View Full Version : LT1-LT4 Modifications
  1. head gaskets
  2. Pacesetter LT's to kooks catted Y ?
  3. questions on putting motor back in
  4. vacuum leak 97 camaro
  5. Tune question
  6. Input shaft seal?
  7. pushrod question
  8. How to or can you clean..
  9. Best spark plugs for stock LT1?
  10. Did i hurt my fuel pump?
  11. I need a new hood
  12. 97 z28 cat removal
  13. Stock HP ratings
  14. Window Switch
  15. Shim Gasket Pics
  16. PLEASE READ: 95 Z28 ignition problem
  17. what music do you listen to while under a car
  18. What mods next?
  19. Head Gaskets
  20. Bolt on tune?
  21. anybody running duals with a chassis mount torque arm?
  22. Dumb question about brake pedal.
  23. cam swap gaskets?
  24. EGR Delete questons
  25. o2 sensor PITA
  26. New guages...
  27. Clutch acting weird..
  28. Cam/Ported Heads & Intake/LTs price
  29. OK what is this thing, Shbox.com doesnt list it or have a pic
  30. aIR removal question
  31. Pics of Y pipe with cats...
  32. will 94-97 fuel lines work on a 93 Camaro?
  33. 94 Z28 gear question
  34. Which ATI or BHJ balancer?
  35. Low voltage causing a stumble?
  36. Update..got the stroked/turbo and nitrous 97 ss tuned ...
  37. water pump fittings move??
  38. ugh, people do stupid things to cars...
  39. let me see pic of cai delete's
  40. I know B-bodies use iron heads, but what about the intake?
  41. Anyone ever try a "Pypesmouth?"
  42. M6 LT1 drop
  43. Die Out Question
  44. Stock pushrods ????
  45. Blast from the past ! Great Video
  46. Dyno tune location?
  47. new 8.8 info...maybe
  48. Pdf repair manual?
  49. Quick Q bout steering shaft.
  50. Coolant/crankcase issue.
  51. delteq opti
  52. Could it be anything besides the OPTI?
  53. So this is what my clutch and inside of tranny looked like
  54. Can't get this d@m clutch bled!
  55. few questions...
  56. peak and hold injectors
  57. Smoking out of the Motor Computer box?
  58. cc503
  59. How to pull tranny for clutch swap?
  60. lt1 turbo
  61. Heat range colder than NGK BR7EF???
  62. Best write up on Optispark install?
  63. A Couple Questions for ES P/A Class...
  64. Need help picking a Catalytic converter..
  65. Any helpful gear installation threads around?
  66. Passengers side (Bank 2) oxygen sensor replacement..
  67. Pulling my hair out......Race car guys in here i need opinions....
  68. MSD Vented Cap Install Question
  69. AIR delete on a 94 LT1?
  70. Shaking
  71. Budget LT1 Build Suggestions
  72. 1994 383 Z28, MAJOR problems, advice needed.
  73. best headers and exhaust
  74. LT1 oxygen sensor issues
  75. Spark plug misfire?? you must read this!
  76. what u guys think??ss emblems
  77. throttle / cruse cable bracket
  78. New PB MPH with hotcam after porting and lid
  79. LTCC who has it?
  80. Cam wont go in HELP!!!
  81. Lawhead Bought another LT1
  82. help understanding how to build a motor
  83. Stupid question about Pro-Mag RR's (noise)
  84. Solid motor mount passanger side
  85. LT1/LS1 4L60E shifter cables... same?
  86. delteq vs MSD opti vs 24x system
  87. EFI24X conversion
  88. quick opti replacement question
  89. what the hell
  90. Pics needed of stock Lt1 engines...
  91. cleaning oil pickup tube
  92. Bad miss!!! Whats going on guys?
  93. what do i need to get rid of all emmisions
  94. Would the GMMG catback be comparable to SLP?
  95. Timing Cover
  96. Where did LE's site go?
  97. How do I find Madz28?
  98. dailiy driver lt1 build
  99. i need a lt1 t56 crossmember!!!!!
  100. Cable to get for tuning and logging??
  101. exhaust manifold bolts snapped
  102. 24x ignition in CA how can I pass smog
  103. Huge problems car doesnt start
  104. Z becoming DD
  105. Moter intermittently cuts out for a second while cruising
  106. Moroso pan /stock dip stick
  107. Magnaflows on my impala ss
  108. .900" Base Circle Cams?????
  109. Quick Q- Clutch disk orientation
  110. How to get egr out way
  111. Ditch the opti and go EFI 24x or not? BIG TIME RACERS CALLING OUT
  112. heater core hozes
  113. Opti to Dizzy?
  114. What is the best way to add horsepower....
  115. Will LS1 intake manifold bolt on to an LT1 motor?
  116. lt4 hot cam kit, Minus the cam
  117. Sigh more 383 problems. Fall down go boom
  118. Oil pump drive assembly...
  119. what am i lookin at
  120. Low oil pressure
  121. my Competition Clutch Stage 3 came in.
