View Full Version : Drag Racing Tech
  1. uh i need help...
  2. Bracket Racing!!!
  3. Trunk Battery Relocators (Ground)?
  4. What camber/caster bubble gauge for alignment??
  5. Running brake lines on rear end...
  6. My Team Z rollcage pictures!
  7. Factory Core Support
  8. Slicks/DR's.... AS and IC questions..
  9. cage/subframes tied together
  10. Coil pack reloations Please post some pics and where are you putting them.
  11. rearend question
  12. ID these boxes under dash
  13. Source for sealed connectors (metripack)
  14. How fat is my car?
  15. driveshaft safety loop, 4" exhaust question
  16. Wheel Studs
  17. Need some HELP!!!
  18. What car hauler do you use?!
  19. slammed f-bodys with 325/50 or 28/10.5 no tubs
  20. 1/8th mile mph is weak compared to ET??
  21. How to hook better on the street???
  22. "Drag" brakes on the street
  23. Couple pics of my 295/55/15 MT DR's
  24. Parking Brake???
  25. nhra license renewal
  26. How to set UMI drag bar end links??
  27. Will The Auto Meter Pillar Pod Clear A Cage ?
  28. Who has made OEM window motors work w/o BCM?
  29. Would you run a radial for bracket racing?
  30. Turbo in batery location, no master disconnect switch
  31. WHos motor plates and front brakes
  32. 6al-2 question
  33. Cam Only This Bitch Is On A Diet And Getting A Makeover-UPDATE 5/1 PICS
  34. Big tire decision to make - Unbiased/candid opinions needed inside!
  35. Budds creek!!!!!
  36. Post pics of your rear master shut-off
  37. another gear question
  38. Dyno Joe
  39. Suspension Mod Order
  40. legal firewall nhra
  41. Awesome fire extinguisher!
  42. cam only 60ft times??
  43. whats changed on a 25.5 to make a 25.3
  44. Few changes for 2010
  45. Info on lightweight carpet, what and where to get, and how to do it.
  46. New round of bullets for this year
  47. Batt relocation guys. Any issues on current with longer wires??
  48. SGMP track conditions for The night the lights...
  49. What would you do with my springs ?
  50. Front spring rates for a roots blown car?
  51. New Car
  52. Stock torque arm + Transbrake?
  53. Help on a 370 build
  54. new parts equal what gains?
  55. Lightweight Camaro Hatch ?
  56. Another 10pt Rollcage, Lightweight Carpet, Winter Install
  57. how does mph/rwhp work?
  58. Pick out my track tires please
  59. MTs and wheel spacers?
  60. 3640lbs... Time for a diet!
  61. Bump stop?
  62. ABS/Air bag questions - street/strip car
  63. Tire help
  64. Racing alternator output
  65. Hit a Snag Removing Air Bags. Help!
  66. BMR Alternator Bracket on 6.0L ?
  67. What's your 60fts
  68. Question about C6 ls2 ???
  69. This gear or that?
  70. Launching ?
  71. Pics of fiberglass hatch? (firebird)
  72. dynatechs vs single chamber flows
  73. Spectator death @ NHRA Arizona Nationals
  74. You high compression guys, I need a battery...
  75. Pictures of my winter Race car complete re-wiring project
  76. Setting up a Vac Can/Catch can.
  77. How much would a(stock) 28lb flywheel slow me down?
  78. Pics of 315 DR
  79. Short times with braked glide
  80. Drag Brakes or Shocks
  81. How to remove the front bumper support?
  82. wolf cage or custom??
  83. ???covering up after removing SAIL PANEL PLASTIC.....
  84. Estimated HP....Tips????
  85. ozite question
  86. Deleting airbags
  87. Susp setup changed?? What could of happened?
  88. Help me choose a new Torque arm
  89. taking out a lot of gear. want some opinions.
  90. 4:56s too much gear for me?
  91. Trap speeds of an auto vs 6 speed on higher horsepower motors
  92. minitub require repainting 1/4 panel?
  93. Wolfe 10 Point, Kirkeys, Ozite Done!
  94. 2000 Trans Am 25.3 Build
  95. steering wheel
  96. My brother is gonna do a 5,500rpm clutch dump
  97. Roll Bar Main Hoop Feet
  98. Swapping LS1 driveshaft to LT1 car?
  99. Which Throttle Cable?
  100. deleting hvac. keeping heat.
  101. 315 MT drag radial tread life/ traction?
  102. Question on 15" wheels on stock rear
  103. Parachute mount?
  104. Progress for the 2010 season
  105. What Motor Plates Are These?
  106. Drag Radial Tire Clearance Question?
  107. Guys with aftermarket tachs...
  108. Anyone ever heard of this company?
  109. 4.30 gearing
  110. Rod-End legal for Swing-Out Door-Bar Hinge?
  111. rearend fitment with min tubs
  112. BMR Fabrication - President’s Day Sale (25% OFF Most 4th Gen Items)
  113. How fast did you take your FACTORY Torque Arm?
  114. Drag Tires
  115. remote battery wire routing and fuses
  116. 13" steering wheels
  117. want to run 29.5x10.5 IPO 29X10.5W will it fit???
  118. Titanium Valves and Rods
  119. Step one..... LATCH T-TOPS
  120. Installing and adjusting front tubular A arms
  121. launching a manual car, how to?
  122. need help with stand-alone engine harness
  123. Those who have mini tubbed and/or cut out trunk bottom-Come inside
  124. Burkhart mid plate system
  125. Aluminum Racing Seats, Sit Lower?
  126. TH400 swap. M6 crossmember. UMI K-member. NO SPACER needed?!?!
  127. tubes in front m/t et's
  128. roll cage material and points?
