- tuner cat help
- sbc lt1 oil pump
- Help! Codes 16 and 22
- HELP! Found my vacuum leak. Just need help identifying the line.
- Spoke with Lloyd Elliot today!! New plans
- Car is going on a diet...
- regretting this project...
- LT1 missing
- Help?? Fresh LT1 Start Up Issues
- anyone know where to buy an engine oil cooler?
- Is Ram-Air hood needed for LS1 lid conversion?
- Engine idea has anyone tried this??????
- Replacing k member with engine still in the car
- hitmanws6's Build Thread
- i need help
- CAR turned on and slowly dies off. now it wont start
- Will these help me go fast?
- Will a bigger cam make that much more?
- L99 4.3L V8 Swap - 95 M6 Z28??
- help with 383 dyno
- Long Tube Headers????
- 70 chevelle swap to a 96 vette lt4 need more horsepowerand install help
- new catback on my TA (today's project)
- Where to buy forged LT1 shortblock
- Temp sending unit on head,set SES?
- where do i start
- How Much HP will I have After......
- Will Long Tubes fit on 95z w/ eiback prokit?
- ITT post pics of your INSTALLED driveshaft safety loops
- Who runs LE hardware on here?
- I'm pissed.
- taller oil filter?
- push rod length?
- Heater hose diagram?
- found part of my oil leak
- The heck? Mcleod Scattershield question
- lt1 vs SBC
- Anyone used the "chalk method" for cutout location?
- 385 Build research ?'s
- Chris1313 ram air on a 96 WS6 LT1
- Good head and cam combo for LT1 impala ss.
- used stroker
- do they maek a catted y pipe?
- Great ride tonight
- timing advance
- LT1 #2: The Rocket(94 T/A)
- oil pressure question
- Acceleration video of my car.
- how is this product?
- my 95 camaro
- Tuning for a converter....OBDI
- heated o2 conversion for 93's with LT headers
- Anyone have true duals with a bolt-on LT1?
- oil pressure
- crank hub
- Will not shift out of first gear
- What is this and where does it go? *pics*
- Question:Starters.....
- Opti
- fuel injector help!
- Racing Seats
- blm's locked while in closed loop???????
- Gauge cluster question
- Teflon tape, paste, red loctite, what to use on fittings?
- Best exhaust headers?
- OBD1 Tuning options
- Seafoam
- Got my 1/4 mile Track Times!
- Will a bullet muffler soak up HP?
- car running again .. tune Q's?
- block align bored now timing chain is too long....now what
- any differences in LT1 4L60E transmissions?
- My Ls1 lid conversion with Ramair hood
- Starting issue, possibly fuel?
- Ls1 injectors
- My ls1 just beat my lt1's times.
- Fuel injector might be plugged -- need help
- Popping/backfiring
- What is the problem.
- Short video of my car
- first passes at the track
- Driver side header on, question. Pacesetter guys come in.
- what plugs do I need?
- Anyone running a pulley setup like this?
- I need more: Cam Swap +
- LT1 turbo what plugs should i run?
- Anyone shorten their dipstick tube?
- Powermaster sucks
- Please help 94 opti replacement question
- So i finally change out the opti
- Getting ready to run nitrous.
- Removed TCS, new throttle cable too long? Need adjustment help!
- '95 lt1 C4 needs some HP
- wiring harness
- A4 won't shift into 3rd at WOT. Computer or Mechanical?
- Best high flow cats?
- LT1 won't start...help.
- 93 formula 383 21*tfs,eficonnection build
- tranny/engine wobble
- Has my tune been knocked off after rebuild if not then wht?
- how high of rpms is too high
- Gas Gauge Stays at Super Full, Odometer also not working
- Opti removal on blown cars
- tuner cat
- LT1 sponsors please come in - need HELP!!!
- stroker block
- Great results!! 10.30's NA 385ci AI HCI Video Inside
- electric water pump install.
- lets see those lt1 turbo setups
- Spark plug gap question.
- LT1 tuning info
- Stock Rear end gear ratio?
- Ported Stock Intake vs. Ported and Epoxy'd Stock Intake...Results
- Cam question
- Bogging?
- NOS brand dry kit questions
- Timing chain
- Has anyone ever heard of Joe prince racing???
- Coolant flush woes...
- Lunati .590/.600 lift cam
- reverse issues
- My old cam, what do you think of it?
- is an electric water pump worth it
- Next mods
- To port a intake or not?
- yukon 4.10 gears for lt1? never heard of them
- Check engine light, can't read codes
- 70-79 pontia TA headers on 96 LT1
- Fuel Pump or Vapor Lock
- What else do I need to do to properly delete the EGR?
