- Question on Grounds for the car???
- LS1 into a LT1 car
- Times from the track!!!
- 373 gears
- Hooker LTs
- Next mod?
- Mitsubishi logo on Opti
- 97' T/A Stock w/ Supercharger
- 350hp rwhp on motor..then spray 75 --is 11 second possible?
- starting problems.
- need help!!!
- anvice for first time nitrous user...
- what is up with my car
- Fuel Pressure issues
- 355 runs .. but feels weak?
- what kind of exhaust?
- oil pump
- Going to track soon
- partnumber questions
- cam without heads
- LS1 vs. LT1
- Anyone with info on Clutches
- LT1 or LT4?
- Please Help, backfiring through INTAKE?
- Muffler switch with LT's and loudmouth
- radiator question for 383
- I need major help
- need a little tutoring from you veterans
- not charging????
- Help with these problems please
- window motor installation
- header questions
- After 14 months of waiting, Finally......
- 1LE elbow on ebay, need advice.
- LE2 vs Advanced Induction 190s
- gas? lt1
- Making weird sound..? HELP!!!
- cc306 track and dyno #s
- building stroker few??s
- So I Removed My Cat And Umm .... Wow....
- How far does your M6 shifter move?
- PO 0171 and 0174
- Reccomend a good manal for LT1 fuel injection
- Bronze dist gear with XFI cam in LT1?
- Does anyone have a picture of a silver LT1 Z28 with chrome snowflakes?
- Ignition Module????
- Info about the "Dynaspark Gen III"
- I must be seeing things...
- LT4 part numbers?
- whats the deal, optispark
- Parts needed for cam swap?
- Gm 847?
- motor mounts
- i dont know what to do
- le3 h/c package
- Wheel Backspacing
- Coil On Plug
- how do i wire a manual fan switch??
- what all does my buddy need to swap a ls2 into his 94 camaro??
- Vig. stall problem
- valve covers?!
- Street Twin users in here please!
- Injectors bleeding down
- Gu6
- Flywheel
- Convince me I need a Stock LT1!
- Convince me to buy longtubes
- LT4 Intake
- Speed Density?!?
- Z06 Maf
- Best plugs for almost stock LT1?
- Great thread on the new AFR heads
- The right way to break in an engine,new383
- a4 not shifting under wot
- head degree
- (LE2 package)LE2 Cam or GM847
- LT4 heads with a 355?
- help on a build?
- Whats next?
- ALL lt1 guys running duals.
- Bolt on record for LT1 fbody?
- X-pipe mod Qeustion
- Which Cam???
- le1 heads cam package
- Edelbrock suspension stuff????
- long tubes or not......
- 1.7 rockers with cam?
- Wierd problem...car stumbles/stalls and hesitates...
- Anyone know where to get a victor JR ready for the lt1?
- Did a tune up!
- Aluminum Drive Shaft
- Big Rockers + Stock Valve Covers = Doh!!!
- motor upgrade?
- Quick dumb question
- Anyone NOT running vent lines from back of head?
- ? about Pacesetter LT's
- i thought z28s were limited slip
- want to do a cutout myself
- 1993 Vats?
- is there such a thing as TOO much intake?
- Any ALT relo that keeps STOCK Powersteering?
- 95 Formula low end power problem
- its alive. but have a question
- Hard Race=Smoke?!
- i need help please!!!!!
- my cutout dilemma..
- What should I do with $400
- some of my progress pics
- best custom cams
- 406 CI build bore/stroke????
- LT1 Guys Serious Problem HELP
- Opti Help!!
- best price on headers
- cc503 cam requirements
- 350rwhp with a hotcam possible?
- What tooth count is the LT1 crank/cam sensors?
- What valve covers are you guys running?
- Question About Wheels....
- Heads
- head and cam guys check me out!!
- what should i dyno at the wheels
- k&n cai, or ebay intake with k&n filter?
- Intake elbow Torn!
