
  13. LT1 Gurus, please take a peep here.
  14. Water Pouring out of Exhaust?
  15. TB Air Foil or get a 52mm
  16. How do you clean your LT1 engine bay
  17. any experience with accel optis?
  18. chance of this being an opti
  19. What Y pip for LT's???
  20. dei lt1 build
  21. alright Tony Shep, GAME ON
  22. Fuel pressure should be
  23. lt1/lt4
  24. Best Catback System For 95 Z28????
  25. kinda dissapointed.
  26. Sensor issues
  27. How do you say in english part which is "Rubber, that stops noise and hold metal part
  28. Best cutout setup for single exhaust.
  29. "Best" Muffler replacement for LM
  30. my car "denzel" is totaled
  31. What do you think?
  32. head porting how much of a difrence
  33. Anyone use the GM 3-wire PCM/Gauge temp sender harness?
  34. running a bit hot
  35. 94 lt1 running rough, what can it be
  36. Port which itake?
  37. Upcoming mod list, tell me what you think!
  38. one of my pulleys is messed up
  39. RWHP gain from LTs?
  40. Finally got to run a LS1!!
  41. New Tires And Wheels????
  42. 2002 ws6 front end conversion ??
  43. No power
  44. First Start with GM847
  45. Nitrous Outlet Kit Installed!
  46. Good header deal IMO
  47. Very unhappy with Taylor wires.
  48. whiner here...
  49. Stock LT1 fuel pump
  50. What is the factory exhaust size
  51. Walbro fuel pump bad afert 1k miles??
  52. Loss of power with CEL?
  53. Oil Pressure Sending Unit - HTF does it come off
  54. Csr Electric Water Pump
  55. Anyone running afr 180 eliminators and what numbers did you get?
  56. No race. No Kill. No death.
  57. bad idea
  58. Spark plug's
  59. LT1 turns over, but doesn't sound like it's cranking
  60. Need help locating some parts pls!
  61. Fuel pump relay
  62. urgent I need this part number please!!
  63. Buzz
  64. easiest way to take off balancer without using puller?
  65. Ls7 Lifters
  66. 4L60E to T400 swap
  67. Another LT4 Hotcam Question :D
  68. where to get optispark harness connector?
  69. New C6 Wheels on My 94 Camaro SS
  70. car spontaneously die's..any suggestions??
  71. new oil pressure sending unit =
  72. coolant disappearing?
  73. any need for cutouts still?
  74. I've been called out...
  75. Compressor
  76. Cooling fan CFM
  77. im really sorry for the newb question...
  78. Cams!!
  79. LT'x Showdown or test & tune track rental with some heads up racing
  80. low vacuum
  81. One Wheel Peel?
  82. got 2 ?s
  83. Testing waters! Strange S60 for sale.
  84. What is this ticking noise?
  85. What The HELL Is Wrong With My Car!?! I Need Help Severely
  86. What next????
  87. I finally ran my Car
  88. Do i really need to rebuild my engine?
  89. lt1 intake manifold
  90. True dual h-pipe
  91. Motor out the top
  92. Car stalled what the hell
  93. mail order tune
  94. Rebuild a 4l60e or Buy?
  95. Rocker Question
  96. New car--figuring some things out
  97. ohhh please not again (head gasket)
  98. RTV for intake manifold?
  99. LT1 Headgasket?Opti? HELP
  100. Took some pics of the 95 formula ;)
  101. akron hp
  102. Two short in-car videos of my 355 w/ 847 cam + true duals
  103. Advanced Induction 185cc/190cc pkgs
  104. Starter ?
  105. cooling problems
  106. Sheet Metal Intakes
  107. No spark and no fuel on first startup... wtf
  108. Can the Crank position sensor cuz stalling?
  109. few questions after pacesetter lt install
  110. just got back from my first car show
  111. timing chain///opti???
  112. mysterious leak
  113. timing chain///opti???
  114. AC Compressor "delete" bypass pulley
  115. HC too high, RX7 LT1, need to fix ASAP
  116. What is this problem??????
  117. fuel tank skid plate???
  118. Fuel Issue?
  119. Just finished P.S LT header install, couple Q's
  120. stock lt1 nitrus
  121. keep hitting the rev limiter shifting into 4th? wth?..
  122. is it the opti
  123. Goals for my car, reasonable?
  124. battery relocation?
  125. went to the track friday
  126. lt1 dual fogger 300shot
  127. how important is matching piston to rings Brand names
  128. 97 WS6 with a stalling problem
  129. Oil pump distributor gear
  130. low fuel pressure, cant figure out why
  131. OBDI to OBDII Swap
  132. t56
  133. Any differences between the 96 & 97 Engine harness/PCM
  134. Motor Rebuild for more RPM
  135. The Cam Is Picked For The 383
  136. 3k lbs. Street car. How would you do it?
