View Full Version : Drag Racing Tech
  1. Good idea for me to move too 28" full slicks?
  2. New coupe stang lq9 turbo build..
  3. Wiring help needed
  4. Kirkey drag seat question for manual trans guys
  5. Who all is running 15x12's in the back?
  6. Convertor stall
  7. Help! More Hp and Slower E.T's!
  8. 6 speed and Nitrous in NMCA Street Race...
  9. PA Racing torque arm factory or tunnel mount.....???
  10. Rear seat pan removal?
  11. evap delete question?
  12. Question about RaceCraft manual rack/steering shaft
  13. What do you think of this cage...
  14. Want to get ideas for fuel cell and bulkhead, please show me your race setup
  15. Black box
  16. Billet Specitalties Competition 15x10's
  17. grant wheel adapter part number?
  18. Advice on power shifting for a novice.
  19. Lights Out! Georiga Roll Call!
  20. i wanna see under the top 275 cars :)
  21. SFI flexplates, most the same?
  22. burkhart spindle weight savings?
  23. 15x10 5.5" backspacing
  24. Help Griffin radiator stock position fit???
  25. Wireing in a BBC into a 4th Gen TA
  26. Motor plates and mid plates question
  27. Im sure some of you might know FWD Drag racing.
  28. Dipstick measure for Moroso oil pan???
  29. PVC Delete driver valve cover breather???
  30. cowl mod with window wipers
  31. Need help - Removing some metal from the interior
  32. battery relocation and remote terminals
  33. Mods please allow: looking for a 25spec roller
  34. Fab 9 100 lbs lighter than a 12 bolt?
  35. Chutes, which one?
  36. custom headers from PVC pipe???
  37. Alignment concerns with adjustable A-arms and a FIXED k-member
  38. help with ls6 intake and 78mm fast TB
  39. Twisted splines inside of front yoke???
  40. New Weld front wheels
  41. Mechanical fuel pump question.
  42. Question about drag susp
  43. Questions on cutting radiator supports out
  44. What Starter for Large Cube and High compression?
  45. Stock Electric Fan wired to run in the pits?
  46. whats the weight of a stock 4th gen camaro?
  47. anyone with full tubbs out there?
  48. battery relocate box?
  49. Weight Reduction
  50. Help Relocating Front Fuse Block
  51. Guys with 4 hole throttlebodies and wipers
  52. Deleted heat guys, thought this was pretty cool and cheap alternative...
  53. 1/4 mile vs 1/8
  54. Inbetween on bolt in or weld in.
  55. Stock Rear End Length...
  56. Drage bar and 8.8 ??
  57. Converter for STOCK motor
  58. What size tire do you run and why?
  59. Tucking 28x10.5 slicks
  60. one more question on JW bellhousings
  61. 2010 East Coast Shootout
  62. AC/heat removal?
  63. XS Power Batteries
  64. Cant decide. UMI Drag Bar or N2o Plate kit??
  65. lexan question. help
  66. 11.80s? Is this guy as retarded as I think?
  67. Lightweight carpet install???
  68. When is a back brace (9") needed. How fast do you run?
  69. Spark plug gap N/A??? Built LS7
  70. Can I Hook?
  71. Nitrous bottle mount tips.....above tank in hatch area.
  72. Tire height change affect on pinion angle
  73. suspension mods for hooking @ the track
  74. 26x10.5-16 MT New
  75. M/T 29.5x10.5W with Wolfe Offset LCA's?
  76. Need some technical help!!
  77. Pinks @ Z-MAX in April?
  78. Strange 12 bolt and drag bar??
  79. Please critique my launch, pic included
  80. Radator support
  81. do 15" weld fronts clear stock brakes?
  82. Is there a good class for me to race in at LSx shootout or Drag Week?
  83. M6 brake pedal removal
  84. Let's see those 10 point cages
  85. Flex plate for Long crank 99-00 LQ4 W/ Th400?
  86. Cage in a street car
  87. MWC Drag Bar anyone???
  88. who has the lightest f-body out there???
  89. Remote mounted waterpump
  90. drag radials or slicks
  91. OFF Seaon at the Titan Race shop
  92. 10 PT cage
  93. weight of SFC???
  94. Prc stage 2.5 5.3 heads & what cam for best results
  95. 275 guys: Do you think the new 295/55/15 will be THE new tire?
  96. subframe question
  97. trex/vindicator/polluter with th350?
  98. Spring question
  99. what cam for 6.0
  100. Trans Break?
  101. New e-mail
  102. Weight difference in coil overs vs. stock shocks and springs
  103. Rear Qa1 settings with stock front suspension
  104. Thanks moser
  105. what's my problem?
  106. 10 pt. cage and SFC ?
  107. spring choice, stock or pro kit
  108. light weight hood for trans am?
  109. drag wheels efect on et
  110. switching from power windows and locks to manual
  111. Suspension help needed
  112. Black Anodized Aluma Stars ??
  113. Trouble hooking up lately
  114. Way too slow?
  115. can you run taller than a 28" slick on a 4th gen?
  116. 28x10.50x15 MT ET Street or 275/60/15 MT ET Street drag radial
  117. wiring questions
  118. wheel screws install ?
  119. 4th Gen NHRA Class Cars- 27" & 28" Fronts?
