View Full Version : Drag Racing Tech
  1. Nawzz, 6 speeds and 4:56s???
  2. New cam only record
  3. debating if going from 3.73 to 4.11 will be worth it??
  4. Traction tips?
  5. custom engine mounting?
  6. Lightweight battery
  7. New engine build! step inside for ?s 388 lt1
  8. MT Radials, A4, 10-bolt, Will it make it tonight?
  9. what will 15x3 rim pick up et
  10. 98 468bbc project
  11. Ram air?
  12. Pin on hatch & Prostock spoiler install. Look inside!!
  13. How much ET gained from 150 hit of dope?
  14. getting weight off the front
  15. Traction issues....
  16. Finally getting this drag radial/suspension/nitrous thing figured out! Vid posted
  17. Going BBC!!!!!
  18. 27" or 28" tire?
  19. 275's
  20. opinions on the 6al-2?
  21. Need help for next mod
  22. Saving weight by using Mr. RotoZip
  23. Drop 15lbs off your heat and still keep it...
  24. Been thinking now I am asking.
  25. Reference point on car for measuring and adjusting rear LCA's
  26. how many guys are running a mid plate
  27. battery relocation(ive searched)
  28. First time at the track, any tips? advice?
  29. MSD 2 step guys come in..
  30. Flexplate recommendations
  31. race craft anti-roll/panhard? anybody running it?
  32. Whats the average et gain?
  33. Just installed QA1 shocks/coilovers, few questions inside
  34. Setting pinion angle, pro suspension tuners PLEASE help out!!!!
  35. How comfortable are drag racing seats?
  36. Front impact bar removal question
  37. recently finished car pics inside
  38. Speedglass installed pics
  39. wheel speed sensor
  40. Removing A/C But want to keep heat
  41. Piston to head clearance question
  42. Need to wake this car up,67 chevelle 6.0
  43. Deleting trunk well
  44. hidden roll bar??
  45. Front brakes.
  46. guys using Comp Engineering rear shocks
  47. Drag car wiring, stock PCM, fan control, fans always on
  48. Drag Racing Accidents opinions
  49. weight reduction
  50. ls1 or ls2
  51. want 10's n/a what to do next.
  52. Looking for some rear susp tuning help.
  53. Front bumper cover removal!
  54. battery relocation
  55. At what point do you start thinking about a chute?
  56. HVAC removal: bolt/screw locations
  57. hairline crack on oil pan...
  58. Just picked up a set of QA1's where to start?
  59. Wtf is going on.
  60. help setting SA strange with 275lb springs for track !
  61. Converters and Motor Plate
  62. So I want to start another build next year..
  63. Should I go with a 2 step?
  64. Anti Roll Bar Pics
  65. Starting a lq4 build
  66. th400 or Glide
  67. Carbon Fiber Fender Exit Exhaust Trim Rings
  68. Rear Shock Damage - Anyone?
  69. Front Shock Drill mod?
  70. Burkhart K Member with motor mounts
  71. first time goin to track
  72. Wolfe 10-point is it enough....582BBC
  73. Car pulling right only under hard acceleration
  74. carpet install with 8 point cage help
  75. A little racing tech.
  76. how much does a TH400 weigh
  77. Used ET fronts?
  78. Finally fabed an air filter for Accufab 4-barrel Throttlebody
  79. Prostar Vs. Weldstar!
  80. new pb, video inside
  81. Trans Temp Sending Unit Location
  82. Steering wheel airbag cover
  83. best mods to hook on the track
  84. WHAT WILL IT RUN!!! (already posted in the right section)
  85. Joe Van Overbeek TA/Firebird Body Parts
  86. Sealed battery box that fits in the f-body spare tire well?
  87. Vette Hub --> 930 CV Stub
  88. ride hight on the front with adjustables?
  89. 100 quickest LS-Powered Cars
  90. Final suspension adjustment double checking
  91. e85 or 93 octane pump gas for low 10 sec street/strip car?
  92. Mating LS1 to Powerglide
  93. Which ATI Balancer Part Number?
  94. where can i buy a nice simple bolt in 4 point roll bar for my 00 trans am
  95. HELP! (i think)
  96. Tips to drop a few tenths
  97. Radiator Cap?
  98. Yet another 275 Radial Build
  99. sunoco camaro hood?
  100. Spring Delimna - What would u do?
  101. Madman Torque Arm and Dana 60
  102. need help setting up suspension
  103. Tripping the beams?
  104. Tampa area machine shop
  105. What RPM to shift TH400
  106. What do you guys run for suspension?
  107. Spohn TQ arm flex?
  108. Dyno'd the ta. Video inside
  109. FAST 4150 TB guys step in please..
  110. Looking for a side mirror bracket
  111. Strange 10 ways and sportlines out back?
  112. Solid roller on a street driven car?
  113. More Drag radial questions switching from bias play
  114. dry film lubricants
  115. VHT or track prep for street racing ?
  116. Cam only class finally..
  117. where to put my 400 dollars ?
  118. Looking to drop a few tenths...
  119. looking at weight reduction for racecar
  120. how should an m6 car be launched?
  121. Anybody ever used AV100LL
  122. torque arm positions
  123. Champion wheel
  124. any real purpose to run qa1s in back with springs setup like this?
