View Full Version : Drag Racing Tech
  1. Is drag racing history?
  2. !AC - How to cap lines at heater box?
  3. Guys that have the PT4000
  4. Rear Gear with a th350
  5. which front coilover spring for mild weight reduction street/strip car
  6. Anything you guys/gals want to see brought to the market?
  7. Lightweight t-top replacement now available...
  8. Noob question about motor plates.
  9. Front Crash Bar and Frame Horns
  10. Suspension help! Madman or guru's advice needed!
  11. Transmission thoughts from the drag racers here.
  12. torque arm relocation crossmember problems
  13. IRS drag racing
  14. At what point is a pro stock wing "necessary"?
  15. Racing seat and harness
  16. Big Thanks to John Beck at BECK INTAKES!
  17. Will a 2step work similar to a trans brake??
  18. Whats your 2011 Goals..
  19. Fuel cell options....
  20. New product for us : 4" and 5" stainless race mufflers
  21. Motovative Solid Motor Mount Install
  22. What does your local track do for the street car crowd?
  23. Broken wheel studs?
  24. Deleting A/C?
  25. Drag racing suspension experts. Question about front springs. What do you think?
  26. PSCA Limited Street engine build
  27. Do I Need A Bigger Stall TC?
  28. which front springs ???
  29. Anti Roll Bar Options
  30. 06 LM7 Harness Generator Battery Control Module - Delete
  31. What Color to Paint Roll Cage?
  32. which control arms for launching??
  33. Which 2-step for no lift shifting?
  34. Anyone W/ TH350 and CSR Super Shield?
  35. Manual brakes?
  36. Best springs for drag racing? 98 SS
  37. Removing unused wires ?
  38. What's the best DA you guys have run in?
  39. Race Fuel System Ideas
  40. Track only clutch break in
  41. What next?
  42. NMCA members
  43. Anyone else running NMCA?
  44. Gateway raceway rumors
  45. 10 pt roll cage for convertable
  46. Gauge Bezel!
  47. convertible chasis mods
  48. 18" drag radials...60 ft in the 1.5's or better possible?
  49. How will 1/4 mph change with ss3600?
  50. Why do some of these "race" parts say they wont work w/ AC.. I dont see why they wont
  51. stock lower dash bar
  52. advice on changes to my setup
  53. Electric water pump WITH heat?
  54. Does lowering the car really kill the suspension????
  55. ACs single digit build thread!
  56. 28" tires on camaro , fender roll ?
  57. Seat question.
  58. School me on chutes!
  59. no coolant
  60. Strange Rear Drag Brake Users!!
  61. stock internal 11.03 video
  62. New build
  63. stock shifter for th400
  64. Battery Relocation Question
  65. Who has been pulled over for driving on slicks?
  66. Burkhart new parts: LW Steering Column and Updated Rear end housing
  67. Passenger Air Bag cover - Screws, Zeus, or Velcro
  68. Nervous to start drag racing.
  69. graphite grey ozite
  70. street/strip suspension: what next?
  71. Ever driven slicks in the snow?
  72. lets see those race car bumper supports!
  73. 4.10's vs Cam...
  74. WTB DMH CF Door Panels
  75. Heads or NO2??
  76. Lets see your remote mount water pump
  77. Suspension setup for street/strip combo
  78. I need some Morel 5206
  79. removal of window wipers n cutting..
  80. Strange Lighweight front Drag Brakes
  81. Earl's Swivel Seal Fittings - how to clean the hose out of the cutter for reuse??
  82. Lexan windows for 02 ta
  83. Discharging my a/c and removing.
  84. 93-02 T/As with roll cages post pics
  85. Can you race at the track with mix match wheels???
  86. Kirkey Seats
  87. Fuel line routing pictures?
  88. Setting preload with rear sway bar
  89. Weight Mods...What You Think?
  90. Tubular Front End Question
  91. Check out our car in Gm High Tech
  92. Neep opinions on rear swaybar-Over or Under Axle?
  93. Need HELP-What sway bar with backbraced 9 inch? Post pictures please.
  94. 95 Z28 L92 Street and Strip Build (now with boost)
  95. Racing seat??
  96. Wolfe Cage fit with Race seats??
  97. Alignment issues after k-member install..
  98. 50 more horses good for how much in the 1/8th?
  99. McCloud RXT/RST for drag racing, 9s and faster????
  100. Newbie questions about motor/mid plates
  101. 315 or 325 MT Drag Radial?
  102. knock sensors?
  103. Stupid Driveshaft ?
  104. Attn: Fabricators, this sale is for you!
  105. Show me what your working with!
  106. Texas mile
  107. FOR THE RECORD ...WELD 2.0 with 1.75 backspace will clear LT1 brakes
  108. spring help again sorry guys
  109. Anybody running PRC 227's?
  110. MS vs Chromoly K member weight?
  111. Upgrade 10pt to 25.5 SFI, few questions?
  112. Dzus rails?
  113. 2 steps with cats?
  114. ET Streets or MT Drag Radials
  115. Cheapest place to buy kirkey racing seats
  116. Madman’s Annual End of the Year Sale
  117. Anybody using aftermarket doors on their 4th gen f-body?
  118. Merry Christmas from Burkhart Chassis
  119. Anyone ever used a Precision Kwik-Shift
  120. What gains from a 4000 Yank
  121. hey rednecks...
