View Full Version : LT1-LT4 Modifications
- Anyone ever see a striping kit for the Ultra Z hood?
- can anyone tell me the order for lt1 (main caps)..?
- pushrod length for hotcam & 1.6rrs
- Help pls respond
- LT1 Edit Noob (HELP)
- Backfiring Revisited
- true duals question
- What times do your 383 stroker motors run? NOS or no NOS
- 12.1 at 111 MPH last week thru manifolds and flowmaster
- Need Help! ABS and Air Bag lights are on.
- anyone with a spare 97 lt1 computer
- catalytic converter question?????????
- water pump question
- cost of 355
- 355, whitch cam??
- wont upshift @ WOT 2-3, 3-4
- hot cam ? shift point ?
- Steering linkage wont budge.
- i converted my LT1 front end to a LS1 front end
- trick flow heads and what cam?
- Fuel req
- my LT1 is out
- weight of a bare lt1 block
- how fast bolt ons with DOT drag tires
- Need help radiator leak
- LS1 injectors to LT1
- Help
- Moroso Cold Air Intake
- LT1 gearing?
- Need some SJM Line lock/ABS delete set-up pics
- Gear Info..please respond!!!!
- 1996 Trans Am front end conversion? is it possible?
- help with argument please
- lol @ my new "screw on"
- What kind of power should I expect from...SC lt1
- what stall with hot cam?
- help on trick flow heds
- need help with lt1 water pump
- Fuel line mod write up (stock lines)
- LE2 385 Dyno numbers, 466hp/449tq
- Installing Headers
- cam? or not?
- napa OEM gaskets
- Clutch Master Cylinder
- Running Bad after Warm Up!
- mounts
- Any advice for LT1 coolant flush?
- Egr
- Corsa with LT's
- Pacesetters
- Throttle Body?
- wats the next best bolt on
- fuel pump fuse
- TunerCat support team ROCKS!
- Fluidampr fit
- Looking for all LT1 Head Porters
- X-pipe for lt1
- wouldn't it be nice if....
- LT1 Swap
- car feels so slow..
- Who has a Th350?
- 03 Cobra vs 97 Formula
- How much NOS can these pistons take? *Pic*
- Kooks Headers and 3 Inch X Pipe
- who has installed a new timing chain? this is pissing me off
- Pics of my car finally
- lt1 throttle body???
- Opti help!
- needing a tune
- tire size
- Difference between optisparks in earlier and later lt1's
- m6 owners
- Service light with radiator fan.
- New track times update!
- 987 valve spring help!!!!
- Vibration issue... I need some input...
- header questions
- Le1/cc306
- Stock Bottom End
- cc305 vs cc503
- coolant temp sensor
- small pacesetter long tube question
- whats the top 5 fastest stock bottomend cars please list .
- How do you wire a tachometer in a 97 SS.
- What goes here/is this?
- I want to put LT1 heads on a old school 350.
- Mod for the money
- Is this to big of a cam?
- super comp LT's touching
- car smokes at idle
- Another Cam Discussion
- cut outs making exhaust quiet
- O2 Removal
- hp est. plz
- ABS Delete
- heads needed!!!!!!!!!!!
- need help badly
- ALMOST COMPLETE..... yea right
- Need a new cam
- LT1 LS1 body differences
- My formy with the exhaust mocked up to headers!
- Possible opti Problem Please Help!
- AC delco rapidfire plugs
- Plugs for Bolt on LT1?
- White smoke?
- Video -- Running at Mooresville
- ANYBODY HAVE TRAck TIMES WITH THE CC503
- Z28 Fiberglass hood
- running low 12s on the motor
- Alt. Relocation Kit
- Cooling Problem! Need help fast!
- Average Weight
- 1993 o2 questions
- what are the best suspension parts i can buy for traction?
- How do you change Pass. Side O2?
- LT1 supercharger kit for sale
- P1351 Code Help Needed! Thanks
- 12.1 at 111 MPH today
- Miss under load when the car is cold
- Texas Speed Rumbler exhaust plz help
- road hop problem
- Budget Build Lt1 Help Me Out!
- lt1 dominates LS1
- Rare parts list:Aftermarket parst no longer made for our cars
- Rocker Arm tightening help needed!
