View Full Version : LT1-LT4 Modifications
  1. Running out of things to replace to fix my problem...No codes...please help
  2. Idle raises when I pump the brakes hard...?
  3. Lt1 intake
  4. Dash light out.. Cant see anything..
  5. 1.7 Rockers with Hot Cam?
  6. Jegs or Street Fire?
  7. overheating again
  8. help me pick gear / tire
  9. MSD 6AL2 questions
  10. Car misses/loads up when wet?
  11. Will a ported intake work with stock exaust manifold?
  12. Power gains from a 52mm - 58mm tb on a H/C car?
  13. stock bottom LE2 cc306 and 5psi?? hp est
  14. Watching the superbowl? or working on your car?
  15. throttle cable?
  16. transmission help
  17. Is it bad that I can change transmissions faster then I can do an intake gasket swap?
  18. tunerpro questions
  19. Whats the best way to...
  20. need help
  21. LE2 Track Times
  22. Speedometer stoped working, after T56 rebuild.
  23. should i chang cams?
  24. Valvetrain in Winter..
  25. Best & Cheapest way to build 355 LT1
  26. should i buy these or better?
  27. Trouble codes 16 and 26?
  28. high milage lt1 guys, step in
  29. strange question
  30. Need help getting motor at TDC
  31. MAF replacement
  32. balancer and hub question
  33. opi spark
  34. need help reassembling motor
  35. TPS no voltage (and some other issues)
  36. Problem? Any ideas...........
  37. Tuner Pro/ OBD 16 pin HELP!!
  38. Kooks True Dual System
  39. My heads are on the way to Lloyd
  40. HELP! Battery Relocation Issue....
  41. coolant flush question
  42. Quick gear install kit question
  43. engine still runs hot!
  44. What else do us LTx guys need?
  45. LT1 block
  46. think im gonna go to the track again
  47. Oil pump drive mods...
  48. Wideband Install Q..
  49. gear installation kit??????????
  50. cant find elbow sleeve?
  51. Door handle question
  52. Supercharger?
  53. Will this "ebay" Y-pipe work with my headers?
  54. NEW lt1 hauler!! well new to me
  55. lt1 exaust
  56. lt1 exaust
  57. 20 Degree and low coolant light come up
  58. Best tune?
  59. Timing cover seal installer
  60. interior parts
  61. A few seconds..
  62. Fast LT1 guys come in... 383LT1, Fast DFI etc... Come
  63. OTVC plug wires
  64. Tranny Question
  65. Intake Elbow
  66. what cube LT1 should i build??
  67. Sweet Z28 Convertible inside!
  68. Camaro gt1 hood
  69. OBDII to OBDI conversion
  70. 1993-1997 Stainless Steel Y-Pipe $80 SHIPPED
  71. Ls1Tech Calender.
  72. Very low end miss.
  73. Best mid length headers for 95 z28..??
  74. codes from AZ
  75. crank repair sleeve
  76. Shift light
  77. Need help picking a stall for a Turbo LT1
  78. carb intake question
  79. 95 Trans Am spark plug stuck not stripped, maybe rusted shut, and feul promblems
  80. 52mm TB to 58mm TB no tune?
  81. Getting the car back on the road after almost 2 years
  82. Strange 12 or 9
  83. Stall Question
  84. Right bank killing O2 sensors?
  85. Changing wiring harnesses
  86. Rotating Assembly
  87. Coolant Frozen
  88. NPT plug size in LT1 heads? Is it 1/4"-20?
  89. Best oil for my LT1?
  90. LT1 fuel fire n o start
  91. Question!!!!
  92. How to change rev limiter ?
  93. Ever Use These Head Gaskets?
  94. Replacing opti, do water pump at same time?
  95. Ring gap, this ok?
  96. head gasket question
  97. arp headbolts
  98. Looking for a Vic E
  99. GAS!! epic fail
  100. Keep Cam....or... Sell to buy Stall?
  101. 1996 WS6 Smells Like gas inside and outside of car.
  102. Car Still Slow, Getting Sick Of It
  103. 1996 WS6 6speed Transmission shakes when i let clutch out?
  104. Who wants a little LT4 manifold??
  105. Cracked Dash? Need Advice
  106. piston and ring kit.
  107. heads/cam
  108. EVAP solenoid resistor
  109. Overheating
  110. GMPP / SLP Cold air intake on a 93 w/ no maf sensor?
  111. p1441
  112. LT1s running skinnys on the street
  113. Stock style replacement radiator?
  114. what gears 3.73 or 3.90's
  115. head gaskets
  116. 4l60e
  117. Set up question:transmission
  118. Getting started with FAST
  119. What's next?
  120. really bad oil leak
  121. Dick Harrel rear flares
  122. Le1+Hot cam what injectors
  123. LT1 Heads FS/T
  124. Anyone got Borla Cat-Back Adjustable Plates?
  125. Seats and Defroster Circuit Breaker
  126. Removed my balancer/crank hub, got a ??
  127. Got the Cam... Now I got some questions...
  128. Borla or True duals?
  129. 1997 camaro shell
  130. accessories brackets
  131. stripped crank snout
  132. Help w/Data log on Datamaster 4.0
  133. The Fastest Bolt On Only LT1's in the World List
  134. Vic E with elbow and WS6 hood
  135. 2.5" or 3" True duals? And what muffler to go with....
