View Full Version : Drag Racing Tech
  1. help with rear studs
  2. Suspension Unloading At Launch..? (Vids)
  3. how front SEAT BELTS come out???
  4. Talk to jim at jim racing tire
  5. Need help with my a single digit N/A setup.
  6. Help with Front shocks
  7. Drag racing change to either a PG or th350, I can't make up my mind
  8. UMI or Wolfe Drag Bar?
  9. proper mounting of 5 point harness
  10. 11 Sec. Bullet Proof M6 F-Body Build List
  11. How do people get sponsors
  12. rollcage rule
  13. wheel stud question
  14. Me vs a 383 stroker "tonight" need help!!!!!!!!
  15. Chassis table leveling questions
  16. Window net question and harness question
  17. Shoulds spool and 4.56's help 60 ft
  18. Need racing suspension help!
  19. Really Pissed At UMI
  20. Burkhart Chassis - Chuck's brother passed away
  21. Rear Bumper Brace
  22. Manual Fans Question
  23. Need help with rear wheels and tires?
  24. abs delete results.
  25. What are the inner rear fender vents for?
  26. front and rear shock and spring set up
  27. Aftermarket steering wheel pics
  28. 60' time difference between ET Streets and slicks?
  29. Can't seem to get a good 60' out of it.
  30. BMR Fabrication Launches New Product - 2010 Camaro Trailing Arms (TCA026)
  31. Rear drag shocks
  32. Beware of bogarts-May come apart at high speeds and low speeds
  33. LS1 Drag Racers: What Headers Are You Using?
  34. electrical pin out needed for drag harness
  35. Link-bar lifter question
  36. QA1s vs Strange single adjustable rear shocks
  37. A4 vs A3 Gearing
  38. IF you foot brake an A4
  39. Fuel Cell Questions.
  40. wheels slowing 1/4 mile time down??
  41. Drag Tire Help
  42. hookers vs. kooks
  43. tell me what i am doing wrong
  44. m6 launch, when do I shift to 2nd gear?
  45. Optimal Converter Stall Speed / Shift Ext.
  46. Mickey Thompson Drag Radial Tire Pressure Poll
  47. Mickey Thompson Drag Radial Tire Pressure Poll
  48. Questions on removing metal weight from interior
  49. Rear Drag Suspension Setup for high 9s/low 10s
  50. Remove ac but keep heater?
  51. MPH on gaunges went out
  52. Missing MPH in the 1/4...Help
  53. Before and After Pics of my Car With Weight Reductions
  54. wtb greg weld skinnys
  55. New best with bolt ons
  56. I need sugestions on a full race suspension
  57. Converting alcohol carb to gas
  58. what solid motor mounts for a PA k-member?
  59. UMI Performance Releases 1.250" Rear Drag Bar
  60. Battery to the back...Drivers side??
  61. Need help with 60'
  62. Suspension Help! Unloading?
  63. Harlan shift light/Battery shut off
  64. LPE LNC-001 and M/T ET Streets, advice?
  65. Helpwith wiring accufab sensors
  66. Help my car 60 1.3X
  67. video inside. help my take off please!!!
  68. Master electrical disconnect problem, alt exiter not shutting off car
  69. Updated c5r pics
  70. NOS launcher- who's using it
  71. Cam only, won't MPH!?!
  72. Grinding calipers
  73. Constantly adjusting LCA's
  74. Attempted burnout in waterbox, UMI torque arm snapped, set off airbags...
  75. NOS mini progressive and 2 step help
  76. brake and tranny cooler questions
  77. Traction: Wider or Taller??
  78. Car slides sideway in a burnout, always to the right
  79. Midplate and off the shelf headers?
  80. what flexplate for a 6.0/th350 combo?
  81. Thinking about taking roll cage out
  82. 15*10 drag wheel ?
  83. 28x11.5x16 ET Streets
  84. Rearview/sideview mirror options - Bracket racing
  85. i need some pictures of the mike moran hood on a camaro
  86. ? about springs??
  87. Front suspension question
  88. narrowed rear and 275 radials????
  89. M6 60' troubles, suggestions please
  90. M/T ET Street DRs.. Tire Pressure Questions
  91. Minimum pinion angle for the track
  92. BCM Delete
  93. Help! car unloading suspension after launch...shock settings?
  94. LPE LNC-001 Video
  95. Bolt-on guys what do you have for shift points and rev-limiter
  96. 27" front runners
  97. Opinons on rear support delete only for now.
  98. Drivetrain Vibrations
  99. Important info about using BS3 with 16V systems
  100. what transmission mount for th350?
  101. need feedback on Strange SA struts
  102. Which Tires should I use.
  103. Burkhart Bumper Support and Manual Master sale LSX Shooutout preorder
  104. quarter mile help
  105. quarter mile help
  106. Last question, A4 vs M6 weight?
  107. weight of stock front seats?
  108. Newbie with AC removal questions....
  109. Trans brake ? w/ spray on a N20 vert.
  110. Anybody run a clutchless? Liberty perhaps?
  111. NGK TR6 plug gap???
  112. 275 Guys...a little advise please
  113. Help with suspension!!!
  114. Shift points?
  115. The Rookie vs. the 25.5 project.
  116. Roll cage question
  117. Dzus
  118. Help.. where to tap Super Victor intake for vacumn
  119. This could be good Legal street racing
  120. whats a good tire pressure
  121. Help determine tire size 26 or 27. Info listed inside
  122. thoes who has a PA Racing kmember, i have a question
  123. QA1 rear coilovers
  124. Joe Van Overbeek parts?
  125. Kind of not thrilled with last track visit
  126. Meziere Race Water Pump Inlet Hose?
  127. Selling my car
  128. Non-electric seats...
  129. what gear to run?
