View Full Version : LT1-LT4 Modifications
  1. will i gain anything by adding a ac delete pulley
  2. Best way to connect headers to muffler without welding.
  3. --> I really really hate optis...
  4. Crap after reading I don't know. Should I do straight or splayed 4 bolt mains......
  5. Intake diagram, pics?
  6. No Power With My Car From A Roll Or A Stop
  7. quick question about the EGR
  8. helicoil size for header needed?
  9. finally made it to dynotune
  10. A/C, belt tensioner questions
  11. ARP head stud torq specs???
  12. ahhh my horns finally!!!
  13. Trick flow questions
  14. Which 4 bolt splayed main caps? Are the olivers ones discontinued?
  15. Which billet steel flywheel to use?
  16. need a tune
  17. Ngk tr6 part #
  18. rear differential service
  19. Engine Wash
  20. Engine bit the dust
  21. Electric Water pump and wiring Q & A
  22. SS Hood, Wing
  23. t56 conversion
  24. Replace/install A/C lines with longtubes installed?
  25. catted Y pipe for lpps
  26. 2 things
  27. another problem
  28. who to tune LT-1 in the southeast???
  29. LT1 fuel pump issues
  30. Nitrous Outlet Victor "E" LT1 Intake (Pix)
  31. oil sending unit/oil pressure
  32. Finished headers, question about egr. . . .
  33. WS6 air box vs. LS1 lid?
  34. Q's about tuning and which direction to take the car.
  35. List of stuff needed for installing headers
  36. Poor Running LT1 w/ lots of new stuff
  37. power loss on lt4 build
  38. Problem with plugs?
  39. takout catalytic converter on lt1
  40. opti spark harness
  41. vats/radio/will it start
  42. Hot cam in non factory roller block
  43. new plugs and gears?
  44. stock leather seats weight?
  45. 21 degree Trick Flows and cam selection
  46. Idles at 3000rpm, only after a session on WOT..help!
  47. ideas or suggestions for lt1?
  48. Not sure if this is the correct area for this question, but it's about 02 sensors
  49. whats best stall converter brand for lt1, or for my Z?
  50. ac question
  51. stock+75 wet shot = what time
  52. stall converter
  53. should a vented opti hold vacuum?
  54. Water pump leaking and A/C problem?
  55. Pics of new hood and intake setup
  56. gm847 86 kpa @ idle?
  57. Who makes single gauge pillar pods for our cars?
  58. i got it running there is a new problem
  59. True Duals, Fuel Lines and Exhaust Hangars
  60. Still no spark after new ignition parts..
  61. Increased Gear Whine
  62. motor mount bolt
  63. A couple of quick questions for you guys..
  64. stock lt1 turbo questions
  65. need to know stock 1995 z28 6-speed differential gear ratio??
  66. cc305 and smog????
  67. Good to buy or walk away from this deal ?
  68. possible th350 swap?????
  69. finishing my top end -would you run CC lifters?
  70. o2 extensions for 93 z28
  71. Hooker catback
  72. LS1 K&N FIPK Firehawk hood?
  73. The Purple Bird
  74. How would you set-up your DD.....
  75. LS7 lifter preload...
  76. Question For Anyone Who Has An A4 4l60e !!!
  77. window motor how well does this work
  78. What to do with my car?
  79. msd opti?
  80. got some issues please help
  81. Got a scenario here but is it worth it?
  82. LT1 Stroker questions
  83. emission friendly headers
  84. What to do with th lt1
  85. 1.6 roller rocker install
  86. Question for LT1 guys running a McLeod Master Cylinder
  87. LT1 representin' at the Hotrod Power tour! I did yall proud!
  88. New Dyno Tune But .....
  89. 1997 Camaro lt1 alternator
  90. missing at crusing speed
  91. Weird suspension issue. Car is 4x4 status out back
  92. Anyone running the Comp 236/242?
  93. Raced the car last night!!!!
  94. k member bolts
  95. Took long trip, very happy w/mileage
  96. Valves to use with 1.6RR's
  97. question
  98. short throw shifter bolts?
  99. any ltx supercharger guys out there??
  100. You won't believe this!!!
  101. Will a Fiero Manual steering rack work on my 96 lt1 camaro or
  102. Check this sound out guys
  103. Some LT1 Powder Coated Eye Candy...
  104. egr block off plate
  105. help please! oil gauge keeps getting lower!
  106. lt1 questions please help me!
  107. flowmaster one chamber will that sound good on a lt1
  108. manifold/injector rail removal
  109. Milling used heads Necessary?
  110. Will an EWP keep the temps cooler?
  111. Looking for LT-1 block in N. Carolina
  112. My idea for my exhaust....advice wanted.
  113. Boltons completed... Tune worth it?
  114. head to intake problem
  115. Any LT1 owners do there own pinto or mustang II manual steering rack?
  116. Vacuum leak
  117. Need to rave a little
  118. Idle running rich(116 blm and going lower) after nearly nothing...
  119. random sputter?
  120. what did i do wrong?
