View Full Version : LT1-LT4 Modifications
  1. what rods pistons for 355
  2. Please help me get these rockers set!!!
  3. Engine bay rebuild thread..
  4. ARP Main Stud kit for LT1
  5. Need a little help please.
  6. Torque converters??
  7. Trick Flow/383 Build/T56 Swap+PICS & NUMBERS
  8. Magnaflow Mufflers on 3" xpipe dumped question?
  9. It's Nearly Install Time!
  10. Need a bolt size anyone?
  11. Can I remove all the PCV's
  12. Single Plane Build on Advanced Induction 385
  13. What windage tray?
  14. R.i.p. Lt1 :(
  15. clutch pedal adjustment
  16. Oil catch can set-up pics
  17. what to do, what to do???
  18. Help with the LS1 Intake Swap!
  19. EGR caps
  20. head and cam lt1 longblock new
  21. If it were your F-body...
  22. Changing Bulbs to L.E.D.'s need help!
  23. exhaust sond normal?
  24. plugs fouling
  25. Parts flowing like water!
  26. Shorty Headers vs Long tubes SLP Exhaust!
  27. What wheels to go with?
  28. Oil pressure sensor...
  29. Cam only now. Heads or nitrous next?
  30. Oil level sensor thread size?
  31. 79 trans am/ t56 question
  32. oil pressure sending unit question
  33. How do you port a Throttle Body ?
  34. How to clean the maf sensor
  35. trickflow 185x heads
  36. bad misfire/choppy idle when hot, code P1361
  37. First Mods on stock LT1?
  38. Starting from scratch *PICS*
  39. 9in problems...
  40. Want a new cam but already have a cam kit?!
  41. cantons and otvc wires
  42. March Pulley Set?????
  43. anyone heard of this shop or seen this car?
  44. OTVC routing?
  45. lt1 removal questions..
  46. lt1 has no spark...
  47. LT1 to LQ9
  48. High RPM LT1?
  49. goodyear super hi-miler hose set
  50. She's acting up
  51. Clutch options
  52. Choosing A Cam
  53. Valve cover issues
  54. LT1 Intake bolts Torque spec
  55. Recommendations need for a 1994 LT1 Camaro power upgrade
  56. got new part today
  57. How can I identify what heads I have?
  58. Wiring guru's please help!
  59. timing cover hitting cam pin...
  60. New hood
  61. Pace Setter Header question
  62. What kind of HP to expect from cam like cc503
  63. Right rear caliper leak after 3 new calipers
  64. lt1 fuel pressure?
  65. td questions
  66. Lid conversion w/ ram air
  67. Best location for MSD 6AL box
  68. Block Tester?
  69. suggestions on heads?
  70. What lifters did I buy?!?!
  71. Ls injector in LT1
  72. Only 17 mpg?
  73. LS1 lid conversion with cowl hood?
  74. ABS light after gear swap
  75. Comp 918s or Yellow LS6s
  76. No cover on Tranny
  77. I need an MSD harness 8877
  78. Bell Housing Bolts?
  79. symptoms of leaking intake gaskets
  80. 292xfi comp cam
  81. plugs question...
  82. ignition switch??
  83. Head light swap..Bulb number question
  84. Anyone looking for an LT4??
  85. I'm getting a GMMG catback. A few questions.
  86. Anyone Know anything about Tom Olsen??
  87. 93 Z28 Specific?
  88. CC Ultra Pro Mag 1.6 RR's Question!!!
  89. Rocker Arm Rebuilds, fyi...
  90. 383 LT1 SR cam 88mm turbo HD VIDEO part 3 The engine
  91. z28 too loud..best way to quite it down?
  92. Cluelesss and new to this
  93. i messed up
  94. Weird light on
  95. GM847 guys come in
  96. Double roller chain with crank position sensor
  97. tunercat questions
  98. OMG new 383 LT1 Not firing..
  99. 1995 Z28 camaro
  100. oil pan windage tray
  101. torque converter trouble
  102. carb conversion questions about electronic
  103. lt4 roller rockers
  104. DMH Cutout --- dont work??
  105. Worth the money?
  106. 94 camaro lt1 fuel pump
  107. 96 vette mods?
  108. 97 LT1 crankshaft position sensor and wheel?