  130. Warm Air vs. Cold Air
  131. Surest way to get my car into 11s
  132. Gear Vendors install started today on my '98 TA........
  133. lightweight carpet Q's?
  134. How Close Can Helmet Be To Rollbar?
  135. Is is possible? (without spending my years wages)
  136. BS tire size's from M/T
  137. More mods, better DA, but slower, confused...
  138. 672BBC Twin turbo O/L 10.5
  139. Subframe connector's question for the big boys
  140. Weighed My Pig of a Trans Am Today....
  141. stock 00' T/A shift points
  142. Did i need a DS Loop?
  143. About ready to order my rear end just had some questions...
  144. Welding A Rollbar To The Plates
  145. Couple quick pics of my Camaro project
  146. Madman or burkheart manual brake support bracket pics?
  147. Manual brakes on DD
  148. weird power steering issue
  149. Carborated motors whos running one??
  150. carb setup, straight or sideways what do you guys think???
  151. Burnout paint protection
  152. southern Il 275 race
  153. need help with car
  154. 6 point cage plate size needed my cage didnt come with them and need to know correct
  155. roll cage question
  156. How does "open comp" work?
  157. Virginia Speed Crank Trigger Bracket
  158. Feedback on Haulmark Trailers?
  159. Anyone Running a Super Shield?
  160. Article: Mark Koehler's 7 Second LSX Firebird
  161. What pinion angle works best for you?
  162. Budget LT1 race car build!!
  163. Lingenfelter vs MSD's 2-step
  164. Speed Inc Molded Carpet Weight
  165. What kind of certification is needed for going a little under 9.99(6.40)
  166. How much does the tube from a moly 25.2 weigh?
  167. Need setup help...
  168. How does this setup sound to yall?
  169. Help getting out of mid 13's????
  170. Help with bad tire rub.
  171. Hey JL ??? about PCV delete
  172. qa1 front springs?
  173. stuffing 28x10.5x15 Slicks ( needpics of were to trim bumper and rocker
  174. GM splined Grant quick release issues?
  175. What pin on hood?
  176. cutout before and after results..did you gain anything?
  177. QA1 settings...
  178. Need a cheap Snell approved helmet anybody know where to get one?
  179. Those with looped rack...come in!
  180. M6 60ft help
  181. Mcleod street twin. Aluminum flywheel or Steel? Wheres the best place to buy from?
  182. what gears for my turbo impala?
  183. which qa1's for me? F's, or R's?
  184. Carpet
  185. Going From ym 17" TTMs to my stock 16x8 rims..
  186. rt 66 speedway
  187. LNC-003 clutch switch hook up questions.
  188. Attempting to remove front swaybar...uh...
  189. Converter ?
  190. How fast have you gone on street tires
  191. What Drag Radials!
  192. Took off sway bar
  193. Shocks hitting Spohn sway bar?
  194. Goodyear Eagle Slicks?
  195. weight of rear glass on ta
  196. Article: Turbo/ LSX/ Carburetor/ 7 Second Camaro
  197. How does extra 300lbs effect time?
  198. Custom SFC's on a budget
  199. How much gear do I need?
  200. Help me pick some tires please...
  201. thinking about going glide
  202. LNC-002 launch controller problems
  203. Just purchased a Gear Vendors overdrive unit
  204. picts from SGMP radial race[project dumbass]
  205. New 8.50 cage getting done.
  206. Please help me launch this c5!?
  207. Which brand Bias ply tire?
  208. DA Strange Drag Shocks Issues
  209. new gun 427 c5r pics
  210. 6.0 bored 60??Overheat??
  211. Gear question
  212. Can get rear suspension square need help.
  213. Race gas question for you track guys?
  214. Is there a rear drag brake kit that will work on my 9" without axle removal?
  215. drag racing with coolant question
  216. What A Typical 550hp 4th Gen Run?
  217. Rear Seat delete.
  218. aftermarket tach
  219. Who's Motor/Mid plate?
  220. Alternator amperage needs for drag car???
  221. 2 step and transbrake on a N/A application?
  222. My slicks are shot should i run free 29/10.5/15
  223. Ethanol and Timing
  224. What wheel weighs less??? Chrome vs. Alloy
  225. 60 ft issues
  226. Removing rear bumper support? (Camaro)
  227. 16" drag setup
  228. I want a 1.5x 60ft out of my car...
  229. drag race setup for c6 z06
  230. help 126.67 mph running a 12.7
  231. What is this & can it go?
  232. Where to start with suspension
  233. hood clearence question
  234. madman front travel limiters.
  235. Caster
  236. "at the track" tios n tricks
  237. Ground my caliper alittle too far. Any way to fix this?
  238. Help with 6speed bog..
  239. Anyway to attach 4-pt belts without Harness Bar or Cage?
  240. My car was all over the track!
  241. Tires For A 16x8 Rim??
  242. just got the seats in the camaro....
  243. Ls1 to ls6
  244. not running right!
  245. 295/65r15
  246. who has removed their whole harness?
  247. Am I expecting too much hoping for 10s from my setup?
  248. 4mph loss in 1/8 mile???
  249. anyone with 29 or 29.5 tires
  250. m6 with et street(bias-ply not the radial one) tubes or no tubes?
