View Full Version : LT1-LT4 Modifications
- car parked/oil question..
- Spark Plug Gap For 12:1 Compression
- Looking for an easy way to plug the oil filter by-pass.
- Cranksaft and pistons
- 52 to 58mm tb
- Best way to dent SS Headers?
- WTF is wrong with my lt1?
- Dropped it 1.25
- Tuning - where to start?
- Quick ? about Opti..
- got my speeddaddy's... couple questions
- Suspension Rebuild
- LT1 Factory Cam Sprocket Bolts... Is the head skinnier???
- ATI balancer hub ?
- LT1 cam help
- ok ive searched.. before i damage it, how do you remove the reluctor?
- lt1 383 question
- 94 lt1 no start
- Mr gasket 5716G Questions
- intake elbow
- what software is good
- LTx Street Stock....we need YOU to register!!!
- New summer project!!!
- 190 MPH LT1 Pass...
- Uh oh, look what Daddy did....
- 10308-1 spring question
- LT1 Double Roller Timing Chain Clearancing Question
- checkin plug wires
- header question
- Thinking about removing my oil cooler...
- New LT1 cam??
- I need help with my LT1
- For those who swapped to beehive LS type springs, a question
- Measuring pushrod length with Patriot springs
- LT1 with a stubborn lifter tick
- Pump seal
- Questions about clutch hydraulics
- Help me pleeeeeease!!!!
- Clutch Pedal Vibration
- Removing the LT1 intake manifold
- Need Lt1 Rod bolts
- drop my SCR or get a bigger cam?
- ls coils
- Looking at another one....
- Opinions on this motor please.
- 98+ Seats into Lt1 Camaro
- a.f.r 225 and lt4 intake
- What did I break?
- Is this Cam worth the trouble?
- clearancing stock valve covers for arp head studs
- lt1 valve cover
- timing cover seal??
- upping my projects value
- ltcc question
- Cant decide on valve covers, help me.
- head bolt or stud install?
- Coolant crossover
- radiator shroud
- 96 camaro cats
- platinum plugs
- ABS Inop...
- LT1 A4 and M6 question.
- 1995 z28 Injector size for my fuel pump 255lph
- What size push rods with ls7 lifters?
- no top end power need help!!!!!!!!!!!!!!!
- Lost oil pressure, need help!
- Trying to cure mis-fire..pulled spark plugs..pix inside.
- HELP! Austin TX Need electric waterpump for LT1 emergency!
- Sup w/ these Ebay headers? Worth it or go Kooks?
- i need more fuel
- post your lt1 radiator covers!
- MoRe PrObLeMs!! Un*******ReAl!?!?
- My cammed LT1 is a dog on the dyno...HELP!
- Oil Level Sensor Block Off
- Meanwhile, over in the classifieds....
- Taylor 10.4mm wires
- Would this be considered quite a bit of porting??
- You guys with ebay headers, what size O2 extension?
- knock sensor cause this?
- Using MLS gaskets
- fuel pressurre
- Over the valve cover wires.
- having an issue and im lost
- what trans in 1993 camaro
- Wiring warning lights for electric waterpump
- Compression test results
- plugs n wires
- this top will get delete soon . LUNCH TIME, WAT TO EAT ?
- BBK Throttle Body
- wire harness swap
- guideplates?
- Spark Plug reading time
- new IAC path for people with monoblade or other aftermarket TB's
- Realistic gains
- Help help help!!!!!!
- 355/383 h/c motors what is your mpg
- Best Spark Plug Wire...
- does anyone know...
- Chasing Head Bolt Holes
- Weird Issue with my T/A
- 355 Hp peaking really high
- HSR Fits!
- Rev Limiter on fresher rebuild with non ARP rod bolts
- 96 lt1 MAF Issue?
- Well this just SUCKS!
- Valve spring selection
- Help with idling noise after plug change
- LS1 engine swap
- best throttle body?
- Dyno Results: Remote Mount Turbo Lt1
- Still recommend vented cap with LTCC?
- door hing pin
- best had gasket?
- Exhaust manifold and coolant passages?
- Going Carburetor
- Removing the passenger's side valve cover
- SA rockers with Chromemoly Pushrods
- Problems with Shifting in an Auto.
- 1 7/8 headers?
- 93 motor into 95 car with 95 trans auto how to make it work?
- Epic Win
- lunati timing chain
- True Duals and Eibach Pros, what to do?
- vortech 1.6rr?
- Ignition switch location
- Which billet steel flywheel?
