View Full Version : LT1-LT4 Modifications
- question with removing the flexplate
- Changing Head gasket on LT1 today. need some advice
- Help - Car wont rev past 1000rpm
- pictures of what i have been up to...
- what is goin on
- car won't start update...any other suggestions?
- Is anyone using a megasquirt in here?
- Here we go again.... LT1 hydraulic roller cam and RR/Valve adjustment....
- Egr delete-possibly overheat and blow gasket?
- OK, I'll post it here...
- 95 camaro a/c problem
- just put in new cap & rotor.. high idle.. help me out
- 398ci LT1 Teaser Video
- Please Help, Can't Figure This One Out
- Car won't start...please help
- LT install
- Dyno#/track times
- Carbeurated LT1
- adj. fuel pressure regulator
- pretty much lost power
- Kooks LT/Y-pipe vs. Pacesetter LT/Y-Pipe.
- Headers
- help with a hot cam
- Alternator Help!
- Gto rims on an fbody?
- Video/Soundclip of 388 Ci Stroker LT1
- How much mpg do you lose by switching to 160 thermostat?
- At what mph do you go into 6th gear?
- Radio Anntennae
- Feast your eyes again.... My LT1 Stroker LE3 Head/4 Cam is complete.
- 28 Mpg????
- 1500$ tune up getting a honda
- Can't win for losing...
- So do I have a strong running LT1 or am I imagining things?
- ls1 calipers
- morning start up
- Going the track tonight!!
- 1.6RR????'s
- Lt4 heads need cam
- LE2 H/C package
- 93-97 body the "exact same" as 98-02?
- Busted a hose
- Help I dont know Whats wrong!
- Clutch/hyd/starting problems
- best lt1 tuner in TX?
- Pics of Updates
- Prep parts for a mild cam??
- How to make Harwood Ram Air functional?
- Power Block
- EGR Gasket
- A/C Worked then went out
- What am I going to do with this.
- not getting spark
- 15inch wheels
- XFI 292 idle Vid
- Putting the converter in the tranny?
- Brake Pad suggestions
- I DID NOT get screwed on these rockers
- egr block question
- does not idle up when brake booster hose is disconnected
- ls1 brake upgrade
- question bout stroker motors
- NEED HELP!!! valvetrain question
- Question for anyone that has run the comp 242/248 cam
- flow charts for mufflers?
- opti opotions
- o2 sensor question
- intake manifold question
- New day new problem: radiator fan not coming on
- 94 formy A/C
- rolled exhaust tips
- is it safe to drive my car???
- Poly mounts on a daily driver
- Ok replaced the water pump..possible problem..
- 13.8@102 with lt headers and cai
- A/c
- surging???
- Tranny Problem...
- LSx lifters in Gen I, II, lt block
- "Stepped" headers?
- True Duals on 94 LT1 Bird
- Header gasket ?s
- sub frame connectors
- My camaro is running too rich!
- starts then stalls
- My car is running rough
- Driving with a bad cat?
- Long Tubes From A '94 Z to a '96 T/A... Will They Fit?
- Will C5 Rear Rotors fit my 97SS without any mods?
- lt1 head studs or bolts?
- CA residents.i think i was harrased! need your help!
- Edelbrock's new LT4 Head
- torque converter question
- Pushrods?
- Dont hate me..
- Big Problems!
- WTB all parts needed for C5 Conversion Brake kit
- stock valve spring OD and installed height
- Which Cam makes the most power from around 2k-6k?
- What does code P0100 Mass or Volume Air Flow Circuit Malfunction mean?
- 1LE AC Delete Pulley
- Header sound differences?
- LT1 weight reduction???
- A bunch of LT-1 questions about mods.
- Freaking off-idle studder
- Bad coil??
- y pipe hits bottom of car
- how good are the LT1's vs LS1's
- LT1 Not Starting pls help
- where can i get a shortblock???
- problem
- Maf sensor
- idle at startup
- Lightweight carpeting and sound deading material
- Help! Temp problems
- What is this light?
- high power dd
- running super rich problem
- Yet another lt4 hot cam ?
- guideplates...do i need them????
- abs light turned off now ses light?
