View Full Version : LT1-LT4 Modifications
- It Finaly Runs
- Question about EGR and AIR block-offs with race style headers
- anyone else have ticking at hot idle?
- Engine Build Choices Driving Me Crazy
- roller rockers need to adjust
- block number ideantification
- Percy's XX Carbon Exhaust Header Gaskets
- B&B Triflow EXhaust??? Whats your opinion
- Where to Buy OEM Quality Body Panels
- Car stumbles when you hit brake???????
- too big a cam for stock heads?
- trifecta
- Doing Head Gaskets
- Timing Chain
- LT4 Hot Cam < ??
- TKO 5-speed vs. Richmond six speed
- got the YSI in last night!
- Suspension
- Broken 10 bolt
- LS1 Smooth bellow on LT1 Ram Air?
- LT1 Power Drop
- Comp Cams 503 in 383
- timing cover removal and help....?
- Fuel pressure Regulator??
- 94-96 Gauge Cluster Anyone?..
- Need suspension measurements form LT1 guys!
- lets hear the break down on bolt on's ls1 and cobras what they run with bolt ons
- Emergency Brake Cable
- Where's the best prices??
- lost driver's license
- So I got an extra $30 Summit bucks with $100 purchase what should I buy?
- overheating issue.
- Bolt for Torque Arm Bushing
- Need help... Oil blow back???? #@@$%&
- truely truely how much can i sell my car for??? 97 383 stroker
- Future Plans
- Reverse Lockout Solenoid
- 96 LT1 timing cover?
- This cracks me up!
- where can I get a ready togo nitrous set?
- 94+ harness on 93 car?
- Running Rich
- LT4 is hard to start - but once started runs OK
- Bought a TA, Doing an A4 - T56 & LT motor swap or Swap Cams, IM etc?
- nitrous question.
- ignition coil
- 98-02 guage cluster
- LT1 Block
- Need some Tuning Help :)
- Dyno tune Jackson ms, little rock ar, or dallas tx
- Help with MSD opti
- Cadillac Racing Lifters Spec?
- What would someone be willing to spend for the 396 from PEPE
- 94 Formula wont start.
- what do i need to install a stall
- Bolt-on E85#'s
- help fast
- Ford injectors
- So who likes my sig?
- Run MSD 8.5's over-the-valvecover?
- shifters
- LT1 M6 Bolt-on guys with 4.11s come on in...
- Strange knocking comming from under the drivers side
- 96 LT1 computer/flywheel Q's
- Rear main observation
- Cam Help
- 94 block heads into 95 car
- hypertech
- Few pics of my car from a local show.
- Header Installation Question
- Pulling my Motor and Tranny out of my OBDII 96 & going to an OBDI 95 TA, Knock Sen. ?
- BCM is making a clicking noise
- whats my motor/trans/ecm worth?
- LT4 Hot Cam Kit What Should I Expect??
- Ladies and Gentlemen, my nitrous is now.......
- Fuel pump/regulator?
- Strange Misfire
- Bad O2 making me lose?..
- does anyone on here have this setup?
- 94-96 camaro gauge cluster in 93?
- Wanting To Run Nitrous On Hyper Slugs
- help!!!!
- '93 LT1 T56 Better Gear Ratio?
- camaros in idaho!!!
- Head bolts. Thread sealer
- 1/4 mile
- bmr vs hotchkis
- 1500$ what to do
- How do u put fluid in a six speed tranny??
- o2's?
- switched to RP, lost some oil pres.
- E.W.P And Heating up?
- Tag lights
- Need injectors
- Ideas on cams?
- detail my car today got some pics...
- cam dowel pin
- 4th of july fun!
- My first LT1 rebuild and I need some help.
- what cam?
- Optima battery problems! Need Help!
- MSD Blaster coil... Opinions?
- How Hard To Change Injectors LT1
- affordable water pump
- Manual fan turn on switch is it worth it
- post slp loudmouth vids if you got em ...
- Next bolt on opinion
- need lots of help! opti install issues
- single plane intake worth it on my setup?
- Any performance advantage w/EGR Delete
- ASR Delete
- what does it do ?
- lt4 hot package
- Need help with Cam swap.
- wanting pacestter headers
- How much ET gain removing the catback
- msd ignition
- Which Brand Injectors
- SES light flashes on and off???
- LT1 Valve Covers
- Odd offering at Autozone for 96 Camaro...