- lt1 engine
- piston choice, 355
- Retarded Question of the Day
- Need Help Identifying Eagle H beams
- found my direction
- oil pan
- Forged crank?
- Compatability
- Reading tire tread
- Pinion seal leaking..questions
- 110 mph speedo in Z28
- my383 setup, what do you think
- impala upgrade
- ECU Flashing....
- LT1 edit and dyno baseline....
- what kind of stall should i get
- TNT wet kit
- Cam change w/o engine removal?
- auto/manual hp difference
- what kind of power increase will a dynotune give me
- 112 or 114 lsa?
- Summit brand radiator????
- bolt on LT1 guys with 4.10s inside.
- Need LT1 Head to Block help!
- Factory LT4 Camaro
- F*cing Weird Noise!!!!
- Speed limiter?
- 1/8 mile times
- help!!
- AIR pump removal question
- powersteering whine
- Help me choose a slick ?
- what to do with $2000
- Exhuast Question??
- accel opti
- Drag Radials or Slicks..
- 2 opti install questions (not a fix my miss thread)
- New times for close to stock car
- H/C LT1 results
- What type of airfoil?
- HP est....plz GUys
- Where can i buy SVO 30# injectors??
- Possibly a true dual aftermarket exhaust for 93-97(98-02)
- still having arcing problems!!
- Went to the track last night and got new best! LT1
- Is it possible to smack a valve with the Lt1
- Hooker LT's plug and wires?
- O2 sensors
- ADperformance lt1 383 rebuild
- Bad MSD
- hooker catback
- hooker catback
- PEPE HRP Track Times/Vids Sep 8th '06
- DYNO results are in !! I'm happy :)
- surging
- LTCC,DELTEQ, vs. New MSD opti....????
- 396 CI build single plain intake????
- Good LT1 Test Day!
- turbo or no turbo???
- NITROUS LT-1 guys what are ya runnin?
- can anyone make sense of this?
- my dyno graph(bolt-ons) 306 rwhp 340 rwtq
- Soon to be getting LT1 car.
- how accurate are the gauges in 97 camaro's?
- lt1edit or tunercat
- help my car want shift!!!!
- ███████Motor Mounts??███████
- auto to 6 speed swap
- 160 thermostat?
- Someone help me diagnose the car!! misfire/chug
- what are the 4 big alan bolts under my intake?
- what lifters?
- damn!!!!!!!!!!!!! i need a rebuild!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- valvespring suggestions for XFI cam?
- Need oil pump and pickup part numbers 94 LT1
- "shorty" spark plug
- Cam specs..
- 93 Vette needs yr support
- Please put me out of my misory.
- need help with this
- 4L60E conversion
- Anyone have True Duals w/BMR TrakPak?
- tunercat help please
- backfire after header install
- LT4 rollers in LT1
- Throttle body problem.
- New setup Need advice
- SRP pistons
- LT1 hybrid exhaust question
- Le3
- Oil Pressure?
- need estimates from others
- Long Block deal, what you think?
- 96 Caprice won't start (kinda long, but please help!!)
- borla pro xs
- How many miles did you have when you got your motor rebuilt?
- SuperVic thoughts: FI vs Carb
- LT4 heads
- Help!
- madz28 tune problems
- YSI On LT1
- Summit Opti spark sucks
- help?
- Car cant go past 5000rpm
- what mods?
- what gauges?
- pcm4less
- ignition: new opti today! Wires?
- Either of these worth it?
- Stroker Kits
- please go look at this
- ASM Monoblade on a SR 396
- 1/4 Mile Times in the 12's
- Exhaust Sounds
- HID H4 Bi-Xenon for the LT1 WS6, PICS
- fuel pump???????????
- GM847 cam
- rims
- how much power
- compression?
- oil dipstick problem
- i have a dillema, which LT1 is the better buy?
- has anyone else had this problem????
- dyno tomarow
- Alternator Relo Question.
- 180 amp alt.
- Which Oil Filter?