  109. ob1 conversion
  110. Transmission removal issues
  111. My Twin Turbo start up Video
  112. !ABS with cruse question
  113. How does the clutch safety switch work?
  114. A little bit of a choice
  115. 93 z28 problems
  116. Almost Time!!!
  117. Oil leak from the front
  118. Sudden bogging :(
  119. Do i need to have my adjust my tune
  120. So i Finally bought an 8.8!
  121. overheating problem
  122. Evap delete
  123. 94 ta no start, please help
  124. How much is it to fill up a 10LB nitrous bottle in CALI? Plus some other Q's
  125. TB/inake assembly
  126. Best stall
  127. Issues running open Hooker LT headers?
  128. Callies Crank questions
  129. Help Before I Buy Headers?
  130. Trade 740i for 97 M6 Trans Am?
  131. Wtf lt1 problems?
  132. 93 z28 camaro problems
  133. Question on Tires and Wheels
  134. LT1 build recommendations?
  135. Heads up On LT4 Knock MOd
  136. Any one know of any LT4 KM in stock?
  137. Starting E-85 conversion...
  138. Can I tap into a tach wire from inside the car?
  139. Odd Fuel gage/pump problem
  140. Competition Clutch Stg 2 Pedal Feel
  141. Deleted Power Steering, how do i run the belts?
  142. something i stumbled across
  143. Exhaust help
  144. Dish Pistons in NA build??
  145. help for fuel injectors
  146. best place to put in a wideband
  147. What is this worth?
  148. spark plugs
  149. oil pressure drops, starving the motor, restriciting plug
  150. Best place for cam, springs,lifters purchase
  151. Am I getting a good deal for this $100 up grade
  152. Finally the bird is back on the road
  153. Is this fair?
  154. Getting ready to open up the rear end.
  155. valve cover question
  156. 70 Z28 with lt1
  157. Boosting a stock 4-bolt main??
  158. Cam Install
  159. help broke oil level rod
  160. Building a 355 need advice
  161. Sputtering at high RPM
  162. FS Mac midtubes and y pipe
  163. Hard-Blok short fill
  164. new motor no start
  165. Getting an e-cutout and a transmission question.
  166. Trac control recolate
  167. Modding my Lt1
  168. Headlight motor for my TA it's a 96
  169. LT1 Timing change swap w/electric pump?
  170. Oxygen Sensor Positions?
  171. Another exhaust ?
  172. 93 Formula No Start! Help Plz..
  173. URGENT ~did UPS screw up my head
  174. Anyone using the Mcleod Bellhousing yet?
  175. Which injectors, CC503 procharger?
  176. cam help
  177. Another Strange Fuel Pump Question
  178. Newbie LT1 cam question
  179. curious about Solid Roller setups
  180. power steering pump question
  181. water pump seal
  182. Im stumped, car looses voltage while running with new battery and alternator??
  183. LT4 heads/intake limitations
  184. Summer mods?
  185. Why the hell not?
  186. fuel rail covers
  187. ls rockers
  188. Are all DS the same length?
  189. Line Lock Kit
  190. Car busted!!!!!
  191. 6.0L swap into LT1 camaro?
  192. Thinking about selling my car
  193. help with shortblock combo for nitrous
  194. msd digital 6 ignition box
  195. MAF Necessary?
  196. Gauge problems
  197. Educate this man : True Duals?
  198. Small, Stupid and Annoying!
  199. Who Dat Nation come on in...
  200. Track Times w/ Bolt On's
  201. Bad stumble on accel....Runs great @ WOT
  202. HEI install and some PCM Qs
  203. Rubbing the bumb stops
  204. Cams??
  205. poll le2 vs ai 190 vs new trickflow
  206. Quite a bit of questions about LT1s
  207. T56 swap questions
  208. difference between 12 inch and 16 inch borla?
  209. opti harness..
  210. Eagle 4340 Forged cranks
  211. Almost everything new, still missfires
  212. LT1 MSD BILLET HELP..do I need to take apart?
  213. Conventional distributor/ intake?
  214. What is this part??? (with pictures)
  215. 95 sb into 97 T/A - kinda newby question
  216. Those with a borla exhuaust qtp electric cutout?
  217. Disassembly of my stock heads, intake valves stick, need help???
  218. speedo and tach problems
  219. I need a clutch
  220. H/C on 355 lt1?
  221. dynomax bullet or borla XR-1
  222. Guessing game - Milling's effect on head CFMs?
  223. weather strip on t top
  224. lt1 HOOKER shorty headers for camaro?!
  225. Magnaflow Catback Owners Come inside
  226. Had a quick question..
  227. The new 385 is off the Dyno
  228. ford 30lbs injector
  229. I am looking for you guys opinion on a shop price.
  230. adapting a 2-piece RMS crank?
  231. How much to pay?
  232. Need some advice on where to buy a few things?
  233. White smoke after headers
  234. Comp rockers?
  235. Help me choose Have To change Exhaust for 355 w/ 200cc AI H/C pkg
  236. Cousin looking to do heads and cam
  237. LT1 CSR 901LT1 EWP Electric Water pump height ?
  238. Another lid question...
  239. Would driving without a gauge cluster cause a 94 to die and get poor voltage?
  240. Water Pump Cover and EGR Bolt Sizes
  241. How much boost safely on this 383 engine
  242. Rebuilt transmission install
  243. rims 4 93 camaro????
  244. ABS module delete/removal. Anyone?
  245. Cam Opinions
  246. Valvetrain Q's
  247. lt1 Throttle body?
  248. lt1 water pump
  249. Headers installed but have a few questions
  250. cluster help??
