- Need help with clutch decision
- 2 bolt 4 bolt
- Is this correct O2 extension?
- Cadillac cam ?'s
- damn my Z28
- 2nd opinion on oil leak!?!
- timing gear drives??????
- A.I.R. delete/removal???
- Any Estimates
- No More HyperTech!!!
- One For You Guys
- New Rims what do you guys think???
- new dyno tune, how fast?
- Specs for the XFI 292
- lt1 in maryland please read
- 94 or 95 LT1 into a 97
- what are you guys times with 3400 stall from stock?
- LT1 swap into a elcamino
- LT1 tuning on Long Island
- 11.2:1 396 and 847 cam
- 125 Shot??
- How good are stock valves?
- What to do when?
- o2 sensor problem
- Opti?
- Oil pressure problem...
- broke rocker stud...
- 1/8th mile time and 1/4 mile time
- specs of stock LT4
- height "1.740-1.750" how to measure?
- Best color to paint an LT1 intake manifold?
- Valve springs for blower motor?
- need some help
- Splayed mains
- Any place that i can get catback prebent tubing?
- what do you think!!
- Helicoil on-car..
- ABS INOP light
- Video of my Z28 in the snow doing donuts!
- Is a wire change really all that necessary when installing LT headers?
- best place to buy oxygen sensors
- Pacesetter TFX or Jegs catback?
- True Duals universal x-pipe question
- deleting tc (help)
- LT1 interior
- Removing ASR
- breather filter
- Racetronix fuel pump install
- MSD ignition system.
- LT1 Roots Blower Vid
- Who has the best price on Trickflow heads?
- Getting Timing Cover off, help
- Metal shavings at the bottom of the oil tank???!!
- Camshaft swap - Oil pump drive question
- HELP!! Need Length On Pushrods
- Need advice on parts
- 396
- Broken Piece
- side pipes *serious*
- fuel pressure regulator help
- I know it has been done before...but MY 383 is finally done!!!!!!
- Blue Smoke from exhaust ??!!!
- 389 information
- car not starting.. help please!
- heating and abs problems
- Does 383 use/burn more oil than LT1?
- lt1 camaro problem keeps dieing is it the opti
- Plug Wires
- LT1 timing gears without waterpump drive?
- Need some quick answers PLEASE.
- My 95 Camaro
- Heater Core
- Fuel pressure regulator torx size help
- Another new personal best with bolt-ons
- Nitrous cam for carb'd LT1
- timing chain??
- lt1 heads/cam combo
- 3rd gen to 4th gen swap?
- Lt1 maf and ls1 maf
- Flow Chart for ported stock heads
- I Need Help With My New Rad!
- Starter question..
- Trickflows
- Might get another F-body. Need LT1 advice.
- lt1 DART heads
- Corvette Lowered with New Exhaust
- XFI 292 or XFI 280 for my 408??
- Accel Fuel Injectors
- OBD2 knock sensor on an OBD1?
- 93 lt4 hotcam in a 96? can it be done?
- 383 stroker question
- oil pressure
- Can this be, bad tranny = car runs like crap????
- Which plugs are best for the LT1
- my dyno tune video
- Thanks to the LT1 Section!
- anyone have dynomax exhaust?
- my winter work thread!!!
- oil cooler???
- Users of Freescan and/or Datamaster in here!
- what would cause...
- Exhaust Cutout Hp gains
- 1969 camaro with LT1 question
- Can anyone spot the problem (PIC)
- which tune do u prefer
- WS6 LT1 Ram Air box on E bay
- Lets play a game... GUESS THIS COLOR!!
- blew my rear main seal
- Don't know what to think. Please Help!!
- Anyone have or heard this exhaust setup?
- Questions on New Exhaust/headers.
- stopped...idled rough..died???help
- best aftermarket intake for lt1
- Hooker super comps
- breather filters question
- engine rebuild
- sorry if this is the wrong section...
- Will this summit x-pipe kit fit or is it going to be a PITA ?
- 95 Front End VS 98+ Trans Am Fron End???
- AC delete
- Rough Idle when Hot
- Lt4
- Leaking Oil Pan On 95 Camaro LS1 PLEASE HELP
- OBD II to OBD I
- Budget Rotating Assembly
- LT1 Valves??
- Help!!
