View Full Version : LT1-LT4 Modifications
- LT1 swap and LT1 runs rich, haven't figured out why yet...
- 6 Speed swap, Should I stay auto.
- broken tranny mount
- Is this cam noticeable?
- another true duals thread
- ???over The Valve Cover Wires???
- Heating problem
- Which cam is more reliable for daily driving??
- Any one have a step by step "HOW TO" on LT install on a LT1
- Headlight replacments
- Lt-4 Knock sensor ....
- LT1 to LT4 upgrade (Link to the Parts section)
- injector question
- want opinions of the new set-up
- LT1 bottom end limits
- What valvetrain parts do I need to install a CC305 cam?
- biggest cam???
- Factory air foil???
- posting pic
- CC503 224/230 VS CC305, both w/ 1.7's
- 1997 30th Anniversary z28
- should i feel a differance?
- arching on lt1
- electrical problem...won't stay running, HELP!
- help!!! passenger side header removal?
- installing 1.6 rr question
- porting intake manifold to match throttle body
- Best Stall Converter?
- m6-th350
- values
- Anyone want a GM service manual?
- Lt1 tune by palm?
- Wierd misfire problem
- LT headers Install Problem
- oil pan gasket replacement
- Opti Wire Harness
- racetronix fuel system
- water pump out?HELP!!!!
- What to expect, Opinions needed!!!!
- hey anyone know will a ls1 ac compressor ??/
- what do i need
- Stroker
- what HP from LT's?
- trouble code 27
- EGR & AIR ? on my 1993 LT1
- question!!!
- fuel rails?
- 383 Guys
- Cool Window Decal
- stroker head and cam package
- Motor Mounts
- what could do this
- FI or Nos??
- ram air Question
- Track Times Inside
- Do I have everything I need for a hot cam swap?
- Gears for auto LT1?
- Appearance change..... low rise spoiler to high rise spoiler question....
- having troblem shifting into 2nd and 5th gear
- turbo lt1
- Post your LT1/LT4 Ported heads Flow #'s
- how many people has had this happen
- Msd Ignition
- What is wrong here?
- L98, = Lt1
- ATI Super Dampner belt question
- ls1 driveshaft
- car won't go past 5 grand
- long tube / y-pipe / GMMG cat back
- Overheating.....HELP ASAP!
- CC306 guys, where are you shifting with an A4?
- Cooling fan trouble
- WTT 230 236 cam for smaller cam
- Will a 02 Hurst SHifter Fit a 96' T-56?
- new tc
- Hurst shifter question.........
- Yahooooo! Magnaflow exhaust installed!!
- Anyone melt thier converter???
- is there such a thing?
- Accel Opti
- SLP LineLock Questions about Install.
- Melling oil pumps ?
- No Throttle Response....
- Crank Advice
- engine lift and stand
- Cowl Hood
- Anyone ever port there intake? Tips?
- What ya think?
- What should it run?
- A Possible Quick Time Performance LT1 Header?
- Why do........?
- Exhaust Questions
- m6 conversion
- Heating up
- fuel regulater/injecters????
- New Dyno Numbers
- starter question
- What would you do?
- Any one ever reuse their Opti?
- Really dissaponted please help!!!
- 4.060 bore on an lt1...need opinions
- Line lock
- header gasket????????
- stock rear end
- True Dual setup
- Is this true???
- Custom Alternators & Tall perimiter valve covers?
- Oil pump problems
- Engine Temp. Sensor Wire Broke!
- Pics of formulas
- ASM headers
- Stroker shift points withComp Cams 230/236 cams?
- 1972 Nova LT1 Conversion
- Adj rockers and installing the opti
- Welding a windage tray in to stock oil pan?
- ls1 brake upgrade
- Is the car worth it?
- Blower intake progress
- exhaust expectations
- Please Help!!! Opti?
- cheap tuners in so california
- AFR Rev Kit Warning!!
- strange problem
- Longtube help..
- 1.7 Roller Rockers
- Intermediate pipe question-?
