View Full Version : LT1-LT4 Modifications
- 2 1/2" or 3" exhaust?
- Pics of my Lloyd Elliot heads
- Is this what the 1.6 cam rocker sounds like?
- Opinions on this Camshaft
- Need 3:73 gears
- Which injectors for 230/236
- Best Sounding Catback
- wiring harness??
- installing a 2004r tranny with an lt1 motor?
- What exactly makes the 1.6 crane rockers tick?
- Does my Dyno Graph look funny to you?
- My car sucks
- just ordered these. are they right
- improving performance parts
- need help on what to do.
- headers to purchase for stock LT1
- Before Cam and stall
- 93 LT1 weak?
- $245 for K&N intake??
- 1997 LT1 Missing under 2500 rpm & stalling at rpm
- oil pressure gauge?
- 96 z28 dyno vid..
- Gm 847 cam install on a 1993 LT1 i need help
- Bolt on NEW BEST
- another exhaust question
- What do you guys think this car would run?
- LT header almost touching fuel lines
- Guys w/ strokers&big cam
- Any NICE lookin' Z's?
- LT1 Problems
- Changing cap and rotor
- Headers Knocking under my car!!!
- Will an Imapala SS's MAF work on a LT1 F-body?
- Where can I purchase spintech exhaust from?
- Injector question. Are 42# too much?
- Story of an LT1...
- what free mods can u do to a lt1
- electric water pumps reliability?
- LS1 or LS6 heads/intake on LT1
- Long start (Optispark?)
- Which Programmer??
- LT4 knock module info please.
- Those who have had a supercharger and nitrous, which did you prefer and why?
- FS ptk gen2 kit
- LT1 motor and 78 350
- which is the better air intake?
- MY 383ci lt1 built up
- Does this seem like a good deal
- Solid Roller Specs
- Another MSD cap and rotor question!
- pcv grommet
- 230/236 which springs
- Lt1 vs ls1
- New T-88 setup from Omaha (Batman's)
- The SB2 lives...
- unclear searches lead to my questions
- TrickFlow Heads
- First time drivin wif new engine
- prolonging opti life
- 2nd gear is bad
- H/C Package HP Numbers?
- Heads and cam question
- What's up with this Lloyd Elliott guy??
- a shorter timing chain?
- Pulley Set LT1
- LT1 rebuild
- O2 code HELP!
- Can anyone find me a part number for this reducer pipe..?
- 97 M6 with 100 Shot NX??
- Rebuild 355 LT1 huge nitrous shot possible stock heads/cam?
- which should I get Supercharger, Procharger, or Turbo?
- Turns over, will not start
- Crazy Problems I have
- Vortech Vs. Procharger
- lt1 vs ls1
- Whats the displacement on a 383?
- Which Timing Chain To Use???
- 396 Or 383??
- timing chain
- Some may say I'm crazy....
- P0300 Random/Multiple Cylinder Misfire
- Routing spark wires above the valve covers
- Msd Ignition Box ?
- timing chain question
- CryO2 Fuel bar, help with detonation?
- Any nice looking Firebirds?
- Pleeease help with nitrous piston selection!!
- 700R4 tranny vs 4L60E?
- throttle position sensor question?
- Is $9,000 too much for a '94 with 133k miles?
- Electric Water Pump install
- Nitrous jet size
- big problem with ignition
- If using this piston can I go down to a 5.7 rod for lowering the compression?
- Heads/Cam for forged 383
- Left overs
- more problems
- lt1 lt4 conversion
- header bolts
- What Do I need to break 11's?!
- piston and the rod/crankshaft clearance?
- Lt1 Basics
- ECM trouble code 42 (IGNITION CONTROL GRND)
- Ok, so now I have a stock time.
- Looking to buy an LT1, looking for some insight
- lt4 help please.
- converting 4l60e to 700r4
- How many of you actually weld your cutout into....
- i pray..and pray so more..valvetrain
- autotap, what to watch
- Knock after cam install
- RPMs drop to idle at any speed??
- need help working out the bugs
- How is this E/T and trap speed?
- Does my motor have more than I thought?
- Is the Steam pipe on the heads necessary?
- LT1 breaking up at high RPMs, please advise
- Oxygen Sensors & LTs; a question...
- trickflow elbow on a 58mm TB??