- Fuel Cell Options
- Universal aluminum radiator?
- Exhaust Question
- Progress on my LTXshootout entry
- Collant Cross over tube in back of heads
- Flat 93-97 Hood?
- ????What to do?????
- i hear there was a thread about me
- Will this flywheel work?
- same car, same issues, but an idea
- Good Old Break Light!
- any idea?
- ajustable fuel pressure regulator
- if noone is interested in my car i might be considering a part out
- want this finished, lotta questions
- Lt4 Cam And The Hot Cam Are Not The Same Guys
- 94 Bird Front Seal Oil Leak
- Diagnosis?
- I need pictures of headlights of LT1
- guess ill show some pictures!
- 94 LT1 camaro window motors
- LT1-LT4 diffrences
- smells like gas
- madman solid motor mounts
- 3 questions i need answers for pls.
- 305's or 315's fitting
- Coming to complete stop the car somtimes stumbles to take off
- how long do the MAF wires need extended to put the LT1 WS6 ram air box onto a 95 T/A
- mpg question
- Passed NJ Emissions!! LE2/LE1 Emissions cam
- Using only 1 knock sensor?
- 1996 Range Rover Overfinch 570
- Power window question
- My project toward the ltx shootout...
- Cam question
- New LT1 intake update
- Question for LT1 owners....
- bad fuel pressure regulator
- Suncoast Predator Hood
- dipstick and oil fill neck are loose
- new timing chain
- Gas Mileage Report...
- should I go coated or non coated on my LT's ?
- Out playin with the Camaro
- so had something wierd happen yesterday
- my next setup
- Headers question????
- Oil Pressure Sensor Help
- Spark plug changing help!
- DynoTune Air/Fuel Ratio Lean Shut-Down Switch
- looking 4 hp #,and some help.
- look 4 hp#,and some help.
- LT1 Moddification ?'s
- Heads for 11's
- Asking for a friend...lt4 valve springs
- Wont start!!! Help guys
- American Thunder?
- new opti suggestions
- Drip.. Drop.. Water pump leaks.
- headers done finally but...
- Im Going To Be A Dad!!!!!!!!!
- AFR Hydra Rev Kit
- Shift problem on automatic
- Fuel Press Help!
- Lots of progress
- Pics of my new exhaust (True Duals)
- Brake light questions
- New 383 runs great but won't idle - what to do?
- Need some ideas for my calibration
- What year LT1 is the best?
- What Kinda Rods Are These?
- kieth black hyperutectics pistons and lt1 rods 150
- 6 speed clutch questions????problem
- Pig rich cough, cough??
- Need serious help!!!
- header clearance
- valve float?
- Thoughts of new LT1 Intake Design
- MSD 6A or 6AL
- Please help! Problem with fuel pump wiring(?)
- i f*cked up
- Weird overheating problem
- What are good numbers from ported stock heads?
- 383 LT1 from Golen -- reliable?
- Opti Spark vacuum ports
- can i keep my stock cam and rockers?
- what msd retard box to use???
- weight question...
- How to take off super tight valve cover bolts?
- how long o2's extensions
- Electrical issue i think?
- Question on OEM fuel line material
- miss / vibration help please
- I need heeeeeelllppppp! help n e one?
- LT1 Valve Adjustment: Comp Valvetrain
- Which Exhaust Muffler is the BEST Brand that gives sound and performance for stock?
- Please Help! Exhaust Bump is driving me crazy
- AIR fitting thread size?
- Need stock electric fan....ASAP
- Looking for pics of Pacesetter LT ORY with Cats install
- Lifter question pls
- Fuel rail upgrades..options?
- Putting a new opti in. Someone help out.
- What Pistons to get for a le1 355?
- Traction control problem on a 93?
- Fuel pressure safety
- what do you guys think?
- Tuning...Maf or Speed Density?
- Injector Size
- this motherf**kin opti man...
- what parts for lt1???
- camaro trans am lt1
- A/C delete?
- TPIS ZZ9 Cam is this the right cam?
- My T70 Build
- Looking to trade my a4 for an m6
- Finished my Car today!!!
- Almost ready for the shootout
- Just picked up my first copy of GM High - Tech Performance
- My car sounds like poop....
- wHAT HEAD AND CAM PACKAGE
- Anyone know where to find OBDI code reader?