  121. crank hub sleeve
  122. Does anyone know how to use mr gasket rocker arm oil deflectors for rocker adj
  123. used clutch and flywheel
  124. Need help
  125. Please help diagnose my LT1!!
  126. Exhaust shop screwed up catback install....need options
  127. why is the temp reading different?
  128. locks and retainers
  129. new longblock
  130. Autolite 104's
  131. supercharger crank pulley????
  132. chandler ebay opti
  133. wanted: 94 harness and ecu
  134. What bearing clearances for 400rwhp + 250 shot, recommended oil weight?
  135. opti stabbing
  136. 2 bolt mains
  137. Why do I keep trashing oil pressure senders?
  138. 4L60 Problems
  139. Classic. One of the best commericals ever...
  140. surging at start up
  141. Who is running Dynaspark ? Opinions ?
  142. Chasing no spark @ coil or plug
  143. 93 camaro code 42
  144. What Converter?
  145. will this dry kit work ?
  146. how much power and/or rpm have you thrown at your forged eagle crank?
  147. lifter question? roller rocker adjustment?
  148. acceleration problems
  149. MLS Cometic Gasket. What size bore gasket for a 4.030 bore engine?
  150. What plugs for a dry nos kit
  151. Whats the difference in alternators for 93-97 z28s?
  152. Electric Water pump install??
  153. Blown 355 or 383??
  154. metal in motor, carbon on pistons
  155. Post Up Your Single Plane PICS!
  156. Misterious Oil leak...Update please help.
  157. Engine Removal!
  158. How much spring pressure can hydraulic lifters take?
  159. 1994 Z28 PCM Question???
  160. Questions about gauges.
  161. Coolant cross over
  162. Idle problem - URGENT
  163. backfire through cold air intake
  164. help with headlights and starter
  165. svo red tops?
  166. Dyno's in Texas?
  167. Head casting#
  168. Setting the TPS
  169. need help. where to get a computer tune?
  170. Pcm tune after headers?
  171. WTF! $550.00 Opti......
  172. neutral balanced flywheel
  173. new motor mounts??
  174. LT1 Not Starting. .
  175. Warm start lt1 issues
  176. cut my muffler off
  177. piston recomendations
  178. Spark Plug Wires
  179. Need help with an oil leak!
  180. 3.4 to lt1 swap harness help
  181. Pacesetter off road Y
  182. EGR delete?
  183. JBA Headers
  184. what color caps are on stock injectors
  185. ebrake problem
  186. Oil inside the intake manifold issue...
  187. Is it normal to get random knock retard counts on cold startup?
  188. do i need a computer tune after header install?
  189. lt1 stock injectors vs. 24lb ford svo injectors
  190. Another rocker question.
  191. Oil Leak From Valve Cover - Help Please!
  192. ECM question
  193. Fuel injector ground wire location?
  194. What size injectors for 396cid LT-1 on E-85
  195. please help, rough running 94 trans am
  196. proform valve covers
  197. Optispark Check Valve Help
  198. LT1 Header Question
  199. rod bearing replacement
  200. Proform Rockers
  201. Scratched side windows, can I remove this safely?
  202. knock sensor part number what year is this?
  203. Volt Gauge Problem Please Help
  204. 1993 camaro z28
  205. Opti replacement
  206. still alive!!
  207. How many hood pins do you pin on guys have?
  208. 95 4l60e speed sensor?
  209. Edelbrock ProFlo XT on an LT1?
  210. TEASER: BLS 93-97 True Bi-Xenon Retrofit --PICS
  211. rear susp
  212. More problems...
  213. Magnaflow compared to GMMG im torn between the two.
  214. LT1 Burning Lots Of Oil
  215. Question about o-ringing my block and using copper gaskets. Also are hellfire rings..
  216. help add some input to my build
  217. Ongoing problem need some help!!
  218. 2010 Build: 3.4 to LT1
  219. MSD Optispark Help..
  220. about to pull the trigger on the S60....
  221. LM1 vs. LM2 bullet muffler
  222. URGENT - Powersteering pump fastening bolts
  223. Belt Slip
  224. wheel wobbling
  225. 1997 Camaro urgent please help
  226. Going to dyno on June 9th
  227. How much strain on the engine by running the AC in 100+ weather?
  228. Frustrated- MSD Opti…
  229. 97 fans aint kickn on
  230. Cracked radiator
  231. lookin for exhaust clip
  232. Dyno Numbers/Misfire Help
  233. It lives and breathes!!!
  234. lt4 camaro computer problem please help!!!!!!!!!!!
  235. LT1 Electrical Concern
  236. Anybody running Kooks LT headers
  237. Gearing question.
  238. Supercharge Or Turbo Lt1
  239. Over size filter for 93-97 lt1 ?
  240. LT1 fuel pumps
  241. need help setting WOT tune.
  242. Piston to valve clearence.
  243. track results
  244. cam bearing
  245. I searched for days. Please help (carb conversion)
  246. knock module issues
  247. Finishing up 383 A1 21*Build
  248. Help Needed!
  249. Found an antifreeze leak...How to fix?
  250. catted y-pipe that works with LPP longtubes?
