View Full Version : LT1-LT4 Modifications
  1. Hows my new set up sound?
  2. 93 Formula.....Code 43 (knock sensor)
  3. Can you rip all this stuff out?
  4. New write up, crank hub removal and installation
  5. tuning
  6. Parts needed for Head gasket Swap?
  7. Stock PCM past 7K RPM
  8. HELP!?!?Misfire?
  9. tb idle air
  10. Ever have a starter stick?
  11. Got a GMMG exhaust on your LT1?
  12. Professional products thottle body
  13. comp 918 springs
  14. breaking starters
  15. 2 ?s
  16. time for new roller rockers
  17. lt-1's and head gaskets
  18. wich atermarket hood for my bird?
  19. bolt on 94 z28 automatic trap mph
  20. Pushrod Question
  21. Crank Keyed, Hub Not?
  22. gm 847
  23. Hendrick Camaro
  24. SBC Scorpion rockers on LT1???
  25. exhaust pop... please read seemes abnormal
  26. New LT1 Owner
  27. is this a good deal?
  28. Having problem with Fans?
  29. first time to the track!!
  30. Energy Susp. Motor mount question
  31. WTB o2 extensions
  32. cam and spark plugs
  33. Starting the MODS! How am I doing?
  34. CODE P0400 - EGR flow malfunction
  35. clutch and flywheel for my build?
  36. What muffler should I get?
  37. optispark at 11,000RPM
  38. People using the LPP headers in here please, got questions
  39. DiY port and polish tips and tools
  40. Help Tchain swap
  41. How your valvetrain parts SHOULDN'T look!
  42. quick valve adjustment question
  43. LTX Shootout tire specs question.
  44. Cam and Heads + install = VIBRATIONS
  45. clutch hissing?
  46. got in a wreck.....
  47. Considering "coming into the light"
  48. Valve Spring help
  49. what the hell does this go to?
  50. Hoses from Throttle body??
  51. freakin wrecked my car
  52. Oil Pressure sensor location
  53. Bullet "cherrybomb" & Ory (sounds great)
  54. I need some advice
  55. aftermarket hood?
  56. new 1/8 best
  57. Very very wierd Opti harness questions
  58. Impala SS pushrod lengths?
  59. nitto tire question
  60. header heated
  61. HELP! I need a few parts...
  62. need help with my first lt1....
  63. Where r Opti screws?
  64. Headlight Cover Installation Advice?
  65. b&m shifter help
  66. What all needs to be done?
  67. need headers so confused
  68. Trading my 4L60E for someones T56, what ALL do we have to give each other? !!!HELP!!!
  69. Rocker arm studs?...
  70. new fuel pump but still psi issues
  71. help rubing sound and knock
  72. 58mm TB and should I tune or not??
  73. camming/idle
  74. airfoil??
  75. injectors?
  76. LT4 Intake Question.
  77. New Twin Turbo Project.
  78. Cam suggestions
  79. Magnaflow exhaust? Advice.
  80. Head gasket change walkthrough?
  81. cam specs?
  82. ARP 234-5501 and Stock Main Bolts
  83. Sealed power gasket kit???
  84. AGH! Damn you cylinder 6 plug wire!
  85. Stock TB question
  86. Purge Kit Help
  87. will I have any problems welding this Bullet in place of the stock muffler?
  88. every thing I need for H/C/I swap
  89. Motor Combos??
  90. adj arm??
  91. SLP intake increase
  92. Troubles with sixty foot
  93. 94 LT1 question
  94. 400hp
  95. LS1 vs LT1 Maf's and Blowing out Oil or Fuel in this video?
  96. 96 camaro z28 having starting problems
  97. PN cross SLP LT1 Ultra Z filter
  98. A couple pics of my camaro
  99. cam size in stroker motor?
  100. My pinks all out compilation video
  101. is there a difference in lt1 blocks and a regular block?
  102. LS1 Size rods in LT1?
  103. Header bolts?
  104. A 383 OR 355 supercharged?
  105. 396 stroker
  106. ram air lid
  107. new na best
  108. PITA to change oil pump on LT1?
  109. i need some help on this!
  110. New personal best 1/4 time
  111. New PB
  112. lt1 m6 ?
  113. MotorSilk?
  114. Heater Core Flush
  115. Which clutch disc. Mcleod/Centerforce
  116. Head gasket on backwards?
  117. factory single cat exhaust bolts
  118. 10's NA first time out with new 396
  119. drillred and slotted LT1 rotors
  120. overdriving alternator? yes or no?
  121. Will this get me low 13's?.........
  122. Valve Spring Dilema
  123. SLP air temp module. a $.50 resistor?
  124. Fire hazard
  125. 2 questions
  126. 11/1/2008 pix
  127. New best for me today! 11-01-08
  128. A couple of new bests-finally!!
  129. What do you all think about porting heads and intake?
  130. Who has deleted their oil filter bypass?
  131. Metal in my oil
  132. LT1 prices sad
  133. why cant i pull a code off of PCM???
