View Full Version : LT1-LT4 Modifications
  1. 93 to 94 gauges
  2. Which Cam and Tune?
  3. help help
  4. Slp dual cat shortys help!!!
  5. Does this sound like a bad torque converter?
  6. Idle problems
  7. 97+ gauge cluster swap
  8. "Cadillac Cam"?
  9. Minimum cam dowel pin length?
  10. Mcleod Clutch
  11. Adjustable Master
  12. nitrous question?
  13. Ported TB or MAF???
  14. 355 or 383
  15. HELP oil lines
  16. me vs eclipse
  17. if your car wont start, start here
  18. Fans will not kick on at any temp, need help to diagnose?
  19. LT1 Exhaust
  20. Stock internal 96k+ mile LT1 goes 11.67
  21. real quick question....how much is stock fuel pressure?
  22. Help HOT
  23. Will this spring hold cc306 lift??
  24. doing rebuild! 355, 383, 396?
  25. looking for a guide for headers install
  26. looking for a guide for headers install
  27. BBK mid headers? Anyone?
  28. Which cam?? for 3.73 and 3000 stall?
  29. Help 383 Carbed In 97 Ws6
  30. 383 build questions
  31. Ignition wiring question, need help
  32. Couple install price ?'s
  33. Give me an idea of the power for these mods?
  34. 95 corvette exhaust
  35. Car will not start after rain, Opti?
  36. what times with 230/236 cc
  37. Gas Mileage improvement?
  38. Hotcam/CC305 owners, what times are you running?
  39. Thoughts on Mac cat-back
  40. How difficult to replace the "Optispark" on a 95?
  41. wanting to upgrade from lt4 intake to carb intake help
  42. LT1 to LS1 swap ??????
  43. cheap horsepower
  44. 306 cam And check these valvertrain????
  45. What Mod Next?
  46. Valve Spring/ Retainers
  47. lt1 oil pump & head gasket????
  48. Hp Estimate
  49. HPE 383 Shortblock
  50. Noisy Valvetrain
  51. Taste Test...
  52. What cam should I run
  53. Anyone running a CC503 on a 114LSA?
  54. 1990 corvette
  55. GM847 vs. cc305 for a daily driver
  56. Pacesetter Header Questions
  57. Catalytic Converters
  58. ____3000 stall how is it with 306 & 3.73??___
  59. 355 6 Speed goes 10.49 @ 130.4 NA
  60. finally got the bottle in the car and got a few pics for ya guys on my 93 LT
  61. throttle body airfoil
  62. smog pump lines were do they go
  63. LT1 with no spark at coil
  64. What is the RPM rang for CC306?
  65. starter issues
  66. Any tips/guides for cleaning the MAF?
  67. How the hell do i tell?
  68. Header/Y-Pipe Combination Question for '97
  69. Header/Y-Pipe Combination Question
  70. Cooling a high HP 383 LT1
  71. Max lift on 986-16 valve springs
  72. Muffler...
  73. 30# Ford SVO red tops
  74. lt header question?
  75. Which cam for Ported LT1 heads??
  76. what couldi get
  77. Will a clogged cat prevent a car from starting?
  78. Someone lend a hand
  79. Any HPE guys in here???? Rick???
  80. lt1 block interneals = sbc internals? yes no?
  81. Vibration from exhaust. Any help?
  82. How hard to get 400rwhp from LT4?
  83. coil wire
  84. tunning
  85. what should i expect?
  86. Recommendatons on Y-pipe
  87. header and exaust install parts?
  88. what kind of numbers should i see with this cam?
  89. Post pics of your longtubes and y-pipes please!
  90. so i raced an 05 GT...
  91. Help Needed LT4 Valves
  92. Compression
  93. Cam Question
  94. CAI Adds How Much Power?
  95. Some updated pics of my project
  96. ??recommended valve springs
  97. Mod Update
  98. almost finished my LT1 rebuild...
  99. 355" LT1 goes 9's!
  100. flow numbers on a stock lt1 head??????????