  137. 97 Camaro Ss Motor Build
  138. LTCC install ?
  139. Vaccum Hose
  140. What's the best Flywheel for hight HP?
  141. well i found my exhaust leak...
  142. Strange headlight issue
  143. Rod swap/install writeup?
  144. Dynaspark vs MSD Opti... which one?
  145. MR2 vs LT1
  146. Help with pushrod lengths
  147. Stock 10bolt with 4.10s T-56???
  148. It Runs
  149. Building an Lt1?
  150. Question about ceramic coated headers?
  151. gap for TR-6s
  152. smell coolant & low coolant light ON
  153. stock rods?
  154. weird problem? any help?
  155. Injectors for a 396
  156. new opti $?
  157. Hotcam Springs?
  158. So heres my bolton plans for the shoot out
  159. NE1 know where to get stock throttle cable for 97 LT1???
  160. more firebird headlight problems
  161. antifreeze agian dam it and low rpm idle
  162. flex plate torque???
  163. crank bearing help do i need my pistons reconditioned and rods
  164. 30# Injectors
  165. Coil?
  166. LTx Shoot out in GMHTP!
  167. Is the CC306 holding me back?
  168. Port the stocks or buy new????
  169. stall?
  170. voltage problem
  171. Please Help!!!!!
  172. 96 WS6 cut hole in front bumper/ hp estimate
  173. Car Starts, but then stalls STRANGE
  174. lt1 to ls1 swap
  175. True Duals WTF!!!
  176. Cam for 385 LT4?
  177. Help me choose, ET streets or Hoosier DRs..
  178. Keep factory ws6 ram air or?????
  179. AIR Delete Question
  180. Auxillary oil pressure port
  181. Clutter
  182. Another Header Question?
  183. 1 5/8 or 1 3/4 which headers best suite me??
  184. Heres some Numbers for my Lt1 owners
  185. Newer GTOs, how fast are they?
  186. need complete lt1 engine
  187. head porting
  188. LT1 Engine Build, Exhaust Ques.
  189. true duals
  190. HEI on LT1?
  191. dumdumdumdum
  192. dumdumdumdum vs. LT1
  193. I neeed help
  194. 93 Z28 M6 to TH
  195. Got the WS6 to the 1/4 not impressed
  196. Added LT4 Knock Module = Knock Count Increased
  197. Went to the track in the SS
  198. Drag radial on Stock rear with 4.10??
  199. Quick question?
  200. something that i do not understand...
  201. well guys my lt1 modding is done got another lsx car
  202. cc503,306,Gm847...Best Dyno #s
  203. how do you drop the stock oil pan
  204. new dyno #s
  205. LT1 stuck
  206. Need stock LT1 Rack & Pinon...help
  207. Help I'm Lost!
  208. Is my machine shop right??
  209. cc503
  210. Left-side Rich Condition - Please Help!!!
  211. Oil Change Causing Higher Engine Temps??
  212. Building my LT1, heads/internals ques.
  213. Putting my LT1 back together, couple Q's on where sh!t goes!!!
  214. tuning out the c@ts
  215. LPP LT1 stainless headers advertising
  216. Ls1 lid and airbox on lt1
  217. Why Is My Longterm Fuel Trim +50???
  218. Lloyd Elliot website not working
  219. Help for a newb on Lt1's
  220. John Deere @ the track
  221. how much is my 396 lt1 worth?
  222. Crank Sensor Problems??
  223. tired of finding "friendly" inspectors, how to pass emissions
  224. okay, i got a question and need some help
  225. LT1 Twin Turbo Kit?
  226. shifter problems
  227. pics of duals with cats?
  228. Video of my true duals and GM847
  229. 400sbc ARP Main Cap Stud part number for stock windage tray?
  230. know anyone wanting trade there 6 speed for my fully built 4L60E?
  231. Let me know what you guys think of this LT1 Camaro I might buy!
  232. I Need a opti spark!!!
  233. if i would have only known then what i know now....
  234. 9" or 12 bolt???
  235. thinking of trying something with my exhaust. tell me your opinion.
  236. 97 TA lt1 head question
  237. high rpm miss
  238. Fuel pump relay
  239. I Need My New Lt4 Programmed And Tuned On Dyno.
  240. She fired after 7 months!!
  241. Part of the AIR system?
  242. MSD box getting too hot?
  243. Difference in LT1s?
  244. Guidplates with SA rockers
  245. wat times for new setup
  246. Southern California Dyno and Tuning???
  247. Headers, What brand?
  248. Where to find a good tuner?
  249. Fuel pressure issues. LT1
  250. Unknown problem LT1