  136. Part # needed
  137. bumper repair
  138. How much compression does a Shim gasket add
  139. Using a 94 MSD opti with a 95+ cam?
  140. Is this guy pulling my chain?
  141. Process for swapping out to 1.6 Comp Cam roller rockers?
  142. quck/electric dissconect sway bar links off road style?
  143. Small starter wiring question
  144. Good Bye LT1....
  145. backfire intake exahust
  146. Lt1 stock rebuild kit
  147. FAST Computers
  148. Beaten to death injector question.
  149. CC503 or GM846, will it pass emissions with a tune??
  150. Need some help guys
  151. Stock rings and rod bearings
  152. does any1 have a picture
  153. LS1 lid swap is easy
  154. Cheap LT4KM?
  155. How much hp can stock 4L60E handle?
  156. help with 94 Z28 camaro
  157. 94 and up questions
  158. electric cut out wireing
  159. headers?
  160. EGR AIR delete?
  161. msd crank trigger
  162. Which muffler to choose?
  163. Removing heads
  164. LT1 Novi 2000 supercharged
  165. Lt1 Revving On Its Own....
  166. y pipe question
  167. whats the best approach?
  168. Quick question about intake porting
  169. What kinda of hp u guys think??
  170. Born to go fast
  171. small problem
  172. Oil on Optispark
  173. Low Coolant light after high rpm
  174. Intake Manifold??
  175. Let Me Introduce Myself
  176. BRE Cam
  177. cam install & degree
  178. power + clutch = $$$$
  179. Question about TCS and the SJM Hurst Style ABS Delete w/ Line Lock
  180. 93 opti replacement?
  181. is this suspension ok for daily driver
  182. Help changing timing cover gaskets!
  183. 24lb injectors
  184. spark plugs? advise please.
  185. 375hp? +/-
  186. Fuel Pressure Regulator Vacuum?
  187. Torqued studs down on heads. A few studs show more threads, should I.......
  188. Gaskets
  189. Gen 1 SBC guys inside
  190. Any one used or heard of this stall ???
  191. Gears installed Dallas Tx area???
  192. Horrible vibration
  193. camaro z28 fans
  194. Convertor size for a Stock LT1 with a 373
  195. lt1pcmtuning.com
  196. Coolant in oil...
  197. Isky adjustable pushrod guide plates
  198. Which Cloyes timing set for LT1
  199. 1.7 rockers on stock cam lift?
  200. k-member???
  201. Golen Heads
  202. Keep My Magnaflow Tips (And Polish Them) or Get Corsa Clones?
  203. Gears, Cam, & Stall???
  204. Idle vid just because!
  205. hooker super comps
  206. tune and steering wheels
  207. winter mods
  208. code p0141 and code p0300 thrown together what does it mean??
  209. modifying a injector rail for 900hp
  210. water pump Question on instalation
  211. Replacing Foglight
  212. Trick Flow LT1 Heads for sale
  213. part number for scorpion 1.6 7/16 stud rockers
  214. Aftermarket Pulley and Damper?
  215. Removing ABS system
  216. PCM Question
  217. LT1 Tuner in Orange County, CA
  218. Stock LS lifters vs LT1 lifters
  219. datalog with a/f readings
  220. Jegs Crank Hub #555-51607 replacement?
  221. Lt1 not running correctly
  222. fuel pump questions
  223. Code p0227 throttle pedal position sensor, help!!
  224. block drain plugs
  225. looking for this LT1 intake,anyone got one?
  226. Stock LT1 Times
  227. Lawhead's 355 Build
  228. Procomp H-beams?
  229. Cold start, won't hold steady idle, stalls at stops.
  230. Hotcam has mild surge when taking off, how to fix it??
  231. Roadmaster w/ LT1 having ignition issues
  232. I ordered my tune!!!!
  233. opti-spark for 93 or 94
  234. Noob Question - Removing PCM
  235. Cheap opti?
  236. Rear end gears
  237. Hooker headers question
  238. Whole new exhaust set up question
  239. What sensor is this??? pics inside
  240. cat question
  241. Skeptical about water pump? help!!!!!
  242. lt4 heads
  243. where are the ls1's?
  244. P0443, P1657, possible bad PCM
  245. opti/throttle body advice
  246. Popping/back firing
  247. Give me a goal for my build. What ET to shoot for?
  248. NEED 2 CATS in any condition!
  249. Opti problems
  250. ABS Light Flashing
