PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. Question about stock main bolts and arp main bolts
  2. VIN DECODER, what happened to compnine?
  3. Arp head an main stud questions..
  4. Gauging interest......5200 Stall Vigilante
  5. ATI MRT Treemaster 8" Converter 4L60E people come on in....got a ? for ya...
  6. Le or ai cam?
  7. Something is VERY wrong.
  8. Car want start after rebuild
  9. Mac or Dougs
  10. Rpms
  11. Bad Ignition Coil Module?
  12. true dual exhaust questions
  13. 1997 LT1 Trans Am
  14. ws6 hood ideas?
  15. Car keeps dying
  16. cam help!
  17. AI & LE 226/232 or 226/234 Cam Results
  18. Hesitation at Low RPMs
  19. LTs Too Quiet?
  20. Electric vacuum pump on street, always on or switched?
  21. broken fuel line
  22. Cc306 cam.. General question..
  23. Need help with my lt1!
  24. Best way to do this
  25. F#ck Optis...
  26. 8.72@158.8
  27. Need to fix these 2 last bugs.
  28. Take your mom for a ride in your LT1 lately?
  29. Check Engine Light
  30. Question on dual pump set-up for 95 formula
  31. ? about 94 z28
  32. How do I gut the stock LT1 valve covers?
  33. car lost voltage then died?
  34. High Speed LT1 cruise
  35. Does this go there, if not where?
  36. Tuning an Unknown ECU
  37. firing issues
  38. Wont run below 3000 rpm or it sputters and dies
  39. Is this an easy fix, electrical problem.
  40. Before I call it a night, my car is okay with coolant still in the block?
  41. Help
  42. What size Cam can I upgrade to?
  43. Can this tail light be fixed or is it junk?
  44. Tune vs tire size
  45. First Kill
  46. What can I get out of 383lt1?
  47. 24x DIY harness help...
  48. Only have 30 miles on new engine. Too soon for dyno?
  49. 355 LE2 Build w/ Pics
  50. Trap door cut, now HOW DO I GET IT OUT?
  51. 24x Plug Wires
  52. PCM for less tune vs Dyno Tune
  53. Firehawk Motor Removal
  54. Traction Control on 93?
  55. Turbo LT1 preliminary results
  56. car vibrates when AC is on
  57. Anyone have the link to the F body exhaust comparison?
  58. Another year gone. Did you meet your goal? Next years goal?
  59. Looking for some opinions
  60. Best, quietest sound for my H/C 383 LT1 - Borla or Magnaflow?
  61. wtf!!!opitspark again?
  62. All those with heads/cam, what's your temp in traffic?
  63. 96-97 ram air
  64. SVO red top injector fail
  65. Damn. Brand new rear main seal is leaking.
  66. Another Lt1 Down
  67. tpi intake
  68. Timing Chain ?
  69. Air filters for the Firehawks/WS6's.
  70. Stumped on Readings
  71. ls1 ir led on lt1 ?
  72. Looking to build a car?
  73. Steering Issues!
  74. Hypertech Power Programmer
  75. O2 extensions
  76. voltage problems
  77. LT1 turbo cam and turbo
  78. Removing the stock passenger side exhaust manifold
  79. 100k for a 1996 Z28 ??
  80. Picture per Question. Wrapping up my build.
  81. Cam selection?
  82. High HP low torque high revving engine options
  83. 355 Winter build plans
  84. New motor mounts alter location of motor?
  85. 8 sec LT1
  86. A/C delete
  87. LT1 radiator hoses, which one is the "feed"?
  88. Gooddbye LT1
  89. black LT1 fuel door cover. where?
  90. 1992 lt1 vette engine?
  91. Whats it worth?
  92. more gear?
  93. WTB Used LT1 Heads
  94. Back by popular demand - Evil Opti Throttle Body Plate
  95. Hood hinge bolts
  96. strange noises
  97. should i tune my car
  98. Lowering springs???
  99. cradle reinstallation
  100. New cam question
  101. My AI heads and cam stoker goes 10.37 @4200 lbs
  102. water pump vs water pump & opti
  103. Another "whats it worth"
  104. TA is for sale.
  105. Is 12's possible with my set-up?
  106. I need help
  107. Cam question
  108. does anyone have weld prostar wheels on lt1?
  109. EWP and LS1 Lid...clearance issues with fan shroud?
  110. How to Fix Low Voltage Issues
  111. ls throttle body conversion...?..
  112. 50 over question
  113. Are these fine headers for a CARB compliant vehicle?
  114. LT1 TURBO 76mm or 70mm
  115. block ventalation questions for the pros
  116. Plugs
  117. Opti recommendations..
  118. Ok guys, stock LT1 options
  119. runnig rough
  120. GMHTP Feature!
  121. Carbed LT1 using the ECM to run the optispark
  122. Can this be fixed or do I need a new brake line? (pic)
  123. 97 ss TUNING?!?!
