View Full Version : LT1-LT4 Modifications
- 1994- 1996 impala guru's
- Going to the track tonight need tuning help
- Help need crank hub
- A rare LT1 part just arrived at my doorstep today.
- LS1 Swap , Electrical Help
- Need Some IDEAS!!
- Wheel Adapters?
- Going with A JASPER 355
- 355 New Build Idle
- Need Veteran LT1 Opinions...
- LS1 PCM swap Vs. Accel Gen 7 DFI
- done lol
- 93 Z28, IAT showing 150+ degrees
- P0332
- Header question's
- pcm? opti? icm? pinched wire? car wont run! what do you guys think?
- lt1 bolt ons..
- 96-97 two piece headlight harness
- Coolant "filter"? (Don't use Blue Devil)
- lt1 overheated...less power than before?
- Rod / pistons
- What 1/4 time would my lt1 run???
- need some stuff to finish my 383
- Autolite 104, 106, or?
- 355 or 383
- Spark at coil, no spark at plugs, wtf!!!???
- Pass side O2 reading false lean, thus running pig rich!
- lt1 injectors not firing
- LT1 dying and hesitating
- lt1 random misfire help
- Lt1 advice
- ltx engines
- Just ordered a couple of BMR Chassis pieces...
- Whats considered a normal/good AFR?
- 1993 Z28 LT1 is Studdering (Famous I know)
- Neutral balance flywheel on stock LT1?
- How's this converter?
- Ignition Switch heat problem
- Symptoms of a dying alternator..
- Painted long tubes vs coated.
- HELP!!!! Loss of Power and Weird Whistling Sound
- $150 for headers good/bad?
- Ignition issues need help!!!!
- Borla ProXS...
- After 14 years together I sold the Z...
- lt1 corvette cai on camaro
- Anyone set up a B&M Pro Ratchet b4??
- Post up pics of true dual exhaust set-ups please
- backfire at wot
- Engine Temp Issue
- Fuel Enable Malfunction?!?! Code 46 - also IAC, completely stumped
- Where to find stock valve cover bolts.
- Tune issue? Keep fouling out 02s
- red plug???
- LT1 to LS1 T56 Conversion
- My junk.
- Fix or replace SLP's 2 on the left muffler?
- Optispark Vacuum Harness
- Anyone know the size of the trans crossmember bolts?
- Lt1 wont crank after opti install
- Stall questions for the new procharged 383 Build?
- Which cam is better for a blower....112lsa or 114lsa?
- 95 scanning woes
- timing chain
- wire harness delima!
- Body Grounds
- CSR Electric Waterpump Wiring
- HORRIBLE gas mileage. 10-15 highway, 5-8 in town. D:
- Question about heads.
- carbing a 97 lt1 motor, hub question
- lt1-427
- Car Won't Stay Running !!!
- New tune question!
- .1" offset rockers on cammed LT1? Valvetrain guys come in.
- Pcm
- 96 LT1 Starter
- Zex nitrous kit yay or nay?
- Too much cam for 6-speed?
- Code Reader Suggestions?
- LT1 gone Optiless "it Lives"
- stupid question...
- bilstein hd's or KYB AGX's??? HELP
- Getting WOT knock on E85?
- LT1 Street cam suggestions
- Cant get it to Lean out (Help Please)
- SLP Loudmouth on 1996 Trans Am
- Help! Starter wont line up
- LT1 runs then dies
- Manual brakes
- temp gauge.. need help!
- harness??
- 93-97 98-02 Exhaust???
- Smh
- sbc 400/lt gen
- whhhhhyyyy?
- What will fit?
- Couple of questions
- From personal experience, how hard is a heater core swap on the lt1?
- ls1 heads on a lt1
- Solid motor mounts
- A little help needed.....
- LT1 would'nt start,...loose coil connector?!
- How do you secure the radiator without the condensor?
- 95 LT1 acting up
- Started my LTCC conversion
- Car will not run at temp
- Intake Question
- Racetronix walbro 255 pump install question
- header gaskets
- Supercharged Stroker Q's
- Starting problems
- Car died on the road
- 1995 Camaro LT1/T56 high idle!
- 12s finally
- lt1 startup issues
- How much Gain with UDP & EWP
- Heads "MILLED" .030
- 355 build with lots of questions
- My how things change, the car is for sale.....
- Cammed LT1 track #'s & Nitrous #'s
- How much slack is too much?