  125. Newbie Launching
  126. Videos of a few runs, please critique the launches.
  127. Battery Boxes
  128. front suspension
  129. Lightweight Carpet?
  130. hot rod wiring
  131. Can I run much better with these mods?
  132. is the airdam needed on a street/strip car
  133. Beginning Street/Strip car build....need advice.
  134. which Coil over springs for iron block Trans am 275 or 300o
  135. Today's weight reduction!!!
  136. Billet Belt Drive Fuel Pump Bracket
  137. What PSI 17in. MT DR's
  138. help with my setup for 60ft
  139. Burkhart Shop Car Updates
  140. Which Braille battery?
  141. Wanna see some 1000.00 stainless turbo headers?
  142. How low is your drag car?
  143. What do I need for this gauge to work?
  144. snell certified helmets, anything for $100??
  145. Help with suspension setup..stock style
  146. Pusk lok Hose
  147. Rear shock travel question
  148. initial suspension setup question
  149. E-98 results or issues??
  150. Best street tire short time...
  151. Help with blower box removal
  152. 8 inch converter can i spray it
  153. New from madman & co.!!! Exhaust outlet rings!!!!
  154. Near future cam swap but ideas about possibly tickling 10's (346)?
  155. Buying track tires, need advise
  156. Any F Body Carbd Race Cars Out There??
  157. Drag Radials and 6 speeds
  158. Am I topped out for my power level?
  159. Race weight???
  160. fixed seta back mount, legal spcs. how did you do yours
  161. Chances of making a 515ish rwhp car to hook on the street?
  162. Door Bar Removal Thread
  163. afco da help
  164. 2000 Z28 M6, bolt-ons
  165. lca bracket question
  166. Critic my M6 launch
  167. Help With Stock Suspension
  168. 6spd guys, ET Drag psi?
  169. Hey True Street Guys....
  170. 408/TH400/S480 shakedown with vid's
  171. need help with suspension
  172. thx umi
  173. any 6spd guys having success on the street?
  174. 6 speed guys..4:88s and 28in tire
  175. mini tubs?
  176. Another 6spd launch?
  177. zssmans drag radial build.
  178. Change convertor?
  179. Custom Carpet For The Mini Tubs
  180. What to do next?
  181. Madman Hurricane Sale!
  182. IAT sensor placement
  183. Were to buy HVAC Delete Plate
  184. What size gear are you running?
  185. Question about lowering springs for you street/strip guys
  186. Anyone running a cam this big?
  187. need some help with 60 ft times!
  188. rear wheel separation
  189. DIY excellent website source great prices...
  190. Motor Plate w/ Mounts
  191. Fastest using Stock PCM
  192. Bracket Racing
  193. trunk delete and mini tub how to?
  194. trap speed increase with taller tire
  195. open headers?
  196. How can you tell if drs are to old and dry?
  197. Decent(Cheap) Wheel Tire Combo?
  198. any info/pics on this car?
  199. Sneaky EVO 8???
  200. 2002 z28 t56
  201. sorry for dumb 0-60mph question but
  202. bmr drag sway bar ????
  203. Blowing head gaskets
  204. looking to get to the 11s
  205. eibach pro kit with zr1's deep dish on 01 f-body clearance questions
  206. Upgrades to the Camaro---Mini Tubs!!!
  207. need a little 60ft help [ ls1 mustang ]
  208. ET Street Radial ?'s before i hit the track
  209. Lug nuts torque spec
  210. ls6 heads,ms3 cam,ls6 intake,373 gear,150 shot?? good combo?? times???
  211. Can I Gut the Wiring from the Firewall to the Tail Lights?
  212. Race gurus? help with qa1 settings
  213. LED indicator off of my 2 step?
  214. Lightest/Best lightweight battary?, Stock position or relocated ?
  215. BMR Torque arm RELO crossmember which holes to run?
  216. 6-speed launch help - Wheelslip graph
  217. Wiring help - removed HVAC, airbags, etc Turn on lights and trunk opens?
  218. Best of luck today Eddie!
  219. Burnout question.
  220. Stall wall, trans or something else? need help now please
  221. How effective is a drag bar???
  222. a different th400 question
  223. Front inner fender pics?
  224. why do people run 17s in front and 15s in back?
  225. Leaving tomorrow morn for LTXShooutout 3
  226. Help me 60' my M6 416
  227. Removing Cruise on a NON TCS car?
  228. A few wiring questions
  229. changing converters
  230. My 99' V6 build
  231. mild steel or c.m rollbar?
  232. MSD 2-step group purchaase, we need 1 more person...
  233. Interior wiring help
  234. Help me understand whatthe rear bulkhead is ?
  235. Burkhart Chassis Availability
  236. Max RWHP for 27x10.5 Hoosier QTP
  237. New bullet is finally here!
  238. What did a gear swap do for your mph?
  239. Need help installing front coil-over’s (Question)
  240. 25.5 project complete
  241. How do you think a Dodge ram 1500 will pull??
  242. Kill Switch question
  243. Battery Relo Wiring question
  244. Gotta love 30min spark plug changes!!!
  245. Cary Chouinard Named Mast Motorsports Director of Cylinder Heads & Valvetrain
  246. Need to purchase race brakes!
  247. I need someone to cut me a switch panel
  248. What is the best way to build your cage in the back of the car?
  249. 1994 Camaro - Suspension help please!!!
  250. How loud is having no carpet?