  120. Going from 8 point roll bar to 10 point roll cage
  121. guys help me out picking a tire size
  122. transbrake>rear defogger
  123. Any classes limited to standard trans?
  124. Konis and drag racing
  125. which clutch switch wire for 12v signal for 2-step
  126. 2-step backfire
  127. Cam trigger with Big Stuff 3
  128. ETX16, can it be mounted on its side?
  129. Roll Cage help / Questions
  130. Va Speed. We'd like to apologize.......
  131. lenco questions
  132. MT 325/50 to 275/60?
  133. A4 corvette with a goal.
  134. QA1 Guys come in
  135. 28 10.5 Clearance
  136. kyb shocks
  137. 2 step off a foot brake?
  138. top fuel dyno?
  139. 12 bolt power?
  140. 2 Step/launch control with cats?
  141. mounting battery box by the books.....
  142. Mathmatical equation to hp vs. weight of a vehicle?
  143. good pushers
  144. Modded M6 guys, what do you launch at?
  145. Burkhart's Christmas sale
  146. body seperation while staged
  147. Pulling air bags tonight need help
  148. Lightweight GM seats
  149. Finally got the AC BOX OUT. YAAAAAAA!!!!!!
  150. First Procharged 99+ truck in the 10's
  151. Old School shock compression limiters, where do you get em?
  152. what kind of SFCs for drag !!
  153. Jegs suspension
  154. msd 2 step
  155. 16" Skinnies
  156. Any track rentals near NJ?
  157. 3rd Gen drag racing?
  158. speed inc carpet installed pics and questions
  159. Tire wrinkle
  160. First time with a torque arm
  161. Won another 7.0 heads up race
  162. 3-point subframes to a 2 point??? Can I cut them
  163. Full Bolt in Manual Rack 595.00
  164. Sneak Peak (The Money Shot)
  165. Article: Barn Find - Chitown Shizzler Found
  166. spindles that accept 1st gen drag brakes?
  167. need Joe van o rear wing
  168. white smoke ?
  169. UMI drag bar installed...
  170. TH400 for high 7's car
  171. Body drop? Am I overlooking anything?
  172. hvac delete ?
  173. quickest tire for my setup
  174. anyone replace there bellhousing on there th350/400's?
  175. I trap high(112)..but cant lower my e.t
  176. batteries or fuel cell in trunk pics?
  177. Chassis rigidity... do I need to upgrade my 6pt?
  178. Important info anyone towing their racecar to the track should have
  179. question about 60ft times
  180. what does everyone use to pull there motors?
  181. Anyone have a list/writeup for ABS delete fittings?
  182. is it hooked as hard as possible if....
  183. what height and weight rear springs you use
  184. More Cubes Result
  185. "CAM ONLY" setup, I want to use LS6 heads?
  186. any one with before/after 1/4 times with cutout?
  187. carpet
  188. battery reloc. fuse question
  189. Electrical/Wiring Question
  190. Where to buy 4130 CM tubing??
  191. Quick easy question, msd 2-users come in
  192. weight
  193. JET power programer
  194. Would a 24" tire help shave off some ET?
  195. Help with T-brake launch (vids)
  196. Anyone know the weight on LT1 style T/A headlights?
  197. Removing weight from rear of car...yes? no?
  198. what thread size are the studs that come with aerospace brakes?
  199. Can I save the wipers with a Carb?
  200. S&w torque arm & frame conectors
  201. 6sp. guys with DR's that HOOK come in please...
  202. lingenfelter 2 steps
  203. bumper support facts
  204. Wheel Tuck
  205. current time (11.66) wanting 11.30's??
  206. Will a 28" tire work???
  207. question on setting up drag brakes
  208. a few pics of the street drag car.
  209. 16v battery with stock computer, no alt?
  210. Burkhart front and rear bumper supports LS1 and LT1
  211. Low-to-Floor Seats????
  212. 10.5 all motor
  213. Veteran’s Day Sale from BMR Fabrication (15% OFF ALL Items)
  214. Needing better 60fts, Pinion Angle off? Vids inside!
  215. Victor Jr.
  216. Hook and Book…….with BMR FAB and NITROUS OUTLET!!!
  217. Better drag racing platform.....Mustang or Camaro?
  218. Cool Fuel?
  219. Cutting below front windshield...
  220. QA1 suspension what height to set the front coilovers?
  221. performance chip, Drag radials w/o subframe connectors ?
  222. Where to go from here?
  223. Lugnuts for Weld ProStars that wont Rust??
  224. Percy Speedglass
  225. Bolt ons exhaust setup
  226. Small radatior, and remote mount water pump.
  227. Which throttle cable bracket for a 4150 Accufab??
  228. look at these launch videos any suggestion
  229. What 60s with 15x8 wheel
  230. Installed wolfe sway bar, need adjustment help.
  231. Is there a 3-step available for ls motors?
  232. Added shocks what kinda et gains?????
  233. People with wolfe sway bar with a 9" inside please.
  234. Help me get a better 60 ft!
  235. Jerico or G force 4 speeds? Who's using them?
  236. Will it hold?
  237. How much room above the front tire is needed
  238. 28in DR Debate: 295 Vs. 275
  239. Who has broken an aluminum spool?
  240. Best deal on Trz products
  241. So What is the absolute best DA????
  242. Anyone have pics of SAM's engine bay? or ...
  243. What tire to make truck hook in 2wd?
  244. some small weekend plans
  245. Making 325/50/15's fit 02 SS
  246. Tubular shock towers
  247. Cam or stall?
  248. Roll cage, what times do you need them
  249. Running worn out M/T DRs
  250. New Trap-Door Oil Pan Baffle for Drag Racing
