View Full Version : LT1-LT4 Modifications
- Thinking about a custom grind
- Mr. Gasket 160 thermostat over hypertech?
- Borla Exhaust
- Poly Trans Mount
- Radiator Rollercoaster
- TDC posistion for timing chain and cam.
- underdrive pulley question
- KM..whats it take for it to sense knock?
- losing power
- O2 Sensors and racing fuel
- Fuel Issues. FPR/Pump. Both?
- whats the diff between vented and nonvented opti's
- Why Me?
- 4L60E trans
- Horsepower TV cam swap this weekend?
- This company sells 52-58 mm throttle bodies NEW for $160!!
- Kooks Lt's true duals and Spintech pro street mufflers!
- 97 engine swap in 95
- Fuel Pump: OE or Aftermarket
- FS: Ported heads, LT headers, plus more
- did i make the right decision???
- CHECK THIS ONE out. what do you think?
- WTB: 1997 LT1 Pontiac digital gauge cluster
- Nitros ?
- 2001 ws6 rearend in my 97 ta?????
- Sim. and Diff. between LT1 and LS1
- Valve train question??
- electric fuel pressure gauge
- mission accomplished
- my car died,need help ASAP
- killing optis
- Which exhaust for this setup...??
- Need help with mods and time
- Magnaflow F@&%ing SUCKS - calling all 96-97 lT1 owners
- lt5 wtf u ever heard of one
- 96 WS6 Low RPM Misfire Part 3...
- spark advance jumping around at idle, is this right?
- Who does the best LT1 head work????
- wire melting everything please help
- How do you know if your o2 sensors are bad?
- I think IAC is going out, what would that do?
- Should I go with a different Cam 584/579
- 97 with TH-350 trans
- Bolts on back of heads???
- 94 LT1 overheating help
- cam on higher milage lt1
- please help. i cant get it right!!
- custom fuel system
- Compression ratio?
- lt1 intake on older style heads
- Better Brakes???
- What to do next?
- new here.
- Need Answers!!! 95 Ta
- Bulb help
- Did the '94 Caprice have an LT1 option?
- Some questions before my build
- need ur suggestions
- Help - Should I buy the LT1?
- Stalling help
- streetability of a carb-style intake?
- 383 average with stock fully ported heads and intake and small cam?
- 602rwhp 780rwtq Sae!
- LT1 piston volume
- Tired of the noise.
- Engine Troubles..
- Lt1 Opti Delete?
- Which one Stroker or Procharger?
- help...spring and rocker arm install
- lt1 vs ls1 question
- power steering question
- so where can i post the what would posts
- hot cam and lt's install
- 383 build up questions
- Optimal shift points
- LE1 Heads
- 93 z28 vs 2000z28 what would happen
- bought a used motor, and it came with aftermarket parts
- LongTubes JetHot Or Hooker?
- Alt's?
- Tightening the banjo bolts in back of the heads.
- Turbo system
- 383 NA LT1 cam question
- MSD Opti install question
- Lt1 Turbo Cams ---
- How loud?
- alternator and valve cover
- HELP! pull motor?
- Bogging
- compresion testing
- Modified floors for true duals
- Should I make it happen?
- will she run?
- 383 Kit
- Engine Info
- Help with camaro purchase
- plastic fog light bolts, where can i get em'?
- my 95 camaro is for sale
- pics of new 383. (almost done)
- customer's LT1
- LT1 Direct Port Nitrous
- LT1 Dead..
- How to tell if I have a higher stall??
- highest hp from lt4 hotcam with a4--
- 383 pistons?
- cam question
- best way to build power
- Accel OPTISPARK..a look inside the unit
- Just sold my 95z
- Quick Part Question
- Exhuast cut outs!! need help
- any guesses
- quick question pacesetter LT's + Hooker Catback
- New fuel pump problem??
- Is this starter ok???
- Here is a vid comp, for everyone that wanted to see my car.
- LT1 in 69 Camaro
- WTF?? Crazy Wire Problems... Starter? BCM? TDR?