- My valve train sounds like a tank comming through
- new engine
- Fast Efi Tuning .. Any One Here Got It
- help with stroker combo
- Efi To Carb Swap On Lt1
- Stay NA or go FI?
- What would it take?
- Bad News!!!!
- Scanmaster worth the money?
- gasket bad?
- power on a 94z
- camaro vs corvette
- problems with getting old headers off
- LT1 383 LE2, ported intake, rocker arms???
- stock LT1 intake
- Mimium header tube size?
- Custom Blower/nos cam LT1
- update on my turbo 383 project
- LT1 overheating after Optispark and Waterpump replaced
- What oil pump should i go with?
- first mods for the z
- Well... I've decided to put a ratchet in the truck... but which one?!
- What Spark Plugs to run with nitrous?
- Disassemble an Optispark
- Enigine Shaking help
- Next Gen Delteq
- EGR Delete
- OTVC plug wire kit
- Question for those running Joe O. Cams?
- off road pipe
- Pacesetter y-pipe w/ cat
- cutout placement
- Lt1 Maf
- what heads on turbo motor ?
- Help w/ new setup
- Tuning out the o2's?
- My oil gauge is very low! WHY ? Please Help?
- Spark Plug Wire Order
- Big Decision, Please everyone reply who can help!
- Best place to find LT1s...
- 383 LT1 w/ msd blaster... having ignition problems!
- 383 LT1 stock heads with nitrous?
- ses light after converter install
- Torque Converter
- So I dyno'd the 97 tonight...
- Drove my 240Z with the LT1 today
- AFR Dealers
- 1993 camaro M6, can i tune it?
- Bad vibes, won't rev. Please help!!
- Anyone with Mallory Hyfire 6AL?
- Converter opinions
- Misfires
- 383 Engine Help, SOOO wierd!!
- 1/4 mile mph??
- Clutches
- 383 LT1 what is ring gap
- Took emissions test today, failed horribly.
- i am at my wits end. HELP!
- OBD1 or OBD2
- How much cam lift
- Will my new 383 hit high 11s? here are the specs.
- Will A LS1 Injector fit a LT1?
- FLP longtubes?
- Thinking about selling the Bad Boy 398 LT1 ~1200RWHP+
- Misfire or Rear Slipping?
- a little help on my car please.
- Car is hesitating and bogging, backfiring while cruising too
- Knock module and fuel pump ?'s
- How do you find SES codes w/out a scan tool?
- Nitrous limits
- Water pump problem
- Setting Tps Sensor
- A/C Delete
- Lg Tubes 96 Lt1 Vette
- What kind of numbers/times should I be looking at?
- car on 6lbs of boost and misfiring
- What To Do Next?
- Mail in tune details?
- OBD1 tuning For turbo
- Strong fuel odor from exhaust
- nitrous pistons and the amount they can withstand?
- strange idea
- Where to BUY a 383 Stroker Crank for my LT1?
- tuning for the LT1?
- need to find a general pulley wheel
- Bad Misfire
- Damn Coolant system.
- LT1 383 LE3 against a LT1 350 LE3?
- Tune?
- 383 stroker fit LT1???
- Grinding sa tabs on pro mag rocker
- cc306 Cam
- Broke the oil dipstick!
- What do you think about this LT1
- PCV Valve vs Breather
- Check this out...
- Can you identify this cam?
- nitrous bottom end recommendations?
- elbow to throttlebody boot
- Borla Exhaust....
- 421 stroker?
- see if anyone here can help
- Newbie - just saying hello
- who builds wazoo!!! 4l60e trans's
- header difference
- electrical problems!
- Speed density and O2's
- Rotate/Remove Coolant Tubes on Water Pump?
- tranny cooler fender mount?
- near future setup
- lt headers
- Just bought a stall :D
- 383 LT1 nitrous head and cam?
- estamating the rebuild
- meziere leaking
- a4 trans slipping
- FS. LT4 block bored .30 over and LT1 block
- Port/header interference
- lt1 newB
- car just died today! :( need some help
- check my car out..
- What is this??
- How bad do i need a tune?
- Horrible misfire caused by heat?
- Exhaust ideas
- tubular k-member questions
- 10's possible
- And so it begins...(car issue)
- Oil dipstick/headers problem.
- Does my car have a MAF sensor