- need stall advice..
- Any ideas on a stuck head dowel pin?
- when is rains it pours
- Very Confused!
- WS6 Ram Air Box, with 85mm Opening conversion
- Steering link swap question
- Gm846
- Help with new 396 top end!!
- Ls1 ??
- On the front
- short block needed
- 1995 Z-28 A.I.R pump bad
- Hotcam goes 10's...
- Anyone make 2inch headers
- lt1 24x convertion
- Rear gears for auto. 3.73?
- Throttle Cable
- LTCC install experience
- Hard Start on Fresh Rebuild
- Permanent Tranny Mount
- driver side cat replacement cost?
- Rough idle at times, stumble @4500+, oil gauge bouncing around. Ideas?
- Dipstick tube
- LT1 Advice please.
- Ignition timing for cruising?
- Check Gauge Question
- car is falling apart, rear shaking now.
- LT1 Motor stumbles only when driving in traffic!
- Gears and stall? For a high 12?
- Black c6 zo6 rims
- New Concept
- Battery Relocation
- Transmission leaking :(
- Dyno blues
- So what are these "free mods" I am always hearing about?
- Heater Hose
- Need Some Help Plz....
- Engine Hours Gauge?
- Quick AC question
- Can I Break Into 12's
- Which of these hoses is NOT for the cooling? (pic)
- Moroso oil pan leaking from one of the plugs. (pic)
- Which side does these wire looms go on? (pics)
- ignition misfire?
- Seals and Bolts
- looking at 95 z28 what to look for....
- thinking about building a street strip car
- A little more progress on GTP AFR/LE SR 383
- Weird Header Question....
- can we put LS1 MAF on LT1?
- torq thrust
- cps reluctor wheel?
- will i pass e check
- Question!!
- solid roller 383 12.5to1 le2
- Cam suggestions with TFS 195's 23*heads
- Ordered parts for cam/boltons.
- Pulling engine...HELP!!
- The Blue Beast LT1
- The Blue Beast
- LT1 Fuel Cooler?
- Got my 4th f body, what mods should i do next??
- missing but not
- Motor torn down !!
- 10.13 @ 136! New PB!
- How hard is it or am i crazy
- need help with a mcloed twin disc
- Wiring gurus - electric water pump warning light help please
- Puzzling LT1 problem
- Throttle Body Spacer and a ?
- Lt1 a4 shift mph?
- 6LE front bumper
- 10% summit discount cupons..
- back firing
- SCAT Rotating Assembly
- 95 t/a died while driving last night
- Low Coolant Sensor
- difference of cutout with my exhaust?
- abs inop & brake light...
- Car died on the highway..help!
- lt1 tuneing help "rev limiter"
- a4 to m6 issues
- opti question
- I has oil pressure!??
- head gasket for boost
- 93-97 e-brake weights, are they necessary?
- holley dual plane 300-36 on an lt1
- Re pinning harness for 24x
- lt1 power loss.. too much/too little fuel, possibly spark issue?
- oil on plugs?
- Ram air help
- Gauging Interest....Help me price it
- trans cable ball/socket end
- icm or maf problem?? (Not iac or maf still same problem)
- Engine Vacuum??
- Throttle Body Plates - Evil Opti is back!
- Price of LT1 F-Bods beginning to rise?
- Street Motor LT1
- I need a roller
- How to post pics
- Carbon Fiber Sail Panel
- sometimes my car makes me look stupid....starter dead spot?
- My 25th Anniversary Trans am
- What Coverters are you guys using?
- Brakemotive....Thank You.
- LT1 tune advice - dfco
- SES and AIR removal
- Voltage regulator going bad?
- Intake Mod for Injectors?
- not starting, any help plz
- cam package help for 96 impala
- Muffler
- hey i had some questions about cams for the lt1 96 impala
- How do I know if it is an LT1 or LT4 KM?
- Trend PR's arrived today
- Rear end shift?
- Front brake wear
- Odd starting problem
- Slp cai
- Fuel Gauge Install Line
- '96 B-Body LT1 Cooling System Questions
- 95 T/A freshly rebuilt AC system keeps shutting down.
- Motor removal
- Amsoil?
- 1995 camaro z28 vented opti spark qestion
- Is it worth putting a cam in?
- O2 bungs and senors on hooker long tube headers
- Why does my car knock so much in the 2-4k range?!
- timing chain 24x conversion
