View Full Version : LT1-LT4 Modifications
  1. Car wont start, see what you guys think of this.
  2. Ride height change, what do you think ? PIC
  3. corvette AC compressor top plate
  4. How to set the oil pickup tube height?
  5. newby to ltq... opti.... never messed with one, need advice
  6. SES light on at idle at lower than 1500 RPM and off at above that RPM
  7. Vehicle Speed Sensor concern 4L60E
  8. Motor Mount replacement help PT.3
  9. Injector Question?
  10. should i keep my ZO6 Wheels? help im undicided.
  11. Help Finding Cam.
  12. Where and how much can I buy a camaro SS hood for?
  13. Best Fuel Pump To Buy???
  14. Put coilovers on the LT1 yesterday...
  15. 383 LT1 SR cam 88mm turbo HD VIDEO part 5 Test Drive
  16. Needing some help finding a bellhousing
  17. abs light on
  18. gettin dyno tuned april19th
  19. concerned about 383 build
  20. lost power with exhaust? help
  21. EFI 24X LS1 pcm conversion
  22. My Spring Break "Build"
  23. help help help!!!!
  24. About to start my build
  25. 1995 Pontiac Firebird Formula - Console Options
  26. LT4 388 ci low number at dyno
  27. Quickest Fix for MAIN SEAL Oil Leak?
  28. What Is The Thickest Header Gasket ???
  29. No Start After Wire Change
  30. SES lights on...
  31. 130MPH and counting...
  32. Slowly getting there!!! Found a few problems on the way...
  33. FUel Questions??
  34. Apperance mod for my black LT1
  35. Motor Mount replacement help PT.2
  36. What can ya tell me?
  37. do i need a S-pipe
  38. Where are you guys shifting the lt4 hot cam?
  39. Exhaust question
  40. Damn my luck. Oil pressure drops during hard braking.
  41. spark plug ?
  42. LT1 Stockers At Rockingham
  43. Opti Vent?
  44. Need a wire harness number and help
  45. Block Filling
  46. Keyless FOB Programming
  47. Any advantage using LS1 injectors?
  48. Motor Mount replacement help
  49. Any Ideas???
  50. Everyone that put GMMG on yout LT1
  51. Anyone having problems with oil pressure sensors when using the white spring?
  52. GU6 non locker?
  53. Lt1 Newbie P0300 code
  54. help with moroso 7 qt oil pan
  55. Im bored and was just wondering since I see so much of these question?
  56. Lets see how good you guys are 1/4 challenge
  57. Did I put my clutch DISC in backwards?
  58. LT1 tune?
  59. My first mod
  60. newby to lt1 got some questions
  61. Where does this hose go!?!?
  62. 93 Camaro LT1
  63. colder pluggs??
  64. Arp rocker arm studs?
  65. dash connector and power steering questions
  66. 96 Firebird Formula pt 2 video
  67. Cranking compression, what is average for a LT1
  68. My 570zx build
  69. School me on Nitrous!?
  70. Forged crank 3.48 stroke
  71. What race weight are you guys able to reach?
  72. 94z egr delete
  73. Questions about FAST XFI
  74. need help
  75. Tempeture sensor doesn't work
  76. harlan shift light rocks
  77. lt1 nitrous
  78. motor issues update:
  79. Want an x pipe but know what to get need help
  80. lt1 bare minimum's
  81. lt4 pushrod length?
  82. Best Header Gaskets
  83. Rocker Stud Questions
  84. speedometer off
  85. Breakdown of a previously supercharged engine reveals.....
  86. TB Bypass Question and ABS Delete
  87. TB bypass and hypertech
  88. driving the car with open headers reply!!!!
  89. Dyno'd Lean as Hell
  90. Motor mount bolts
  91. lt1 383 is shutting off at wot
  92. LT1 Alternator Relocation Bracket Problem
  93. Lt 1 IAC Removal
  94. i need ram air box dimensions
  95. How do you clean a MAF
  96. New Best 60ft
  97. oil pump rebuild/relief valve
  98. Help Please! Engine electrically died on return road after run
  99. vacuum hose diagram
  100. Anything else while I'm in there??
  101. 58mm throttle body
  102. Head bolt size?
  103. 04-06 GTO fuel pump into LT1 F-body???
  104. Safe CR with E85 on TC78 383.
  105. ECU Code: Low-Res Failure?
  106. Oil Pressure problem???
  107. Fog light socket
  108. Fuel economy sucks.
  109. should i be worried?
  110. valve spring/roller rocker install
  111. GM white spring/ Weld pickup on?
  112. Harness Question
  113. If the 7.09 made you mad you will love this!
  114. New build & OBD1 LT1 PCM won't turn on??
  115. Light weight battery
  116. missing
  117. Low Trac Light
  118. just installed an SLP loudmouth 1
  119. MAF electrical problem please help.
  120. fluctuating tps voltage + %, coolant temp and iac
  121. 97 Z28! ABS & Coolant light.
