View Full Version : LT1-LT4 Modifications
- LT1 engine on ebay - is it worth it?
- timing chain question
- Rebuild/Blue Print Questions
- pacesetter shorties on a 95LT1
- t56 conversion from A4
- Sticky This Lt4 Conversion Why Not To Buy
- Valve Spring Question
- Couple new problems, help me out.
- Best 58mm TB
- UD Pulley's??
- best head gaskets for lt1
- Next bolt on?
- cam only autos
- New Cam only Lt1 times!!!
- Formula to run mid-12s on street tires?
- Iridium Spark Plugs
- Cam Swap plans Complete
- wheels
- Times with boltons + 100 shot
- Engine Swap Question
- Drivability question?
- Cat back with cut out?
- SI LT1 Drag List Please
- what is this
- torque converter
- help head gasket failure
- Lt1 To Lt4 Conversion W/ 9 Lb. Powerdyne
- Help Me!!!!
- Lets Talk Sensors. . .
- spark plugs
- Snow Sucks Balls
- fiberglass or carbon fiberhood
- Over the valve cover wires
- In need of help.
- LT1 Fuel Question
- rear end damage pictures
- LT1 rx7 advice =)
- Plastic fuel tanks
- Head And Cam Question
- Turn Signal Switch broken?
- Head Lights Motor Making Noise
- head and cam 97 SS
- couple of questions about gm847 cam
- EGR removal
- Couple of Questions
- aaaaahhhhhhhhhh
- BIN file for Hot Cammed LT1 A4 1993
- Header Gaskets
- 6spd inspection cover
- Need a ? answered please...
- Alarm wiring kit / mod for electric H2O pump
- Can someone tell me...
- electrical problem
- K&N cold air kit, not applicable?
- bouncing off rev limiter
- close on a deal, looking for insight on the build
- gear drive for lt-1? 1/4 mile times with h/c
- Changing Fog Lights
- Traction with 4.10s'
- Anyone know anything about Lingenfelter cams??
- fans not turning on
- Anyone Need Metric Rings?
- new combo
- opti
- question
- Rear End Question
- Ingredients for 11's in my sig! ! !
- Blower setup for my 383 LT1.
- Couple of questions
- cammed smog...
- 396cid+ LT1/4's?
- black zr1s who has them???
- 700R4 Transmission?
- opti?
- Stock Internal LT1 Record
- 05 Mustangs, Fast?
- ASP crank pulley??
- Bolt on lt1 New best
- timeing question
- This is probably a NewB question, but here goes
- Anyone know about these LCA's/manufacturer?
- $1,500 Budget Vavetrain
- heads vs cam specs>>>technical question
- 12 bolt questions?
- Question about camshafts and high mileage engines...
- Is a K&N even worth the money?
- A little help please?
- Cheapest lt4 intake?
- Long tubes
- belt screaming
- Do I Need New Injectors???
- Converter Question?
- Exhaust fitment thougths
- bellhousing
- exhaust for 95 z28
- TSP Catted-Y, and installation on LT1
- Spark plug or opti?
- i searched for this first but i have a tranny question
- LT1 upgrades advise
- Stock LT1 cam ##
- Is this a good recipe for my 96 ws6??
- how much to fix rear end????????
- Transgo Reprogramming Kit
- Help Me Choose heads for daily driver
- LT4 cam kit
- What Is Da 1995 Stock Transam Convertible 0-60???
- soo... 93-97 converting to 98+ front clip...
- Im so screwed.... need help asap
- How does this sound?
- Hooker Y-Pipe question.
- Some Exhaust Questions
- What mods CANT I do?
- overheating problem...
- Borla Exhaust Purchased, Questions
- Gear question?
- What's wrong with my car?
- Timing chain
- tunign for my 93....Deltq???
- Is this rare?
- Igniton Switch Or Security System
- Suspension suggestions
- LT Header Q's
- need help 95 lt1 T/A
- Best heads?
- What should I buy??
- Exhaust question...