- Help with finding correct shift points
- Wat cam for up to 6200rpms
- CC 986 Dual Coil Springs
- rebuild question?
- Radiator Question
- How much would you pay for an OPTI???
- Brake Light Problem!!!
- obdII guys-reluctor wheel
- more car problems yayyyyyyy
- oiling your air filter?
- underdrive
- EGR Block Off Plates
- headers for lt1?
- Ls1 catback on an lt1
- Lt1 383 Dyno numbers
- Rear main seal question.
- A4 shifting wierd...
- Weird Start-up Problem
- Interior Swap
- Jet-Hot Headers
- Dyno #s
- I've got the LT1 squeaky brake
- Where do the abs and tcs sensors go?
- Race day video with new converter
- Transmission issue
- True Dual Question
- Fastest stock times?
- question about emblem
- magnaflow
- Car acting weird
- opti
- automatic takes too long to shift
- wondering something bout a cam in a 94 :)
- abs sensor/
- lookin for t-56 fork pivot
- Check That Opti Spark!!!!!!!!!!!!!!
- fuel line question?
- Best shift points for a stock auto?
- revving issue
- factory rev limiter
- cut out question
- Is there any window fuses other than the one on the dash fuse box?
- anyone have a hays clutch?
- Has anyone relocated their coil?
- LQ blocks
- fuel line questions. kinda stupid
- Does anyone have a video of....
- Where to buy: Lt4 KM
- supercharger
- Tranmission dipstick not tight?
- exhaust
- Car is hot as hell on the inside..
- Im lookin for a lt1
- How do I remove foglight hole covers on firebird nose?
- Who do yall reccomend for a clutch?
- New Toy
- Corsca exhaust
- A/C compressor
- SES after new muffler
- Any Ideas?
- hesitation and a little miss at idle when worm up
- think i found a vid ellis draggin a hyabusa
- where u guys getting your AC Delco O2 sensors??
- Anyone relocated radiator and kept AC
- 1st time 1/4 time
- No Spark, Please Help
- How much power??
- 4" exhaust questions
- i need input, lots of it!
- relocation parts
- lt1 valvetrain upgrade questions...
- 95 z28 a4. is it worth it?
- GF's 94 TA won't start...
- Car refuses to breathe uptop, help.
- Car falls on face at start up.
- Opti vacum line relocation
- 1996 Reluctor Wheel GM Part #????
- timing chain cover?
- an fittings for fuel rails?
- SES light is on...
- Gen I and Gen II small block differences
- Bad O2 symptoms
- gears?
- oil pan gasket leak??
- Old Style Heads On An LT1 Block?
- Engine Help...
- crank hub: the worst lt1 part. by far.
- need a p/n for fel pro oil pan gasket
- I found a hole on the bottom of my intake...
- Normal compression test #'s
- Radio shuts off sometimes
- GMMG too Loud? Bullet maybe?
- wow, just.......wow
- turbo tuning
- Dtc Codes
- Carbed Lt1
- 96 Monte Carlo shooting water out the sides of the engine wont Start
- data log that needs to be looked at.
- Hitting the rev limiter @ aprox 4500-4800
- Have a problem.
- Allright, how hard is it to fit a HEI distributor
- Will the oil press. sending unit cause no startup?
- So are the new LT1/LT4 intakes that bad?
- crank hub install- where the hell do you get threaded rod?
- How much fuel pressure is normal?
- Car wont fire, any suggestions???
- What kind of whp will this produce??
- anit seize on head bolts and spark plugs
- Are Carmaro owners a little snobby?
- window
- oil pump problem! please help!!!!!!!!!!
- rear bumber reinforcement weight reduction help!!
- Carshow this sunday!
- Turn signal ?
- LT1 has some problems...HELP PLEASE!
- Y-pipe
- Where can I find OEM body parts cheap?
- unable to read codes obd1
- if i seafoam my car will it have sludge
- Headers? Need Advise!!!
- 58mm TB
- LT1 swap
- What next?
- some new pics of the car
- ttII's for zo6 rims?
- car doesnt pull hard
- Pro 5.0 or hurst?
- Completely Lost Help
