View Full Version : LT1-LT4 Modifications
- Which Cam???
- le1 heads cam package
- Edelbrock suspension stuff????
- long tubes or not......
- 1.7 rockers with cam?
- Wierd problem...car stumbles/stalls and hesitates...
- Anyone know where to get a victor JR ready for the lt1?
- Did a tune up!
- Aluminum Drive Shaft
- Big Rockers + Stock Valve Covers = Doh!!!
- motor upgrade?
- Quick dumb question
- Anyone NOT running vent lines from back of head?
- ? about Pacesetter LT's
- i thought z28s were limited slip
- want to do a cutout myself
- 1993 Vats?
- is there such a thing as TOO much intake?
- Any ALT relo that keeps STOCK Powersteering?
- 95 Formula low end power problem
- its alive. but have a question
- Hard Race=Smoke?!
- i need help please!!!!!
- my cutout dilemma..
- What should I do with $400
- some of my progress pics
- best custom cams
- 406 CI build bore/stroke????
- LT1 Guys Serious Problem HELP
- Opti Help!!
- best price on headers
- cc503 cam requirements
- 350rwhp with a hotcam possible?
- What tooth count is the LT1 crank/cam sensors?
- What valve covers are you guys running?
- Question About Wheels....
- Heads
- head and cam guys check me out!!
- what should i dyno at the wheels
- k&n cai, or ebay intake with k&n filter?
- Intake elbow Torn!
- lt1 engine
- piston choice, 355
- Retarded Question of the Day
- Need Help Identifying Eagle H beams
- found my direction
- oil pan
- Forged crank?
- Compatability
- Reading tire tread
- Pinion seal leaking..questions
- 110 mph speedo in Z28
- my383 setup, what do you think
- impala upgrade
- ECU Flashing....
- LT1 edit and dyno baseline....
- what kind of stall should i get
- TNT wet kit
- Cam change w/o engine removal?
- auto/manual hp difference
- what kind of power increase will a dynotune give me
- 112 or 114 lsa?
- Summit brand radiator????
- bolt on LT1 guys with 4.10s inside.
- Need LT1 Head to Block help!
- Factory LT4 Camaro
- F*cing Weird Noise!!!!
- Speed limiter?
- 1/8 mile times
- help!!
- AIR pump removal question
- powersteering whine
- Help me choose a slick ?
- what to do with $2000
- Exhuast Question??
- accel opti
- Drag Radials or Slicks..
- 2 opti install questions (not a fix my miss thread)
- New times for close to stock car
- H/C LT1 results
- What type of airfoil?
- HP est....plz GUys
- Where can i buy SVO 30# injectors??
- Possibly a true dual aftermarket exhaust for 93-97(98-02)
- still having arcing problems!!
- Went to the track last night and got new best! LT1
- Is it possible to smack a valve with the Lt1
- Hooker LT's plug and wires?
- O2 sensors
- ADperformance lt1 383 rebuild
- Bad MSD
- hooker catback
- hooker catback
- PEPE HRP Track Times/Vids Sep 8th '06
- DYNO results are in !! I'm happy :)
- surging
- LTCC,DELTEQ, vs. New MSD opti....????
- 396 CI build single plain intake????
- Good LT1 Test Day!
- turbo or no turbo???
- NITROUS LT-1 guys what are ya runnin?
- can anyone make sense of this?
- my dyno graph(bolt-ons) 306 rwhp 340 rwtq
- Soon to be getting LT1 car.
- how accurate are the gauges in 97 camaro's?
- lt1edit or tunercat
- help my car want shift!!!!
- ███████Motor Mounts??███████
- auto to 6 speed swap
- 160 thermostat?
- Someone help me diagnose the car!! misfire/chug
- what are the 4 big alan bolts under my intake?
- what lifters?
- damn!!!!!!!!!!!!! i need a rebuild!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- valvespring suggestions for XFI cam?
- Need oil pump and pickup part numbers 94 LT1
- "shorty" spark plug
- Cam specs..
