- Electric Water Pump Sticks Out How Far?
- duraflex ws6 hood
- Lost 3rd and 4th?
- another quick video
- electric wp? realistic numbers
- need advice
- 4l60 convertor drain plug?
- my C5 wheels wont fit ?
- Upgrading valve train for big boost
- 383 Question....
- 4.10 what size?
- 95 Z28 Coolant leak passenger side
- Texas Speed True Duals?
- next bolt-on mod?
- A little help please
- still a low oil light
- How much to mill LT1 Trick Flow Heads for higher compression?
- Cylinder head bolt re-torque
- gauge idea
- camaro headlights
- Time for a cam....I don't know jack about cams
- cant get pulley off
- Mid 12's off the bottle.. Recommended setup?
- What is the best head for the money???????
- supercharger for a 383 stroker
- Impala head gasket...Is there a top & bottom surface?
- SBC double roller and clearance?
- Just wondering what mods you guys recommend to go 12's
- Port Pros 396 LT4
- gasket under throttle body plate?
- 93 lt1 wont start
- car wont start with new cam and heads
- torquing heads
- i need some help.
- need some specific engine pictures
- crank sensor
- harmonic balancer question
- LT1 swap to 64 chevy II(help)
- headers or NOS
- my car wont pass emissions what can i do ?
- Cam suggestions...
- coil packs?
- Car starts but then dies
- overlap/valve events at different lift points
- XS Power Headers
- Damage pics..
- Is 1995 Trans Am Use Obd-ii Or Which Code Reader?
- motor mount question
- broken mounting screw for throttle body plate?
- Speed sensor or is it the gauge gear?
- Tune for 55lb injectors?
- Fuel injectors low or high impendence?
- aftermarket steering wheel.
- LT1 X-PIPE TSP vs. Custom
- Good deal?
- fast 10 bolt's
- Bad fuel pressure regulator?
- fuel injector cleaner
- need help car wont idle setting off codes
- Stock a4-M6 LT1 times
- Installing MSD Wires
- Whats the difference in these pushrods
- Kooks, LT1 GUYS INSIDE
- Le2 H/c Stahl
- where to buy a good cam>
- ***PICS**** had my headers coated
- Harness Pin Diagrams
- LS1 6 Speed. What's the difference?
- Roller Rockers
- procharged 383
- LT4 hotcam question
- water pump shaft seal
- gen 1 sbc swap
- Need Help: gasket sealant
- I want YOUR expert opinion.
- Looking for some video clips of 355 lt1
- anyone race a bolt on 96 cobra?
- mods...
- looking for good tuner in nw indiana
- bret's custom cam ?
- oil pressure?
- Video of my Trans Am
- Vote for my tune
- $1000 what to do?
- Just got my stroker running!! Here the clip>>>>
- help!!! main cap positions
- What converter?
- ported throttle body, how much power added
- Leak
- shifting the 4L60 manually...
- Why is there coolant coming out of the top of the reservoir?
- anyone know anything about Pacesetter longtube headers
- My 96ss and my ls1 check it out!
- new best
- SS Hood
- Ls1 Airbox Conversion
- K&N Filter for CAI
- With pic: What is this supposed to be plugged into??
- stock rockers studs on 95 lt1
- I am in Love with this LT1 TA conversion
- Holy Valve Covers!
- I love my Lt1.
- Weld Drag Lites?Size needed
- First (and only) run in my 1995 LT1 z28
- What size are the lifter gallery Freeze plugs?
- 95 LT1 fuel pump question...
- Yank Stealth 3000
- holley tb
- Help!!!!!!!!
- help trying to hook up tech
- Thumper Cam
- Ultra Z Help!!!!!
- Thread length and pitch for stock throttle body screws?
- Flash Tune LT1: Good Idea?
- 1st gear engage?
- iron heads??
- how much vacuum?
- LT1 running rich, ECM indicates lean condition
- Check it out.
- 96 ss hood problem help!
- stock lt1 injector size?
- Car failed inspection for emissions.
- VICTOR EFI CONVERSION?(intake)
- Putting motor in with headers attached
- Sandbags
- k-800s with a hotcam?
- Problems Problems
- something different
- Finally got my car back.
