PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223
  1. Lost 1st and overdrive!!! HELP
  2. slp where are you...
  3. Degreeing a LT1 Camshaft
  4. can someone take a pic for me?
  5. Who are your LT1 hero's???
  6. solid roller. to, or to not.
  7. Crane 10308 springs
  8. head questions
  9. '94 Corvette with 250,000 miles and a D-1SC
  10. Anyone used the LS1 pcm from EFI Connection
  11. Tony - 2010 LTX Shootout?
  12. LT1 block + 0.068 bore
  13. cant read the pcm
  14. Fixing now= Problems later
  15. Getting my MSD opti back from MSD tomorrow
  16. Alternator question
  17. Can I see your OTVC setup pics.
  18. Driver side window dont work, no blinker on passenger side.
  19. K&N CAI Bigger Filter Part Number
  20. Mysterious Oil Leak
  21. Flashing CEL after rocker swap
  22. Dynaspark vs Delphi/OEM
  23. 9 sec LT1 all motor ???
  24. header??? anyone have dyno or dragstrip timeslips
  25. 93 model years enter here
  26. skipping?
  27. 96 Caprice
  28. Wyotech
  29. tranny problems
  30. easy favor please! header measurment
  31. HELP!!!! weird ignition issue is driving me nuts!
  32. Help!!!! cooling probs
  33. lt1 help needed. Please
  34. a friend needs help
  35. Comp R???
  36. Opinion on EWP and valve cover gaskets???
  37. Recommend a parts store radiator?
  38. plug wire organization
  39. Are These The Rockers You Would Use ? ??????? ???
  40. LT1 Spec Stage 3 Plus clutch and pressure plate in stock at a price too low to print!
  41. Two new bests for me. moving closer to the record and breaking 8's...
  42. Modding obssession.
  43. Tune Question
  44. Billet Specialties????
  45. header install problem
  46. stock rear end gears?
  47. cutting out/slight backfire high rpm
  48. Car keeps turning off!!!
  49. replace alternator w/ whose?
  50. Help, no start
  51. header bolts stuck
  52. EVAP Delete??
  53. # side up on HG's?
  54. Cruise control w/ th350
  55. Acessories do not seem to work
  56. Possibly a bad o2 1 month after header install?
  57. wiring harness
  58. Question: Ram Air Hood Mod
  59. Drop in oil pressure upon braking
  60. Need lt1 longblock
  61. bigger rockers on cc503 cam
  62. rear end gearing?
  63. What type of gains will i see?
  64. sputtering/missing when warm
  65. Nitrous Outlet Still Loves the LT1 Crowd! LOOK!
  66. I've got some bad news guys
  67. plug wires on ebay
  68. why do you need tuning for 160 thermostat
  69. mail order tune for hotcam
  70. Do these rockers sound ok??
  71. Street LT1 rebuild
  72. Dial Indicator
  73. 10-15 Amps switched source needed under hood
  74. need quick help. knock sensors yelling after intake man. gasket fix
  75. maf question
  76. MAF sensor
  77. 95 T/A fans inop!
  78. Help! (Not so) cool-ant boiled over. Engine overheated.
  79. Need Help ASAP, Picture of 95+ Opti Dowl Pin in car!
  80. Installed my 383! blew head gasket..
  81. MAP sensor??
  82. Is this re-useable???
  83. bad intake gasket?
  84. Ram Air Hood
  85. so close...so close...started but wont idle
  86. Non-vented opti on vented opti motor?
  87. LT1 oil pressure at 0 at idle, leaks like a sif
  88. LT1 missing, spuddering, backfiring, no power, bad gas mileage
  89. oil pump drive gear bolt size
  90. Patriot Valves vs. Manley Valves?
  91. HELP!!! Coolant leak at rear but don't know where from?!
  92. Late model 93 vette OBD2??? can it be code scanned for emissiosns test?
  93. Aftermarket brakes
  94. Code 36
  95. I think my engine is shot
  96. drain plug Q
  97. nothing but problems at Test N Tune....
  98. Quick Question!
  99. Lt1 swap for 94 V6 Camaro?
  100. Header question.
  101. Do I need an aftermarket TB
  102. Motor Mount Brackets
  103. trouble removing rear LCA bolt
  104. Running rich
  105. Firebird owners, front bumper delete
  106. weird car died when driving...
  107. Gauge Pods Install [help]
  108. yet another snag sapping cams
  109. quick rocker arm question
  110. NGK TR55-IX plug gap
  111. Lt1 tuning
  112. Oil Pan Removal?
  113. Car wont start.. Here are the symptoms.
  114. drive shaft?
  115. AC keeps blowing the Fuse.
  116. Intake Manifold Bolt Sleeves/Washers
  117. Snapped Pushrods....
  118. **PIC* which tuning cable is this?
  119. Pulling Timing
  120. spark problem
  121. dyno sheet
  122. Just shipped my heads off to Advanced Induction
  123. lt1 cam question
  124. congrats to meeeeee and my lt1!!!!!
