View Full Version : LT1-LT4 Modifications
  1. clutch slippage
  2. Throttle sticking?
  3. 400rwhp with lt4???
  4. Header question
  5. Help, i don't know if this is normal.
  6. 4l60e ????????
  7. Got my TH350.. Now what
  8. LS1 rear brake conversion help...
  9. Sanpped vacuum lines
  10. Intake conversion..
  11. How do you measure a custome brake line...Need help fast?
  12. "stages" of head porting?
  13. I need a list of the plugs/sensors that need to be removed to pull motor
  14. Combustion Chambers
  15. 96 z/28 to fix or part complete
  16. Will cars run ok with open manafolds
  17. crankshaft position sensor
  18. Slicks
  19. LT1 Intake Oil-Leak
  20. New Set-Up
  21. Went to Lonestar 11-24
  22. i love that sound !!!!
  23. AFR 180cc LT1 heads-sponsors selling them?
  24. opti-spark stub harness??
  25. CAT cranks/rods?
  26. Shift Points for my Car?
  27. Difference(s) b/t LT1 vs. LT4
  28. 236/242 .560/.580 112LS good for my setup?
  29. Potential problems??
  30. New 847 setup
  31. compression help!!!
  32. Should i change gears
  33. I'm installing headeres please help
  34. fluidDampr question
  35. need help with an engine cradle replacement
  36. Center caps on
  37. 93 T56 question
  38. New Times
  39. The Crankshaft Depot...anyone heard of 'em?
  40. Plugs Gap
  41. got my car done NEED HELP!
  42. Exhaust
  43. Finally low rpm miss gone!!!! Digital6
  44. HELP PLEASE! bad opti harness?
  45. questions about beefing up my trans am
  46. a/c delete question
  47. guage cluster??
  48. Best LT1 Emissions Legal Header/Exh. System?
  49. 383 Injector size
  50. oil filter leak pt 2
  51. cc503 cam
  52. Radiator Cracked
  53. Long Story But Need Help!
  54. RR Clearence Issue
  55. 400 horses
  56. A quick and easy question for you LT1 guys
  57. lt1 2 lt4
  58. switching to 383
  59. Header instalation time LT
  60. Lots of stuff for sale...
  61. Help! need pics.
  62. lt4 heads???
  63. Whats A Set Of Lt1
  64. what all should I replace?
  65. LT4 top end stuff
  66. I fixed my Miss at low rpm under load.
  67. 95 LT1 in 95 V6 Compatibility Questions?
  68. My damned heater doesn't work!
  69. Stick with LT1 or go LS1?
  70. 4.3 L Lt1 ??????
  71. Cleaned Out The Garage
  72. Opti on the bench, should I mess with it?
  73. Conversion Confusion...
  74. TCI torque converters
  75. Injector size
  76. Who Is Best For a LT1 Custom Grind Cam?
  77. A slightly different clogged cat question
  78. 93 Fbodies make yourself known!
  79. So I Got A Ls1 Now!!!!!!
  80. ground clearance
  81. Tv Show(the shield)
  82. CC306, 3500 TC, and 3.23's
  83. more on headers...
  84. How hard to sell lt1
  85. Any fellow LT1 members need a timing set?
  86. Lt1 276hr-14
  87. ok thinking about getting rid of it all
  88. exhaust popping....
  89. Victor E (LT1 Guru's Please Come in)
  90. Help me think of more winter plans..
  91. SPLAYED mAIN cAPS
  92. How much is my car worth?
  93. dyno
  94. Driver side cat, '96 LT1
  95. changing non-vented opti to vented
  96. Head and cam time
  97. Detonation problem
  98. Someone pinpoint my problem
  99. 93 Lt1 Datalogging
  100. 431rwhp/386rwtq - TEA LT1 heads/custom TR cam
  101. Just bought a Magnaflow Catback
  102. header gasket help
  103. tube the last sprk plg wire runs through drv side
  104. Oil pan change? help please
  105. A different kind of exhaust sound?
  106. PUMP GAS 396ci LT-1 engine dyno numbers
  107. Wheres the Bird in GMHTP??
  108. rocker adjustment
  109. Is this a good setup?
  110. lloyd elliot and head gaskets
  111. Question about AC delete??
  112. Dual cat LT1's enter
  113. I need some insight...
  114. Nitrous LT1 guys --->
  115. carb style intake?
  116. rocker question
  117. Quick question I.D. & O.D. exhaust
  118. top end package for 383 stroker?????
  119. Surging LT1 Conversion
  120. pcv valve grommet
  121. header choice's!help me choose!
  122. AC compressor
  123. 94 z28 worth
  124. Bang for the Buck
  125. Water Pump out..
  126. Dry shot for LT1?
  127. stroker kit, forged or not?