- Closed Loop Problems
- E-Bay HID kit
- smashed y-pipe
- bleed brake tomorrow, question about bleeding order
- *Gasket* between block and oil filter??
- Bought another LT1, now 2 projects.
- belt falls off
- LT4 availability question
- another site with a 8.8 solution
- 91 Roadmaster LT1, 40,000km
- Any easier way to get to my back passenger side spark plugs?
- How to and detail to remove all emission gear not needed
- LT1 Hoods
- Tired of spending money
- Fried my computer
- BBC 4th Gen Question
- what spark plugs for 383
- Wont go into closed loop
- Tach not working
- rpo code nb8 emmision override
- Forced induction LT1
- SES light on at 50 mph
- what should i do?
- Help!!!!!!!!!!!!!!!!
- which color is the tach wire on a 1994 lt1 z28
- 97 lt1 cranks but won't start
- Out with the crap, in with the horsepower.
- two codes someone plez help
- Oil Pump Drive saver Pix inside.
- Vacume sealed gasket BS!!! How bad is this?
- Having issues! Need your guys' help ASAP.
- K&N cold air intake drycharger
- Congrats Tony Shepherd...
- 93 camaro A4 NSS pinouts
- new posi. any suggestions?
- Best Way To Get Rid Of The EGR?
- Studs vs bolts
- shitty day at the dyno. need some help!
- Procharger + Crank Pulley Installation?
- Is there a quick and easy way to lean out an Lt1?
- Rag joint eliminator and power steering pump pulley
- oil pan gasket 97 z28
- Old Car And Driver Article On The 1996 Z28 SS
- Got a starter problem
- fuel line dryrotted, where does it go??
- LT1 Backfire Pop
- Header and 1.6rr questions
- car bogs on launch after cc306 install
- few quick questions engine harness clean up
- charging problem
- Stepped long tube headers/1 7/8"
- Updated Fuel Pump
- Quick question on LE "306" vs CC306
- 383 LT1 Fuel Injector Selection
- LT1 Ghost...I Guess.....
- PAC 1518 recall
- Timing Chain is in
- How to go about replacing the exhaust manifold gasket??
- K800 Springs Locator HELP??
- knock sensor
- Bright Lights in a 93 Formula.
- New shoes on my busted LT1 Camaro
- single fastest 7.5 10 bolt pass??
- Speed Sensor
- Electric fuel pressure gauge install?
- Ignition control module question
- How to remove engine harness
- cleaning oil off T56
- Exhaust V Bands
- Edelbrock Victor Headers are in!
- What to do now?!?!?!
- 1-4 lamp circuits
- tuning lt1 with lt4 hot cam..with C.A.T.S
- ic ?
- After 2 years, what to do?
- rear sways a little to much!
- Suspension question!!
- Pulled Headers Off... **PIXXX*
- Whats going on here?
- James Montigny's 383 build thread - Lots of pics
- Different camaro models?
- 97 t/a, spins over but wont start
- Popping and Cracking, No power when I hit the Gas
- Lets build a 383 ? "forum group effort"
- car is leaking fluid.. not sure what it is
- Spark plug wire question, or two!
- Cam Question
- TH350 in LT1
- Crank pulley bolt question
- steering intermediate shaft
- Budget minded ecm upgrade
- factory pcm limitations
- efi connection
- bogging and backfire
- LT1 SS intake
- No "X" on flywheel
- which oil pump?
- Anyone running PGX on Stock cam?
- Need some help
- 383 Build
- wiring mallory 685 box?
- 6 speed swap again.... what am I in for?????
- lets see your aftermarket valve covers
- Can the hypertech be of any help?
- Going to quiet my LM1 exhaust down
- 30psi idle on 93 firebird lt1? Please Help
- Is it really just my car and its gears? Or my speedometer??
- 1994 Firebird
- MSD Wires
- Stroking a LT1
- Trying to start for the first time, need help!!
- Installing Heads
- Magnaflow True Dual under the axle...pics/vid
- Code: P0441 LT1
- Burning oil? Bad Lifter? HELP!!!
- LT1 to Carb
- Gasket question.
- Carbeureted LT1 with MSD 83811 Distributor?
- Please help, my car is WAY underpowered and bogs at certain times!!!
- Does anyone have a full manual valve body in thier car?
- Is 20 inches/ 50 centimeters of vacuum good or bad?
- EFI connection guys!! RPM limit on your setup
- Need pics/ideas for exhuast. Single bullet dump after Y
