View Full Version : LT1-LT4 Modifications
  1. Overheating
  2. Looking for the guy who was selling AC opti's
  3. Does anyone have experience with one of these??
  4. 95 lt1 starts, runs for 3 secs and dies ??
  5. 94 Camaro Misfire, SES lit
  6. Motor mounts on my LT1 not wanting to fit 68 camaro mount perches
  7. Coolant lines question
  8. finally decided to go with nitrous
  9. Flashing CEL at Start Up!
  10. Help me find a cam for my set up
  11. AFS75 O2 sensors, 96 LT1, did Delco change the design?
  12. Shift light
  13. Shift light
  14. opti swap now it wont start
  15. 305 cc 114lsa
  16. ARP main stud torque question
  17. 95 t/a build what can I hope for?
  18. Victor Jr Question
  19. motor ?
  20. What did you guys to for this?
  21. charging problem
  22. issues at low rpm(video)
  23. LT1 Throttle Body Replacement Questoin.
  24. new pb what to expect now
  25. Dynaspark Opti any good.
  26. I think I may have an EVAP problem??
  27. Need some help with t56 swap!
  28. Newbie with questions?
  29. found a deep oil pan. will it fit?
  30. Recommend me a cam
  31. ignition control module
  32. Whats the difference in these cams?
  33. M6 vs A4 fuel economy read, opinions, thanks...
  34. Pacesetter Midlength LT1 Headers
  35. Any step by step cam install threads for LT1s?
  36. how many stock oil pan guys with stroker motors
  37. LT4 knock module and water pump question
  38. best plug wires for a budget?
  39. moroso oil pan hitting crank
  40. Gauges
  41. low pop out of exhaust
  42. LT trim is stuck at 24.98 no matter what I do
  43. HVAC Delete Question
  44. Melted o2 wires. Need to rewire them
  45. Breaking up after 4500 rpm *UPDATE**PROBLEM FIXED*
  46. Lt1 build... Suggestions
  47. New 355ci AFR/LE Video and Pics
  48. eas electrical fault
  49. 93 TA gets redone
  50. Where to put flush and fill kit
  51. rebuild
  52. speed pro oil ring question.
  53. cannonball run
  54. Anyone looking:GM 4L60E,95,T/A,wrecked
  55. is a harwood ws6 hood lighter than a factory ws6 hood?
  56. What header gasket for turbo application.
  57. Rain problems
  58. Any HR guys spinning to atleast 7500 RPM
  59. please help fuel injector problem on 95 z28
  60. Upgrading ignition on LT1
  61. Possible fowled plugs?
  62. 3.23 to 3.73
  63. Will an engine harness from a 96 work in a 95
  64. cam tuning help
  65. 1994 b4c
  66. Will stock valve covers fit on AFR heads
  67. Throttle Body and SLP CAI issues
  68. What gaskets to use?
  69. I want to figure out what cam I have
  70. Running rich need help!!
  71. just needed opinions
  72. 1995 firehawk
  73. Best LT headers for the money?
  74. Relocated battery to trunk...now starter clicking??
  75. 8.8 inch
  76. sort of a beging to a buidl thread
  77. Overheating problem
  78. Help with water pump mod
  79. Help, LT-1 Looking for a tune
  80. Anyone know what brand hood this is?
  81. LT1 Oil Priming Question
  82. Dyno near SW MI?
  83. I'm a dumbass, help me get my broken dipstick out of my oil pan
  84. Any Good shops in Las vegas for LT1s
  85. Hard to shift into 1st, 3rd, 5th, and reverse. Ideas?
  86. EFI 24x Timing Chain
  87. McCleod twin disk question
  88. Anyone have any problems with Kooks hitting the steering shaft? I need HELP!
  89. How well will my combo work
  90. where to find ws6 ram intake???
