View Full Version : LT1-LT4 Modifications
  1. will it run ok?
  2. oil leaking EVERYWHERE :(
  3. records
  4. Throttle Cable Adjustment?
  5. LTX Shootout 2010 - The rest of the story.
  6. Going to refresh my motor, need some advice
  7. indicators of worn spec 3 clutch?
  8. 1st of many tuning questions
  9. What's thicker 40 or 20w50 SAE?
  10. fuel pump
  11. Blower on an LT1?
  12. 96/97 lt1? and theory, trying to figure out distributor signals and such
  13. Need advice from of you LT1 guys
  14. wrong crank hub?
  15. Anyone ever hear of this fuel system cleaner?
  16. Is my clutch going?
  17. Clutch replacement parts list
  18. car wont start after cam and bolt ons
  19. LTX Shootout Video/Pics
  20. Just wanted to say thanks to a few folks
  21. LT1 tach output issue, tach reads double actual
  22. Video: 2010 LTX Shootout Finals
  23. Replacing my fuel pump. Came across some things along the way.
  24. Spider Gear Replacement?
  25. SLP cold air intake
  26. Is a bad radiator the cause of my problem??
  27. 1997 SS power suggestions...
  28. Dynatech Headers?
  29. clutch master cylinder reservoir
  30. Shbox, need part # help!
  31. -8 Feed conversion and fuel system plans
  32. are 1.6 rocker arms worth it? read more inside
  33. white smoke out the intake
  34. where to get a tune in or around northern ohio
  35. New LT1 engine build, help or suggestions
  36. Can my shortblock handle a 150 shot?
  37. TA is dead
  38. Can these stock rods be ID'd?
  39. procharger on a stock lt1
  40. New toys for my 383!
  41. do i need to get this tuned
  42. Hot Cam + N2O
  43. Whats your guys' true dual setup like?
  44. She purrs
  45. Need a retune?
  46. Loudness: True Duals vs. ORY
  47. lunati 54762
  48. Official 2010 LTX Shootout Results
  49. which ignition box to go with (boost)
  50. 1 7/8 headers on the street?
  51. Stock fuel filter micron rating? Need one for E85
  52. is it possible to buy a pcm already tuned?
  53. 355 or 383????
  54. LT1 Build
  55. Hooker slip-fit primary leaking issues?
  56. My custom Ram Air
  57. what do you think of this setup
  58. LTX Shootout! (Photos Added)
  59. smokin after cam install?
  60. exhaust questions
  61. Need Help Fast! Opti Issue
  62. school me on Opti's please..
  63. Replacement Oxygen Sensors??
  64. TB Bypass, do I need to bleed the cooling system?
  65. Need Trans Mount Advise
  66. PCV Catch Can Setup/Writeup... PICS!!
  67. Air Conditioning R&R
  68. A day to forget
  69. TPS output voltage lead?
  70. high beam will not come on
  71. LT1 schraeder valve, fuel pressure sendor question.
  72. bleeding brakes
  73. Signs of a wiped cam lobe??
  74. ever wondered why you should change your cap and rotor?
  75. okaaay
  76. Injector question...
  77. Overheating at idle or moving
  78. Cam and Heads + Build Question(s)
  79. Shootout results?
  80. gasket kit
  81. what poly bushing kit?
  82. Finally it lives!
  83. Brand new 383's oil smelling like gas :(
  84. Coated rod and main bearings.
  85. ok to jackstand here??
  86. where can I get them?
  87. mech. oil pressure gauge
  88. LT1 Custom Build ??'s Computer.....what to do??
  89. Anybody see this?
  90. New times!
  91. Ignition coil/control
  92. Anyone know of a wesbite/forum that got .cal tune files?
  93. Help on figuring out if MAP is 1 or 2 bar?
  94. Good DFI Deal on Ebay!
  95. security light flash Help
  96. Need Advice: Oil in Radiator :-(
  97. stock 6 speed lt1 c4 corvette rear wheel horsepower?
  98. PCM For Less saves the day again!
  99. 02 wire hack and rant....
  100. Cranking partially disassembled engine for compression test
  101. LT1 in a 98 hoe
  102. LTxTech is back up
  103. Our ProCharged Formula featured in GM High-Tech
  104. Egr & air ?
  105. LTX-Shootout Roll Call, Who is here in BG?
  106. Dumb 1st time Header install question...
  107. how much abuse can a stock lt1 take?
  108. Installed LTs/backfire
  109. weird signal light blinker problem
  110. Post pics of your non pillar gauges
  111. ES NA head count
  112. Got the True dual set up!
  113. timing table
  114. surp belt need some help please
  115. Is this the same as the OE AC Delco opti?
  116. what exactly do i need for e.g.r delete and a.i.r delete
  117. Re: LTx Shootout here I come
  118. Gonna send my block out for a cleaning. I'm so tempted to go 383..
  119. Question about catch can????
  120. Need a new starter
  121. Crap, power window stuck down, how can I force it back into the up position?
  122. running rich
  123. How do you get the balancer hub bolt out without an impact gun?
  124. in need for fuel pump info
  125. Changing BCM
  126. Valve spring change getting the best of me...
  127. Help with leak
  128. true dual question.