  122. Suggestions for suspension setup at the drag stip?
  123. How much should this cost?
  124. Lightweight carpet
  125. Hood picture/advice request
  126. Engine angle Pinion angle????????
  127. Seat Belt w/ racing seat
  128. mini tub question
  129. I need some help
  130. Roll Bar in the Daily?
  131. 5pt? 6pt? wolfe
  132. bracket removal question
  133. Bring on the flamess!!!!!!
  134. Solid Motor mounts...old idea, whole new design!
  135. Stock cubic inch 6.0 record
  136. Cutting the radiator support?
  137. Anyone running just an alternator? (no wp, ps, etc)
  138. Oil for you street/strip guys?
  139. Switching from a trac-loc to a locker tomorrow. Any gains 4.10's?
  140. What kinda gains??
  141. Help my street car into the nines!
  142. 12" Wheels in True 10.5 Tires!! Updated 12" narrowed Racecraft 9" rearend
  143. 1998 Formula Firebird drag build-Bright Purple Metallic
  144. Motor out, how to remove front part of heater box?
  145. 1995 Firebird 4.8L Street/Strip Project
  146. weld magnum 2,0's on a 94 LT with stock brakes
  147. anybody running a 4.33 gear with 28in drag radials?
  148. Rear spring for drag racing?
  149. 4.8L ET Record?
  150. Wiring Harness Question
  151. Steering wheel w/ buttons
  152. Fast 102 vs Super Victor
  153. Can you remove window motors?
  154. some progress on our 9' IRS vette.....
  155. Looking for 12 flat!!
  156. Old school 12 bolt
  157. Need Some Opinions Fellas. Nitrous Or Turbo?
  158. 2002 Trans Am WS6 Drag Car - Project
  159. Definition of Acceleration!
  160. Pulling wires
  161. Who has removed HVAC through the glove box?
  162. anyone had problems with Strange? or know warranty info ?
  163. What to do with ABS wiring
  164. double adjustable shock question.
  165. Whats the best a 10 bolt could handle
  166. Tampa area trannny expert
  167. Manual Windows
  168. Minitub vs. tire size?
  169. How fast will it be? 665 fwhp street/strip car.
  170. Securing Seat to Roll Cage
  171. motor plate info, post pics of yours
  172. 8 point cage?
  173. Reposting an old battery relo. idea.
  174. pics of santhuff front struts on 4th gen's?
  175. Staging question
  176. Pcm wiring question
  177. front shock, solid upper shock mounts?
  178. motor plate with PS
  179. cutting rear bumpstops metal / coil pocket off.
  180. 10 bolt limits
  181. 18" drag radials
  182. Wheel question.
  183. Battery Cutoff with battery up front
  184. drop spindle
  185. Heads up to all 9.99 and faster cars...2011 rule change for padding
  186. anyone heard of the 4L60E "power gear" upgrade ?
  187. why does my rear end raise when im staged to launch? video inside
  188. Vfn dash
  189. my racecar rewiring project
  190. Upgrade from 8 to 10 point cage.
  191. burkhurt spindles and drag brakes
  192. wiring question
  193. anyone make gauge plate
  194. Rear drag brakes ?
  195. What converter
  196. looking for tips on launching my stalled a4
  197. tow vehicle
  198. Street-able lighter front seats
  199. Race wiring question...
  200. T400 Trans Brake Launch RPM ?
  201. F-body rear suspension tech info
  202. Finally did my battery relocation
  203. Question about slp line-loc I put in today
  204. After market fuel Cell
  205. Chained down
  206. Rear lower control arms?
  207. LSX DR heads
  208. Noob Suspension Question
  209. Lightweight Flexplates...
  210. Wolfe Torque arm??? Anyone using it???
  211. building a street strip car need advise
  212. Should i expect lower 60 ft. ?
  213. BMR Launches New Product - Lowering A-arms (AA020)
  214. Burkhart Black friday sale
  215. what do i need to run a vic jr
  216. Question
  217. turbo ta traction issues....vid inside
  218. Decided to go auto, not sure which one
  219. a/c delete
  220. Check Out The New Moroso LS1 Electric Water Pump
  221. Rubber Mat behind dash?
  222. New Wheel Porn!
  223. Radials and 6 speeds dont mix huh?
  224. Extended Hood, how close to the windshield?
  225. BMR xtreme TA or Burkhart TA ??
  226. Manual windows with roll bar/cage?
  227. Racecrafters A arms and travel limiters
  228. LIVE BROADCAST street car super nationals vegas
  229. best 60ft with a 4l60E
  230. Nittos, MT's, M&H Racemasters... which has better hook for 3800 lbs?
  231. suspension gurus....m6/drag sus/bias ply....vid inside
  232. 9s CAM ONLY new record !!!!
  233. F body control arm angle
  234. Front Shocks: Best Bang for the money?
  235. 15x12s
  236. Thought I posted already
  237. Track Day
  238. Where to buy a cage kit.
  239. Anyone have true rear coilovers?
  240. Where to tune your drag car
  241. What gears need help
  242. Read NHRA rules...still a few Q's.
  243. S&W cage, anyone have one installed?
  244. Race front susp install questions.
  245. Is it worth staying stick for drag?
  246. Mounting a 5" tach in a panel?
  247. Wheel Alignment
  248. Heating the tires with a M6
  249. Rear suspension, gears and K member help.
  250. Who has ripped out ALL radio, A/C, cruise control wires???