  128. street racing story
  129. So I Want To Build A 396 For My 94 Z...
  130. performance ?
  131. Cam Question!!
  132. Will this fit mine
  133. Trans Am Update
  134. 94 z28 manifold
  135. Pulling engine, have a/c question...
  136. Won't Start...opti???
  137. sick of it / LTCC or Delteq peopel inside
  138. a/c delete pulley
  139. Ticking Under Valve Covers.....
  140. LE2 cam + stock heads idle vid----->
  141. ??????? Transam 1995 Coolant
  142. What cam, please help?
  143. LT1 Heads FS
  144. LT1 401 question
  145. what do you think?
  146. Exhaust Question?
  147. which opti is best for the money
  148. Oil pressure drop at WOT
  149. How Do I Convert To Vented Opti???
  150. True duals Which performs better?
  151. pinion gear question
  152. Low oil pressure??
  153. Hello I need parts and I cant post...
  154. camquest6 request!!!!
  155. 3.90s, 3.73s or 4.10s
  156. LT1 exhaust diagrams???
  157. gas smell
  158. PCM question
  159. GM part number for 1LE AC delete pulley
  160. Vats bypass
  161. Head Gasket?
  162. roller rocker question
  163. $220USD to spend
  164. need a cam
  165. XFI High Extreme energy Cam, any one like this cam? .584"/.579" 292/300
  166. Rocker Arms
  167. headers are done
  168. miss
  169. My Zex Nitrous System.......Pics inside, post yours.
  170. Cylinder Head problem??
  171. dead spots in rev band?
  172. header bolt question
  173. G/F has givin me 500 dollar x-mas limit what shall i get
  174. accel opti or msd opti
  175. Locking header bolts
  176. March Performance 2 Piece Pulley Set?
  177. Newbe question about the T56 shifters
  178. 1/8 mile to 1/4 calculation
  179. h/c install quote
  180. what timing chain for a 97
  181. PACE SETTER HEADERS EGR or NO EGR
  182. Symtoms of optispark failure.
  183. Symptoms of Fuel injector problems.
  184. Siphoning out 2 year old fuel on my 93 Z?
  185. nitrous help please
  186. Fixed my car, look inside
  187. Need to beat SC 350z
  188. Making weird noise
  189. My Cam Thread
  190. 480 RWHP LT-1 build, dyno, and 1/4 VIDEO
  191. Heater Problems
  192. Finally Fixed My Car! =]
  193. Newbie questions LT1/LT4 parts
  194. stroker vs. bigger cam
  195. Happy Thanksgiving
  196. Why are you guys still holding on to your lt1s?
  197. Need Good Used Opti!!! Anyone??
  198. price to swap an engine out?
  199. distributor cap removal question ?
  200. Eibach Sportlines and Long Tubes?? I dont think so...
  201. Have to pull heads to get springs off/on??
  202. need help replacing oil pan gasket 95lt1
  203. HELP ME PLEASE 94 Z28 problems!!!!!
  204. lifter noise??
  205. lifting motor for header install
  206. LT4 Hot Cam kit
  207. Need good advice for a street car.
  208. needing 96 or 97 lt1, M6 stock .bin
  209. Flywheel
  210. What type of spark plugs do you use?
  211. LT1 Plugs & Wires
  212. l--l that much closer!!
  213. Bolt-On LT1s Dyno Numbers (Help settle arguement)
  214. True Dual Suggestions with BMR TrakPak
  215. help! high idle, no shifting
  216. any cammed LT1 out there w/ cutout+stock exhaust?
  217. car idel
  218. Torn intake elbow = SES Light and slight miss, right?
  219. gains from single plane with mild H/C setup?
  220. Front Brake Issues
  221. Pictures of my Sweet Ass Fuel System.
  222. LT4 VS stock P&P heads
  223. Whatcha think...
  224. the right cam??
  225. LTCC problems!!! PLEASE HELP
  226. header questions
  227. Lt1 Vs. Lt4
  228. Fuel Pump, input
  229. Knock Sensor Location
  230. Oil Leak
  231. Need some help guys!
  232. Got Her Runnin
  233. Will it fit?
  234. Clearancing Issues 396 Vs 383
  235. high map code and another problem..help?
  236. Stroker or 355?
  237. Starter Wire ?
  238. The Best stroker setup??
  239. True Duals
  240. rocker question
  241. clutch problem
  242. is this the real LT4 hot cam kit?
  243. 396sbc ?
  244. Went to the track! Killed the TH-400, first pass!
  245. madman alt reloc.?
  246. Ok, I need some tips on this installation.
  247. CAM GURU's : please enlighten me...
  248. LT1 heads
  249. what to look for?
  250. LT4 Hotcam (help with cam swap)