  129. Fresh build...knock? (video)
  130. Intake Manifold Connections
  131. Car shutting off problem
  132. Ebay ported LT1 intake whaddaya think? Pics!
  133. Opti-spark problems?
  134. Intial LT header install startup/short drive ?
  135. Anyone know where to find 93-97 T56 Slave Cylinder Spacer P/N 12523315
  136. What size nitrous shot so 4L60E lives?
  137. rebuilt or replace lt1
  138. LT1 to LS1 Front Clip Conversion Question...Hindges same or different?
  139. Break in oil/trans fluid question
  140. High RPM stumble
  141. Are the AFR#8002 springs to much for hydraulic roller lifter?
  142. No crank. Have spark and fuel psi
  143. how to launch w/ Stall ?
  144. LT-1 Rods. Difference in years??
  145. New bullet is finally here!
  146. Passenger side motor mount bolts open to oil passages?
  147. High Flow Fuels fuel pump, possibly dead already?
  148. 95 Corvette, stock LT1 with Votech centri, cam ???
  149. Lt1-Ls1 swap questions
  150. %% Official AC Delco 1104032 and 10457702 Optispark Announcement %%
  151. Valve Cover Woes...Need Help!
  152. T56 VSS Sensor!
  153. LTxTech.com Members
  154. Cleaning pistons still in the block. What do you use?
  155. LS1 lid conversion: what lid to buy?
  156. Post up in the attendance thread...
  157. 95 trans am check engin problem HELP!!!
  158. 97 camaro a/c on and off on and off
  159. Help! throttle/cruise cables-delete tcs!
  160. 4th gen Formula question
  161. injector offset what the heck!!!
  162. Before I put new heads on, opinion on this cylinder
  163. my lt1 beat me up today
  164. 1 mod all LT1 owners should do
  165. ltxtech problems, anyone else having them?
  166. Air/Fuel gauge ?'s prior to purchase
  167. Need help finding part..
  168. Does anyone have a stick of dynamite?
  169. need to know required bolt size for oil dipstick tube bracket
  170. New PreBled clutch Hydraulics wont break Slaves "white plastic piece"
  171. one piece rfeaer main seal cranks, are they the same??
  172. Fixed my busted ABS module...Now works perfectly again.
  173. Show me your cooling solutions!!!! Need some advice....
  174. Headers question
  175. lt1 tunning
  176. Gonna attempt my first clutch swap! Any tips or pointers I should know?
  177. Engine coming together but small problem...
  178. AI 355 Build Thread and More
  179. where I can find a 97 lt1 Die Cast toy online at ?
  180. Latest round of mods complete
  181. introduction and a question for the guru's
  182. Quick Video For The LT1 Crowd
  183. Worth it to remove ABS? SJM kit?
  184. Anyone use ARP Ultra Torque Assembly Lubricant?
  185. How big of a difference is a SBC timing cover vs an LT1 cover?
  186. Wtf help.
  187. speedtweakerz 255 install
  188. gauges acting weird
  189. pulley is making bird noise/ and what is this hose for ?
  190. clutch pedal free travel??
  191. lt4 knock module
  192. whats this wire? + funny idle
  193. Lets Go RACING !!! LTX-III
  194. rear end making noise
  195. LE2 over stock heads, whats the HP increase?
  196. Motor mount bolt part #s
  197. headers question (a.ir. or e.g.r)
  198. O resistance when checking fuel sending unit???
  199. Runner up at NMCA True Street today :)
  200. Can anyone give me an Idea what these are worth?
  201. crank sensor
  202. My Dyno Video
  203. Motor?
  204. Sugar in gas tank
  205. Tips for dropping in the new engine?
  206. pulling motor from top!
  207. stock maf? or highflow maf?
  208. 94 camaro wont idle
  209. Blew a head gasket on a fresh motor
  210. Vortech/Emissions questions
  211. M6 Vert won't turn over
  212. A.I.R. delete
  213. Found on EBay
  214. Smoke out exhaust only at high RPM's / WOT?
  215. autopartsdealer.com - do not use, what a joke
  216. Need Help! Stuck at TA Nat's - Ignition Fuse Issue
  217. best looking cold air intake for the moneys help pls
  218. Changed my intake gasket and will not idle????
  219. Walbro and KR questions
  220. best place to purchase a t56?
  221. MSD mounting question
  222. LT1 paxton supercharger Plug gap question
  223. overheating what ya think?
  224. 97 camaro 95 lt1
  225. Does the M/T ET Streets (bias-ply) require inner tubes?
  226. Mufflex Exhaust Tubing
  227. Intake Setup
  228. Car died yet again, and wont start back up for about 20 mins.
  229. Crank Bearings.... can they be fixed in the car??
  230. Bad day at the track.
  231. Just Picked Up My New Toy!
  232. Trick Flow Twisted Wedge heads.
  233. Question about gears
  234. Injector Size Question
  235. 85 z28.. lt1 swap
  236. What should I do for exhaust?
  237. long term question, ebay headers
  238. Some banjo playerz told me TR55's go for 2 dolla?!?!! any1 know where?
  239. x pipe with short header ?
  240. 95 trans am starting issues
  241. My true dual setup.
  242. Picked up a set of NGK TR55ix iridium for my LT1..how long u think will last in mile?
  243. Gas tank issues, is this normal?
  244. replacing fpr
  245. Mother f#@@! !@#$ !@#$@!!
  246. any write up on how-to change opti on 97 camaro ?
  247. LS1 air lid on LT1
  248. oil leak over opti spark, how to clean it up ?
  249. is this too close to the header? help me out here.
  250. what does 4th gear top out?