  91. Been through a few ICM's... any help out there?
  92. What do you think?
  93. 93 z28 wont start
  94. Official headlight replacement write up for the ultra n00b
  95. ARE YOU KIDDING ME??!! Broken Camshaft?!
  96. New LT1Tech'r
  97. New bolt-on 1/8 times. what do you guys think??
  98. ECM Readings from mods?
  99. MSD's RMA returns
  100. pics of stereo system
  101. Another possible rip off seller
  102. Holly CRAP!!! No Rasp!!! On a Y pipe!!!
  103. 383 LT1 SR cam 88mm turbo HD VIDEO part 6 Dyno tuning
  104. Cheapest SVO 30
  105. Pulling Codes on a 95 Z28
  106. Cam and RR question for the Iron Head LT1. Stock engine being replaced with Impala SS
  107. What woudl it take to put a Carb on an LT1??
  108. Aluminum driveshaft?
  109. Opinions on Borla XR-1's
  110. New plugs
  111. Tuners
  112. FINALLY build time..need some opinions
  113. optispark trouble advice
  114. Any difference between painted/stainless headers?
  115. zr1 lt5
  116. BMR K member not meeting up with motor mounts????
  117. Overheating in minutes - Air in the cooling system?
  118. This Cam?
  119. No coil voltage
  120. Would a burnt plug wire boot cause the engine to hold back?
  121. finally heard my engine start after a while of sitting and possible issues
  122. Rear end q??
  123. funny idle
  124. Junk wiring harness
  125. Is this car worth it?
  126. Lost Oil Pressure....Need experiences please!
  127. Whats the fastest "TRUE" LT1 out there
  128. Time for a new cluch
  129. Why you go with sponsors over ebay...
  130. Track prepped bolt on VS street prepped cam'd
  131. Some fuel related advice needed
  132. Water Pump drive shaft coupler
  133. Longer pluger wires for headers?
  134. Anyone know what size or how to remove the plug in..
  135. Are those non name brand headers on eBay any good.. (ap1 ap2)
  136. T56 lower cover, where to get small bolts??
  137. Trying to switch to OBD 1. Have tried two separate OBD1 PCM's and car still....
  138. Datalogging a '93 LT1?
  139. K-Member Mounting Bolts
  140. Dynaspark Experience (Long)
  141. changin gaskets, front seal is leakin oil,
  142. How much do these special "LT1" headers go for
  143. difference between 8.5 & 8.0 wires
  144. Alt relocation
  145. Anyone besides Fel-Pro make the water pump drive seal?
  146. Tuning a boosted Lt1?
  147. Another Name That Vacuum Line Thread :)
  148. Newbie from FL
  149. Borla observation on my LT1
  150. Stuck between the XE230/236 & the XFI466... Help..
  151. Profile picture
  152. I HAD to share this with you guys. Enjoy!
  153. The dreaded optispark
  154. Who has the SLP loud mouth on their lt1?
  155. Car pulls strange on cruise control
  156. ARP head stud ?
  157. Fel-Pro 1091 head gasket
  158. engine block warmer/heater?
  159. 4L60E Tranny Help
  160. where to post my build
  161. Quick question about center consoles
  162. i need help for a good start
  163. Bad Camshaft
  164. Ca upgrades what u guys think??
  165. Dynaspark
  166. M6 A4 computer swap
  167. Opti Delete
  168. What part(s) are broken pertaining to the wipers?
  169. where to mount my MSD box
  170. Looking for Heads to send to LE
  171. valve spring 1.750???
  172. Throttle body ????
  173. A/C Delete and Alternator Reloc. Question
  174. who tunes cars in the chicagoland area?
  175. suspension setup
  176. ebay sts style turbo
  177. fuel sending unit or?
  178. Injector opinions....ball type or lucas type..has anyone experimented?
  179. Bigger Injectors? HP guess?
  180. Christine Update
  181. Lt1 tuner needed
  182. Speed Density wtf ????
  183. Help me piece together a very budget single turbo kit for 68 camaro with LT1 please
  184. timing play, how much is too much? vid inside
  185. Auidble Knock/Ping Under Acceleration
  186. Couple of Questions, Continued (PICS THIS TIME)
  187. Installed New Jegs 8.5mm Wires Today...
  188. 383 build
  189. whats causing my high idle?
  190. MSD Distributor?
  191. First time at the track
  192. 385 LT1 new best.
  193. New intake is here!
  194. Motor mount bolts touching...wtf
  195. What is the size of the plastic fuel lines up top in the engine bay? 3/8ths? or?
  196. Retainers and locks
  197. anyone know if these are stock Springs??
  198. PTV clearance for a friend
  199. Keith Black Forged Pistons - Why No Likey?
  200. Who is the "LT1 walking encyclopedia"?
  201. Help-T56 Issues in Germany-SOLVED
  202. Connecting rods
  203. Injector question
  204. Backspacing question
  205. Startin a new Build.. '95 Trans am Got Some Questions.
  206. What the hell is going on?!? Stripped oil pump drives
  207. forsale? twin turbo
  208. ARP part number for LT1 pressure plate bolts?
  209. New Best 60' and MPH for old Car...
  210. IAC Ac offset help! !
  211. Fuel pump not priming...
  212. Intake and Elbow
  213. estimated horsepower or 1/4 mile times?
  214. mass airflow sensor
  215. 97 lt1 shuts off
  216. power steering pump...rebuild or replace?
  217. Cooling on the dyno? 396 dyno pull vid
  218. LT1 Help?
  219. D@mn !t
  220. 97 Trans Am Shutting Down
  221. Lifters not pumping up
  222. car bogs in low RPM
  223. video of the ta.
  224. saturday night!!
  225. Newb here, Can you tell me if this looks right
  226. Flywheel Bolt Spec ?
  227. coolant sensor issue
  228. nitrous hook up
  229. Did my Opti go????
  230. Intermittent problem
  231. Picked up an early borla adjustable
  232. Mechanic Needed...
  233. overheating problem
  234. Low Oil Sensor Block Off
  235. Fuel Lines and regulator on VIC E??
  236. M6 tune ---> A4 tune
  237. Cutouts
  238. Help!!!!
  239. lt1 swap using painless system
  240. Ls7 lifter preload
  241. New personal best...If only I could launch the M6.
  242. Header 02 sensor question
  243. Header Bolts/Gaskets?
  244. LT1 coil plug '95
  245. Hydraulic Roller Lifters
  246. Crank snout keyway and timing marks?
  247. Part Number ??
  248. Cam/Stall choices & recommendation please!
  249. Replacement Clutch disk for Centerforce dual friction
  250. cutting off the muffler....yay or nay?
