View Full Version : LT1-LT4 Modifications
- ATTN nitrous users
- lt-1 ss owners
- part number
- P1351
- Best Oil For A New Cam Install
- Headlights wont go down, but go up...
- o2 censor problem
- OMG!! plz help
- Running with no header gasket?
- Firing order maybe ?? HELP
- what should I torque my pressure plate to?
- What weight oil for a LT1 with 132,000 miles?
- CAR WONT START ? SOMETIMES? ? Help
- lt1 coolant issue...HELP PLEASE!
- Engine Knock
- Port and polish easy to do
- Fans running question
- Headgaskets?
- Best Cam
- just got my opti from napa but looks wierd come look at it
- My baby!
- let me know what you guys think.
- PLX wideband & PLX DM100
- could my car be rare?
- stock bottom end lt1 question.
- Idea on how much this car really makes?
- The lil old bolt on LT1
- what kinda tranny should i build
- Bottom End Assembly
- Quick question about spark plug wires..
- Why so slow?
- need a speedinc caliber shop to work on my car
- MAC Underdrive Pulleys
- 1996 3.8 Tranny and 1996 LT1 Tranny Swap Ques
- Delteq Plug Wires
- Radiator hose help
- might be a dumb question
- Tunes?
- Nightmare at the track last night. Help
- ramp for lowered F-cars
- took the car to the track..how to knock down my 60ft??
- water in the wrong places
- I Need Some General Header/Exhaust info
- idle after start up??
- Self-aligning rocker arms
- Ford fuel injectors
- what would 355 build in hp/tq
- Removing the K Member... what should I expect
- In NEED of 93-94 lt1 pics
- Hp/ Et?
- Hey stealth formula please read
- I'd call this the ultimate tribute
- Stripped a spark plug....ideas?
- Relocating Plug Wires?
- Castrol GTX Commercial
- A/C not working
- cat. converter
- C4 body kit
- What should my next mod be?
- Looking for -24cc dished piston who to talk to?
- cooling prob question.
- Cats
- almost stumped: LT1 problems
- 1996 LT1 need some help over here
- My Unicorn runs...pix
- 2 700R4 Qs
- Help With LT1 Diagnostics? Date Inside
- new cam need to know shift points
- Open headers?
- new 383 lt1
- Hotcam results w/ videos
- Best parts catalog for LT1 Vettes?
- HVAC problems with 95 Vette
- o2 extensions for 97 LT1
- AWFUL AWFUL Gas mileage
- Will This 255 Fuel Pump Be Ok Look Here
- A/C Question?
- solutions for Front License plate holes? retractable front license
- Whats everyone Avg 1/4 time with thier hotcam
- Doing the LS1 Brake Upgrade... I need to remove my A-Arm... Bolts...
- Car Stalled, Wont Turn over, Bad Starter and flywheel
- *PICS* 6,000 mile old opti, toasted.
- check these out!
- switched to royal purple (a little long)
- New 08 LTx Showdown Banner (I got bored)
- Race question Plus odd happening..
- Quick couple of cam questions...
- H/C stock bottom end LT1 looking at NOS
- How much is this cat worth?
- bet torque converter for hotcam?
- I just got unbelievable gas mileage
- Need To Move - 94-95 LTI Pacesetter Shorties
- why does this happen to me!!
- my LT1 is the slowest
- Anyone know where I can find LG World Challenge Camaro wheel center caps?
- LT1-early sbc swap
- LT1 to gen 1 swap-reuse radiator?
- Lt's and cats
- god it feels good
- Hotcam backorder
- LS7 fuel injectors
- M6 interior pics...
- lingenfelter cai came today :D
- teaser pics
- 355 is slowww
- LT1 vs 335i
- H/C/I 100 shot.
- bad idle
- ls1 who, lt1 conversion 12.83@108
- header gaskets
- intake whats this
- Does this seem right?
- how hard are dauls
- N/A 355 104mph in the 1/8th 6-speed VIDEO
- Tuning?
- Can you guys help me with a price?
- Car wont start no spark
- Subframe Connector Question?
- can you give me a price on this
- How different is Polo Green to GM's Carbide Green
- no start
- f u oil companies! ! !! !!!!!!!!!
- i got the new valve springs in and ?
- 9 inch need help on brakes
- Waaaaay Faster, and 50 mpg too!!! *PICS*
- header tutorial
- New timing chain?
