View Full Version : LT1-LT4 Modifications
  1. What should my oil psi be?
  2. Gas fumes wont quit!
  3. hp gain ??
  4. Safe or Not safe AFR hydra rev kit
  5. just thought that i should post this up
  6. Walbro pump fitmennt
  7. Wire Mod
  8. wierd..
  9. Adjusting rockers-valves??
  10. Dynosim advanced
  11. V6 for LT1 SWAP
  12. mods and high dyno numbers
  13. oil
  14. Will These Fit?
  15. Turbo application
  16. Has anyone tried the accel opti yet??
  17. carburated crate motor?
  18. Fuel Pump Fuse
  19. Problem at 5200 rpm
  20. why wont she shift?????
  21. What is the proper intake manifold leak cure or method??
  22. how to swithc out pcm's
  23. best build for LT1???
  24. My Pacesetter y pipe is touching one of the brake lines
  25. valvetrain question (pushrods)
  26. Wow, what a pain
  27. Maf?
  28. FOG lights
  29. Finnaly after 2 years of being down and out !! shes alive
  30. My track times
  31. Xtreme Blazer w/LT1...need advice
  32. New AI H/C 355 Lives, but Pig Rich
  33. Cam=Slower low end torque?
  34. ? about valve covers and pcv system
  35. ABS Inop after longtube install
  36. Best ECU for LTx?
  37. best y-pipe for jet hot LT's
  38. Wierd pops from rear hatch/suspension
  39. Dynoed my 383
  40. Can ABS be disabled by tuning?
  41. Change an LT1 from a Impala
  42. Another questions about after market heads...
  43. hot weather problems
  44. cant anybody explain this optis**t
  45. Turn Signal question
  46. Gears....
  47. LT1 OBDII Tunercats
  48. Why cant I just Delete my ac compressor without adding a pully?
  49. oil woooows
  50. 87-90 iroc z ?
  51. Wrecked the TA
  52. Ever Seen One Of These Intakes
  53. LT1 purchase advice
  54. injector size??
  55. Lt1 Intake
  56. Needed: 94-95 LT1 Vette or Ram Air TA Bin File needed
  57. Boosted LT1 ????'s
  58. Anyone here know a thing or two about T/A headlight adjustment?
  59. a4 to t56 conversion
  60. LT1 Wiring Help!!
  61. Do I need to replace my wires/optispark?
  62. 110* or 90* Elbow?
  63. Need help with random misfiring
  64. 383 running rich
  65. here is my problem
  66. Having problems starting new motor.
  67. 315s on a '93
  68. The good news and the bad news.
  69. removing intake
  70. Removing cat
  71. lt4 module
  72. LE2 Dyno. What's Wrong??
  73. Tuning help
  74. power results from headers
  75. lt1 longtube header question
  76. Yet ANOTHER header thread!inside please!
  77. Opti Going Bad?
  78. Dyno Tuning around Northwest Ohio...
  79. turbo cam ?s
  80. were to buy fiber glass hoods?
  81. Nice to meet you, opinions needed
  82. Front mounted Turbo or Rear Mounted
  83. Next mod?
  84. What do you guys think? 12.9xs?
  85. finally got my dyno numbers (dissapointed)
  86. what does this mean
  87. 700r swap
  88. Can't read codes any ideas?
  89. Having access to a lift is sooooo nice!
  90. HELP w/Pushrod length
  91. lt1 headers
  92. 93 computer redline
  93. after pacesetter instalation?
  94. cam question
  95. can a 96+ steering column fit a 94
  96. how does the fuse box work, im confused
  97. nitrous ????????
  98. Header and emissions help...
  99. Missing out problem need help!!!
  100. New pics of my LT1!
  101. LT1 Plug Change Help
  102. radar systems
  103. Rounded vale stem tip...Do I need to yank the head?
  104. how would i fare against this?
  105. Pushrods too long? Picture inside........
  106. i need a bigger cam
  107. Want to hit the 12's with this mod. Need your opinions
  108. Starting Problem
  109. Checking interest: Z28 200mph Overlay with Speedo Corrector Kit
  110. Delteq/LTCC and big cam..WTF!
  111. got my baby out tonight..finally
  112. Sibling Rivalry.
  113. Help with DTC PO300 code
  114. Destroked LT1
  115. whats wrong with my Formula?
  116. Starting issue question
  117. leak wont seal!!
  118. Is nitrous good for me and car
  119. ***Urgent*** help plz. Old starter has 9 teeth new has 12...