- lt1 guys check this out, finally an aftermarket intake
- LT1 Header install
- As it is correct to install cam drive pin installed
- Reasons to keep you lt1.. Lt1 vs LS1 vid inside
- Ignition problems??
- AIR/FUEL Gauge instalation ....and cooling fans will not work ...and car over heats..
- Cam degree results in...I have 3 degrees above spec on the cam card...
- Looking to build a 396.
- lt1 headgasket
- Idle adjustment screw location? (idle problem)
- Quick EGR Question
- OBD2 LT1 w/ double roller timing set?
- z28 camaro
- Which Harenss, Computer And Stuff...
- Headers for a 396 LT4, what to do with?...
- DFW Tuners????
- loudest cat back
- B-Body guys in here
- Good or Junk??
- My LT1
- what size valves to use for ported lt1 heads on a 383?
- good deal or not?
- heads and cam
- MAC shorties/ory universal with all lt1 fbods?
- LT1 stock info
- help need 2 bolts that hold steam pipe to heads
- 160 deg stat make Cat go bad?
- Accuracy of factory Tach...
- LT1 And LS1 OEM LIfters Question???
- Oil level sensor prob...
- Rear end...AHHHHHH
- Sticky shifter
- Magnaflow
- SLP CAI Fitment on LT1 + Warning
- oti- trouble
- FIPK Cleaning
- Lets Talk FULL rebuild… fam i need your help
- Anyone know?
- i just took some pics of the Z28
- taillights
- egr tube to pacesetter lt's
- 02 extension
- 1/8 mile times
- Start of Something big *pic*
- oil pressure reading 80 help please
- What Muffler Should I Change To?
- TT LT1 pix!
- White face gauges: 95 Formula
- Starter...
- 1996 impala ss
- Finally took to tracks
- Whats going on with...
- AI 200 cc heads
- How much difference in lope 111lsa vs 112lsa ???
- 233/239 on 111lsa ????
- Firebird and Corvette Crankshaft Position Sensor's Different Sizes?
- Canton+Oil Pump
- Oil Pressure Sensor Boot
- Engine won't start
- Switching 383 setups, have a couple internals questions.
- another oil leak..
- vacuum lines with no egr
- buying a 95 Z28 Head gasket? and fuel issue?
- Due to a suggestion I will reask the question who here is running 9's to mid tens
- changing a power window motor
- Ford 9" Rear
- Motor Mounts
- EGR tube
- AFR 227 Heads....which VALVE COVERS?
- Help!!!! Turbo Owners
- header bolts and gaskets
- Front shocks
- option......
- Car not running to full potential?
- 2.73 gear question
- whats the biggest cam duration & lift that you guys were able
- engine go BOOM!!!.............. mod time
- i need a peadal assembly wiring diagram
- 97+ tail lights
- Fuel pressue issue...NEED HELP ASAP!!
- Connecting rod side to side clerance (end play) out of spec.
- 89 Lt1 Vs 94lt1
- x pipe importance
- Egr
- electrical trouble
- Where is the 2nd Location for the OPSU?
- LT1 Pistons and rods going in...Need help fast!!!
- o2 sensors
- Need a part #
- t-top ?????
- Finished Swapping Cam Will Not Start Now
- What heatrange plugs are all you h/c guys running?
- Trans am hatch
- Bullet or Catback?
- Who has the fastest cc306 cam only car?
- Lowest Price on a 1997 Fuel Pump Assembly??
- Running really slow
- Hotcam help!
- O2 issue did some tests have a few questions
- tonights drag results
- Guess what i got today..
- quick question
- What to do with 3000 for most power???
- getting gas= getting ass
- bbk pulley and thermostat
- Need to cut down an ARP main stud...
- Fun in 07
- cut out
- lt1 computer programming
- You've got to be kidding...
- Loss of fuel pressure after key is turned off
- Cm 233/239 Tuning?
- conversion from LT1 to LT4
- Interesting happening
- 7.2" chromoly comp Hi-tech pushrods forsale
- First time to drags
- Defog sw won't stay on long enough??
- New edelbrock lt1 and lt4 intake.
- T/A Cut off and won't start
- Oxygen Sensors?