- Cam bearings: coated or not?
- Is there an engine cradle I can build or buy?
- 1996 Impala SS/lt1 crank pulley size??
- Ok to use brass fittings for oil pressure sender?
- If you could rent a lift/bay by the hour...
- Help, my car wont run!
- My New "mufflex like" custom catback
- LT1 Feature car?
- how high should coolant level be in radiator?
- went through 4 opti's in 250mi...wtf!
- Stock 95 LT1, What size piping for exhaust?
- E/T and mph guesses?
- What should I look for - Car missing/backfiring
- opti
- since searching hasn't helped... tuning
- ttop leak
- code dtc 18 -- injector circuit -need help
- How much horsepower do you think I'm making?
- LTI individual throttle bodies? EXTRUDABODY ITB FOR SBC?
- Fuel economy
- Anyone using EFI Connection ignition with a double roller timing chain?
- Starting problems
- total hilarity
- crankshaft/balancer hub
- Should I buy it?
- Whats your brand?
- how to get 400hp
- proven hp from lt headers
- Shaft rockers
- Bigger Injectors?
- Removing front bumper cover?
- TPS voltage too high at WOT??
- stock oil cooler questions
- AI 226/234 results, very happy!
- My LTx Shootout Pics...before my Camara died...
- I need a frame width measurement frome an lt1 guy
- GEN 3 Dynaspark for delteq
- Newbie. Need to be pointed in the right direction!
- Rare 95 TA?
- trying to save money, cant decide ?
- Strange Race Brakes on the Street???
- Whatever happened to the ARAO heads?
- Fuel Delivery Issues
- Questions questions.
- LT1 intermittent crank no start...HELP!!
- Possible to build windage tray in stock oil pan?
- E85 and the LT1?
- Alternator support question.
- 95 Trans Am LT1 Build Thread.
- Gauging Interest - My 455whp 95 T/A...
- New times - Video
- What thread is the side of the block for oil pressure gauge?
- Mcleod Street Twin floater plate / first clutch disc install
- What size belt for march underdrive crank pulley?
- Hit the track last night...did ok
- "What's that hump on the floor?"
- a little vid of the ltwon on her new sneakers
- Have to love multiple torque recommendations
- cam bearings
- how to install rear main seal with the engine on the stand
- Time to play "Whats that wire"?
- pacesetters or ebay stainless headers?
- Mass Air Flow Sensor and 10psi?
- 96 Trans AM LT1 Production numbers.
- 4 wire 02 sensor conversion?
- New personal best 1/8 miles
- What do you guys and girls think
- Anyone weight LS7 lifters vs stock LT1 lifters?
- this ever happen to anyone?
- mattcossel29's build thread
- Irritating Blinker Problem
- Anyone ever sleeved an LTx block?
- Joined the 10 sec club at the Shootout
- What is the best LS1 Lid? Whisper lid any good?
- PHOTOSHOOT: Girlfriend and car!
- pacestter hedders Question. oxygen sensors
- 94 z28 wont start unless wot,and acts like timing is off
- installing new opti question...
- Cam Motion cams
- deeper 9 sec. club : UPDATE
- Oil getting in radiator from intake manifold??
- My GF made a LTXshootout vid for me
- New Opti- Runs terrible
- PLEASE help me identify these heads and springs
- Clutch install question?
- sputtering and cutting out
- Low coolant light
- Mcleod Bellhousing - knock out plate - I am an idiot?
- New times.
- Finally, cam installed and engine running but questions
- VATS Worries in a 94
- A few favorite Pics from LTX Shootout.
- More Tuning Questions (1 at a time now)
- '94 Z28 tunercat file needed
- cai v.slp lid
- 2010 LTX Shootout in car cam videos
- Optispark problem
- clutch/shifting problems.
- how can i make my lt1 faster
- some EFI connection dyno numbers
- Clutch/flywheel recommendations for the new build
- Splash guard for opti
- anyone seen this before eliminate opti
- CC Pro-Magnum rocker arm jumped off the valve, new rockerarms?
- Installed LTs...now fans wont come on
- Difference between Corvette and LT4 Starter?
- What's your best 60' with an LTX M6?
- Complete comprehensive rebuild
- OBX Headers
- what fuel pump to order?
- Stolen car from chicago, need help now
- Factory LT1 Rear End Question
- Ltx Shootout Vids
- LTX Nitrous Outlet Customers
- Passanger/Driver Seat: Possible to swap?
- optispark vs. knock retard
- 2010 LTX Shootout new photo gallery posted
- timing cover and oil pan gasket
- will it run ok?