  122. Fuel Pump Trap Door Mod---PICS!
  123. fuel filter
  124. 96/97 WS6 hood, oem steel or fiberglass???
  125. Rebuild Kit
  126. Little updates...
  127. car want start with 30 lb fuel injectors
  128. Smoking lt1 /motor build
  129. Help needed, car being a PITA
  130. Help Please, grant steering install
  131. Best 15 dollars i ever spent
  132. What's my used GMMG exhaust worth?
  133. Tunerpro RT V5 Beta - All in 1 datalogger / tuner
  134. High RPM misfire? random
  135. What trans?
  136. 11.04 @ 122 - Stupid LT1!!
  137. 58mm vs 52mm TB article. Dyno & Test Results
  138. E-Cutout in Borla Catback
  139. About to install motor mounts any tips/advice?
  140. 1997 Camaro z28.. ready to do a 1500 in mods!
  141. ready for a few mods on my stock 1997 Camaro z28.
  142. LT1 aftermarket oil pan, info would be great!
  143. Small backfire through intake - '94 LT1
  144. MSD OTVC SP Wire Question
  145. photo request
  146. Oil in the coolant
  147. Fuel Line question..
  148. Low Oil Light
  149. could my valvetrain be out of whack?
  150. Timing set question
  151. OBD 1 switch
  152. 93 Z71 97 LT1 Swap
  153. Parking brake binding
  154. Knock module bypass
  155. Oil in the intake manifold?
  156. Adjusting valves
  157. comp cams 26918-16
  158. Rear brakes
  159. help with cold starts!!!
  160. cutouts??
  161. Coolant crossover banjo bolts?
  162. Cutting out/misfiring through all RPM's
  163. new dyno numbers
  164. Local Shops??
  165. Longtubes big sound difference?
  166. Mcleod street twin!!
  167. 95z big problems...
  168. engine gets hot when I turn it off
  169. My running lights won't turn on
  170. Bearing wear and piston mark
  171. intake question
  172. yank ss4000
  173. need help with rockers
  174. Another 383 question...
  175. Need help??
  176. o2 sensors and E85
  177. Leaking LPP Header W/pics
  178. Used Heads
  179. What Carbs is everybody using on the lt1
  180. question about supercharged LT1
  181. Alternator VS Valve cover
  182. 97 Lt1 slp install kit?
  183. clutch master cylinder
  184. WTF hapened to my harmonic balancer?
  185. Check this out!!!
  186. weird noise when cluch is out
  187. 4l60e
  188. Gota leak somewhere
  189. reuse roller lifters
  190. 163 tooth flex plate with gear reduction starter
  191. Oil leaking through valve cover bolts when engine running...anyway to fix this?
  192. Car Died with No Codes
  193. Federal Mogul?
  194. Very particular question
  195. Help with adjustments after new cam install.
  196. heli coil size?
  197. spark plug indexing on factory lt1 heads?
  198. Will GMMG fit on a 96 z28?
  199. differences in 94 and 95 lt1...
  200. How heavy is an LT1?
  201. Car security acting wierd
  202. Mid range, RPM dependent vibration - how much is cause for concern?
  203. Hi kinda new, just bought a 96 FIREBIRD FORMULA
  204. Door stuck locked!?
  205. cat/exhaust noise????
  206. Need help with heat in my 97 Z
  207. Patriots Ls Series gold spring kits
  208. Still Misfiring!
  209. Scratching that spring itch...videos of my buddy's '94 TA
  210. whats rods and pistons you 355 guys runing
  211. A/C is down!!!!
  212. Can someone tell me the wahlbro part number for the 255 fuel pump?
  213. 93 to 94 intake question
  214. Deleting EGR/AIR
  215. can lt1 or ls1 beat a 460 fox??
  216. A Couple of stupid noob questions
  217. Need tuning help!! lol
  218. Spec 3???
  219. start off stuttering
  220. question about advancing an 292 xfi
  221. It's that time again! Build #2.
  222. Pro Stars, Summit Stars
  223. plug wires
  224. My lt1 is killing me!!!!!
  225. Brake calipers
  226. Lt1 vs sbc crank pulley
  227. Ceramic coated headers VS Stainless headers????
  228. fuel pump replacement
  229. Map harnass is shot
  230. Anybody run Milodon 30909?
  231. It runs!!!!!!!!
  232. Roll bar install...
  233. Wanting to get a good exhaust. need opinions
  234. Floor pans
  235. 13K$ What would you do?
  236. locks and retainers
  237. Need help upgrading please help!!
  238. Billet Grill
  239. EGR Delete
  240. lt header install
  241. After marker oil pan
  242. Oil leaking problem......
  243. Lt1 in 98 V6 camaro
  244. Change over to 12200411 ECM
  245. Poly motor mounts. Vibration problems?
  246. a few questions for you guys
  247. Cam suggestions for cam only setup???
  248. what head gaskets for 355?
  249. wanted to introduce myself
  250. LT-1 Rebuild.....back in car Wont Run