  125. LT1 heads/cc 306
  126. P0123 Code - Holley 58mm is the cause
  127. went on the dyno jet
  128. shortie headers
  129. Center Console Cover
  130. Percy's Header Gaskets - Why So Many In Package?
  131. crank hub Q
  132. What cam do I have numbers inside
  133. Main bearing choice (blower stroker)
  134. Trans Am foglight bulb
  135. 383 forged crank, forged I beam rods, forged pistons...what heads?
  136. cracked flywheel!!!
  137. Even new AC Delco Opti's suck!
  138. Anyone ever see a pilot bearing/bushing do this?
  139. got my car running finally
  140. Accel or Dynaspark opti
  141. re balance rotating assembly
  142. best piston rings
  143. AC problem
  144. Oilpump drive gear anybody have a fix?
  145. valve spring question
  146. Help!!How do you get the crank key off??? Help
  147. 96 LT1, gm847 cam and 1.6rr valvetrain install, some input needed
  148. Anyone using a lunati 60123 or 54799 camshaft (4/7 swap same as 60123)
  149. A little help?
  150. Wiring Harness Mod?
  151. Canton Oil Pans???
  152. high speed drivetrain vibration
  153. over heatin
  154. Car wont start WTF is p1371?
  155. irwindale 1/8th mile times!!!
  156. Rebuilt Engine Break in
  157. lines, hoses, belts etc help!
  158. LT1 block only from B-body same as F-body???
  159. front main seal
  160. LT1 convert to a carb and 84 gutluss
  161. head gaskets
  162. Why remove the water pump gear when installing electric wp? besides for timing chains
  163. quick egr question
  164. Are 410's a big jump from 373's?
  165. opti problem...maybe?
  166. goals
  167. porting high mileage heads
  168. iac and tps
  169. Purolator oil filter changed?
  170. Dynotuning Le1 heads 306 cam with 110 octane. Advancing timing give noticable gains?
  171. HELP ! I Nedd Piston Part #'s !!!
  172. Oil Restrictors
  173. Waterpump Drive Shaft Bearing
  174. Did OTVC last night...
  175. Miss around 5k RPM's
  176. 408 pistons?
  177. why is my car doing this???
  178. Splayed Main Cap Question
  179. Labor costs for replacing opti/water pump
  180. Anyone with LT1 Tuning Software??
  181. Is this possible
  182. rod bent??
  183. cracked block, leaking head or what?
  184. Car Won't Crank...Help
  185. Opti FTL
  186. 94 lt1 no start
  187. ARP Pressure Plate Bolts....
  188. msd 6al
  189. Finally! Im starting my build !
  190. 1/2 Turn = How much preload?
  191. Ouch...
  192. What vacuum line is this?
  193. pushrod?
  194. Stock M6 launch techniques
  195. 94 lt1 PCMforless tune and 4l60e problem please help!!!
  196. What's it like having 500 HP? VIDEO
  197. Carbed LT1?
  198. Lincoln Nebraska people step in
  199. cam swap, hit a snag
  200. ? about carb'd ltx.
  201. Dart LT-1 blocks
  202. E-brake snapped...help
  203. LS7 lifters
  204. LT1 t-56 anything out there to help make faster shifting?
  205. Starting to backfire at 4000rpm???
  206. gm 847 cam
  207. header install help
  208. Rubber rear main seal install
  209. Long Tubes
  210. Mine's down as well..time for a refresher
  211. Install EFI connection LSX PCM
  212. Cooling Fan Fuses Blowing
  213. HELP!! What would cause an injector to stick open??
  214. K1 products?
  215. LT1 tt headers
  216. What do you guys think he'll make power-wise?
  217. Well the camaro is going down for the count..
  218. Tranny on its way out?
  219. Why can't I use Mallory hyfire ignition as a launch controller...
  220. Currently buying a 93 trans am
  221. quick question on raditator fittings
  222. Question about wiring fans and A/C with FAST
  223. getting rid of a lot of parts (mostly lt1 stuff)
  224. What are the weak points in the lt1 bottom end ?
  225. 93 Z28 LT1 Long Tube Header Install Writeup
  226. abs
  227. where to get oil feed for turbo?
  228. Lpe cai?
  229. oil leak 94 lt1
  230. ebay headers
  231. crank hub problem
  232. miss fire ?
  233. Vette tach and speedo
  234. throwing a throttle position code
  235. what pistons for my build?
  236. I Need A ARP Part # ! !!!!!!! !!!
  237. What launch controller for an LT1 m6 to use?
  238. Some CC503 questions
  239. Procharger Waterpump Clearance Mod?
  240. Lack of oil
  241. TB bypass help lol
  242. Need serious help
  243. dipstick wont go back in help
  244. Small problems with my lt1 trans am
  245. now my cam?
  246. Got my Canon back, here a few pix. Netzero GoFyourSelf
  247. Identify this Vacuum line
  248. Another new best ET and MPH
  249. if it aint broke doin't fix it?
  250. Oil pan gasket install