  122. throttle body coolant bypass
  123. degreeing a camshaft- lol sorry
  124. Identify this part
  125. 475rwhp A4 NA
  126. are these the right isky guideplates??
  127. best opti for rebuild
  128. oil catch can question??
  129. Racetronix fuel pump wiring question
  130. GM Lifters Question
  131. 93 Firebird LT1 w/ bad tank ventalation, low fuel pressure, & rpm drop & shudder...
  132. Centerforce clutch or something else?
  133. Hesitation at part to full throttle
  134. stroked/turbo/nitrous 97 ss camaro built in progress
  135. Misfire found. Finally.
  136. Time to Do it.....Putting the car on the market..700rwhp LT1
  137. Rough running, down on power.
  138. Elbow plug?
  139. Oil pressure question
  140. Questions about VATS system & aftermarket alarms
  141. what size injectors?
  142. Hot Start Issue
  143. Little help
  144. A little PCM help please
  145. Lean at idle + IAC 0 = Intake Manifold leak?
  146. HELP: Putting '96 Impala LT1 in a '93 Z Roller
  147. Quick Q about LS1 lid swap in LT1 car...
  148. camshaft opinions
  149. SES light knock sensor
  150. Clutch problems.......advice?
  151. Golen crate engine with LE cam and heads
  152. question about stock valvetrain
  153. Gets warm and dies...stumped
  154. Make shift Y-pipe adapter
  155. factory plug wire protector
  156. Engine no-start with speedometer moving while cranking
  157. Which heads are better?
  158. lt1 Hesitation after warming up
  159. noises from tranny or rear???
  160. adjusting LT1 rocker arms - 1.6 comp pro mags????
  161. I have seen it all now, LT1 Trans Am LIMO!
  162. Clayton Racing???????
  163. LE heads
  164. Harmonic Balencer Problem
  165. Is this a good budget buy or are these those "fitment issue headers"?
  166. Finally going thru the car wash
  167. need help
  168. Spec Stage 3 clutch
  169. looking for ideas
  170. Can I do these upgrades out of order?
  171. My forged 355 first start
  172. Overheating problem.
  173. Knock-off flowmasters on ebay
  174. Hot start problems
  175. LS7 Lifter problems?
  176. Heater hose/coolant help *PICS*
  177. good reasonable freight company??
  178. What do you think?
  179. New Carbon Fiber Elbow..what does everyone think?
  180. Throwing some codes, help me out!
  181. "Low Oil" Light
  182. Need everyone's input on something
  183. Stock motor but full suspension?
  184. What would you do?
  185. Injectors & starter FS
  186. spark plug wire cylinder 7
  187. Need all the help I can get
  188. Ground?
  189. great, #6 cylinder is dead
  190. best intro nitrous kit
  191. How much PAG oil to add to Delco AC Compressor?
  192. runs for a few seconds and dies.
  193. high idle after throttlebody clean?!
  194. Build me a coming home present
  195. What to do with my car
  196. Eficonnection how do you like it
  197. post the best vid u ever seen
  198. finally starting to mod!!
  199. 95 impala lt1 tune
  200. arp head bolts question about sealant/lube
  201. Will an lt1 w/ minor mods benefit from a tune ??
  202. general build info
  203. Could my clutch have seized up or did my motor get screwed up?
  204. Egr delete question
  205. EFI 24x Conversion
  206. Please Help Me
  207. LT1 radiator bracket?
  208. 1.7 or 1.6 pro and con list help
  209. Stock bottom end with this cam?
  210. What to shift at for a LT4
  211. 355 build advice
  212. to do list done for now
  213. Anyone setup Howards 98215 valve springs?
  214. what do you guys think about this set up?
  215. Cheap junkyard rear end solution?
  216. Upgrades to do while replacing a head gasket?
  217. Good y pipe w/ cats to go with LT's?
  218. Nitrous helps
  219. Pulling Intake
  220. Magnaflow or borla cat-back
  221. rough estimate?
  222. A4 qustions
  223. ?
  224. lt4 valve covers - 95 z28
  225. LT1 383 or LS1
  226. custom cluster for trans am
  227. Just want to say good bye lt1
  228. Whats the highest fuel pressure anybody has run with Bosch EV1 style injectors???
  229. SLP Speedo Recalibration Box Instructions Inside
  230. What is this?
  231. Knock Sensor??
  232. LT1 MAF Question
  233. Mother @&$" I need the torx? Screw/ bolt for the hatch that holds the lift support :(
  234. Removing Rear Wheel Studs?
  235. Need help with my LT1
  236. opto masters please read
  237. No spark from coil
  238. 94 Z28 Idling issues
  239. lt1 rotating assembly question
  240. What do you think about wrapping your headers
  241. LS1 front brakes, what are you running for lines?
  242. HELP lt1 acting funny
  243. Spark plug wire looms?
  244. Radiator Cover
  245. 396 Stroker SR build FTMFW!
  246. trans or rear end? what blew up
  247. 300 horses?
  248. LT1 Headers & Dual-Cat Y-pipe Package??anybody
  249. Engine break in ??
  250. Comps recomended the XE276 224/230 112lsa..