  101. Looking for 383 396 LT1 Stroker Info
  102. rough idle backfiring after motor work
  103. 1994 formula six speed for sale,$2000 firm
  104. under hood pics
  105. Best heads and cam
  106. Best heads and cam setup
  107. LT1 headers problem
  108. Carbed 383
  109. LCA's worth it?
  110. Dynaspark no longer available at DTE
  111. underdrive pulleys
  112. noise when launching
  113. zz9 cam
  114. optispark
  115. Pacesetter Mid-Tubes Question
  116. Long Tubes or Converter ???
  117. Post Cam/Valvetrain Specs
  118. LTs for a 96-97 on a 94?
  119. Weight of LT1 Motor
  120. Hotcam F/s
  121. Short or mid or long tube headers?
  122. bog issue
  123. How is the sound for Flowtech muffler????
  124. Biggest cam for daily driver??????????
  125. Shortys or Mid length headers - '97 LT1 Ram Air
  126. Anyone with the cc305
  127. lt1 questions
  128. car surging
  129. Tsp duals on LT1s
  130. Catted Y- Pipe
  131. Work in progress 56K users beware!
  132. SLP LT headers buy it or don't buy it?
  133. strokin it
  134. Recalls?
  135. Pics of the HPC coated Y-pipe
  136. What do I need for 12's?
  137. Need Help Tuning! 94 Procharged Z-28
  138. supra vs TA
  139. cam question
  140. Plans and questions
  141. 1500 - 1800 rpm Stumble
  142. Hooker Aerochamber? Or Full Hooker Catback?
  143. Pacesetter Midtubes fit with stock y-pipe?
  144. how much horse power can i expect
  145. question involving intake removal
  146. I need an Estimate from you guys
  147. Neeeeeeeeed Your Heeeeeeeeeeelp!!!!
  148. 10s on stock bottom end?
  149. LT1 ss
  150. Best Mod?
  151. LE3 LE3 <-- its the rage right?
  152. radiator overflow lines?
  153. quick: intake inlet elbow & airfoil
  154. is there a forumula for LT1s hitting 350 whp
  155. Custom Grind Cams For LT1?
  156. lt4 hot cam kit
  157. Air pump for engine?!?!?!
  158. What's the fastest you've gone?
  159. OK I found out whats wrong with my car but how to fix??? EGR
  160. Brake Kits
  161. Help! I need to beat a supercharged 99 Vette!
  162. got a couple questions im new
  163. Nos
  164. mods for my 95 ta
  165. Swap A4 to M6
  166. What should I get from these mods @ 1/4?
  167. pistions at 30 pounds
  168. crane valve springs
  169. Can someone explain?
  170. what do i need for lt4 hotcam?
  171. LT1 Newbie....
  172. LT4 Knock Module
  173. Many LT1 Hypertech Power Programmers in stock $275.00 ea
  174. whats wrong??
  175. dash swap
  176. Its been beat to death.. but still
  177. Pacesetter headers
  178. headers choices
  179. Power Programmer Plus for '95 LT-1
  180. Comp "R" lifters yay or nay
  181. Changed out my comp R's to Morels....What do I do about Pushrods????
  182. Stall
  183. Rocker Arms
  184. What is the diffrent between internal balance and external balance ?
  185. meziere
  186. 190,000, rebuilding question
  187. different lt1 intakes
  188. cam
  189. Head studs on a '94 LT Formula
  190. will no rear o2s plugged in cause bad missing??
  191. A cool cruiser for you LT1 guys - LT1 Jag XJ6
  192. cant find the thread
  193. Cam research/question
  194. Questions about running a single plane intake with EFI
  195. Pics of Any 96-97 WS6's???
  196. running with open headers
  197. camshaft media
  198. Afr heads
  199. Another stumbling block with the Pacesetter install
  200. 52MM Throttle Body- Worth $$$?
  201. Big Problem
  202. white faced gauges
  203. Magnamouth
  204. 90K on engine, LE1 or LE2 still possible?
  205. 4.10 Gears good, bad?
  206. Block off plates
  207. Some LT1 problems resolved
  208. Replacing Opti-Spark, Cap & Rotor - Advice?
  209. SB2.2 progrees update, pics..fuel cell, NX,
  210. GM847 vs LT4 HotCam
  211. 2 - Obd II Code
  212. New to site, new to F-body,...yeah...just...new!
  213. 1996 WS.6 w/ sportline springs (pics inside)
  214. Getting head (another head thread)
  215. afrs or lloyd elliots
  216. running rich
  217. 94 formula project car for sale
  218. Difference in Nitrous kits
  219. O2 Extensions
  220. Who Converts to Rev. flow cooling?
  221. lt1 starter replacement
  222. car is still sputtering need help
  223. Newbie here
  224. LT1 bogging in high RPMS
  225. hp gain on lt1 with electronic water pump ?
  226. LT1 Cubes?
  227. Balancing Question
  228. aftermarket coils, which is the best???
  229. Sugg. springs on a LT1
  230. Loudmouth/lt1
  231. Pics of modified stock LT1 maf
  232. Largest cam to past smog in Cali??
  233. stock replacement lifters and spring pressure
  234. bosch 13111's LT1
  235. Lt4 compression ratio
  236. Bolt-on's & NOS or sts turbo...
  237. A4 Z vs M5 'Stang?????????
  238. Oil sending unit location?
  239. bought me a lil bottle today heheh, goin to the strip the 13th :-)
  240. underdrive pulley problem
  241. took new motor pics today
  242. Shorties or mids?
  243. loss of power?????
  244. GM847 cam
  245. cc305 and 1:5 or 1:6 rockers?
  246. 300Rwhp?
  247. LT4 Hot Cam
  248. LT headers will they fit?
  249. routing sprak plug wires on a 93
  250. big problem please help