- Best OIL for the LT1
- Do I need a knock module with my new exhaust?
- Funny noise in my '95 Z28
- Best way to bleed lt1 t56 hydraulics?
- Anyone ever used the Jegs Universal radiators?
- BC4 Package???
- FS:94-95 Hooker Shorty Headers w/Y-pipe(New)
- Need a cam
- That pain in the ass...
- my new z28
- Trickflow Heads (pics)
- i need clutch reccomendations
- info on zex kit and set up
- Who is the best mail order tune available?
- SS Hood?
- should i tune my pcm???????????
- LT1 A4 cam recomendations
- anyoen have pics of black camaro with black zr1s?
- Got my new Z28 today
- Dyno today
- Cool, hope for us roots blower guys from Magnacharger.
- Any one here have a mad z28 tune on their lt1?
- LT1 Engine Modification help
- breaking in a new cam
- LT1 vs. LS1
- horrable gas millage
- best LT1/LT4 heads
- Car tries to start with no keys, need help fast
- Cam/Springs/Retainers/Locks For Sale
- bad fuel pump???
- fuel pump trap door and other ?s
- Airbag light
- LT1 true duals
- LT1 Hesitation
- factor of safety for parts
- Anyone else have LT1 Carbon Fiber valve covers?
- lt1 body kits
- What should be my next mod?
- please help
- Smoke Problems!
- Cam kits
- Spark Plugs
- Converting 94 opti to 95 opti what all do i need?
- A/F Ratio
- LT1 is being GAY
- ceramic coating
- Opti cap and rotor help please
- Canton Oil Pan
- how much n2o can this take?
- Cut outs
- recommended spark plugs?
- Lt1 roller rockers (need help)
- Single plane injection?
- What will this do to my mileage?
- Mikronite???Stronger gears?
- -97 WS6 project. Need help!
- 96ss want to run low 12s cheap
- Cold Air Intake vs. Ram Air Kit
- Lifters Damaged?
- OBD1 Problem
- Delteq and Dis-4
- Question about my headers VS my Spark plug wires!!
- GM Parts Direct Number For 1LE Elbow?
- Manual fan switch on 93 LT1
- How much does a Zr1 corvette motor cost?
- possible opti problem?
- ignition options for heads/cam lt1
- any free mods
- Automatic help needed (4L60E)
- Adj fuel press reg
- Trip on Odometer BROKEN
- which valve springs??
- Which Pulley??
- Pulley MPG
- over the valve cover plug wires...
- Has anyoen done twin T's on a lt1?
- problems on 95 corvette with tcs
- backfiring after Long tube install
- 4:10s in an A4??
- Kooks Headers Dyno Numbers? Anyone?
- What To Do NOW??
- tranny cooler lines leaking?
- LT4 Performance Help
- NOS Question
- I need Pics of LT1 TDs.
- Rotating Assembly
- Msd
- 160 or 180 Thermostat?
- Block conversion...
- How much horsepower does my car have at the CRANK with the current modifications?
- anyone rev a cc306 to just 6200-6300rpms
- Trick flow#s
- Balancing on 383 Stroker LT1 Engine???
- msd box
- where to buy good hvac overlay!!
- LT1, slp LoudMouth Exhaust??
- clutch help
- motor and trans install pics
- exhaust question
- Need Help with #2 Cylinder Spark Plug
- swapping y pipes
- Replacing Head Gaskets
- need help
- mass air flow
- LS1 into an LT1 F-Body?
- Setting the oil pick up tube
- LT1/LT4 2 Stage Nitrous Plate
- 847? where?
- What RPM would you shift?
- Is it worth it to buy a hi-flow cat?
- Head Gasket
- Porting
- weight reduction??
- WTB: LT1 f-body supercharger
- Comp 977 springs
- Head Flow And Milling
- Computer Tuning
- Cam Question
- Trick Flow LT1 Heads?
- post ur pics!!
- hotcam with auto, please help
- 396 or?
- LTCC users, where do you get the long plug wires?
- Anybody running the Hydra-rev kit?