- How hard is it to over heat o2 sensors?
- check this cam out;something different
- Piston hunt.
- Cam Questions
- Opinion on which 1.6 RR
- Anybyody seen or heard from TurboBob?
- ENGINE REBUILD.. help
- LIght weight flywheel questions.
- does anyone know what this is?
- 1/4 times
- replacement EGR tube
- 93 LT1 Z28 overheating?
- top to bottom
- slp fan over ride switch
- how many miles to break-in magnaflow catback?
- coolant light!!!
- Intake leak causing oil pressure to be low?
- Whats up with lloyd elliot?
- Croosed drilled vs. stock...
- 4L60E's weight comparison
- Engine Balancing
- Need suggestions!!
- A couple issues after longtube installation and EGR/AIR removal
- injectors?
- LT1 controlled shut down
- spring question
- Stall and Longtubes
- need help please, where to find these for cheap?
- Summit opti
- Injector help please
- 3" collector to a 2.5" x pipe?
- open borla vs. open cutout?
- Spintech
- lt1 question need answers
- which torque converter?
- What Is The Correct Torque For 97 LT1 Head Bolts?
- Low oil pressure?
- opinions on exhaust for my LT1 magnaflow/SLP/rumbler with LT's
- do i need a monoblade?
- 488 LT1 at KC LT1 Shootout
- Need M6 Part..
- LS1 vs LT1
- tracking a miss/ plug wires are crap
- Next bolt on?
- Header Gasket Help
- ?? Will these rotors fit on my 95??
- O2 Extensions for the 93 1 wire?..
- Lt1
- What auto trans used in 93 Z28s?
- ltcc guy's in here please!
- need help on were the wires go on the starter
- tune question
- went junkyard hopping!!!!!
- Tuning software?
- Car died, now wont start.
- engine/trans mount
- Wiring harness for a M6 96 Z28. Where to buy?
- hot cam question
- i just got fucke.d my pacesetter lt's are for a 94 not 93,what to do?
- Backfiring motor
- Running Megasquirt on your LT1? Post your setup!
- steering shaft help
- Stock to Ram Air Hood swap?
- Got my cam yesterday!!
- A few photos of the car
- Deciding on Exhaust
- Nitrous LT1's come in!!
- thinking about swapping to M6
- HELP! car wont start :(
- Headers
- 58mm Arizona Speed & Marine throttle body, how much can I sell it for???
- Slight irregular tap at idle
- Which wheels? Telstar's or Convo Pro's?? WITH PICS!
- ? About Timing
- cam decision
- LT1 blocks
- Cheap effective mods?
- non emissions exhaust question
- Iac?
- LT1 intake leak??? HELP!!!
- I want 350 hp
- Raced my buddies fully built procharged 306!!
- Maybe I'm out of touch?
- Funny Idle, Falling on Face
- Finding your calling insight needed
- Lt1 head removal guide
- LE1 LE2 How to tell them apart by looking at them HELP.
- 383 stroker kits
- electrical issue
- Eh.. bent/roughed up the headgasket..
- New LTs
- TSP Rumbler LT1 exhaust clip
- best in ontrio
- cam install questions please help!
- Question about LT1 SLP Air INTAKE KIT
- i need a new crank pulley, how about an underdrive?
- ignition problems
- Locked keys in, opend door with no key
- car problem
- Mid range Stumble???
- AT IDLE WHEN I HIT GAS TIGHT CAR Knocks and ENGINE STOPS
- Got some parts in..
- random cylinder missfire 97 TA
- convert to a single plane intake?
- What Header gaskets
- Gen I/ Gen II Differences
- Camaro Window Parts
- alternator relocation brackets.
- a/c compressor removal
- What happens when you burn the clutch instead of the wheels?!?! (PIX)
- LT Headers WITH EGR/AIR
- Optispark Options For My 93 Lt1
- Trans....????
- LT1 bird body parts
- could yall check this stuff out???
- cc503 or Ai grind?
- true dauls give me the opionins
- Formula Guys Come Inside!
- The Problem
- got the y-pipe welded...
- Gas mileage?
- What size Dynomax Bullet
- burning plug wires need help!
- power steering pump
- wanted: 95 impala pinouts
- Dtc-13
- Quick ?: Front O2 sensors.
- WOW wtf. I just got beat by a freaking 300c ??
- Think I've Decided On My Combo....