  120. Best cam for a 120k Stock motor
  121. Any difference in elbow's for 93-97 LT1 Camaro's?
  122. Questions on cam experience
  123. i think im sad
  124. Sb1:
  125. quick question
  126. weird shit
  127. Crank sensor problem
  128. Optispark problems inside!!!
  129. AZM Monoblade question?
  130. Any dragstrip numbers with a HOT CAM and stock heads?
  131. opinions inside please
  132. Noob here with a newb question
  133. Direct Port Nitrous Users???
  134. Small part, big problem. Knock Sensor plug is missing. Help.
  135. Timing and Cam????
  136. What are some signs/symptoms of your opti about to go out?
  137. lt1 mods
  138. SLP exhaust question
  139. 1LE elbow
  140. machine work
  141. headers for lt1 ?
  142. Electric water pumps
  143. whats the deal with steering wheels, need one and dont know about um
  144. Video of roots blower setup on F-Body
  145. LT-1 cutting at 5000 rpm!!??
  146. dyno - 1/4 mile sadness
  147. Good or Bad DYNO #?? And E.T prediction??
  148. Fuel pressure
  149. SLP Loudmouth 2
  150. Would it hurt to remove my condensor and lines? But leave the compressor?
  151. Headlight upgrade.......
  152. piston rings
  153. Good Head/Cam Combo
  154. Please help with my lt1!
  155. Mono bladeThrottle bodoy
  156. Mono bladeThrottle bodoy
  157. What Should i Get next
  158. i hate punk ass kids!my poor baby!!!
  159. I HATE my Lt1!
  160. Group buys on...about anything
  161. 97 SS T-56 Tranny Removal
  162. cams
  163. medim quasar blue metallic TA*Pics Inside*
  164. Camaro's running rough
  165. Best way to do a huge burnout M6?
  166. Edelbrock exhaust...
  167. cam brand/type/specs
  168. street/strip car ?'s
  169. Size (Stall)??
  170. What kind of gas mileage would I get with this setup?
  171. How much for an LT4 HCC
  172. Motor NOISE
  173. wont start help??
  174. whats is this sound?
  175. lt1 engine bay pics
  176. Are my fans bad?
  177. Get ur done! New dyno #'s
  178. Still overheating problems....
  179. ET Performance LT1 Heads (PICS)
  180. need pics of your intakes, not the manifold but the actual intake tube
  181. finally finished with alt. mounting *pics inside*
  182. LT header install?
  183. running car with out thermastat
  184. LT1 runs rough in Closed Loop
  185. Say Hello to my new car!
  186. 11/32 Valve with Gen III Spring
  187. arcing problem
  188. What will the order of procedure be for this quasi-massive undertaking?
  189. HELP PLEASE!!!!!! water pump problem
  190. let me know what you think
  191. stumbles at high rpm's
  192. best intake for single plain?
  193. Spy photos: Single Plane, NX, Crank trigger,Low profile dist>
  194. LT-1 in a street rod, hot cam worth it?
  195. H/C plan. thoughts?
  196. piston rings
  197. Choice in new coil?
  198. Which springs/locks/retainers with the CC306???
  199. README: Change with posting F/S threads in this forum...
  200. Up top
  201. Weight of stock hood?
  202. engine woes....
  203. swap or buy?
  204. brakes!!!!!!!!!!!
  205. Harmonic Balancer Recommendation
  206. Help with injector selection LT-1
  207. Collapsed lifters...
  208. 100* Elbow and 90MM Accufab Tb For Sale!!
  209. swaybar
  210. Help please
  211. valve cover spacers
  212. Jet Hots
  213. long tube question
  214. Why build/keep an LT1?
  215. Cat Back Question
  216. Pics of stainless steel Ram Air inserts, chrome filler bird & Strano front 35mm
  217. Failed Emissions - Need Help
  218. Does this work - or is it a scam? Hypertech programmer?
  219. fuel filter location?
  220. Problems with 95 LT1 T/A
  221. Any trick on changing spark plug wires LT1
  222. do you know.............
  223. Radiator & Low Coolant light PROBLEM!!
  224. Are these any good.
  225. Tran am LT1 O2 sensor questions
  226. How much Power should I have?? What Gears??
  227. Le2
  228. who does single plane EFI intakes
  229. Aluminum Driveshaft For Sale
  230. Steering Wheel Adaptation?
  231. can you use a 400 sbc block with an LT1 topend
  232. 1st Time @ Strip
  233. CC306 & springs question ---->
  234. AC compressor, Quick Question?
  235. camaro death
  236. OMG people are soo funny!
  237. biggest lt1 cam
  238. How do Cam bushings work?
  239. Little hesitation...I smell a problem afoot!
  240. Low Res Code... Once again..
  241. TSP True Duals
  242. Single Plain w/ IntakeElbows.com set-up
  243. Washers for head bolts???
  244. F/S: Aftermarket LT1 Parts
  245. Lt5?
  246. rearend question
  247. lt1 weight?
  248. Meanest looking LT1 Z28 Hood?
  249. Having an issue with Ford Injectors
  250. ABS INOP Light..