  124. Turbo engine build questions
  125. Best emissions legal setup (headers)
  126. LT1 turbo tune
  127. Trickflow 195cc with 72cc... throwing an idea around
  128. Side markers and front blinker... opinions/legailty
  129. lt1 tuning
  130. sunoco and ls1 lid -not fitting so far
  131. Throttle body opinions
  132. High idle at start up
  133. Vac lines
  134. Want to completely change direction with my car...
  135. Carbon Fiber Valve Covers
  136. Almost lost the Bird last night but a new PB
  137. Is it .030 or .040 over?
  138. vacuum lines
  139. 1995 Z28 Camaro cold engine start runs fine. when heats up problems appear.
  140. lt1 lt headers
  141. wiring
  142. Rotating assembly recommendations for 96 Corvette LT1
  143. Starter problems, need help
  144. Those with EFi Connection system done
  145. Headers with stock y pipe?
  146. Brake Line Flare Type
  147. Whatcan cause a 4L60e's transmission pump to consistently go out?
  148. Ls1 airbox conversion
  149. Urgent Ultra Pro Magnum lt1
  150. results of a loud pop....
  151. fuel pump
  152. Best/cheapest LT1 LT headers, where to get them
  153. 24x Re-Pin - 94 or 97 Harness
  154. Do they make spray on BBQ paint?
  155. 12.05:1 Static - Dynamic ?? & What is good for boost ?
  156. 14 years later, it's lives.....(vids)
  157. Gregrob Update my status, Greg97z I DID IT...
  158. ruled out fuel pump...exhaust leak?
  159. How to plug heater core lines from waterpump?
  160. Opinions!
  161. Is this an lt1 or ls1?
  162. Lt 1 for sale Houston,Tx
  163. Not sure what to buy
  164. Oil Pressure Sensor 94 LT1
  165. Where to get a fan bracket?
  166. idle drops when pressing clutch
  167. Lt1 is out of action again
  168. anyone have pix of complete dash out of car?
  169. Copper Braided ground wire??
  170. Fuel Pump dead?
  171. Vegas
  172. more codes
  173. wheel adapters
  174. Coolant leak behind motor
  175. Why would these wires to the PCM be tapped?
  176. Valve covers needed
  177. water pump
  178. Lt1 (need help!!)
  179. heater issues need fixed soon!
  180. Lt1 grounding out...
  181. Oil cooler lines question
  182. !!! I need a stock oil pan!!!
  183. security lite
  184. All the catted y pipes/fit pacesetter LTs
  185. Pump the gas
  186. Hooker y-pipe in but not a perfect fit. (pic)
  187. Will an auto lt1 idle with a manual pcm?
  188. 95 LT1 swap into 94 camaro Q&A
  189. Idle problem after 52mm ported TB install
  190. First Crank on the new motor
  191. Waterpump Driveshaft Seals...discontinued
  192. Will kooks headers clear angled plug heads?
  193. Panhard bar????
  194. Catback Vs Straight Pipes?
  195. PCM problems
  196. HP limits of stock fuel pump?
  197. is gasket port matching worth it?
  198. Cat question.
  199. LT1 after market cam check???
  200. Craiglist add?
  201. need a fuel pump
  202. New to nitrous, a few questions
  203. New Racetronix fuel pump and new fuel tank installed but forgot the harness!!
  204. Can't use stock clips to hold down 42lb injectors
  205. Help Finding Specific Valve Covers
  206. Valve?
  207. Give me some ideas for fastest cam only options
  208. Custom catted y pipe vs manufactured
  209. Stumble start and roaming idle
  210. cooling fan relay bypass
  211. Heater hose assembly question
  212. road crews.
  213. keep my cat back or not?
  214. Pulsing Vibration in Rear
  215. Head gasket question
  216. AEM wideband
  217. Help! Cannot find parts in the UK
  218. LT1 Build plan while in the Air force
  219. ACCEL DFI GEN 7 for lt1 any good?
  220. Part Number for heater hose
  221. 95 LT1 F body - best fitting long tube header today?
  222. Stand alone fuel injection questions
  223. fuel pump trap door plate dimensions. help!!!
  224. 02 sensor help
  225. Went to the track, anyone got a spare t-top?
  226. advice need
  227. LS1 Lid Conversion....pics
  228. Torque converter bolt?
  229. ls1 knock sensor on LT?
  230. 93 lt1 problem
  231. Anyone running hypereutectic pistons in their 400+rwhp N/A motors?
  232. LT1 paxton sn95 model qestions on product
  233. compression and boost question with a cometics head gasket
  234. 95 z28 with heat coming from behind the center of dash and console area
  235. GM discontinued the LT1 pressure plate bolts. Now what?
  236. Your muffler of choice to replace SLP muffler? (pics)
  237. Weird Overheating Problem again
  238. 409ci lt1 with 300 shot
  239. 396 SR Setups
  240. Will a LE ported intake work with my Non-LE ported heads?
  241. Flexplate Issues, please help!
  242. What are these idle control parameters?
  243. 900hp lt1 build not going so good need help asap!!!
  244. O2 sensors??
  245. Ai 385 LT1 Stroker Build and Pics
  246. 1994- 1996 impala guru's
  247. Going to the track tonight need tuning help
  248. Help need crank hub
  249. A rare LT1 part just arrived at my doorstep today.
  250. LS1 Swap , Electrical Help