  129. bfgs or nittos which is the best..
  130. 25.3 Outlaw Drag Radial Camaro Build
  131. Muffler suggestions
  132. Summit 3way Drag Shocks
  133. powerglide crossmeber ?
  134. Diode Specs for LPE 2-Step
  135. Going to try 26" tire insted of 28".
  136. I need some Harness's, where to get them?
  137. Wire hole for line-loc in firewall
  138. fastest 60ft on nitto drag radials?
  139. Burkhart Stimulus package through April 15th
  140. Guys with powersteering deleted come in
  141. new motor by mistake
  142. Percy's Rear Hatch Tinting?
  143. Relocating Yellow Top Optima to rear
  144. what tires to run
  145. Anyone have a autometer rpm pill 5.8-6.2
  146. racestar wheels??
  147. anyone have pics on how to remove the wiper motor?
  148. Lexan windshield
  149. Project removable "one piece" front end using factory bumper and fenders
  150. TNTAddict's launch issue
  151. ???anyone running a FUEL CELL using the FACTORY FUEL DOOR.....
  152. nasty performance fuel tank lighter than stock steel tank?
  153. tire size
  154. burkhart torque arm
  155. Rollbar swing out kit?
  156. How much to cut off my rear
  157. 12 Bolt Drop Out for a 9", Who is using?
  158. How much did you gain!!!!
  159. Some help with 4 link.
  160. part question / weight reduction
  161. Wolfe through-floor subframe connectors-Are they needed?
  162. What size tire and gears?
  163. My Extreme WEIGHT REDUCTION list & questions inside.....
  164. VFN rear bumper
  165. Some ladder bar questions
  166. Update Burkhart shop car Kurt Urban Dist Drive
  167. Do I need to brace a Percys Windsheild?
  168. Chassis pro's in here. Instant Center calculation question.
  169. what will it take to get into the 10s
  170. Fox Body or F-Body
  171. FPR before or after fuel rails?
  172. Spring rate with LSX block??
  173. 8" vs 10" wide drag wheel
  174. What's the highest ET for an F-Body to pull a wheel?
  175. Local 275 radial race help
  176. Bullets off the collector or keep Y pipe
  177. afcos vs strange
  178. Oh god wheeeeeeel hop
  179. need 35 more horsepower, or so?
  180. I need camshaft ideas!!!!!!!
  181. What rpm to launch from on 2 step
  182. Skinnies- Bias Ply or Radials up front?
  183. Need a sticky 16" tire.
  184. what HP are the LSX nitrous motors making
  185. Do you have a 25.5/.2 or a 8/10 point cage
  186. TR7IX wont fit??
  187. where in back are you guys mounting trans coolers?
  188. Foam in the tank?
  189. Lets see thouse STOCKERS!!!!
  190. broke-dick-racing roll-bars and Cages???
  191. 2 Step or leave off the limiter (teach me)
  192. anyone know what stock weight is?
  193. how to adjust phb
  194. Tall deck RHS block ...
  195. How high is it safe to rev stock ls1 threw the traps?
  196. Anyone running a Watts Link instead of a panhard?
  197. Gearing
  198. has anyone tried the new nitto d.r.
  199. Holley LS Fest, September 10-12, 2010
  200. Turbo Smallblock Camaro Project
  201. Who makes/sells complete batt relocation kit?
  202. has anyone removed this stuff to save weight see pic
  203. How bad is it to lower car??
  204. Hvac Delete wires
  205. who knows what the wheel base length
  206. 4:10s vs 4:30s? What tire size?
  207. Narrowing rearend opinions
  208. Manual rack?
  209. QA1 suspension what height to set the front coilovers?
  210. Took the T/A to the track, 1st time
  211. roll cage advice?
  212. trans am pro stock wing
  213. Manual brakes, whose master cylinder are you using?
  214. weight reduction ?.
  215. Which type glue to use for slicks?
  216. tapping and baffling valley cover for AN line for PCV
  217. Choosing Front Coilover Spring Rate?
  218. Time to start building a motor
  219. Glide in a Bolton only car?
  220. Iron block 427 or different for a NA Build
  221. Who runs a Beck intake?
  222. questions about what backspacing I need
  223. Weight reduction/Daily Driver
  224. 3600 stall 60'?
  225. Paul Major in 275?????????
  226. Does anyone have the 295/55/15 MT in stock?
  227. Looking for true hood weight savings w/fiberglass
  228. Questions about my car, no sub frame connectors.
  229. 1/8 mile Torque or HP
  230. What should I upgrade first...transmission or rear end?
  231. wondering how a certain TA works
  232. Removing excess wiring
  233. Pics of under body with the use of bmr extreme torque arm!
  234. Anybody know this car??
  235. Nitrous guys, how much are you picking up if your already going quick?
  236. Avg ET?
  237. Do I need a Engine Limiter with motor/mid plates
  238. Strange 12 bolt does not spin freely?
  239. QA1 stud to eyelet brackets
  240. Vacuum - Ported or manifold?
  241. ls1 torque strap/link
  242. short vs long tq arm
  243. question about shoot plate mount-how many degrees*
  244. Anybody know About Acid Dipping ?
  245. Installing CE 3 ways,bolt too short?
  246. twistin problem
  247. ???Super Short Belt Mod.....
  248. Good idea for me to move too 28" full slicks?
  249. New coupe stang lq9 turbo build..
  250. Wiring help needed