  134. p0300 giving some problems, need some help!
  135. ¿ Is is Necessary to change timing set to use cc306 on stock motor ?
  136. is my torque conveter in far enough
  137. Installed bigger injectors. Left BLM went to 108
  138. 396 LT1 Stroker Questions
  139. bad ECM/ECU
  140. Code 15?
  141. pulling out the lt1
  142. round 1 of mods complete. and some pics
  143. Need some advise..
  144. Craziest thing you've done with your car?
  145. passenger sag
  146. Pros and cons of a tubular k-member
  147. Low Coolant Light on, AGAIN!! Help me!
  148. Thank You
  149. Spark Plug Wires
  150. plugs and wires?
  151. need a lil help lol
  152. Lt1 heads
  153. cyl. head cumbustion chamber size
  154. Pig rich.
  155. Tell us about your nightmare/failed builds
  156. Y-pipe question
  157. LT4 conversion or just intake manifold?
  158. Cell 18 at WOT and 47 degrees of spark advance on launch.
  159. Headliner replacement
  160. LT4 intake gasket part number anyone?
  161. my winter work finally!!
  162. Best upgrade heads? Pricing?
  163. Someone please measure dipstick
  164. 91 octane?
  165. pcv valve
  166. How do you feel about
  167. Typical gains from mild porting?
  168. 3.90 R&P to 4.11 R&P. What do I revise in my tune?
  169. code 36 while cruising on highway
  170. How high so you spin your LT1?
  171. calling all with flowmaster Y merge on pacesetter y-pipe????
  172. Tell us about your Extravagant stroker build
  173. voltage drop under load?
  174. Exhaust option dilemma!
  175. I hate this LT1
  176. Speaking of 1.7 roller rockers...
  177. what do you guys think of my car
  178. spec for head clearance
  179. Delima..head choice..not your typical street head..this is a race question.
  180. Vacuum pump delete?
  181. True Duals Question..
  182. Parking brake
  183. Maybe a new exhaust setup??
  184. atleast i got me some nice headers... ;)
  185. ok now look at my dot to dot for my timing
  186. Brand New Racetronix Hotwire Kit and A Toasted Pump
  187. Where did you guys get your EGR block off plates?
  188. where to get scorpion 1.7 rr
  189. My LT1 layin down some rubber (video)
  190. Common Front Oil Leaks, 160 vs 180 Thermos & Tuning & Oil Leveling Sensors Leaking...
  191. SLP LoudMouth 1 Help! install???
  192. LT1 Hates me.. intermittent stuttering!!!
  193. New engine in, runs (video)
  194. check this out....
  195. obdII swap for obdI
  196. What exactly are tru dual exhaust?
  197. Video inside. What mods are on?
  198. Corsa cat-back?
  199. Who has an MSD Opti?
  200. When to replace motor mounts?
  201. lt1 head question?
  202. Any turbo 355 guys??
  203. pros/cons to 1.7 RRs
  204. help!
  205. Whitish smoke from TB?
  206. throttle body too small for cam?
  207. My cars history
  208. "Hays" street/strip clutch..
  209. Wiring/vacuum diagrams?
  210. LT1 smoking out valve cover
  211. We got it! 1996 Impala SS 4600lbs 10.86 on RADIALS with roadrace suspension. (VID)!!!
  212. All Ignition Update Please Read!
  213. Vortech Supercharger Installed now what?
  214. im thinking about selling my t/a
  215. Vortech Supercharged LT1 Problems. Long but need some help
  216. Easier to pull motor or leave it in?
  217. Rattling the Transmission, Help Please
  218. does NE1 know where to get a 97 throttle cable???
  219. LT1 Dick Harrel???
  220. How To Flip The Miles Back On My Cluster
  221. Taylor Wires..
  222. does my dot to dot look right?? for my timing
  223. VIN check
  224. what'd be better?
  225. Distributor in an LT1, can I just drop the motor?
  226. turbo 400 on lt1 what do i need???
  227. What does a stock rear camaro hatch (w/glass) weigh?
  228. I hate tools..
  229. Flushing Brake system
  230. Need Help Please!!!
  231. vic efi
  232. another cam question
  233. turbo kit
  234. Temp gauge randomly spikes after new radiator.
  235. milling heads?
  236. cam and stall
  237. To buy or not to buy?
  238. Bumpin redline.
  239. How much horsepower should this set-up make
  240. Heater Core Flush
  241. happily ever after
  242. Injectors
  243. Fix one problem heres another... Heater Hose Fitting Leaking o.O
  244. gapping spec on NGK TR-6 plugs...
  245. She's Alive!!! Not to shabby sounding for just an LT4 kit
  246. what do i torque jesel shaft mount rockers to??
  247. what do i torque the cam retainer to?
  248. Show me ur aftermarket lightweight hoods!!!
  249. Wow, it started!
  250. I need a picture of your ICM, Coil and Wiring (Esp Grounding)