- 93 Vette needs yr support
- Please put me out of my misory.
- need help with this
- 4L60E conversion
- Anyone have True Duals w/BMR TrakPak?
- tunercat help please
- backfire after header install
- LT4 rollers in LT1
- Throttle body problem.
- New setup Need advice
- SRP pistons
- LT1 hybrid exhaust question
- Le3
- Oil Pressure?
- need estimates from others
- Long Block deal, what you think?
- 96 Caprice won't start (kinda long, but please help!!)
- borla pro xs
- How many miles did you have when you got your motor rebuilt?
- SuperVic thoughts: FI vs Carb
- LT4 heads
- Help!
- madz28 tune problems
- YSI On LT1
- Summit Opti spark sucks
- help?
- Car cant go past 5000rpm
- what mods?
- what gauges?
- pcm4less
- ignition: new opti today! Wires?
- Either of these worth it?
- Stroker Kits
- please go look at this
- ASM Monoblade on a SR 396
- 1/4 Mile Times in the 12's
- Exhaust Sounds
- HID H4 Bi-Xenon for the LT1 WS6, PICS
- fuel pump???????????
- GM847 cam
- rims
- how much power
- compression?
- oil dipstick problem
- i have a dillema, which LT1 is the better buy?
- has anyone else had this problem????
- dyno tomarow
- Alternator Relo Question.
- 180 amp alt.
- Which Oil Filter?
- video from my dyno tune
- Msd ?
- Ticking valvetrain.
- 87' up 350 carbed intake
- another tb question
- New Stocker
- Video
- LT1 in the 12's
- ..help..long tubes and oil cooler housing issues.
- ported heads
- Random Miss Help?
- 94 TA rebuild
- Lt4 Conversion Or Supercharger???
- LT1 intake manifold
- Any Pics Of Lt1 Procharger???
- 45 Injectors???
- Machine Shop in Houston?
- nitrous friendly cam?
- Calling everyone with www.IntakeElbows.com
- I Have Some Questions About My Car...
- Elliot Portworks LE1, LE2, LE3 heads
- Slp Mfs
- True dual pics?
- arcing???
- heater hose
- V6 swap to LT1 or LS1????
- OEM shiftkit
- To put on ignition or not?
- Anyone running 'big' XFI cam on LT1?
- Radiator problem?
- No low RPM power
- MSD ignition help
- march underdrive pulley
- 3 speed people..simple question
- Rattling ?
- 355 or 383
- Lt1 fuel rail covers?
- For those of you in denial about what size the stock manifold bore size is inside
- Convince me I need long tube headers...
- Can't get engine out
- before u do this is it worth it?
- Cam Question
- OptiSpark Eliminator
- LT1 Start up Prob's
- HP Tuners needs to happen for the LT1
- Question about a 93 Z28
- fans/actr
- msd ignition stuff?
- Finished Door Panel pics for Project 8sec LT1
- Arizona Speed & Marine are 1st Class to deal with
- new to these cars
- LE2 help?
- Its Christmas!
- did i mess up my optispark timing
- 330hp/350tq
- 383,396 which one
- LT1 in a g body....... questions inside
- forged rotating assembly
- tranny tick?
- Shooting for a new best..
- heads, pistons, and cr??
- bad results bad bad!!
- bad oil leak
- Summit brand lt1 throttle body
- Glowing coil
- Comp Cam Pro Mags
- Any ideas?
- mods. for mileage
- LT4 Intake ????
- oil pressure gauge
- cold air intake
- Gen 7 DFI/Innovate LM-1 wide band/Accel DFI dual sync distributor
- Lowering springs
- 93 O2 single wire conversions
- Finished MSD opti install
- DD cams, whats your MPG and dyno #'s
- Parts for my cam?
- gettin hot
- LT1 no2 users.....
- A question for those who own the MSD Pro-Billet Optispark
- Vortech elbow design vs. Trick Flow elbow design
- stock lt1 springs