- LT1 vs 10 bolt rear axle
- Oil Pressure Sending Unit. Where Is It
- Opti Was NOT the Problem
- Port stockers or buy new castings?
- cam only times
- part ID needed v. WTF
- Borla vs. GMMG
- whats up with this?
- lost power with LT Headers
- Car overheated today, can I test the waterpump?
- Anyone use Hamburger oil relocation components?
- Electric Water Pump... Need some help
- Odd issues after installing CAI
- What color green is my car and who has an Aqua Green one?
- Little Sluggish at Low RPM's
- not the normal what cam thread, but what cam?
- best cam for stock bottom end lt1
- 4.10's & 150 shot
- motor mounts
- Lost 100 HP over a Cam swap - HELP!!
- ac compresser
- Speed density or maf/
- FS:94 LT1 Engine/Tranny/ECM/Harness
- Motor Tear Down Pics
- any last ideas on the idle?
- If you were a thief...
- Cleaned up the ole engine bay
- 1.7 LS1 rockers on a LT1
- help--name everything i need 2 have my 4.11 gears get installed
- Exhaust swap from ls1 to lt1
- Best cam that will run ok on a stock tune?
- Ram air hood questions...
- Who on Ls1tech makes the most RWHP on stock motor ?
- Pacesetter Lt & Ory Pics Need
- need help removing airbags!!!...and installing them
- opti relocate kit
- new project..
- where does optispark vent hose go?
- Quick Question
- Need a picture please
- Off road y-pipe for stock manifolds
- friend got a 86stang and some1 told him about the hidden gear in the trans lol
- burning oil
- fuel pump or opti?
- Worried about SS3600 driveability?
- LT1 to the max
- Antifreeze again help me find the hole
- Felpro gasket problems?
- Anybody Know LALT1?
- LT1 edit
- ALDL cable failure..HELP!
- valve springs trick
- Moroso CAI or Lingenfelter CAI which should I buy?
- I Am Stumped
- Looking a buying an LT1, advice please...
- help
- crank pully
- headlights flip up when ignition is on.
- is this totaled?
- intake leak plus oil pressure issues
- Installed a Holley 58mm TB now I can not hit WOT
- LE3 with supercharger possible?
- is this possible
- 383 LT1 runs 13.30's
- can someone diagnos these scans please?
- 5" auto meter tach.. how do you wire ???
- Changing to Auto? what the best setup
- FINALLY ive been waiting for this since Feb 1st
- 96 motor in a 94
- How to: LS1 lid to LT1 lid
- Help finding distributor...
- Change from lt1 to ls1 CAI
- 1le elbow vs stock?
- over heating, thermostat's go bad this easy?
- Clutch?
- diy cold air intakes
- what mods should i do now?
- Weight reduction easy to do's
- Wiring question?
- header with no gaskets to head
- Got my tax return, gonna get a new hood! which one?
- lt4 long block swap... no oil pressure
- Gray Smoke.... Fuel????
- Found small chunks and shavings on drain plug magnet. LT1 screwed??
- HOw to adjust Throttle Cable Length, IAT Readings and Idle
- stroker kits info???
- 1.6 roller rockers
- Why a CAI should be a first mod. lol
- Difference is sound between Powersticks and Sweet Thunder?
- I need help! Please read!
- Difference Between SBC & LT1
- how much hp???
- ebay Cold Air Induction
- ebay opti?
- Anyone using the LC1 as a narrowband replacement inside please
- Track Times
- Oil Pan replacement
- what rwhp with these mods?
- front end conversion
- Looking for 58 mm tb
- What did you do to stop oil in your Intake Manifold
- Headlight problem
- valve spring/head gasket/pushrod/etc. recommendations for 383
- 1993 camaro z28 vs ford cobra
- Best Heads for the LT1
- Speed density--->Mass Air??
- Your thoughts on this Cam
- first time at the track... satisfied
- Who's the best for OBDII LT Tuning, how is this company?
- lt1 ls1 throttle
- DELTEQ OPTI BOX? ANy experts know the difference of years?
- HSW nitrous question
- PCV and an LT4 Manifold... wheres it going?
- Track Numbers
- Still finding oil in the IM after the TB can not find from where
- need help please
- 4th gen camaro vs mustang 07 GTs
- My E85 swap, help needed
- WTF Electicrial gremlims.............HELP
- a bunch of OPTI / timing chain BS!
- Smoke coming from valve cover after head swap
- need lt1 oil pan
- Cable failure..