- what is this??? pics
- miss/stumble at part throttle and cruising speeds.
- I need some help,where does this go?
- i ran a 14.7 @ 97mph
- mph differences
- car has demons need exorsized
- 1995 Pontiac Firehawk Specs??
- Quick question about AIR Injection
- grinding or scraping
- New best! 7.58 @ 90MPH
- Just went for the 1st pass in the beater with a 100 wet shot :)
- cc306 problems
- How hard is it to change the plugs w/pacesetter LTs?
- Looking at Pacesetter LT w/Y-pipe. On lowered car w/Umi tunnel mount TA.
- radiatpr overflow relocation?
- Car wont start!
- magnaflow exhaust
- Pics of my TA after some paint work!
- help with LS1 air intake on LT1 (Pics?)
- Valve Spring Question
- Supercharger guys in here plz...
- Where is the schraeder valve on the fuel rail located on my 93 LT1?
- gear help!!!!!!!!!!!!
- loudmouth 1
- Help with headers
- Car is DONE!
- 1.6:1 rockers: losing top-end power?
- Miss when cold
- 383 finally done, ut oh!
- Gauges
- Fans not coming on ? :( Help !!!
- How much will the LT4 HC pull to?
- need help pleaseee
- LT1 re build kit?
- little K&N filters
- Exhaust Setups
- Finally nice out... got new pics for you guys.
- ordered the parts
- solid motor monuts?
- Raptor shift light vs. Gtech
- throttle sticking
- I don't trust ebay...
- Some help please?
- 2nd time broken down. Car will not start even w/ spark
- 10 BOlt rear end cover
- Need Spark Plug Reccomendation
- Are 215cc heads too big for a 355?
- Taking some weight out of EPPs LT1 project car
- Turn key, nothing happens
- wrapping up my ls1 frontend conversion
- Which o2 sim?
- Looking for some more power
- LT1 swap into mustang help
- I have 95 z28 and need help please
- LT4 Cam VS. CC503
- Need part numbers and engine shop
- lt1 conversion question
- Oil Pressure Concerns (again)
- Help.. i think some thing is way wrong...
- another header install ?
- extending true duals
- New set up, and a new look
- Curious on highest Lt1 mileage.
- ring and pinion interchangability?
- supercharger question
- How much Compression can I run LT1?
- car running rich
- What Do Yall Think Of This???
- poly trans mounts
- It Dont Run...
- cam help
- why would he do that?
- fuel filter
- What cam should i go with?
- Emissions question for ODBI
- RHS 235 heads and Super Vic progress pics
- Low Track, and Brake light flashing?
- Buying a 94 - can I verify the PCM is correct to the VIN?
- de greased my engine
- why is my car so slow??
- LT1 fuel regulator
- fuel pump
- Speed Density Conversion ?!
- car cutting out
- need radiator
- dragging starter, lossing volts when starting
- Cc305 Cam For Sale... Cheap!!!
- time for an opti :-(
- lt4 hotcam + emissions = ?
- LT Header Install
- Built Lt1/4l60e For Sale
- Going Vented... the opti
- Blocked EGR now car is smoking?
- formula ws6 vert.
- Lt1 torque monster...no horspower though.
- wanted o2 sims
- Blown LT1 dyno results...
- Datamaster tuners come in
- Custom cam info?
- hydra-rev kit
- code 34- Map sensor voltage low
- Cc306
- Any test pipes out there?
- LT1 in a 1972 Chevelle with Pics
- stock oil pump limits
- Question???
- Best way to get streetable 400-450HP LT1 engine.
- Is this good 1/8 times
- Ignition Box = No Start
- got tune
- what valve seals?
- any intrest turbo kit?
- JUST IN LE2 Dyno #'s....
- Fixing Up My 94 Camaro
- Shift lights general q's
- LT4 Knock Module
- Its Alive!!!!!! Mwa Ha Ha Ha Haaa!!!
- Lingenfelter CAI - LPE
- Where to buy this Elbow??
- MBA shifter knob, with tail or w/o?
- longtube header install
- Deleteting egr System 96 Z28 Lt1
- LT1 OBD2 scan software
- Wiring Harness question
- Can VSS (circuit) be bad, but speedo still work?