- What is the fastest Bolt-on LT1 full weight daily driven street car?
- Vibration Under WOT
- Hypertech Power Programmer for 93TA?
- Spun Rod /Main Bearing?
- Surging. What causes it?
- Loudmouth gains?
- heads and cam?
- Delteq or Opti Spark
- Is 142,000 miles, Can i still CAM it?
- hydra rev kit,solid roller
- Hypertech Power Programmer opinions?
- Please Help Me with belt size.
- Looks like I'm set.
- Help!@# Car Trouble!!!!
- Power Programmer on a stock WS6?
- Looking for a new cam
- Power Steering removal
- whats next?
- What would you choose?
- Wheel swap
- how many stock heads, rr's and 847's are there
- got a baseline dyno done today
- air injection bypass?
- Madman Racing & Co.- Out of Business?
- 1.6 roller rockers
- Stock Rods.. How strong?
- clutch for 95 lt1
- oil cooler removal
- camaro hood
- Where do I get a AIR SENSOR relocator?
- Alternator Relocation Kit
- Anybody have a link of this video handy?
- what is my car worth?
- car stumbling bad
- 13.7 m6 on street tires will the rear handle nittos?
- How to.....??
- LT1 overheating... little bit wierd. Help
- Which gears in my car????
- Cam choice for stock heads????
- Lt1 Rods??
- optispark
- ok how do gut the cat?? is...
- LE head suggestions
- Damn Waterpump
- lt1 intake on an l31?
- Ok how bout these?
- lt1 owners stock driveshaft
- LT1/LT4 Build plan.. i need help.
- Headers and y-pipe for xmas..have some questions
- anyone got any ideas???
- lt1 heads wanted
- i know another oil thread
- Who makes CC305 & CC306?
- LT-1 Experts step inside...
- head bolts metric or standard
- How a tailshaft breaks with your tranny mounted torque arm........
- Please, take a minute to help me!
- Pacesetter LT's (question)
- Cam vs Head flow?
- These mufflers decent?
- 6 speed vibration
- spark plugs
- Got a noise
- 400cid sbc for LT1, some questions??
- New track times..{$40 worth of mods}
- Went to the track today and broke my tailshaft
- Anything Better?
- is my cam limiting power
- only shop manuals
- Back from the track>>>
- cap and rotor ....
- 94 Formula
- 96-97 Firehawk Foglights
- Well the tranny finally went
- hight flow cat or custom y pipe??
- So i bought my first f-body
- Track times on LE2 heads
- What do you use to Datalog
- stock lt1 1/4 mile times
- popping out exhaust
- My plans for the LT1.
- wILL THE lt4
- Elliot's flow results
- If your a LT1 guy in need of a cold air kit check this out!
- to black or keep chrome!!!
- lets go fast!!!!!!
- parts for cam install?????
- Allen key?
- Has anyone builted a 10 bolt?
- How much power 383
- tire sizes
- Just Changed Distributor, ,, Problems Now
- SLP CAI question
- installing a H/C package?
- So who is the "king" of mail tunes?
- Tire question
- Need help - new 383 and now front of thrust bearings are wiped out
- Which plugs and wires should I go with?
- running like crap
- What kind of headers?
- Rear end swap?
- vaccum lines on the opti spark (1995) lt1
- cc305 in stock lt1
- LT1 > LS1? Some ideas why...hehe
- Overfuelling problem
- help with GEARS
- 490hp Lt1
- Does anyone have a 52mm TB?
- Is a cobra faster than a LT1 WS6?
- Please Help!!!!
- Header Compatability??
- Help! car wont start
- LT1 Cap and Rotor only replacement pocedures needed....
- Difference in LT1 and LS1 Catback?
- Valve Spring question?
- roller rockers and valve covers
- suspention...
- gas gauge?
- 2nd gear start question.
- cam questiom
- help me make my engine bay look sick!!
- Need an opinion.
- What heads are you running ?
- LS1 brake conversion or Baer brakes?