- Heads without cam
- please HELP with 170 deg. thermostat
- Super Chevy San Antonio
- I Need Help Before 10am With What Muffler I Should Get
- removed cat from 93 camaro
- how do you know if you have a 1le?
- Any LT1/4 owners running a Gen 7 in here??
- a4 shifters
- cc306 with stock heads
- How much is my car worth???
- LT1's dont like water
- Predicted rwhp/tq with a cc305 setup?
- is this for real?
- 3 inch exhaust or 2.5 inch
- Ai Trickflow head & Blower cam
- who really spends 400+ on an exhuast
- fans dont work
- Is this worth it?
- mid-leath headers
- LT4 Starter or LT1 starter??????????
- LT1 spark plug tool
- LT1 Top End Question
- Any Ideas - my car wont run
- anyone running a le2 383 stroker setup?
- Headers
- NEED HELP! problem Tunning or Transmission????
- 96 formula carburated?
- Car acting up?
- when you guys do a auto to 6 spd swap
- diagnosis tools and tuning, what are you using?
- Car wont start, save me.
- Damnit?? Anyone know where to get those LT1 oil caps?
- Selling my bird :(
- Dynaspark Yes Or No?? Help!!!!!
- 94z opti has air hoses or vents?
- Borla mouth
- 'Hissing' sound from new fuel pump, normal?
- Calling Jason Short
- What Hood For My 396? Pictures and Poll Inside.
- GMHTP Shootout
- Trick Flow heads
- Delete Cat?
- My next mod?
- Stock fuel pump
- Question on Grounds for the car???
- LS1 into a LT1 car
- Times from the track!!!
- 373 gears
- Hooker LTs
- Next mod?
- Mitsubishi logo on Opti
- 97' T/A Stock w/ Supercharger
- 350hp rwhp on motor..then spray 75 --is 11 second possible?
- starting problems.
- need help!!!
- anvice for first time nitrous user...
- what is up with my car
- Fuel Pressure issues
- 355 runs .. but feels weak?
- what kind of exhaust?
- oil pump
- Going to track soon
- partnumber questions
- cam without heads
- LS1 vs. LT1
- Anyone with info on Clutches
- LT1 or LT4?
- Please Help, backfiring through INTAKE?
- Muffler switch with LT's and loudmouth
- radiator question for 383
- I need major help
- need a little tutoring from you veterans
- not charging????
- Help with these problems please
- window motor installation
- header questions
- After 14 months of waiting, Finally......
- 1LE elbow on ebay, need advice.
- LE2 vs Advanced Induction 190s
- gas? lt1
- Making weird sound..? HELP!!!
- cc306 track and dyno #s
- building stroker few??s
- So I Removed My Cat And Umm .... Wow....
- How far does your M6 shifter move?
- PO 0171 and 0174
- Reccomend a good manal for LT1 fuel injection
- Bronze dist gear with XFI cam in LT1?
- Does anyone have a picture of a silver LT1 Z28 with chrome snowflakes?
- Ignition Module????
- Info about the "Dynaspark Gen III"
- I must be seeing things...
- LT4 part numbers?
- whats the deal, optispark
- Parts needed for cam swap?
- Gm 847?
- motor mounts
- i dont know what to do
- le3 h/c package
- Wheel Backspacing
- Coil On Plug
- how do i wire a manual fan switch??
- what all does my buddy need to swap a ls2 into his 94 camaro??
- Vig. stall problem
- valve covers?!
- Street Twin users in here please!
- Injectors bleeding down
- Gu6
- Flywheel
- Convince me I need a Stock LT1!
- Convince me to buy longtubes
- LT4 Intake
- Speed Density?!?
- Z06 Maf
- Best plugs for almost stock LT1?
- Great thread on the new AFR heads
- The right way to break in an engine,new383
- a4 not shifting under wot
- head degree
- (LE2 package)LE2 Cam or GM847
- LT4 heads with a 355?
- help on a build?
- Whats next?
- ALL lt1 guys running duals.
- Bolt on record for LT1 fbody?
- X-pipe mod Qeustion
- Which Cam???
- le1 heads cam package
- Edelbrock suspension stuff????
- long tubes or not......
- 1.7 rockers with cam?
